 Old 05-08-2013, 11:45 AM   #1
aldekei's Avatar
Posts: 831   (View Stats)
aldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the world
Default White smoke
Occasionally I see a single puff of what looks like white smoke come from the engine bay at startup. The car runs just fine and logs show no indication of any problems.
This has happened three times since February, and I can't tell where it is coming from.
Any ideas?
tapawhat
HTP 3" MAF and Turbo Inlet in Candy Blue over Chrome Smoke
CP-E Downpipe /w Custom Cat | Corksport Catback Exhaust
Beachshoer Intake Manifold P/P /w VTCS Delete
Sure Shortcut | Sure Anchors | Sure 1/8 TIG
Cobb AP | Cobb FMIC | Cobb Sport Springs
ATP GT3071R /w Stratified Boost Dial
Stratified Automotive Guardian Angel
Go Fast Bits Respons (100% VTA)
Autotech Internals
I tune myself, bitches
aldekei is offline   Reply With Quote
 Old 05-08-2013, 11:48 AM   #2
exhaust leak
aldekei (05-08-2013)
 Old 05-08-2013, 11:53 AM   #3
aldekei's Avatar
That was my first thought. There is some minimal streaking where the downpipe connects to the turbo, but seems odd that it would only leak like that once in a blue moon.
tapawhat
Autotech Internals
 Old 07-02-2013, 02:22 PM   #4
11MZR's Avatar
Posts: 786   (View Stats)
11MZR is the leader of the world11MZR is the leader of the world11MZR is the leader of the world11MZR is the leader of the world11MZR is the leader of the world11MZR is the leader of the world11MZR is the leader of the world11MZR is the leader of the world11MZR is the leader of the world11MZR is the leader of the world11MZR is the leader of the world
Groaned at 17 Times in 8 Posts
@aldekei;
I just installed a catless UR test pipe and the same thing has been happening to me recently. It smells, and the smoke comes out randomly after I drive, then stop at a light or stop sign. It does not do it at the first start up, or any start up. Did you ever figure out if it was an exhaust leak, or something else?
FreekBuilt.
I like turtles.
11MZR is offline   Reply With Quote
 Old 07-02-2013, 02:32 PM   #5
aldekei's Avatar
Originally Posted by 11MZR View Post
@aldekei;
I did. The muffler shop that installed my exhaust neglected to tell me that they had trouble reinstalling the forward most stud on the downpipe and ended up leaving it off entirely. The leak only occurred for a few seconds when I cranked the car after it had sat for 2-3 hours.
I've since gone BT with a cp-e downpipe (the corksport design will not work with the atp hotside, btw), and my issue is now long gone.
Where is the smoke coming from in your case? If it is coming from your tail pipe and makes your car look like a fog machine, then I would pull your TIP and check for shaft play in the turbo (assuming k04). Otherwise, get under your car and look for signs of a leak. They should be pretty obvious.
tapawhat
Autotech Internals
 Old 07-02-2013, 02:38 PM   #6
11MZR's Avatar
I'm thinking it's a leak because it's not pouring out like the bad turbo seals problem that these cars have. It's just a quick white/blueish puff randomly. I did have a hard time installing the test pipe, so it may be that. I'll have to check it out.
FreekBuilt.
I like turtles.
 Old 07-20-2013, 11:33 AM   #7
KennyG's Avatar
Posts: 52   (View Stats)
KennyG has a brilliant futureKennyG has a brilliant futureKennyG has a brilliant futureKennyG has a brilliant futureKennyG has a brilliant futureKennyG has a brilliant futureKennyG has a brilliant futureKennyG has a brilliant futureKennyG has a brilliant futureKennyG has a brilliant futureKennyG has a brilliant future
I have done plenty of research on the white smoke pouring out my exhaust. Reading many threads I am glad it happens to others. I don't believe mine is turbo seal because it spools consistent. If you run catless like me you run rich, so that is what I believe my issue is. People yell at me all the time "your car's smoking". I have to turn it off at the bank or drive thru. Told the wife the turbo is bad and needs a GTX.
KennyG is offline   Reply With Quote
 Old 07-22-2013, 12:26 PM   #8
11MZR's Avatar
I did the same thing. Once I started running cat-less, it smoked a little and I was like "oh man, blown turbo, guess I need a new one". She fell for it
Sent from, uhh..
FreekBuilt.
I like turtles.
White smoke campaign kneedraggin101 Mazdaspeed3/6 General Discussion 4 04-06-2013 09:29 PM
Need help, white smoke and cooland gone AGAIN!~ speed31982 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 1 02-03-2012 10:56 PM
White Smoke Soriku1489 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 15 07-08-2010 05:25 PM
White smoke? PLEASE HELP Fallenvoices MazdaSpeed 3/6 - Troubleshoot/Diagnostics 13 01-06-2010 03:39 PM
finally got the white smoke bombdotcom MazdaSpeed 3/6 - Turbo Induction 3 01-29-2009 04:53 PM
Page generated in 0.27495 seconds with 23 queries
