 Old 08-05-2019, 10:41 AM   #1
tmaiorca's Avatar
Posts: 193   (View Stats)
tmaiorca is a glorious beacon of lighttmaiorca is a glorious beacon of lighttmaiorca is a glorious beacon of lighttmaiorca is a glorious beacon of lighttmaiorca is a glorious beacon of lighttmaiorca is a glorious beacon of light
Default Chasing an EVAP Leak...
Threw a P0442 the other week. Replaced the Purge Solenoid Valve (PSV), code remained. Replaced the gas cap, drove 500+ miles, no check engine light.
Just left now to get the car inspected, threw a P0456.
Previous threads on here seem to either have been resolved by the PSV or gas cap, or have not been updated with what resolved the issue.
Besides replacing every single vacuum line, what other direction can I troubleshoot in? Vapor canister? If I perform a smoke test, what would the best method for performing this?
RIP 2006 MS6:: CP-E CAI // 3" CP-E TIP // SU Turbosmart BPV // M2 3" Catless DP // Cobb AP v2 //CP-E Rear Motor Mount // JBR SSP //JBR OCC // 1" Springs // EGR Unplugged // JBR Coolant Bypass // JBR TIG
2010 Genpu:: JBR SRI // JBR TIH // SU Turbosmart Full Recirc BPV // Cobb AP v2 // S-OTS Tuned // RallyArmor UR
tmaiorca is offline   Reply With Quote
 Old 08-05-2019, 02:56 PM   #2
Posts: 2,233   (View Stats)
i got that same with the cx7, i will watch to see if someone have good suggestions...
EVAP not ready and P0455 EVAP CEL issue aviator79 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 35 03-04-2016 07:12 AM
CEL - P0441 ( EVAP ) Caldwell Mazdaspeed3/6 General Discussion 10 04-14-2014 01:39 PM
P0455, P02187... Evap leak ItalianSA MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 04-04-2012 03:05 PM
Very Small Leak (evap code) CEL Mizzle MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 06-16-2010 01:09 AM
Page generated in 0.22887 seconds with 21 queries
