 Old 09-25-2015, 11:28 PM   #1
mazda-speed-3's Avatar
Posts: 188   (View Stats)
mazda-speed-3 has a brilliant futuremazda-speed-3 has a brilliant futuremazda-speed-3 has a brilliant futuremazda-speed-3 has a brilliant futuremazda-speed-3 has a brilliant futuremazda-speed-3 has a brilliant futuremazda-speed-3 has a brilliant futuremazda-speed-3 has a brilliant futuremazda-speed-3 has a brilliant futuremazda-speed-3 has a brilliant futuremazda-speed-3 has a brilliant future
Default Quick check for my logs
Can anybody check my logs please lol
Mods: FMIC CX racing piping and tr6 core
Catless dp, hks axleback
3 inch intake jbr silicone, ebcs
Full egr delete
Hks bov
Internals
tb thermal spacer (jbr)
Jbr mounts
Tb traction bar
mazda-speed-3 is offline   Reply With Quote
 Old 09-25-2015, 11:32 PM   #2
Oh fuck wrong section any moderator can transfer this to right section sorry im posting this thru my.phone sorry
 Old 09-25-2015, 11:41 PM   #3
littleloogy's Avatar
Posts: 4,005   (View Stats)
Logs look fine. I'm curious what they look like when you on and off the throttle. BOV's VTA can make you run rich.
Sent from my iPhone 6
 Old 09-25-2015, 11:43 PM   #4
Yes it does lol.
And btw im tuned by Mr. PD will dawson
 Old 09-26-2015, 07:34 AM   #5
I love after fires, especially at night!
 Old 09-26-2015, 07:44 AM   #6
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
You're getting some consistent KR >1.0 in the top end. Either decrease ignition timing in the affected regions or lower your AFR targets. I can't see what you're running right now although I don't live in CA, so I don't have the best frame of reference for your gas quality and what you should be able to run. Personally I would just decrease timing. If you're getting this kind of KR with BAT's in the 90's-100's, your engine is going to be quite unhappy on an actually hot day. Personally I set my ignition timing on my 93 tune so that I can go WOT any time BAT's are <135-ish.
2007 Mazdaspeed3 GT
 Old 09-26-2015, 09:02 AM   #7
speedfreak44's Avatar
Posts: 1,391   (View Stats)
Sounds counterintuitive but when I start seeing KR I actually leaned out a bit and it went away so may have to play around with that in the upper rpm. I would start with timing first
The line up:
Can someone check these logs? Keefer MazdaSpeed 3/6 - ECU Computer Tuning 3 01-16-2015 09:40 AM
Please check my logs IlleztImportz MazdaSpeed 3/6 - ECU Computer Tuning 7 03-28-2013 10:16 PM
Another 'check my logs please' speed d3mon 2010 MS3 - ECU Computer Tuning 3 03-18-2012 10:06 PM
Check my logs please kabobulate MazdaSpeed 3/6 - ECU Computer Tuning 11 05-01-2011 02:01 PM
Yo! check my logs plz. mr_mazda329 MazdaSpeed 3/6 - ECU Computer Tuning 22 02-26-2011 09:57 AM
Page generated in 0.26230 seconds with 24 queries
