 Old 05-08-2019, 07:07 PM   #1
Yelpats03's Avatar
Posts: 3   (View Stats)
Yelpats03 is an unknown quantity at this point
Default Stock tune 3-KR during WOT
This all started when I noticed some knock going on. Since I don't have a RMM, I figure some knock is fine, but I started seeing a few times when the knock would go way high. I figure, without a RMM, ghost knocking being a thing, higher boost temps (AZ here) as well as other factors, this shouldn't be an issue.
And then one day I did my typical on-ramp pull and noticed the KR go up to 8. I thought that was super odd, so I did another pull (dumb I know), this time logging it to see if it was just noise. While the car actually didn't see 8 on the monitor, it did see 3 on the next pull I did in the logs.
Before I go on, here's a mod list:
CS HPFP
Full CBE (stock DP)
CS SRI Stage 2
CS TIP (Need a tune?? Website says not)
Forge V2 BPV
COBB AP V3
Autolite Iridium XP gapped to .03
I ran without the Cobb OTS maps because well, they're shitty. But I decided to test and see if that would improve my AFRs, KR, and a few other things. And it did in almost every part of the graph. With the only KR I'm seeing at low RPM of a maximum of 0.89.
Here are the logs for the two pulls:
https://datazap.me/u/yelpats03/stage...log=0&data=1-2
Log 78 being Stage 0, and Log 79 being the COBB S1+SF
Also, both the stage 0 and stage 1 tune have the WGDC set to -15% if there is overboost, if that's relevant at all.
EDIT: One thing I did notice as well - The stock tune has the throttle position all over the place while the stage 1 does not.
Yelpats03 is offline   Reply With Quote
 Old 05-09-2019, 06:37 AM   #2
LenSpeed6's Avatar
Posts: 164   (View Stats)
You should really invest in a tune and probably close the gap up with your plugs.
06 Speed6
White/Black interior
 Old 05-09-2019, 10:34 AM   #3
Bertospeed3's Avatar
Posts: 149   (View Stats)
Bertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant future
Yeah I wouldnt be sure where to start but a proper tune and plugs gapped .026-.028 definitely sounds like a good start
2010 MS3 - Tuned By Nishan
Autotech Fuel Pump Internals
OBX R Custom Exhaust
Cobb SF Intake & TIH w. Blitz Filter
CP-e TMIC
Corksport Dual VTA BPV
JBR 88 Duro RMM
Bertospeed3 is offline   Reply With Quote
 Old 05-09-2019, 04:11 PM   #4
Yelpats03's Avatar
Protune was the next step when I get a DP.
I still don't know where to start either lol. Considering I have mods that don't require a tune I couldn't figure this out. And I gapped them to .03 because that was within factory spec, but I didn't realize the OTS tune required lower. Guess I can go do that. Wasn't planning on running the OTS tune either, but if it's safer I will.
 Old 05-09-2019, 06:32 PM   #5
tegxsi's Avatar
Posts: 1,281   (View Stats)
Groans: 87
FYI
The factory plugs on my 2013 were running just over 0.025" gap.
2018 Audi RS3
2007 Acura TSX 6MT
 Old 05-10-2019, 06:49 AM   #6
Police - Grammarhead
Vansquish's Avatar
Actually, according to the revised Mazda workshop manual for the L3-VDT engine, the spark plug gap is supposed to be 0.024" - 0.027".
stock tune wot KR mig02 Mazdaspeed3/6 General Discussion 7 11-11-2013 08:09 AM
Stock tune ms3 vs stock s2000 ap1 Tokay444 Street Racing Stories ( Bench Racing ) 28 08-26-2011 03:49 PM
FFS on an otherwise stock tune SpdFreak
Cobb ATR Support
5 04-29-2010 05:37 PM
Page generated in 0.26145 seconds with 24 queries
