 Old 05-29-2013, 03:32 AM   #1
shaneski's Avatar
Posts: 505   (View Stats)
Default 3 inch wide path intake couple of questions for Gen Pu
I am currently running a corksport stage 2 intake and wanting to go 3 inch, I need to run an air box due to laws where i am, can the corksport air box be used with this, even if it does need to be modified.
Does the intake come with a vacum hose that goes from the intake to engine (the cork sport intake has it moved further down the intake and uses a short hose).
 Old 05-29-2013, 06:55 AM   #2
I'm willing to bet that the the air box could be modified to work or at least well enough that you'd pass inspection.
It comes with the the boost control solenoid vacuum hose. You'll use the OEM hose to connect the intake to the cam cover vent.
Hope this helps...
allo80 (05-29-2013)
 Old 05-29-2013, 08:28 PM   #3
shaneski's Avatar
Thanks for that, i shall order me one of these bad boys
 Old 06-11-2013, 12:49 AM   #4
shaneski's Avatar
Bummer they are out of stock. i has to wait .
 Old 06-11-2013, 07:29 AM   #5
SKiZZ's Avatar
Posts: 288   (View Stats)
SKiZZ has a reputation beyond reputeSKiZZ has a reputation beyond reputeSKiZZ has a reputation beyond reputeSKiZZ has a reputation beyond reputeSKiZZ has a reputation beyond reputeSKiZZ has a reputation beyond reputeSKiZZ has a reputation beyond reputeSKiZZ has a reputation beyond reputeSKiZZ has a reputation beyond reputeSKiZZ has a reputation beyond reputeSKiZZ has a reputation beyond repute
Do you have a tuner ready? It's not going to run right out of the box.
2013 CWP Mazdaspeed 3
SKiZZ is offline   Reply With Quote
 Old 06-12-2013, 04:58 AM   #6
shaneski's Avatar
Yeah i know i will do the install and get it towed, i am Ecuteck tuned so it wil have to be done on the dyno at the workshop. Am in Australia so we don't have any AP tuners other than an etune and i can't do WOT 4th gear logs with out getting arrested or hitting wildlife.
 Old 07-15-2013, 03:23 AM   #7
shaneski's Avatar
It's fitted, the corksport airbox did need some butchering as the air filter position is a lot more forward and to the left with the JBR.
Bonus was the JBR outside MAF housing diameter is the same as the corksport so put the corksport housing in and clamps up fint to the widepath so i can drive t to get it dyno tuned.
It fits fine with the stock battery box, it barely touches the ECU bottom cover so didnt bother removing that. I'm in Australia so not sure if our battery boxes are a bit more to the left as our steering and break/clutch master cylinder are on the right side
Easy as to install as it is flexible with out obstructing the flow path and don't have to worry about if you have not correctly placed/tightened one of the 6 clamps you have on other intakes
i will be getting the JBR MAf housing fitted and tuned in a couple of days and see how it reacts.
Overall was great product and easy to work with.
The Following User Says Thank You to shaneski For This Useful Post:
JBR (07-15-2013)
New JBR 3.5" Wide Path Full Intake In Stock!! JBR JAMES BARONE RACING 945 02-22-2015 11:44 AM
Questions before ordering a "Path Stage II Power Intake" levon.mark JAMES BARONE RACING 37 03-26-2013 05:01 PM
My Mod Path - Some questions Nachtsturm MazdaSpeed 3/6 - ECU Computer Tuning 51 07-22-2010 03:47 PM
Page generated in 0.27519 seconds with 22 queries
