> 2010 MS3 - Torque Specs & information
Like Tree23Likes
 Old 11-29-2011, 07:42 PM   #121
dantes5823's Avatar
Posts: 6,576   (View Stats)
dantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the world
Groaned at 52 Times in 48 Posts
OK quick question. im gonna attempt this tomorrow morning, CP-e catted dp, and i see some people pull out the stud. How do you go about fixing that?
dantes5823 is offline   Reply With Quote
 Old 11-29-2011, 07:52 PM   #122
skeurton's Avatar
Posts: 745   (View Stats)
skeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the world
Depends if the nuts are seized to the studs, and how badly if they are. Do the prep work tonight and hit them with some PB Blaster. Then hit them again in the morning, run the car up to operating temp, then more PB Blaster. I've installed 2 downpipes and the nuts came off the studs like butter.
2011 MAZDASPEED 3
BNR: 352 hp / 342 ft-lbs
K04: 296 hp / 343 ft-lbs
BNR Supercars Stage 3 Turbo Aquamist HFS-4 Alcohol Injection Cobb Tuning AccesPORT • AccessTUNER Race KMD Tuning HPFP Internals v2.2 NGK 6510 Spark Plugs Bosch 3-Bar MAP Sensor Saikou Michi Oil Catch Can Grimmspeed 3-Port EBCS JBR TIGs • EGR Delete • Rear Sway Bar • RMM • PSMM • TMM HTP 3" TIP • Battery Tray SURE Motorsports 3" MAF • Shortcut • CounterShift • Anchors • AGS 621g Shift Knob Ultimate Racing Catted Downpipe • Test Pipe • Cat-Back Exhaust CP-e FMIC • SAFEseals Turbosmart Dual Port BOV PTP Injector Seal Studs EBC RedStuff Brake Pads • UPR Rotors Swift Spec R Springs Bilstein B8 Shocks SPC Performance Rear Camber Arms Tanabe Sustec Strut Tower Brace TWM Performance Full Replacement Shifter 5zïgen ZR+ 18x7.5 (Ceramic Bronze) Nitto NeoGen Tires Rally Armor Mud Flaps Morimoto 6000K HID Replacement Bulbs DDM Tuning 3000K HID Fog Lights Headlight Armor Yellow Fog Overlays Qualir QL-MZD723 Headunit Glowshift Mechanical Boost Gauge • A-Pillar Gauge Pod Aeroforce Dual Interceptor Gauges
skeurton is offline   Reply With Quote
 Old 11-29-2011, 08:01 PM   #123
dantes5823's Avatar
but arnt the bolts under the heat shield that only comes off after the top O2 sensor is off?
 Old 11-29-2011, 08:16 PM   #124
skeurton's Avatar
Ah yeah, you're right. Just run the car up to temp in the morning (this helps in cracking the O2 sensor and downpipe nuts loose). Then...
1) Remove the upper manifold heat shield
2) PB the O2 sensor and remove it
3) Remove the downpipe heat shield
4) Remove the lower mani heat shield
That should expose the nuts on the turbo and allow you to hit them with the PB. Let it set in for a little bit, then remove the nuts.
I downloaded and read through every how-to I could find. The attached guide is the one I ended up using. It worked out perfectly.
dantes5823 likes this.
2011 MAZDASPEED 3
The Following 4 Users Say Thank You to skeurton For This Useful Post:
Caboose (12-01-2011), dantes5823 (11-29-2011), SJP0tato (12-03-2011), superq7 (01-06-2012)
 Old 11-29-2011, 09:26 PM   #125
dantes5823's Avatar
Hey good deal, thanks. Im hoping the drive to my buddies house just a few min up the road is enough to do the trick. I think im gonna go back out and pb the O2 some more.
Edit: Install is going smooth as hell right now. The top o2 came right off..thank you impact gun Im, done with top side i think just jacked up the car and sitting in class now -_-
 Old 11-30-2011, 09:10 PM   #126
dantes5823's Avatar
Well all is said and done. Took about 4 hours or so. Not bad..So much easier than i thought. I read around and saw people making it sound like a damn motor tear down. Wasnt bad at all.
 Old 12-01-2011, 01:41 AM   #127
f-castrillo's Avatar
Posts: 1,342   (View Stats)
f-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the world
I wish mine was that quick. Shit took ~10 hours IIRC, and that was with TWO people. A lot of time was wasted by trying to maneuver parts out of tight places, taking snack breaks, and not having the right tools available.
(310whp, 341 ft/lb wtq) 91 octane + 100% methanol
JBR RSB, Stage2 OCC, Stage 2 SSP, IM TIG, 70D RMM, 70D PMM // DevilsOwn Stage 2 WMI kit + DO7 nozzle (MSF-prize) // COBB AP (Self-tune), XLE BPV // Corksport TMIC, SRI, TIP // Racing Beat Cat-back Exhaust // Denso Iridium ITV22 Spark Plugs // SURE TB TIG // Ultimate Racing Test Pipe // KMD HPFP Internals // TSW Nurburgring 18x7.5 ET45 Matte Black // SWIFT Spec-R Lowering Springs //
f-castrillo is offline   Reply With Quote
 Old 12-01-2011, 02:07 AM   #128
Postulio4joo's Avatar
Posts: 284   (View Stats)
Postulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the world
Groaned at 14 Times in 6 Posts
Can someone post up which tools were needed? I am so tempted to attempt this now.
Postulio4joo is offline   Reply With Quote
 Old 12-02-2011, 06:18 AM   #129
DISIindahead's Avatar
Posts: 911   (View Stats)
DISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the world
There should be a How-To on here as far as DP install. I've installed/uninstalled my CNT Catted DP several times ( 5 times to be exact). Corksport's installation instructions make it a lot easier since they suggest removing the alternator to get at the studs easier. I might try this on my next install once i get the Corksport Exhaust and DP cleaned out from blown turbo syndrome. It sounds a little more difficult but according to Corksport it doesn't take as long as compared to most other installs. You can find the instructions on their website.
2010 Mazdaspeed 3 - Built Motor - GTX3071: SOLD
2012 Jeep Wrangler Unlimited Sport: Current DD
DISIindahead is offline   Reply With Quote
 Old 12-02-2011, 10:06 AM   #130
thatsmrgimp2u's Avatar
Posts: 834   (View Stats)
There is a pretty thorough product review/DIY from Haltech on the cobb dp.
Cobb DP Review
DISIindahead likes this.
Fluids
Rotella T6 A lot
Rislone Engine Treatment
Motorcraft XT-M5-QS(trans)
VP Methanol
~Splash of E85~
The Following User Says Thank You to thatsmrgimp2u For This Useful Post:
 Old 12-03-2011, 11:04 PM   #131
dantes5823's Avatar
Yea i actually didnt use a whole lot. Granted my car only had i wanna say 4k miles on it... The thing i would say to make sure you have is a swivel head. After that it was a good extension some pb and time. We only stopped for a smoke break like 2, pizza break, a class i had to go to...and it was done. I think i actually had a harder time putting on the dp than taking the stock one off. The pain was the lower right nut on the flange cause of the way the dp was you couldnt get a socket on it to good. The top 02 came of with a few hits from a impact .
Damn 10 hours.. thats a long ass time lol. But from the looks of it, i think everyone has a different experience. Some people back out their studs and other things that delay them. I had no delays and no hick ups. Everything came right off. I was amazed actually.
Last edited by dantes5823; 12-03-2011 at 11:04 PM. Reason: MSF Database - Automerged Doublepost
 Old 12-03-2011, 11:53 PM   #132
Schmitty5's Avatar
Posts: 979   (View Stats)
Schmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the world
Groaned at 20 Times in 12 Posts
5 hours.
Downpipe = winning. Why the fuck did I wait this long. Stage 2 has transformed my car
Scoobs likes this.
2010 MS3 - 13.42 at 107 - street tires - 306whp/338tq Moore automotive (dynojet)
Roadcoursing > all http://www.youtube.com/watch?v=GO-xoFpsgj4
Schmitty5 is offline   Reply With Quote
 Old 12-04-2011, 12:04 AM   #133
dantes5823's Avatar
Originally Posted by Schmitty5 View Post
5 hours.
Yea i was so close to just having someone do it. But omg how much difference it made to the car. I go like 75% throttle and it feels like i was at WOT from stock.
 Old 12-04-2011, 12:39 AM   #134
Schmitty5's Avatar
75% throttle? who does that?
I'm either chillin or WOT baby, I have no traction in 2nd gear. love it
 Old 12-04-2011, 01:01 AM   #135
dantes5823's Avatar
2nd gear stays at redline lol.
 Old 12-04-2011, 01:04 AM   #136
Ckmazdaspeed3's Avatar
Posts: 2,077   (View Stats)
Groans: 134
It only counts the first time when you remove the stocker, after that, the shit is so easy to get off that you don't even think about it... I bet now I could get it off the car in under 30 minutes.
And to the people talking about getting the nuts to come off without the studs, who cares if the stud comes out too? Some of mine do, and most others that I've seen as well... Never really seems to matter.
Ckmazdaspeed3 is offline   Reply With Quote
 Old 12-04-2011, 10:08 AM   #137
If your talking about just taking off an aftermarket downpipe, then yes i can believe that. But going from the stocker to an aftermarket and vice versa, its going to take longer than that, even with power tools. Most of the guys on here are using basic tools (like myself) and still pull it off in less than 4 hours. Plus I like to take my time and make sure everything is done correctly so there are no problems in the future. But like i said, that's just me.
 Old 12-04-2011, 12:01 PM   #138
breakfasteatre's Avatar
Posts: 308   (View Stats)
breakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the world
I found mine was easier when all the studs backed out copared to my buddy who had 2 studs left in, and it was a bitch manoeuvring the cpe downpipe over the studs
breakfasteatre is offline   Reply With Quote
 Old 12-04-2011, 12:05 PM   #139
Groans: 134
I wasnt really trying to brag, I was just saying that once the stocker is off the first time, it is simple... I'm sure anybody could do it that quick. The only tough thing about the stocker is that all of the bolts and o2 sensor are on super tight... I guess the cumbersome size is a bit of a pita too.
It's not so much a how to that is needed, just a collection of tips for stuck bolts, not stripping the o2 sensor and that 1 bitch of the bolt on the bottom left of the turbo.
 Old 12-04-2011, 12:39 PM   #140
thats the one that pisses me off the most. But with some caressing and a couple beers, it can be done at ease. I really need to put my DP and exhaust back on, problem being I must burn all the dry oil out of both. Sucks bc my plan was to pour gas in the exhaust, yet a friend reminded me gas burns black as hell and I dont think the neighbors will approve and call the Fire Department on me. But o well, im always looking to bust the neighbors balls
 Old 12-05-2011, 01:58 PM   #141
For us, taking the stock DP out proved to be the hassle. Putting the CNT piece on took a fraction of the time lol
 Old 12-05-2011, 02:21 PM   #142
dantes5823's Avatar
I think it was harder for us to install lol. But for that I have my wiggle master. My boy can wiggle shit around somehow and get it in.
 Old 12-05-2011, 02:27 PM   #143
adlpb's Avatar
Posts: 6,998   (View Stats)
Groans: 669
I think you know what's coming.
Scoobs and f-castrillo like this.
The Following 2 Users Say Thank You to adlpb For This Useful Post:
Caboose (12-05-2011), f-castrillo (12-05-2011)
 Old 12-05-2011, 03:16 PM   #144
dantes5823's Avatar
This should be good
 Old 12-05-2011, 03:45 PM   #145
Caboose's Avatar
Posts: 141   (View Stats)
Caboose has a reputation beyond reputeCaboose has a reputation beyond reputeCaboose has a reputation beyond reputeCaboose has a reputation beyond reputeCaboose has a reputation beyond reputeCaboose has a reputation beyond reputeCaboose has a reputation beyond reputeCaboose has a reputation beyond reputeCaboose has a reputation beyond reputeCaboose has a reputation beyond reputeCaboose has a reputation beyond repute
Master packer of the fudge?
Caboose is offline   Reply With Quote
The Following User Says Thank You to Caboose For This Useful Post:
adlpb (12-05-2011)
 Old 12-18-2011, 11:20 PM   #146
xb2ms3's Avatar
Posts: 636   (View Stats)
xb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the world
failed at my attempt to install dp today. lost daylight and my vagina succumbed to the cold.
do you remove the mounting bracket for the dp in there or leave it in there?
2011 Black Mica MS3
NJSPEED3 Ported IM + other shit
NJ NATOR NY
316.52 hp / 352.12 tq 93 oct K04@ Nator DC Dyno Day 11.10.12
xb2ms3 is offline   Reply With Quote
 Old 12-23-2011, 07:13 PM   #147
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
I think you should remove it. I'll be removing mine.
Right after I figure out how to remove this rounded off bolt head. On the lower manifold heat shield right against the firewall one of the 10mm bolts just refused to come out and I ended up rounding it off.
Any suggestions?
 Old 12-28-2011, 06:46 AM   #148
NinjaT1985's Avatar
Posts: 551   (View Stats)
NinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the world
Groaned at 33 Times in 10 Posts
Any suggestions?
Get my help lol...
2012 Toyota Tacoma
NinjaT1985 is offline   Reply With Quote
 Old 12-28-2011, 09:58 PM   #149
xb2ms3's Avatar
5 hours.
wish I had one of those
or at least a ratcheting breaker bar that would have cut down my install to about 4 hours instead of 8.
did my install on ramps and it wasnt difficult at all removing or installing the new dp. Wiggling out the stock dp and hooking on the cobb dp took me probably 15 minutes total.
Just those damn hard to reach bolts that you have to get at with the right angle while trying different combinations of extensions, u joint and breaker bar, were time consuming.
2011 Black Mica MS3
NJ NATOR NY
 Old 12-29-2011, 10:40 AM   #150
Schmitty5's Avatar
Yea, its just that 1 bolt. When I put the new DP on, I had to use a tiny ass manual wrench and wrench it on from underneath the car. 1/10 of a rotation at a time...
 Old 02-03-2012, 09:18 AM   #151
xb2ms3's Avatar
Lol I remember that bolt
Gonna retorque the bolts soon
How the hell do u torque that one?
Just tight as possible with man strength?
2011 Black Mica MS3
NJ NATOR NY
 Old 02-03-2012, 09:49 AM   #152
Schmitty5's Avatar
Strong dick it
need hlp after installing SU BPV camdensms6 MazdaSpeed 6 - Engine, Transmission & Driveline 3 11-02-2009 02:54 PM
help on installing MBC tburton101 MazdaSpeed 3 - How-To's 1 08-27-2009 02:35 PM
Page generated in 0.52116 seconds with 34 queries
