> 2010 MS3 - Torque Specs & information
  • 1 Post By himurax13
 Old 05-10-2013, 07:08 AM   #1
sbohr57's Avatar
Posts: 6   (View Stats)
sbohr57 is an unknown quantity at this point
Default Smoking speed3
A buddy of mine put on his Ultimate Racing TBE and a few weeks later or a few hundred miles of driving it with the cobb ots maps he started to blow smoke like a chimney! How can we prevent that from happening all together? I heard a Catch Can helps it but wanna hear what people did to fix there smoking speed3.
sbohr57 is offline   Reply With Quote
 Old 05-10-2013, 07:11 AM   #2
BNR
/EOT
chaser27 (12-30-2014)
 Old 05-10-2013, 07:15 AM   #3
MazdaBoy2.3's Avatar
Posts: 5,797   (View Stats)
Groans: 51
Donate and unlock the power or NY NATOR!
The Following User Says Thank You to MazdaBoy2.3 For This Useful Post:
Kdawg207 (05-10-2013)
 Old 05-13-2013, 05:33 PM   #4
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
A catch can will do little to stop a smokey turbo.
Some have had luck with using Shell Rotella T6 5w40, BNOON bolt, and raising the RPM's to 950.
Others have had luck with going big turbo or installing a low mileage/rebuilt K04.
You could just reinstall stock exhaust.
Hoyoman likes this.
Pickles Tune in progress
 Old 05-17-2013, 08:27 PM   #5
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
Definitely agree with himurax; some good ol' 5w-40 oil and raise the RPM's (850-950 I believe is the standard).
There's TONS of posts about smoking turbos; read and learn yourself!
Silver 2007 Speed3 GT
himurax13 (02-13-2015)
 Old 12-30-2014, 08:49 AM   #6
FatalSinz's Avatar
Posts: 70   (View Stats)
FatalSinz has a reputation beyond reputeFatalSinz has a reputation beyond reputeFatalSinz has a reputation beyond reputeFatalSinz has a reputation beyond reputeFatalSinz has a reputation beyond reputeFatalSinz has a reputation beyond reputeFatalSinz has a reputation beyond reputeFatalSinz has a reputation beyond reputeFatalSinz has a reputation beyond reputeFatalSinz has a reputation beyond reputeFatalSinz has a reputation beyond repute
DISI Turbo Oil Restrictor Bolt.
/thread
FatalSinz is offline   Reply With Quote
 Old 12-30-2014, 12:43 PM   #7
WAMBUSHHHH!'s Avatar
Posts: 1,599   (View Stats)
/thread
year old thread revival should /thread.
 Old 12-30-2014, 02:43 PM   #8
FatalSinz's Avatar
I've really gotta start paying attention to that... Sorry massa.
JBR Rear Sway Bar / JBR Short Shifter Plate / JBR Shifter Bushings / JBR Small Battery Box / JBR 3.5” Wide Path Intake / JBR 88A RMM / Bosch 3Bar Map Sensor / Bosch PNP Harness / CS Turbo / Purple Drank Tune / Ultimate Racing Catted DP / Ultimate Racing Test Pipe / NGK6510 Spark Plugs / Damond Oil Catch Can / Grimmspeed 3 Port EBCS / Autotech HPFP / Braided SS 5AN Fluid Lines / Treadstone TR8 FMIC / CX Racing FMIC Piping / Vibrant Couplers / Koni STR.T / H&R Springs / Forge V1 BPV / CS STI Front Lip / 17x9+35 XXR 968 / 245/45/17 / Potenza RE760 / 94 Octane + 4 Gal E85
The Following User Says Thank You to FatalSinz For This Useful Post:
WAMBUSHHHH! (12-30-2014)
 Old 01-07-2015, 11:05 PM   #9
ChiMi_ChunGa's Avatar
Posts: 3   (View Stats)
ChiMi_ChunGa is an unknown quantity at this point
Default 2010 mazdaspeed3 blown turbo seal
My 2010 just started smoking this past weekend. Blown turbo seal at 57k miles. Warranty covers 50k 5 years. Mazda dealership wants nothing to do with it. Just bought the car 8 months ago at 46k and now having to do rebuild on k04. Has anyone rebuilt their k04's at G-POP Shop? Going to try and take out and send in some time next week. Been hearing lots of good things about G-POP.
ChiMi_ChunGa is offline   Reply With Quote
 Old 01-07-2015, 11:21 PM   #10
Masterbaiter's Avatar
Posts: 137   (View Stats)
Masterbaiter has a reputation beyond reputeMasterbaiter has a reputation beyond reputeMasterbaiter has a reputation beyond reputeMasterbaiter has a reputation beyond reputeMasterbaiter has a reputation beyond reputeMasterbaiter has a reputation beyond reputeMasterbaiter has a reputation beyond reputeMasterbaiter has a reputation beyond reputeMasterbaiter has a reputation beyond reputeMasterbaiter has a reputation beyond reputeMasterbaiter has a reputation beyond repute
Have you tried the above stated remedys for a smokey turbo? Those are all easier and cheaper to do than rebuilding a turbo. Unless you absolutely need to rebuild it. Also might be a good time to consider upgrading too.
Masterbaiter is offline   Reply With Quote
 Old 01-08-2015, 12:07 AM   #11
Default 2010 Mazdaspeed 3 blown turbo seal
I don't think this is simple pcv or anything simple. I removed intercooler and wet and fresh oil and lots of it in turbine housing and intercooler. Seems to be like the thread say. Pcv valve no working properly at idle causing oil pressure to build up on turbo seals due to the fact that oil cannot drain out properly. Seeing that the only way that oil seals can go bad early is not enough oil causing turbo seals to go bad at an earlier state or oil pressure on turbo seals from pressure inside turbo from not returning properly on return line causing seals to become weak. I believe banjo bolt seems like a quick bandaid for lightly smoking turbo but think more oil would help with longevity of turbo itself. Raising idle to 950 RPM's might keep vacuum high on pcv valve to help with drainage of oil from return line. I've seem a vid on Mazda dealership relocating pcv vacuum line from I take to turbo inlet side to try and increase vacuum pressure moving line closer to turbine. I've always believed that more oil is better for a turbo just as long as it can drain out properly. Seems like mazda has made a bit of miscalculations with developling. Will post up again once k04 has come back from G-POP. Total rebuild and balance and hope it will give me more mileage than the one from factory.
 Old 01-08-2015, 12:13 AM   #12
Has anyone done a Garrett upgrade that will pass smog. That is the only concern. They sell Garrett gt28 direct bolt on from website but ball bearing which means more air. More air means more fuel. Fuel pump upgrade and so forth. Need to keep my ride as stock as possible for smog purposes. California laws are a pain and don't got time to be wrenching all the time. Currently on hypertech tune, cpe cold air, jbr RRM, HKS bov, cobb shift bushing. Don't want to have to do anymore or go with Cobb AP due to fuel upgrades. Car drives good 17psi with HT tune.
 Old 02-13-2015, 04:37 PM   #13
JewBagel254's Avatar
Posts: 21   (View Stats)
JewBagel254 has disabled reputation
what's the minimum requirements for the BNR S3 upgrade? Manifold? Built motor? My turbo started to smoke and would really like to do it right especially with RPMs sale going on, but unfortunately i'm not to familiar with turbo induction.
2010 Mazdaspeed 3 with Tech
BNR S3v2 Turbocharger with 3 Bar Map | Grimmspeed EBCS | CS Stage II SRI with TIP | Autotech Internals | cp-e QKspl™ Downpipe | Cobb XLE BPV | cp-e xFlex™ Stage 2 RMM | Cobb Accessport V3 | Rice; EVO X Recaro seats | Rally Armor
JewBagel254 is offline   Reply With Quote
 Old 02-13-2015, 06:56 PM   #14
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
You only "need" the BNR S3. It's a bolt-on replacement. It's highly recommended that you upgrade your MAP sensor and EBCS at the same time. That's why companies like RPM offer bundles like this:
BNR S3 Upgrade Bundle @ therpmstore.com
2007 Mazdaspeed3 GT
 Old 02-13-2015, 07:19 PM   #15
himurax13's Avatar
Groans: 255
I highly doubt that there is any Garret Turbo that you can bolt on that would pass visual. The drain line alone is a dead giveaway. So is the downpipe, midpipe, and probably a Front Mount as well ...
A beaner turbo is a better option if you want to look "Stockish."
All you really need is to be at or near being fully bolted. Things like an upgraded HPFP, 3 port ebcs or restrictor, having an Accesport married to your car, losing one cat, and upgrading the intake is basically the minimum requirements.
 Old 03-20-2015, 05:51 PM   #16
2ndGenM$3's Avatar
Posts: 62   (View Stats)
2ndGenM$3 has a spectacular aura about2ndGenM$3 has a spectacular aura about
Typically it's Not cost effective to fix the k04. They fail too often if you ask me... I had two blow in 40k miles even though the second one kinda died from oil starvation. Search k04 replacement Turbo. I think EdgeAuto has remanufactured ones. This will be your best option if you don't already have HPFP, Cobb AP, or anything else listed above. Just the AP and HPFP is close to a grand... Hope you have a credit card or are really handy though cause the parts $ add up. $600+ turbo install unless u know somebody who knows somebody who yeah.. u get it. Mazda will charge you twice that and they wont guarantee any parts you buy so if something fails, your out of luck. Keep that in mind.
My first turbo started blowing smoke due to " Loose Turbine Housing" according to Mazda. I let them fix the first one @ 10k miles. This last one I replaced with BNR. So far so good! But I had everything else needed too..
BNRs3 Turbo--SU RMM--CS Intake w/ TIP--CS STB--CS Radiator--TurboSmart DP BOV--ATP TBE-- Autotec HPFP--CP-e TMIC--v2 Cobb AP-- Stratified Tune--JBR Boost tubes--SURE rear Sway Bar-- Tanabe Front Chassis Brace-- GT Spec H brace--
JVC Double DIN Nav-- JBL p660s front/rear-- RF P3 10" Sub--3 Amps 1200w RMS total System powa!--
2ndGenM$3 is offline   Reply With Quote
2013 speed3 smoking blkonblk 2010 MS3 - Troubleshoot/Diagnostics 20 06-08-2013 11:16 AM
Smoking MS3 DV8 MazdaSpeed 3/6 - Turbo Induction 10 02-25-2010 04:29 PM
Page generated in 0.36326 seconds with 31 queries
