 Old 07-02-2018, 01:37 PM   #1
inclininggerm's Avatar
Posts: 2   (View Stats)
inclininggerm is an unknown quantity at this point
Default Weird Chime/tone noise through speakers
Hey Everyone, I have a weird problem that no one I have talked to could answer. I have a 2013 Speed3 and when I drive around the music will go from all the speakers to the rear and get quiet, then a chime/tone/ring will go off 3 times and then the music will return to all speakers and normal volume.
There are no indicator/warning lights on when it happens. As far as I can tell it just randomly happens as well, no pattern that I can detect. I have attached 2 videos that have the noise in them.
This was caught with my dashcam, so the volume is not the greatest, hopefully good enough for someone to have some idea.
Thanks for the help!
inclininggerm is offline   Reply With Quote
 Old 07-02-2018, 04:56 PM   #2
Solarsurge's Avatar
Posts: 577   (View Stats)
Are you using bluetooth by chance?
The Following User Says Thank You to Solarsurge For This Useful Post:
Pu Manchu (07-03-2018)
 Old 07-02-2018, 05:00 PM   #3
Yes. I might be jumping the gun, but its not from texts or calls. My phone is always on silent and I get texts and calls without that beeping going off.
 Old 07-03-2018, 11:27 PM   #4
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
it's prolly a facebook notification from John Thompson messaging you.
94 M
MS6
IS350
The Following 2 Users Say Thank You to Pu Manchu For This Useful Post:
Db09ms3 (07-08-2019), monkey.bones.007 (07-04-2018)
 Old 07-04-2018, 09:19 AM   #5
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
Do you have the tech package on your car? If so the chime is from speed/red light cameras. You'll have to go into the settings and turn off that notification.
Tapatalk, it sucks for free!
 Old 07-08-2019, 01:52 PM   #6
san1234's Avatar
Posts: 20   (View Stats)
san1234 is an unknown quantity at this point
Does this one have the keyless start, keyless entry? could be your battery is low in your keyfab. My car will chime when the key leaves the car
san1234 is offline   Reply With Quote
Name that weird noise?! rguzman56 MazdaSpeed 3/6 - Suspension & Brakes 6 03-18-2015 04:31 PM
Some weird noise Bockie84 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 08-04-2012 08:03 PM
weird noise babyjake Gen2 MS3 General Discussion 12 11-30-2011 10:55 PM
Weird Noise ms6 envy MazdaSpeed 6 - Engine, Transmission & Driveline 16 05-22-2011 04:52 PM
Page generated in 0.25379 seconds with 25 queries
