 Old 01-25-2017, 07:39 AM   #1
Flameninja00's Avatar
Posts: 11   (View Stats)
Flameninja00 is an unknown quantity at this point
Default P0245 CEL
Hey all
I'm having an intermittent P0245 CEL ever since I flashed the Cobb stage 3 tune. It was on an unknown tune before, so I flashed to a OTS temporarily until I have time/money to hit up Rob at Hypnotic. I know OTS tunes aren't the best
Car likes to make anywhere from 12-14psi max. I know Cobb tunes are load based, and in cold weather it'll take less psi. But Stage 3's goal peak psi is 18.5, and I'm making 14.
I haven't had time to look at it yet (I'm staying out of boost for right now), but if anyone could point me in the right direction as to where to check, that'd be awesome. My first instinct is a bad EBCS, but I could be wrong.
I can post logs if needed!
Sent from my Pixel XL using Tapatalk
2010 Mazdaspeed3 - Velocity Red Mica
ATP Gen1 GTX3071, CP-E exhaust manifold, CS injector seals, VTCS deleted and lightly ported intake manifold, CS OCC, Turbo xs catless downpipe and midpipe, RamFab 3.5" intake, CP-E FMIC with aftermarket crash bar, Tial QR BPV, CP-E recirculation hose, CS shifter and bushings, HPFP, Avid.1 AV20 17x9, H&R springs, rear wiper delete, Aquamist HFS-4 meth injection, Howerton Engineering tank. Hypnotic Tuned
96 Miata - Montego Blue
OEM Seatbelt tower brace, Retrofitted oil pressure gauge, Thermostat relocation, Oil filter relocation, ARP Head studs. Stripped interior, power steering delete, AC delete. Eventually turbo.
Flameninja00 is offline   Reply With Quote
 Old 01-25-2017, 08:17 AM   #2
Police - Grammarhead
Vansquish's Avatar
Originally Posted by Flameninja00 View Post
Hey all
I haven't had time to look at it yet (I'm staying out of boost for right now), but if anyone could point me in the right direction as to where to check, that'd be awesome. My first instinct is a bad ECBS, but I could be wrong.
Based on a quick search, it sounds like your EBCS may be failing.
 Old 01-25-2017, 08:19 AM   #3
That's what my research came up with too, I just wasn't 100% sure on it
 Old 01-25-2017, 07:00 PM   #4
sheston's Avatar
Posts: 1,847   (View Stats)
Woo Hoo! Upgrade time
 Old 01-26-2017, 08:45 AM   #5
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
The Cobb OTS tunes are boost-based and shitty.
P0245 usually means your EBCS wiring or connector is either disconnected or bad. It could also mean the EBCS is bad.
2007 Mazdaspeed3 GT
 Old 01-26-2017, 01:49 PM   #6
I checked all the wiring to and from the EBCS and everything is all good. Looks like I'll be adding a GrimmSpeed part to my sig soon lmao
 Old 01-26-2017, 03:07 PM   #7
MD1032's Avatar
Groans: 143
Yup. You can also order the MAC kit from JBR. It's literally the same exact valve.
2007 Mazdaspeed3 GT
 Old 01-26-2017, 03:30 PM   #8
http://www.jamesbaroneracing.com/sho...roducts_id=877
Well hell, $30 less for the same thing? I can dig it
 Old 01-26-2017, 06:50 PM   #9
sheston's Avatar
I found with the upgraded EBCS I could get that K04 to actually hold more boost. Good upgrade for those who like a little more at the high end....
And you've already got the Meth to deal with the heat.
MD1032 (01-27-2017)
 Old 01-26-2017, 07:04 PM   #10
Good to know! It is a good thing, huh?
 Old 01-26-2017, 07:07 PM   #11
sheston's Avatar
Absolutely
p0401 and p0245 cocoleveo7686 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 15 12-10-2013 01:55 PM
P0245 CEL Zbrit00x Gen2 MS3 General Discussion 2 08-09-2012 09:46 PM
CLE P0245 ms6ms6 MazdaSpeed 6 - Engine, Transmission & Driveline 1 09-20-2011 11:26 PM
P0245, with MBC? 11cruzito11 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 12-20-2009 08:29 PM
Page generated in 0.31519 seconds with 23 queries
