![]() Join Date: Oct 2011 Location: Boca Raton, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,717
Groaned at 50 Times in 17 Posts
(Thread Starter) | Not Ranked : 0 score hours and hours reading about with no luck, ordered a ATP DP, thinking my CP-E DP would be the proble,... Then (Thanks to) @2012FailWheelDrive; said, when he grease the BPV, problem fixed. So I installed yesterday a GFB BOV (50/50) and code gone, now I drove the speed for about 90 miles and no code,
__________________ 2012 LSM MS3 Some mods, No list, too much "zapos". |
| The Following User Says Thank You to speeed For This Useful Post: | 2012FailWheelDrive (07-19-2013) |
![]() Join Date: Jul 2012 Location: West Palm Beach FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 101
| Not Ranked : 0 score Glad it worked out!
__________________ "under construction" |
| The Following 2 Users Say Thank You to 2012FailWheelDrive For This Useful Post: | Boost_creep (11-25-2013), speeed (07-19-2013) |
(Thread Starter) | Not Ranked : 0 score Fuck...code came back..... Will change the dp next week. Just ordered a catless ATP DP....let's see how it works....
![]() Join Date: Dec 2012 Location: Colorado Springs
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 193
Groaned at 7 Times in 3 Posts
| Not Ranked : 0 score |
(Thread Starter) | Not Ranked : 0 score No. Just weld short bung like a month ago.....
![]() Join Date: Feb 2011 Location: Cleveland, Ohio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 46
| Not Ranked : 0 score I just installed the ebay catless dp this past weekend and got this same code (along with P0139). I can't remember if the second sensor is extended or not so I am gonna take a look tonight and also check for leaks.
__________________ PushingRedline 2012 Mazdaspeed 3 - Red w/ Tech -Cobb AP/S-OTS Stage 2 -AT Internals -JBR 80 Duro RMM -JBR Stage 3 CAI System -CorkSport SSP -JBR Solid Shifter Bushings -Ebay Catless Downpipe -NGK Iridium IX 1-step Colder Spark Plugs -Forge V2 BPv |
![]() Join Date: Feb 2012 Location: Murrieta, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,285
| Not Ranked : 0 score I get this code about once a month, and just reflash my map to get rid of it. I've noticed my AFRs begin to slowly dwindle down from 14.7-8 or stoic while I idle or drive at cruising speeds, so I'm sure there is some sort of correlation.
__________________ FreekTuned |
![]() Join Date: Nov 2010 Location: Ft Bragg, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24,632
Groaned at 9 Times in 5 Posts
code just popped up for the first time this morning. cleared it with the ap but it came back. plan on unplugging battery to reset ecu then reflash map. hopefully that fixes the issue. gaahhh this sucks.
__________________ 2010 Velocity Red MS3-Eibach PRO-KIT-EVO X Rims-SU RMM-SU solid shifter bushings-CP-e HPFP-CP-e tip-CP-e cai-CP-e hks ssqv bov kit-ddm slim hid kit 35w-5000k-JBR Heavy Shift Knob-JBR RSB-AQ Motorsports catted downpipe-Magnaflow full 3in CBE- SPC camber arms (Stratified tuning) 91/e85 tuned ![]() | |
Im on tapafuck and cant read your sig. ..
__________________ 2012 LSM MS3 Some mods, No list, too much "zapos". | |
| Not Ranked : 0 score No I have an aqmotorsports catted dp, its been on for a good 20k miles with no problems. So I don't think that is the cause. I plan on getting under the car tomorrow and checking for any leaks Sent from my EVO using Tapatalk
__________________ FreekTuned | |
![]() Join Date: Aug 2015 Location: Houston, TX
Rep Power: 0 ![]() Thanks: 0
![]() Join Date: Dec 2018 Location: Milpitas California
Rep Power: 0 ![]() Thanks: 15
What In the actual fuck? Lol. | |
I don’t want your stupid rash viagra | |
I give up. Bots are weird nowadays. | |
| CEL p2096 ? help? | RobLoMS3 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 3 | 06-29-2012 09:22 PM |
| Finally fixed my knock problem! | ricknm | Gen2 MS3 General Discussion | 32 | 06-13-2012 05:00 PM |
| P2096 | Andrew_MPS | 2010 MS3 - Turbo Induction | 14 | 01-30-2011 08:35 AM |
| finally fixed the boost cut with cs sri+tip | TheFranchizeSLB | 2010 MS3 - Turbo Induction | 26 | 12-11-2010 08:07 PM |
| My car is finally fixed! | volodya84 | MazdaSpeed 6 - Engine, Transmission & Driveline | 8 | 05-26-2010 02:36 AM |
