> 2010 MS3 - Torque Specs & information
 Old 07-05-2012, 09:22 PM   #41
makjur's Avatar
Posts: 1,313   (View Stats)
makjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the world
Groaned at 15 Times in 8 Posts
both time I changed the oil (first time was at dealer, 2nd time I did myself) I noticed that the filter had to get screwed on tighter after the new oil got its first warmup
both times i noticed drippage on the filter until i gave it another hard twist
anyone else notice this?
2010 blue with tech, cobb sri+tip+dp+cbe, ets tmic, grimmspd ebcs, autotek hpfp, jbr boosttoobs+rmm+roundknob+bushings, turbosmart bpv, swift springs, APv3 FreekTuned
retrofitted headlights: morimoto 5k HIDs with XB35 ballasts, in mini D2S projectors. VLED triton 5k switchback DRL/turn signals
♡°☆(ಠೆಒಠಿ)☆°♡
makjur is offline   Reply With Quote
 Old 12-11-2012, 07:26 PM   #42
qweedqwag's Avatar
Posts: 233   (View Stats)
qweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the world
Groaned at 22 Times in 10 Posts
Im thinking about going with a Fram oil filter
their sizes for filters are:
Mazda 6 V6: 4.92 inches in length.
Mazdaspeed: 3.34 inches in length
Will going with a larger filter effect fuel pressure whether positive or negatively?
Fuel pressure....really thumbdick...fuel pressure.
qweedqwag is offline   Reply With Quote
 Old 01-01-2013, 02:43 PM   #43
Limeybastard's Avatar
Posts: 578   (View Stats)
Limeybastard is the leader of the worldLimeybastard is the leader of the worldLimeybastard is the leader of the worldLimeybastard is the leader of the worldLimeybastard is the leader of the worldLimeybastard is the leader of the worldLimeybastard is the leader of the worldLimeybastard is the leader of the worldLimeybastard is the leader of the worldLimeybastard is the leader of the worldLimeybastard is the leader of the world
Groaned at 68 Times in 30 Posts
I use the Bosch 30333 filter.
British Expat living in the land of the "3"
2013 W/tech
Limeybastard is offline   Reply With Quote
 Old 01-04-2013, 08:08 AM   #44
flyinspeed's Avatar
Posts: 38   (View Stats)
flyinspeed is a glorious beacon of lightflyinspeed is a glorious beacon of lightflyinspeed is a glorious beacon of lightflyinspeed is a glorious beacon of lightflyinspeed is a glorious beacon of lightflyinspeed is a glorious beacon of light
I use Mazda white filter with not a days problem. take 5.50 to 5.75 quarts of oil.. call it a day..
[FONT="Comic Sans MS"]First car. 1995 Mazda MX-6 great first car
2007 speed 6. Full bolt on on BNR stage 3 .. went 12.5 on stock clutch . SOLD
2008 Mazdaspeed 3
Car made 314 WHP and 354 WTQ on LEX Etune On 93.
330 WHP And 400 WTQ on 1/3 tank of E85 SOLD
Current. 2010 speed 3.. JBR sway bar.. Ebay test pipe, Ebay downpipe, Magnaflow catback, Corksport intake and inlet, Fordge V2, CPE TMIC, Corksport lowering springs. Home made shifter bushings, Auto tech internals, Corksport cold air intake box, Tuned by LEX on 93FONT]
flyinspeed is offline   Reply With Quote
 Old 02-01-2013, 09:44 PM   #45
dhsieh911018's Avatar
Posts: 530   (View Stats)
dhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the world
Groaned at 55 Times in 35 Posts
went to the dealer today for an oil filter. LF05-14-302B
what's the difference between LF05-14-302B and LF05-14-302A?
2011 VRM w/ tech pkg
SURE SRI+TIP
NGK LTR7IX-11
CPE TMIC
JBR rmm 88
Cobb AP
ATP dp
UR test pipe
Autotech FP internal
Moddiction Anvil shift knob
JBR solid shifter bushing
SURE ShortCut+CounterShift
Corksport LED light kit
Corksport lug nut set
Enkei Raijin
Corksport LED fog light kit
H&R Springs
UR axleback
Shell Rotella T6
Motorcraft XT-M5-QS
dhsieh911018 is offline   Reply With Quote
 Old 02-05-2013, 01:30 PM   #46
90210's Avatar
Posts: 271   (View Stats)
90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world
I would like to know this as well. I used to buy them from Rosenthal for my 2012 Mazda 5, and they sell the 302-A.
Checked today to order, and its all 302-B...
90210 is offline   Reply With Quote
 Old 02-06-2013, 05:14 PM   #47
just did an oil change with 302-B. the engine took 6 quarts exactly
SURE SRI+TIP
NGK LTR7IX-11
CPE TMIC
JBR rmm 88
Cobb AP
ATP dp
UR test pipe
Enkei Raijin
H&R Springs
UR axleback
Shell Rotella T6
Motorcraft XT-M5-QS
 Old 02-07-2013, 12:56 AM   #48
intotheice's Avatar
Posts: 85   (View Stats)
intotheice is just really niceintotheice is just really niceintotheice is just really niceintotheice is just really niceintotheice is just really nice
Are you sure? I put around 5.7-5.8 quartz and its a bit over the full mark already
Did you drive the car for 10km and wait at least 5-10 minutes before checking the oil? You need to check the oil when the car is at normal operating temp
intotheice is offline   Reply With Quote
 Old 02-07-2013, 07:19 PM   #49
yep
SURE SRI+TIP
NGK LTR7IX-11
CPE TMIC
JBR rmm 88
Cobb AP
ATP dp
UR test pipe
Enkei Raijin
H&R Springs
UR axleback
Shell Rotella T6
Motorcraft XT-M5-QS
 Old 03-15-2013, 10:03 AM   #50
90210's Avatar
Originally Posted by gitarpik View Post
I used a NAPA gold filter recently, would like to give the dude credit that posted on here for ripping a bunch of filters apart and posting everything about them
It was the same size as the white "OEM" filter I replaced, wonder if NAPA makes one thats just as tall as the black one you got there and will still work normally
Do you know the NAPA gold filter?
I have a Napa by my house, and also Oreilly (which has the WIX).
Thanks
 Old 03-15-2013, 11:44 AM   #51
makjur's Avatar
Thanks
I have used napa golds for my past 3 oil changes, going to stick with them
 Old 03-15-2013, 11:54 AM   #52
90210's Avatar
Thanks!
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f435/oil-filter-info-45738/
Google INTERIA.PL - szukaj: 2.5l mazda mzr cut off This thread Refback 06-28-2013 08:47 AM
Where is my oil filter? JunkSpeedS!X MazdaSpeed 6 - Engine, Transmission & Driveline 4 01-07-2010 07:56 PM
OIL & OIl filter rtabagaboy MazdaSpeed 3 - Engine, Transmission & Driveline 30 09-16-2009 08:53 PM
oil filter? gtlaw MazdaSpeed 6 - Engine, Transmission & Driveline 5 04-01-2009 10:57 PM
Air Filter MS3-oholic MazdaSpeed 3/6 - Turbo Induction 4 05-19-2008 11:51 AM
Page generated in 0.31201 seconds with 27 queries
