> 2010 MS3 - Torque Specs & information
 Old 02-01-2010, 01:35 PM   #1
Darien's Avatar
Posts: 13   (View Stats)
Darien is an unknown quantity at this point
Default Transmission plate to RMM
Just wondering if someone with a service manual could give me the torque specs on the three bolts that attach the plate to the transmission and the front of the rmm? 2010 Speed3.
Darien is offline   Reply With Quote
 Old 02-01-2010, 01:55 PM   #2
ms3077's Avatar
Posts: 4,024   (View Stats)
ms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the world
Groans: 974
Groaned at 738 Times in 373 Posts
I want to say ~ 80ft-lbs but I'm not 100% sure.
ms3077 is offline   Reply With Quote
 Old 02-01-2010, 04:10 PM   #3
Darien's Avatar
Hopefully you are close, I put them at 70 but was unsure if that was to tight due to the transmission case made of aluminum (skerd of stripping). Thanks for your help.
 Old 02-01-2010, 04:12 PM   #4
HLR Element's Avatar
Posts: 2,477   (View Stats)
HLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the world
Groans: 109
i think it's like 70-80 too when i looked it up... I did it to 100 just to be safe... you aren't striping anything even beyond 100... It was wayyy more than 100 to get those damn bolts off... and it's not cause of locktite or anything -_-
Mk7 GTI
HLR Element is offline   Reply With Quote
 Old 02-02-2010, 06:21 PM   #5
Darien's Avatar
I hear ya, lol. I didn't think mine were bad at all, but then again I turn wrenches on a regular basis. I used a 1/2" breaker bar about 14" long and it was actually easy.
 Old 06-17-2011, 03:41 PM   #6
2010Speed3dragan's Avatar
Posts: 11   (View Stats)
2010Speed3dragan is an unknown quantity at this point
70 FT/LB is the proper spec.
2010Speed3dragan is offline   Reply With Quote
Rho-Plate pharoh Exterior 17 01-24-2010 07:53 PM
my tow plate for $6.99 TWOptSL0W Appearance - BLACK 9 12-09-2009 10:08 AM
another STS plate pic huffentuff09 MazdaSpeed 6 - Engine, Transmission & Driveline 0 11-18-2009 04:53 PM
Page generated in 0.26238 seconds with 23 queries
