 Old 05-21-2012, 08:54 PM   #1
mre
mre's Avatar
Posts: 50   (View Stats)
mre is a glorious beacon of lightmre is a glorious beacon of lightmre is a glorious beacon of lightmre is a glorious beacon of lightmre is a glorious beacon of lightmre is a glorious beacon of light
Default p0098 and p0108 codes
I haven't touched my motor, except for an oil change in 5000 miles. today while driving to work, codes p0098 and po108 came one along with my cel and traction control light. My boost gauge is maxing out at 22.3 and my map gauge is maxed out at 255. car runs fine, but i babied it until I could reset ecu, clear codes...still no luck.
I checkd for chewed up wires near the intake clamp like ohers have mentioned and it looks ok there. I did go ahead and move the clamp up a little though, there was signs of a little rubbing, but the black tape around the loom is still intact. Hasn't rubbed thru.
Any other options that anyone car share would be appreciated. I have a track weekend in three weeks and was planning on installing a catch can before the event, but this newest developement really screws my plans up.
Please help if you can.
11 ms3 lsm, cobb stage 2, rmm, sri, tih, fp internals, tmic, shifter bushings, test pipe, rear sway, DGauge, child seat.
Check out my track videos in the ms3 on my youtube channel meggerthree
mre is offline   Reply With Quote
 Old 05-21-2012, 09:03 PM   #2
POWERED BY POLSKA
themytb's Avatar
Posts: 762   (View Stats)
themytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the world
Groans: 38
check hose from turbo to bcs
should be more than that but its all i got for you at the moment
BNR S3---GS 3PORT---3bar map---COBB SRI & TIP---PG/GODSPEED FMIC ---DNP MANI--- CNT catted TBE--CP-E HPFP-- DIY P&P'd intake mani---SURE TIG(mani & tb)---DIY EGR delete---DIY VCTS delete--- DIY OCC/PCV reroute(through old egr port)---CP-E S2 RMM---JBR 80 PMM---TS BPV--- SURE ANCHORS---JBR shift weight---Whiteline RSB
25%E85FREEKPERMED
Last edited by themytb; 05-21-2012 at 09:03 PM. Reason: MSF Database - Automerged Doublepost
themytb is offline   Reply With Quote
 Old 05-30-2012, 08:01 AM   #3
mre
mre's Avatar
thanks for that advice. I will check it. Anyone else with any good ideas please feel free to chime in. I am open to suggestions.
 Old 06-15-2012, 10:26 PM   #4
motherfnmonsta's Avatar
Posts: 2,308   (View Stats)
Groans: 106
Know this is a little late but check your map sensor and the harness around it I bet when they did your oil change they checked your air filter and unpluged the harness and forgot to plug it back in.
 Old 06-17-2012, 01:20 PM   #5
mre
mre's Avatar
Default my fault
I allowed the clamp from he intake to rub into the wiring harnes. I replaced the wire and all is golden. I of course, moved the clamp so that it wouldn't rub anymore. Thanks for all of he good suggestions. Hope I can return the favor someday.
 Old 06-17-2012, 03:51 PM   #6
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
bj's and hand jobs always work around here glad its all settled
The Following User Says Thank You to skeeter149 For This Useful Post:
AwAfrican (03-19-2017)
 Old 06-20-2012, 10:15 AM   #7
Groans: 106
or donations for beer lol
 Old 10-27-2013, 05:33 PM   #8
soccerballz's Avatar
Posts: 596   (View Stats)
soccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the world
Just Got These Two Tonight, I'll Check Some Of These Out In The Morning When ITs Light Out
08' Black Mica MS3
Mods: Vibrant 3" SRI, CP-E 3" TIP, GT3071 IWG, Manley H-beam rods, Wiseco Pistons, BSD, PG Exhaust Mani V3, CP-E Catted Downpipe, Borla CBE, CP-E FMIC, Cobb AP, CP-E HPFP, Turbosmart DP BOV, Cobb SS + Bushings, Cobb Shifter Weight.
Sponsored by NATOR VA
soccerballz is offline   Reply With Quote
 Old 06-03-2016, 09:28 PM   #9
Worbit's Avatar
Posts: 2,552   (View Stats)
Groans: 142
*bump*
What wire are you referring to? I just got these codes myself and I'm trying to figure out what happened....
Zoom-Zoom-Coons on 05/10/16
BUILT BY CORKSPORT
 Old 03-19-2017, 05:00 PM   #10
Atticaz's Avatar
Posts: 621   (View Stats)
Atticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the world
Thread resurection for clarification. What wire harness were you referring to? I have these codes after injector seal replacement.
2017 Mustang V6 - Soon to be Supercharged
2007 MAZDASPEED3 - SOLD
Atticaz is offline   Reply With Quote
 Old 03-21-2017, 02:21 PM   #11
Atticaz's Avatar
Nevermind. I had these two codes due to a combination of two leaks at the same time, after doing my injector seals; a loose turbo inlet clamp and the 22mm EGR tube nut was missed. But, I got it all corrected.
 Old 07-31-2019, 02:05 PM   #12
SKippy552's Avatar
Posts: 14   (View Stats)
SKippy552 has a little shameless behaviour in the past
Default Please help p0108 and p0234 codes
Any suggestions to these two I lost throttle response 3 times in a row then it popped up with these codes
SKippy552 is offline   Reply With Quote
abs codes carter8622 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 07-18-2012 07:31 PM
Need help with codes please. SketchyMark 2010 MS3 - Troubleshoot/Diagnostics 2 01-16-2012 11:41 AM
codes ms3-87 MazdaSpeed 3 - Engine, Transmission & Driveline 1 07-18-2009 08:46 AM
help with cel codes... Decepticon MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 07-16-2009 09:07 PM
Page generated in 0.30253 seconds with 27 queries
