> 2010 MS3 - Torque Specs & information
 Old 01-04-2010, 01:21 PM   #1
ROADWAR's Avatar
Posts: 289   (View Stats)
ROADWAR has a reputation beyond reputeROADWAR has a reputation beyond reputeROADWAR has a reputation beyond reputeROADWAR has a reputation beyond reputeROADWAR has a reputation beyond reputeROADWAR has a reputation beyond reputeROADWAR has a reputation beyond reputeROADWAR has a reputation beyond reputeROADWAR has a reputation beyond reputeROADWAR has a reputation beyond reputeROADWAR has a reputation beyond repute
Default Oil filter info
I change my own oil and have investigated the discrepancy between the size of the filter that comes on the 2010 speed 3 and the listed replacement for it. The filter that comes from the factory is marked as a Ford part and is much longer than the listed replacement. I purchased a Wix replacement (Wix #51348) which is 3.404 inches long. There has been discussion either here or on another forum about the 2010 cars not holding as much oil as listed in the manual when the oil was changed. Researching the Wix site, I found that the filter listed as a replacment for the Mazda 6s (with 3.6 v6) Wix #51516 is identical to the 51348 filter except for length (it is 4.828 inches in length). All other parameters including thread size and length, flow rate, bypass pressure, media particle catching size, and gasket dimensions are identical. This filter obviously will hold more oil. I believe that the Mazdaspeeds are coming from the factory with v6 sized filters. Why is the smaller filter listed as a replacement? Who knows? The smaller filter is the replacement for the 2.0 in the 3i. I'm going to be using the larger filter and getting oil capacity closer to the manual's specification.
Cliff notes version:
Wix "big" replacement filter (like factory installed)= #51516 (holds more oil)
Wix "small" replacment filter (same as 2.0 spin on)= #51348
For those of you that let the dealer do your oil changes, you can specify that they use a Mazda 6s replacement.
Hope this helps.
Kelly
Scoupe likes this.
Yeah I got some stuff installed on it.
ROADWAR is offline   Reply With Quote
The Following 7 Users Say Thank You to ROADWAR For This Useful Post:
BLK_MS3 (11-11-2010), Dre (01-04-2010), frothy (03-20-2015), paradigme (02-14-2010), rfinkle2 (02-28-2011), Scoupe (10-20-2014)
 Old 01-04-2010, 02:50 PM   #2
ChrisK's Avatar
Posts: 1,168   (View Stats)
ChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the world
Groans: 56
My post is not an answer to your question, but I have a question of my own.
The 2nd gen Speed 3 has a spin-on filter from factory?
ChrisK is offline   Reply With Quote
 Old 01-04-2010, 03:42 PM   #3
liquoredonlife's Avatar
Posts: 198   (View Stats)
liquoredonlife has a reputation beyond reputeliquoredonlife has a reputation beyond reputeliquoredonlife has a reputation beyond reputeliquoredonlife has a reputation beyond reputeliquoredonlife has a reputation beyond reputeliquoredonlife has a reputation beyond reputeliquoredonlife has a reputation beyond reputeliquoredonlife has a reputation beyond reputeliquoredonlife has a reputation beyond reputeliquoredonlife has a reputation beyond reputeliquoredonlife has a reputation beyond repute
I use the Mazda OEM maintenance filter (LF05-14-302A) that fits the 2.0/2.3/2.5. It is slightly smaller than the original FoMoCo one. I filled to the top of the dipstick at 5.25 qts. And yes, 2nd gen is a spin-on.
liquoredonlife is offline   Reply With Quote
 Old 02-14-2010, 06:31 PM   #4
Itchy's Avatar
Posts: 46   (View Stats)
Itchy is a glorious beacon of lightItchy is a glorious beacon of lightItchy is a glorious beacon of lightItchy is a glorious beacon of lightItchy is a glorious beacon of lightItchy is a glorious beacon of light
What was the original FoMoCo filter part number? I let the dealer do my first oil change after 2000k miles (free with purchase) but I'll be doing the rest myself.
Thanks
Itchy is offline   Reply With Quote
 Old 02-16-2010, 01:50 PM   #5
ROADWAR's Avatar
Sorry, I don't know the Fomoco number. Just saw the logo on the picture of the filter and went from there. I believe a parts house should be able to cross reference the "big" Wix filter number to a Motorcraft (Ford) number though. Hope this helps.
 Old 02-16-2010, 02:02 PM   #6
deuce_WI's Avatar
Posts: 234   (View Stats)
deuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond repute
Groaned at 6 Times in 2 Posts
I asked the parts desk guy at my dealer if he could find some part numbers to possibly switch over an 07-09 MS3 to the spin on oil filter along with the newer style splash guard that allows you to change the oil without removing it.
'That'll void your warranty.' was the first thing out of his mouth.
'I'm pretty sure I voided the warranty by putting gas in the car too.' Stupid clown-shoe, why do I even bother stopping in when there's the internet all over the place.
Anyhow, back on topic. Does anyone think the splash guard from a 2010 will fit on the previous model Speed3? And would that allow for easier oil changes, with a spin on or with the stock cartridge filter?
deuce_WI is offline   Reply With Quote
 Old 02-16-2010, 02:19 PM   #7
Itchy's Avatar
Default Original FoMoCo oil filter
from another forum:
-original filter was black FoMoCo #LF8J-14-302
The Following User Says Thank You to Itchy For This Useful Post:
ROADWAR (02-17-2010)
 Old 03-16-2010, 11:50 AM   #8
eric8's Avatar
Posts: 66   (View Stats)
eric8 is a jewel in the rougheric8 is a jewel in the rougheric8 is a jewel in the rougheric8 is a jewel in the rough
Groaned at 8 Times in 4 Posts
So the OEM filter is labeled as a Motorcraft? Cool, I can buy the OEM filter at Wal Mart!
eric8 is offline   Reply With Quote
 Old 03-16-2010, 11:52 AM   #9
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
part numbers galore - http://www.mazdaspeedforum.org/forum/foru...numbers-28485/
panache dk likes this.
 Old 03-16-2010, 01:17 PM   #10
wankular's Avatar
Posts: 4,343   (View Stats)
I've heard that the dealer will install the spin-on if you ask (and pay out the ass). Now they're saying they will void you? It's a FoMoCo part!
I actually like having the oil filter covered by the splashguard. But the easiest option would probably be to just cut a big enough hole in it. I shudder to think what Mazda would charge you for a 2010 one, if they even fit.
2009 MS3 sport MGM
 Old 03-16-2010, 01:23 PM   #11
phillyb's Avatar
Groans: 1,940
dash08 got a new engine under warranty with a spin on installed.
i really think every dealer is different
 Old 03-23-2010, 11:50 AM   #12
dachtler's Avatar
Posts: 170   (View Stats)
dachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond repute
Neutral  :  -1 score
Has anyone tried the K&N HP-1002 as a replacement oil filter instead of the stock unit? I've used K&N filters in the past on various cars and have been reasonably happy with them.
Update: I ordered one from Amazon.com for $10 to see what it looks like. I'll update this post with the results.
dachtler is offline   Reply With Quote
 Old 05-05-2010, 02:31 PM   #13
Lateapex36's Avatar
Posts: 36   (View Stats)
Lateapex36 will become famous soon enough
FWIW the Mobil 1 filter for the 2.3 liter is the same size as the stock one and with the manual recomended 6 quarts its like right at the full line, maybe slightly above
Lateapex36 is offline   Reply With Quote
 Old 05-05-2010, 04:09 PM   #14
Itchy's Avatar
Before I get the "use the search function" comments I have used the search function on this and other forums ... with no luck.
At some point someone posted a comparison of the different filter dimensions for the original filter and the replacement filter.
Anybody know what I am talking about?
 Old 06-13-2010, 07:28 AM   #15
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
Im thinking about going with a Fram oil filter
their sizes for filters are:
Mazda 6 V6: 4.92 inches in length.
Mazdaspeed: 3.34 inches in length
Will going with a larger filter effect fuel pressure whether positive or negatively?
 Old 06-24-2010, 02:58 PM   #16
randyb559's Avatar
Posts: 92   (View Stats)
randyb559 has a spectacular aura aboutrandyb559 has a spectacular aura about
I can vouch for that Lateapex. Just did my first oil change at 2650 yesterday and the MOBIL 1 (#M1-102), which is $12.99 at Autozone, is the exact size as the OEM Fomoco filter. Used 6qts and it was @ FULL line.
2010 Black Mica w/Tech Package
Current Mods: CS SRI | CS TIP | CP-E RMM | Turbosmart Dual Port BOV | JBarone Stage2 SSP | DDM 55w 6000k HIDs | Hoen Endurance Fogs | CS LED Light Kit | Dual Switchback LED Turnsignals
Future Mods: HKS Hypermax V-Sport Coilovers | CS Racepipe
randyb559 is offline   Reply With Quote
 Old 07-07-2010, 11:03 AM   #17
z31maniac's Avatar
Posts: 35   (View Stats)
z31maniac has a spectacular aura about
Groaned at 35 Times in 6 Posts
Good to know that my local dealer is on top of things.
Walked in and asked for two oil filters for a 2010 Mazdaspeed 3, and I get a couple of cartridge type filters.
z31maniac is offline   Reply With Quote
 Old 07-07-2010, 12:22 PM   #18
cesaros's Avatar
Posts: 1,261   (View Stats)
cesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the world
Groans: 106
Groaned at 53 Times in 41 Posts
hahaha...dealership fail.
cesaros is offline   Reply With Quote
 Old 07-25-2010, 05:58 PM   #19
Kris Speed3 CWP's Avatar
Posts: 303   (View Stats)
Kris Speed3 CWP has a reputation beyond reputeKris Speed3 CWP has a reputation beyond reputeKris Speed3 CWP has a reputation beyond reputeKris Speed3 CWP has a reputation beyond reputeKris Speed3 CWP has a reputation beyond reputeKris Speed3 CWP has a reputation beyond reputeKris Speed3 CWP has a reputation beyond reputeKris Speed3 CWP has a reputation beyond reputeKris Speed3 CWP has a reputation beyond reputeKris Speed3 CWP has a reputation beyond reputeKris Speed3 CWP has a reputation beyond repute
Groans: 32
Groaned at 80 Times in 41 Posts
Just looked over my service records for the first oil change they put in right filter part# LF10-14-302 and 5W30 oil 2nd oil change right oil filter but wrong oil 5W20, 3rd oil to resolve smoking wrong oil filter LF05-14-302A-CA with 15/40 Amsoil synthetic under warranty. You just have to watch these dealers!! I'll be in there Monday get right filter put on the bastards!!!
Kris Speed3 CWP is offline   Reply With Quote
 Old 07-25-2010, 06:02 PM   #20
Itchy's Avatar
I think that the official Mazda line is that LF05-14-302A is the correct filter.
 Old 07-25-2010, 06:50 PM   #21
Groans: 32
That would be the wrong part as the oil capacities are different in the 2.0L and the 2.5L go to page 10-5 in your Mazda3 owners manual, then take a quick glance at page 8-20 for the caution!! If you use the filter you state you will be way over fill line if you put in 6qts! So the question would be why would you want to run your Speed with less than the recommended amount of oil and an incorrect filter? Mazda Dealers have the right part as my first 2 oil changes were with the correct part# LF10-14-302 the 3rd one I failed to spot it!! FUCK!! Unless of course you do not have a 2010 Disi engine??
 Old 07-25-2010, 09:55 PM   #22
Itchy's Avatar
No I a 2010 MS3. I was just stating that officially Mazda lists the smaller filter as the correct part. It's not really that much smaller than the FoMoCo one from the factory.
When I changed the oil it took 5.5 qts instead of the 6.0 listed in the manual. I find it hard to believe that a 1/2 qt extra would fit inside slightly larger filter.
I still have not heard a good answer from Mazda explaining why downsized they filter, (or why the factory installed one is not even available as a replacement) but putting on the filter that is the listed replacement part by Mazda will not hurt your car, as long as you check the fluid level on the dipstick when refilling.
My driving habits are probably far worse for my engine and transmission than my oil filter selection.
 Old 07-26-2010, 11:41 PM   #23
Groans: 32
Went to Mazda dealer today and Parts manager stated that they had changed manufacturer of the filter, hence the new part number. He still had some old stock of LF10-14-302 but from now on will be the slightly smaller LF05-14-302A-CA. Also jumped over to the Ford dealer and gave the part number listed as O.E.M Ford from here LF8J-14-302 and he could not pull it up! The only thing he could get from part number was this filter see pic! But if everyone is getting the right results with the Mobile 1 filter I think I would just get the dealer to install it and ask for credit for filter, hopefully filter is better than mobile 1 oil lol. Went to Canadian tire to get Mobile1 filter and got some pictures of a Fram and a Quaker State both seem bigger than the Motorcraft one and mazda parts both old and new ones! The mobile 1 internals looks like it holds more oil by the design.
 Old 11-12-2010, 09:50 PM   #24
bertrand_CX_7's Avatar
Posts: 1,455   (View Stats)
bertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the world
Originally Posted by Kris Speed3 CWP View Post
right oil filter but wrong oil 5W20, You just have to watch these dealers!! I'll be in there Monday get right filter put on the bastards!!!
They did the same think on me. I've asked the to change oil because the car was more that 3 months on their lots with 12 miles on the odo. So they went there and put 5W20. I noticed it because I was seeing more smoke that unsual when pulling the car and I asked to see the service receipt of the oil change: Was reading 5W20. Asked what that means. Answer: No this is the code we used for oil change, the system doesn't have code for 5W30..... BS. But afterwards they change it the next time.
Why they are doing that? No idea. Because when you open the engine bay the oil cap is red and says 5W30 for the speed3. I'm just not sure what will be Mazda toughts on those practices.
I'm just thinking to give them a 0 in the survey so next time they won't mess up with me again.
Honestly those guys are really dangerous. Next time they'll do somethink like that I'll call Mazda corporate even withouth giving them the chance to repar the rip off. Just imagine, we just got a new car and their are doing that to our babies. What if we show up with an 6-10 years used car. We'll just go broke the next day.
I mean how will you trust those guys?
Any one know if the factory oil in the engine has some breaking fluild on it?
All my next 7 oil changed are payed by the dealership. With all what I'm reading here I'm not sure if I'll let them do the rest 6 free oil change on my car.
2010 MazdaSpeed3 Velocity Red: Forge BPV V2, CP-e [HPFP, TMIC, Driver + passenger Mount, 75-A], CorkSport [RSB, Coilover, camber plate], SPC rear camber arm, JBR SSP stg2 + heavy knob, Cobb [ SRI, AP ], HTP 3.5" TIP, - STG2 PERM tuned by DJ, Ultimate Racing TBE (Metal core DP). Aeroforce dual guages, Hankook R-S3 on stock wheels, Sparco Evo2 race seat. ARP long wheel studs -- 17x9 ET 45+ Kosei K1 TS on 255/40/17 on Dunlop Direzza ZII.
Pending install: JB EGR block plate
Next mod:CorkSport[ Front + Rear swaybar endlinks ], OCC, brake upgrade (CorkSport or BBK), 6 point Harness.
2007 CX-7 GT AWD: CPE CAI, ETS 3" TMIC, JB EGR block plate ,Matt's OCC, AutoExec Strut tower bar, AutoExec lower arm bar, Nittos 420 tires, 12" JBL subwoofer with Bose system.
bertrand_CX_7 is offline   Reply With Quote
 Old 11-21-2010, 09:49 AM   #25
ebnash's Avatar
Posts: 244   (View Stats)
ebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond repute
Hope this helps.
Kelly
Keep in mind that aftermarket parts manufacturers look for every opportunity to fit parts to multiple models. You will often find that WIX and others will have one part number that replaces 5 or 6 factory numbers on multiple manufacturers if you look through the cross reference sheets. That being said, what you should really be concerned about is the capacity and bypass pressure setting on what ever aftermarket filter you are using.
Bigger capacity is always better because it can filter at a higher volume and normally means you have more filter surface area depending on the manufacturer and you should always try be be as close as possible to the factory bypass pressure setting. This is the pressure at which your filter will start bypassing the the filtration media and just recirculate back to the engine. Bypass pressure setting is available in the master catalogs as well as WIX's website. Not sure about other brands.
I almost always use factory oil filters unless I research the aftermarket equivilent. By the way, I believe WIX to be one of the better aftermarket brands and NAPA/Carquest premium filters are made by the WIX/Dana corporation so they are the same.
Good luck
Hunt Hard, Kill Swiftly, Waste Nothing, Offer No Apologies...
ebnash is offline   Reply With Quote
The Following User Says Thank You to ebnash For This Useful Post:
ROADWAR (11-21-2010)
 Old 01-29-2011, 02:19 AM   #26
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
Originally Posted by monicachenny View Post
im a newbie here! happy to know you!nice forum!
its looks so good! wholesale embroideryamamzing!
wa, it looks so interesting! i like it ~
very happy to meet you here!
Fuck off doucher!
Sent from my iPhone using lame ass Tapatalk
 Old 06-17-2011, 03:47 PM   #27
2010Speed3dragan's Avatar
Posts: 11   (View Stats)
2010Speed3dragan is an unknown quantity at this point
Thumbs up
Absolutely stick with the OEM maintenance filter.
2010Speed3dragan is offline   Reply With Quote
 Old 06-24-2011, 08:24 PM   #28
bmannn's Avatar
Posts: 162   (View Stats)
bmannn is a splendid one to beholdbmannn is a splendid one to beholdbmannn is a splendid one to beholdbmannn is a splendid one to beholdbmannn is a splendid one to beholdbmannn is a splendid one to beholdbmannn is a splendid one to behold
Groaned at 133 Times in 24 Posts
I own a auto repair shop. We do over 500 oil changes a month. Most oil filter manufactures have went with smaller filters last few years. Think its just so they make more money. Don't really see how it could negatively effect the engine. Other than slightly less oil.
2011 ms3
gone
bmannn is offline   Reply With Quote
 Old 06-27-2011, 11:08 AM   #29
SFWD 1934's Avatar
Posts: 973   (View Stats)
SFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the world
I have a 2011 and I use the Mobil 1 M1-102 filter. When I did the first oil change, it took just about 5 1/4-5 1/2 quarts. The manual stated it would be about that much. I am in fact going to do another oil change today, so I will verify the amount it takes again and log it.
Jason
SFWD 1934 is offline   Reply With Quote
The Following User Says Thank You to SFWD 1934 For This Useful Post:
rfinkle2 (06-27-2011)
 Old 07-03-2011, 09:34 PM   #30
dkapetansky's Avatar
Posts: 171   (View Stats)
dkapetansky has a reputation beyond reputedkapetansky has a reputation beyond reputedkapetansky has a reputation beyond reputedkapetansky has a reputation beyond reputedkapetansky has a reputation beyond reputedkapetansky has a reputation beyond reputedkapetansky has a reputation beyond reputedkapetansky has a reputation beyond reputedkapetansky has a reputation beyond reputedkapetansky has a reputation beyond reputedkapetansky has a reputation beyond repute
I checked with my local stealership, and they confirmed that the Gen1 and Gen2 splashguards have different part numbers, which implies that they are not interchangeable. So just cut out a hole in the tray, under the oil filter, to make filter changes easy.
dkapetansky is offline   Reply With Quote
 Old 08-27-2011, 09:47 PM   #31
Rustysocket's Avatar
Posts: 263   (View Stats)
Rustysocket is the leader of the worldRustysocket is the leader of the worldRustysocket is the leader of the worldRustysocket is the leader of the worldRustysocket is the leader of the worldRustysocket is the leader of the worldRustysocket is the leader of the worldRustysocket is the leader of the worldRustysocket is the leader of the worldRustysocket is the leader of the worldRustysocket is the leader of the world
Can not believe Mazda does not list the Filter Specs in the owners manual...
However a little research led me to this, and i happen to have a shelf full of them already. Motorcraft FL-400s
Here's the dimensions which seem to correalate to the first post regarding the OEM filter shipped with the car. Cheap and available at Wal-mart. Also cross referenced to a Napa Gold #21516 which is a Wix 51516
Motorcraft Number FL400s
Part Number: 51516
Principal Application: Ford/Lincoln/Mercury (81-09), Chrysler/Jeep/Mitsubishi (02-09), Mazda Trucks (94-07)
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.828
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Max Flow Rate: 7-9 GPM
Beta Ratio 2/20=14/31
Burst Pressure 275
Normal Micron Rating 20
Gasket Diameters
OD 2.734
ID 2.43
THK 0.226
Rustysocket is offline   Reply With Quote
The Following 2 Users Say Thank You to Rustysocket For This Useful Post:
kairojya (03-01-2012), ROADWAR (08-28-2011)
 Old 09-18-2011, 10:43 PM   #32
urville's Avatar
Posts: 193   (View Stats)
urville has a reputation beyond reputeurville has a reputation beyond reputeurville has a reputation beyond reputeurville has a reputation beyond reputeurville has a reputation beyond reputeurville has a reputation beyond reputeurville has a reputation beyond reputeurville has a reputation beyond reputeurville has a reputation beyond reputeurville has a reputation beyond reputeurville has a reputation beyond repute
I've found conflicitng numbers for the Ford Motorcraft filter:
FL-793
FL-910s
Never the 400 though
urville is offline   Reply With Quote
 Old 09-19-2011, 01:01 AM   #33
FL910 is the short version of the FL400s. The FL400 is dimensionally equivalent to the OEM filter, instead of the shorter one the dealer is now selling.
It is what I am running on my car. You can get all the dimensions from the wix website as well.
Motorcraft FL 910 - Bob Is The Oil Guy
Here are the numbers for a 51348 which is the short filter FL-910
Part Number: 51348
UPC Number: 765809513488
Principal Application: Various Chrysler/Dodge/Jeep (82-11), Various GM, Saturn (85-07), Lexus (90-10), Saab (67-09), Suzuki (86-02), Toyota (88-11), Ford (03-11), Mazda, Mercury (05-11), Yugo (86-89), VW (09-11) Various Lawn&Garden, Farm, HD Equipment
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Thread Size: 3/4-16
Beta Ratio: 2/20=6/20
Burst Pressure-PSI: 275
Nominal Micron Rating: 21
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.734 2.430 0.226
Hope this helps
2011 MS3 Liquid Silver with Tech Package - Corksport SRI // TRZ RMM
Ethanol Free Fuel database - http://pure-gas.org/
 Old 09-19-2011, 11:35 PM   #34
urville's Avatar
I see I see, the Wix is the replacement for the 793 AND the 910s. I'll check it out cause i saw alot of UOAs that made the motorcraft filters look like the best bang for the buck but none on this wix model. Research away...
 Old 04-21-2012, 12:57 PM   #35
urville's Avatar
any benefit or con to the 400s?
//2011 MazdaSpeed3 Tech\\
//ATI•JBR WP (ip)•RMM\\
 Old 04-23-2012, 05:31 PM   #36
I can't see any +/- either way. They are cheap and readily available at wal-mart. The extra volume over the 910 is probably statistically insignificant. For me the only benefit was that I already had a shelf full of them.
The Following User Says Thank You to Rustysocket For This Useful Post:
urville (04-23-2012)
 Old 05-03-2012, 08:52 PM   #37
Dubcnea's Avatar
Posts: 223   (View Stats)
Dubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond repute
i have read these posts but i'm annoyed that mazda would sub such a rather sub par looking filter for what comes on stock. i'm not an engineer but just eyeing them both...one looks quality...the other looks like shit (relative). i semi-reluctantly put the 302B on only because, well, there was no choice. i doubt mazda would put out a filter that would cause an engine issue, but who the fuck knows?
the car ended up taking 5.75qt instead of 6. i checked it several times, the last after a 20 minute drive and 3 minute cooldown (running idle). checked the dipstick right after i shut it off and it was right at the 'max' line.
just for reference, here is the stock (black) vs the replacement i got at the dealer. they even looked up which one via my VIN. i will call tomorrow to see if i can get the black one going forward.
2012 CPW Mazdaspeed 3
Dubcnea is offline   Reply With Quote
 Old 06-19-2012, 02:01 AM   #38
Daftboy's Avatar
Posts: 136   (View Stats)
Daftboy has a reputation beyond reputeDaftboy has a reputation beyond reputeDaftboy has a reputation beyond reputeDaftboy has a reputation beyond reputeDaftboy has a reputation beyond reputeDaftboy has a reputation beyond reputeDaftboy has a reputation beyond reputeDaftboy has a reputation beyond reputeDaftboy has a reputation beyond reputeDaftboy has a reputation beyond reputeDaftboy has a reputation beyond repute
So what did the dealership say? did they replace it with another one ? if so what part number
Cobb AP/Magnaflow CBE/ Cp-E Nano/ JBR 88RMM/ SURE AGS 621/SURE Shortcut
Daftboy is offline   Reply With Quote
 Old 06-25-2012, 07:06 PM   #39
makjur's Avatar
Posts: 1,313   (View Stats)
makjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the world
Groaned at 15 Times in 8 Posts
I used a NAPA gold filter recently, would like to give the dude credit that posted on here for ripping a bunch of filters apart and posting everything about them
It was the same size as the white "OEM" filter I replaced, wonder if NAPA makes one thats just as tall as the black one you got there and will still work normally
2010 blue with tech, cobb sri+tip+dp+cbe, ets tmic, grimmspd ebcs, autotek hpfp, jbr boosttoobs+rmm+roundknob+bushings, turbosmart bpv, swift springs, APv3 FreekTuned
retrofitted headlights: morimoto 5k HIDs with XB35 ballasts, in mini D2S projectors. VLED triton 5k switchback DRL/turn signals
♡°☆(ಠೆಒಠಿ)☆°♡
makjur is offline   Reply With Quote
 Old 06-27-2012, 08:40 AM   #40
CaptObvious75's Avatar
Posts: 535   (View Stats)
CaptObvious75 is the leader of the worldCaptObvious75 is the leader of the worldCaptObvious75 is the leader of the worldCaptObvious75 is the leader of the worldCaptObvious75 is the leader of the worldCaptObvious75 is the leader of the worldCaptObvious75 is the leader of the worldCaptObvious75 is the leader of the worldCaptObvious75 is the leader of the worldCaptObvious75 is the leader of the worldCaptObvious75 is the leader of the world
Groaned at 12 Times in 7 Posts
I use Fram's synthetic oil filter: FRAM® The Synthetic Oil Filter
I'm happy with it and people online tend to be happy with it as well
--2010 Black Mica Mazdaspeed3--
Stock af
CaptObvious75 is offline   Reply With Quote
The Following User Says Thank You to CaptObvious75 For This Useful Post:
RACER_X (12-24-2012)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f435/oil-filter-info-45738/
Google INTERIA.PL - szukaj: 2.5l mazda mzr cut off This thread Refback 06-28-2013 08:47 AM
Where is my oil filter? JunkSpeedS!X MazdaSpeed 6 - Engine, Transmission & Driveline 4 01-07-2010 07:56 PM
OIL & OIl filter rtabagaboy MazdaSpeed 3 - Engine, Transmission & Driveline 30 09-16-2009 08:53 PM
oil filter? gtlaw MazdaSpeed 6 - Engine, Transmission & Driveline 5 04-01-2009 10:57 PM
Air Filter MS3-oholic MazdaSpeed 3/6 - Turbo Induction 4 05-19-2008 11:51 AM
Page generated in 0.59795 seconds with 48 queries
