> Ultimate Racing
Ultimate Racing Catback Exhausts, Test Pipes, High Flow Cats, Downpipes, Front Mount Intercoolers. We've got your 2010 Mazdaspeed3 covered!
  • 2 Post By Tomas
 Old 07-19-2012, 07:15 PM   #1
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Default UR V2.0 Downpipe
Upon receiving the standard metal core catted downpipe and mocking it up to an ATP turbine housing noticed that the flapper would contact the DP flange after opening. To a certain degree, that is also the case on the K04 housing but since the flapper is smaller it has more travel. Many running this DP with the K04 so I suppose it's not a problem.
Contacted Ultimate Racing to point out the issue thinking they would probably just brush me off and not address the problem. To my pleasant surprise they immediately asked that I ship the DP back to them with both the K04 and and the ATP turbine housings so they could take a look. A week or two later they had fixed the issue by increasing the size of the bellmouth and revising the flange. Those shmexy canucs are solid people. They sent the DP back to me and it works like a charm. No contact of the flapper against the flange anymore. Dealt with a dood named Daryl. He says UR will call the revised DP the "version 2" and that it will retail for slightly more than the standard DP. Welds look high quality just like the overall construction of the unit.
K04 turbine housing
ATP turbine housing
Ebay uncatted turbine housing for comparison
Tried removing material from the flange to increase flapper range. Results unsatisfactory
Flapper respective to the flange of the DP.
And the V2.0 downpipe.
Domino81 and Standsideways like this.
The Following 15 Users Say Thank You to Tomas For This Useful Post:
802MS3 (08-22-2012), atvfreek (08-22-2012), DingoDave (08-25-2012), Dmurray06 (07-19-2012), Domino81 (09-14-2012), Easter Bunny (08-22-2012), El_Diablo (11-24-2012), FistPump20fo7 (07-21-2012), fywdyl (08-22-2012), helmetface (07-19-2012), Lex (08-22-2012), Nliiitend1 (08-22-2012), Standsideways (07-20-2012), Tokay444 (07-19-2012), uncorked11 (08-24-2012)
 Old 11-11-2012, 06:20 AM   #2
WattHappened's Avatar
Posts: 11   (View Stats)
WattHappened is infamous around these partsWattHappened is infamous around these partsWattHappened is infamous around these partsWattHappened is infamous around these partsWattHappened is infamous around these partsWattHappened is infamous around these parts
Groaned at 119 Times in 11 Posts
Seen this DP in person and I like it but I must admit I'm not a fan of how this DP uses nuts in place of actual bungs for the O2 sensors.
WattHappened is offline   Reply With Quote
The Following User Says NO Thank You to WattHappened For This Un-useful Post:
theschrum (11-24-2012)
ATP downpipe psmith22 Mazdaspeed3/6 General Discussion 12 03-31-2012 05:59 PM
I need help wth Ms3 downpipe screemo1128 MazdaSpeed 3 - Engine, Transmission & Driveline 23 12-20-2011 10:43 AM
AP and CS downpipe EvilMonkey 2010 MS3 - ECU Computer Tuning 16 03-25-2011 08:01 AM
Page generated in 0.23883 seconds with 21 queries
