Like Tree6Likes
  • 1 Post By phate
  • 1 Post By G26
  • 1 Post By f-castrillo
  • 1 Post By atvfreek
  • 1 Post By jme
 Old 07-25-2012, 09:01 AM   #1
f-castrillo's Avatar
Posts: 1,342   (View Stats)
f-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the world
Default DTC P2004, P2009
So last night I installed an OCC, EGR delete/blockoff, and IM TIG. Of course, that involved removing a number of things:
- Battery box, to allow access to move the inlet hose out of the way to access the EGR piping.
- Throttle body, in order to gain access to EGR piping and remove the IM.
- Black box on top of IM, as well as disconnecting the tubing on the black box leading to that VTCS controller thing, in order to remove the IM.
- MAP sensor
- Intake manifold, to get good clearance to route the OCC tubing for the PCV outlet and IM inlet.
- a variety of electrical harnesses and plugs to pull the IM out.
I reinstalled everything, and tightened everything down. All was well, (save for the P0401, EGR CEL, which I deleted promptly) until I noticed that I wasn't making boost targets. I command 20 psi across the board from 3000 RPM on up, but I was only getting 16 psi, and it seemed to taper down as RPMs rise, mimicking the boost curve I commanded, just much lower.
This morning, on the way to work, the CEL light came back on, and this time it pulled a P2004 and P2009. P2004 was described by the scantool app as "Intake mani runner stuck open", and P2009 was described as "intake mani low circuit".
I did some searching, and the only issues related to P2004 or P2009 seem to be VTCS delete-related, which is a mod I did not do.
I did not get a chance to log yet, but this morning I went WOT for a few seconds, and noticed that my AFRs are way off as well (seeing 10.x and even high 9.x:1, when I'm commanding 11.8 at the same range). I will make it a point to log at some point tonight or tomorrow.
So I have a few thoughts running through my mind as to what could be causing my issues.
- possible loose TIH? The inlet hose isn't pressurized though, so I shouldn't be seeing massive leaks here.
- Loose IM? Possibly, but I made it a point to make sure it was bolted tight enough, and I'm sure I would've had some vacuum leak CELs by now if it was an IM leak.
- Unplugged harnesses/wiring? I'm positive I reconnected everything, but I'll check again.
- MAP wire tap for WMI controller? I disconnected the Posi-tap connecting the WMI controller wire to the MAP wire on the ECU during the battery box/ECU removal, and reconnected it after. Could a faulty connection to the controller be skewing MAP voltage readings, and therefore boost readings?
- MAP sensor - this thing is plugged and bolted into the manifold as it should be. I can't imagine my problem lies here.
- JBR Stage2 OCC setup - since the IM is now connected to the OCC outlet, could the tubing act as another airflow path and possibly pressurize the OCC, and leak through the drain valve? The stage2 kit has a check valve in place right after leaving the PCV, so I know at least air won't make it back to the PCV area if this is the case. Are tuning changes needed to account for an OCC and EGR delete?
- I checked all hoses connecting the TIH to the turbo components and valve cover. Nothing out of the ordinary.
Any help would be appreciated. I'm at work, and will try to deal with this again later.
@rfinkle2
@djuosnteisn
@silvapain
@Dano
@Bucker
@cld12pk2go
@Ziggo
@phate
(just calling on the people who have been helpful to me in the past )
EDIT: I should note that drivability is more or less OK, except that it doesn't pull nearly as hard at WOT. Part throttle seems to stumble a bit if I rapidly stab the accel pedal
(310whp, 341 ft/lb wtq) 91 octane + 100% methanol
JBR RSB, Stage2 OCC, Stage 2 SSP, IM TIG, 70D RMM, 70D PMM // DevilsOwn Stage 2 WMI kit + DO7 nozzle (MSF-prize) // COBB AP (Self-tune), XLE BPV // Corksport TMIC, SRI, TIP // Racing Beat Cat-back Exhaust // Denso Iridium ITV22 Spark Plugs // SURE TB TIG // Ultimate Racing Test Pipe // KMD HPFP Internals // TSW Nurburgring 18x7.5 ET45 Matte Black // SWIFT Spec-R Lowering Springs //
f-castrillo is offline   Reply With Quote
 Old 07-25-2012, 09:07 AM   #2
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Did you plug in the VTCS thingy on the driver side of the intake manifold?
-06 MS6
-Corn fed 07 MS3 - Sold
btstarcher (07-25-2012), f-castrillo (07-25-2012), rfinkle2 (07-25-2012)
 Old 07-25-2012, 09:09 AM   #3
G26
G26's Avatar
Posts: 2,988   (View Stats)
G26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the world
Groans: 39
Check all the vtcs plugs, the little solenoid on the right side of the IM, and the black box plug.
2011 MS3 / Fully Bolted / 290whp - 320wtrq ~ Sold
2010 Accord Coupe EX-L V6 ~ Current ~ K&N SRI / 4300k HIDs
G26 is offline   Reply With Quote
The Following 3 Users Say Thank You to G26 For This Useful Post:
Bucker (07-25-2012), f-castrillo (07-25-2012), rfinkle2 (07-25-2012)
 Old 07-25-2012, 09:10 AM   #4
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
Just what they said, make sure the VTCS shit is all connected. Sounds like a leak.
403whp/451ft/lb Dry Shot
The Following 2 Users Say Thank You to Bucker For This Useful Post:
 Old 07-25-2012, 09:13 AM   #5
G26
G26's Avatar
Groans: 39
You definitely have a leak someplace, as well as maybe forgetting to plug in the vtcs system.
The matt damond OCC kit has the check valve off the intake mani side to prevent pressurized air hitting the occ.
The Following 2 Users Say Thank You to G26 For This Useful Post:
 Old 07-25-2012, 09:13 AM   #6
Oliverms3's Avatar
Posts: 1,632   (View Stats)
Oliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the world
that black box on top of the mani... right below it.. there's a rubber o-ring.. check if its there also.. if its not.. then that's why your boost is low
2010 BM MS3 - Cobb AP||3gal corn||Autotech Internals||ETS TMIC||Forge BPV||Denso Iridium ITV22||TurboXS DP||ARK exhaust||CP-E Nano SRI||PG TIP||JBR RMM||JBR PMM||TRZ TMM||NRG ETD||DDM 55w 5000k HIDs and DDM 35w 3000k HID fogs||JB Heavy Knob||JB SSP||ST Coilovers w/ Eibach rear Camber Kit(made by SPC)||17x9 +28 Drag DR31 (track) RPF1 18x8 +35 (DD)||HKS TT Type 0||Clarion EQ||MB Quarts speakers||Pioneer amps and 10" Competition Sub.
346hp 392lbs of sexyness
Oliverms3 is offline   Reply With Quote
The Following 4 Users Say Thank You to Oliverms3 For This Useful Post:
Constantin (07-25-2012), f-castrillo (07-25-2012), G26 (07-25-2012), rfinkle2 (07-25-2012)
 Old 07-25-2012, 09:18 AM   #7
Constantin's Avatar
Posts: 3,907   (View Stats)
Constantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the world
Groaned at 18 Times in 16 Posts
Make sure VTCS "motor" was not damaged. @MS6FL brocke his the other weekend when we did valve cleaning. And yes, tripple check all connectors.
2008 MS3 Tuned by rfinkle2 on 93 - 321whp / 365wtq
Cobb AP, SRI, TIH, DP, BPV | Autotech FP Internals | Treadstone TR8L + PG Pipe Kit | Grimmspeed EBCS | JBR TIGs, RSB, SSP & Bushings, EGR Delete, RMM (88dm), TMM (88dm), PMM (80dm) | MD OCC | KW V2 | SPC Camber Arms | GTSPEC Trunk Cage | Goodridge Break Lines + StopTech PowerSlot Rotors + Hawk HP+ | Whiteline End Links (front) | MOOG End Links (rear) | DDM 55w 5k Head Lights and Fog Lights | Speedline Mirrors
Constantin is offline   Reply With Quote
The Following 3 Users Say Thank You to Constantin For This Useful Post:
 Old 07-25-2012, 09:30 AM   #8
MS6FL's Avatar
Posts: 1,753   (View Stats)
MS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the world
Groans: 43
Yup, I ended breaking that lil white plastic piece on the VCTS that hits the switch to let the ecu know if the flappers are open or closed. Make sure that piece is still there. Apparently it breaks easy. Lol
“From a business standpoint, the Boss 302 shouldn’t have happened. But it happened. My dream for the car was that it would make a lot of money for a guy street racing. It should be a car that winds up on YouTube doing something illegal. I’ve been waiting 20-plus years to launch a car like this.”-Jim Farley
MS6FL is offline   Reply With Quote
The Following User Says Thank You to MS6FL For This Useful Post:
 Old 07-25-2012, 10:27 AM   #9
When you installed the IM Gasket, did you use supplied spacer?
 Old 07-25-2012, 11:25 AM   #10
G26
G26's Avatar
Groans: 39
On mine I did not, and did not reinstall that bolt, or the ones that go sideways.
The Following User Says Thank You to G26 For This Useful Post:
Bucker (07-25-2012)
 Old 07-25-2012, 11:27 AM   #11
It sounds like a large leak and I'm hoping f-castrillo didn't crack his manifold.
 Old 07-25-2012, 11:28 AM   #12
G26
G26's Avatar
Groans: 39
It sounds like a large leak and I'm hoping Fcastrillo didn't crack his manifold.
O ok. lol. I was going to say, that bolt down there doesn't seal anything.
 Old 07-25-2012, 02:58 PM   #13
Thanks for the replies guys. I will go back and recheck all the manifold bolts once I get off of work, as well as the vacuum lines and electrical harnesses around the IM (black box and VTCS control thing).
@rfinkle2 I did not use the supplied washer, nor did I reinstall that bolt. I did the same for the SURE TIG I had prior to this, and didn't have any issue. I cracked my manifold last year, so I'm familiar with the signs of a massive vacuum leak lol.
I don't remember anything being odd when I reinstalled that black box on the IM, or the vacuum plugs under it. I will double check tonight and hope that all is well. I hope the problem isn't with the JBR OCC, as I really don't want to deal with the PCV valve again lol.
Will keep you all updated, thanks!
The Following 2 Users Say Thank You to f-castrillo For This Useful Post:
Oliverms3 (07-25-2012), rfinkle2 (07-25-2012)
 Old 07-25-2012, 04:12 PM   #14
Best of luck f-castrillo! Hope it is something small and easily fixable.
 Old 07-25-2012, 04:27 PM   #15
atvfreek's Avatar
Posts: 7,787   (View Stats)
Sounds like the vacuum lines are mixed up for the vtcs.
Freekn tappin
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 2 Users Say Thank You to atvfreek For This Useful Post:
 Old 07-25-2012, 04:33 PM   #16
atvfreek's Avatar
Actually is that p2009 a circuit low input code? If so check for a pinched or shorted wire at the solenoid.
Freekn tappin
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 07-25-2012, 06:37 PM   #17
I'm gonna double check all connections and bolts, but I think I may have found the culprit in the DTC codes. Hopefully this somehow helps my boost leak issue too.
https://www.youtube.com/watch?v=JymY...e_gdata_player
-- via Jellybean Galaxy Nexus
jme (11-13-2014), N2o (06-23-2014)
 Old 07-25-2012, 06:45 PM   #18
atvfreek's Avatar
Lol, at least it was an easy fix!
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 07-25-2012, 08:51 PM   #19
All is well now
Went WOT several times in 3rd and 4th gear, and my logger app's boost gauge read a solid 19-20psi, and maintaining my commanded 11.8 AFR the whole way. I retightened all possible clamps that could leak pressurized air, but I think my issue was with that black box plug (see video above). No more CELs!
Gonna drive her to work tonight and verify all is OK after a freeway cruise. Thanks all!
dhcorr likes this.
The Following 3 Users Say Thank You to f-castrillo For This Useful Post:
lilred (10-11-2012), Oliverms3 (07-27-2012), phate (07-25-2012)
 Old 07-25-2012, 09:33 PM   #20
Constantin's Avatar
All is well now
Funny video man - "mother fucker"! Great it turned out like quick fix
The Following 2 Users Say Thank You to Constantin For This Useful Post:
dereeek (07-25-2012), f-castrillo (07-25-2012)
 Old 11-13-2014, 06:43 PM   #21
jme
jme's Avatar
Posts: 39   (View Stats)
jme is a jewel in the roughjme is a jewel in the roughjme is a jewel in the roughjme is a jewel in the rough
I just had this code happen to me. I went to my car after watching the video and pushed the black plastic piece in. It clicked and I smiled. SWEET!!!
Casanova likes this.
BNR stage 4 turbo, Full race exhaust manifold, Mahle 2618 Forged Pistons, Darrell Cox vvt, Manley H-Tuff Rods, Clevite H-Series Main & Rod Bearings, SP63 Custom Age 625+ 10mm Head Studs, ARP main studs, Keyed Crankshaft, Pulley, & Sprockets, pioer stage 2 camshaft
Guardian Angle with 4 bar Corksport 3" TBE, HPFP, 3.5" intake, Corksport FMIC, JMF Intake Manifold, Synapse DV, toyota fuel injector seals, Grimm speed EBC, RMM, Balanced Crank/Clutch/Flywheel, Balance shaft delete, James Barone Oil pan Baffle, South Bend stage 4 Extreme clutch kit, Injecting yummy METH "CM10"!
jme is offline   Reply With Quote
The Following User Says Thank You to jme For This Useful Post:
Constantin (11-14-2014)
 Old 02-03-2015, 11:20 AM   #22
jonathanrivera545's Avatar
Posts: 24   (View Stats)
jonathanrivera545 will become famous soon enough
Im see if I can do this today after work crazy part is this happen to me this morning on both my rsx and speed3 im like what the hell same thing and I never have cel on but maybe is due cause its so cold? question do I have take the intercooler off?
jonathanrivera545 is offline   Reply With Quote
 Old 07-14-2015, 02:19 PM   #23
mcdonut420's Avatar
Posts: 10   (View Stats)
mcdonut420 is an unknown quantity at this point
Hey I had the same problem today but my speed6 was acting up yesterday also, got it a bit muddy washed it then my traction control was kicking in for no reason , that problem seemed to solve it's self after awhile, then I got that code p2009 checked the black plug that was previously mention, it was good but a grey plug to the right of it was loose hoping this solves it for me. Find out after work I suppose.
mcdonut420 is offline   Reply With Quote
 Old 07-14-2015, 02:53 PM   #24
speedfreak44's Avatar
Posts: 1,391   (View Stats)
English much?
The line up:
 Old 07-14-2015, 07:27 PM   #25
mcdonut420's Avatar
Well the plug didn't solve my problem. All vaccum lines are on going to check all my piping clamps anything else to look for?
P2004 Fixed djuosnteisn MazdaSpeed 3/6 - ECU Computer Tuning 5 07-24-2017 07:23 PM
MS6 Throwing Codes P0123 P0222 and P2009 Speedn253 MazdaSpeed 6 - Engine, Transmission & Driveline 4 01-19-2012 11:17 AM
P2004 - APV Stuck Open sallyspeed3 MazdaSpeed 3/6 - Turbo Induction 3 03-12-2011 06:52 AM
P2004 and P2010 with vtcs delete Jarods7920 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 09-16-2009 12:49 PM
P2004... APV STUCK OPEN!! WTF !! boost_me
Cobb Access Port/Maps
25 08-22-2008 04:16 PM
Page generated in 0.46697 seconds with 32 queries
