 Old 09-27-2019, 04:39 AM   #1
Parrowman's Avatar
Posts: 2   (View Stats)
Parrowman is an unknown quantity at this point
Default Hesitation at WOT CorkSport turbo
So I have what useems to be an intermittent issue.
At WOT around 4.5k to redline I get some hesitation and what sounds like some backfiring or sputtering from the exhaust .
Mods:
Built block. Manley pistons and rods. King bearings
CST4 turbo
Cs TMIC
CPE HPFP
Cs BCS
Cs BPV
Cs 3.5 bar map sensor
HTP 3.5 intake
Stock dp
UR race pipe
Stock cat back
The map I’m running is custom map that Will at PD did for the previous owner. However the car had a CS TBE with that tune. Looking at my logs i see fuel cutting to around 900 then shooting right back to 1800 2 lines after boost drops to like 4 psi then right back 18 psi. My logic is saying a massive intake with stock exhaust may be the issue.
I’m guessing I need a tune. Planning on getting one anyway. But I don’t want to pay for a tune if I my have an underlying issue. Oh. And I’m not going back to CS exhaust. The noise is just too much. That will be for sale here shortly. If any an can help me out it would be greatly appreciated.
I can post up a log if anyone wants to see it.
Parrowman is offline   Reply With Quote
So, about the new Corksport turbo... dale_gribble CorkSport 1859 08-01-2017 01:32 AM
corksport turbo in CA desertbound1024 MazdaSpeed 3/6 - Turbo Induction 4 04-11-2017 05:51 PM
Corksport Turbo EWG Jester2552 CorkSport 60 12-03-2015 06:53 PM
Corksport Turbo Set Up 406Speed6 CorkSport 7 07-15-2015 11:29 AM
Page generated in 0.22062 seconds with 20 queries
