Mazdaspeed Forums
-   JAMES BARONE RACING (http://www.mazdaspeedforum.org/forum/forum/f493/)
-   -   80a RMM installed-lots of vibration (http://www.mazdaspeedforum.org/forum/forum/f493/80a-rmm-installed-lots-vibration-159321/)
The Ridge 11-18-2013 09:59 AM
I just got a 80a RMM from your company last week and installed it this weekend. Well, the vibration and noise between 1000-2000rpm under any reasonable load is more than I am comfortable with. I now hear new interior panel rattles etc. Granted, the car definitely shifts and responds to throttle input better but not enough for me to justify the vibes on a DD. My questions are how much does break-in help, would a 70a insert make much of a difference;do you sell just the insert to swap, and could there be an install issue that causes more vibrations than expected?
The quality of the part looks great and would appreciate any help. Thanks
trancehead 11-18-2013 10:03 AM
Don't be a puss about it? Vibes are natural.
swsmailman 11-18-2013 10:05 AM
Its natural, it will go away a little bit after you break it in, if you don't want racecar status, go back to that stock one...
The Ridge 11-18-2013 10:10 AM
I was expecting a couple people to tell me I'm lame. Seems normal on here. I guess I was hoping that JBR or someone would have some constructive ideas.
jseams 11-18-2013 10:11 AM
I thought the 88a would rattle my teeth out compared to the Sure street urethane because of posts like this. Then I finally switch, and although there is a marginal increase at very low rpms it's barely noticeable at normal driving ranges.
Either some folks ares a bit too "sensitive" to any vibration or there are other things possibly amplifying an existing issue?
MZRSPEED 11-18-2013 10:17 AM
Its normal, any stiffer mount is going to transfer more noise/vibrations. I had the 88d, didn't care for the vibes, went to the 80d, it's a little better, but still very noticeable.
There are other options, some guys are starting to use the ford efocus rmm, maybe look into that.
Tacheny 11-18-2013 10:19 AM
Quote:
If you don't like the NVH of the mount, find a softer one, reinstall OEM, or break it in.
CWP_MS3 11-18-2013 10:21 AM
Give it time to break in before your write it off. Every mount, regardless of brand, needs time to break in; so the vibes will settle down.
JgamB 11-18-2013 10:40 AM
I've insisted JBR make a "vagina" mount with a rubber bushing. We've probably got a majority that DD the car, and the E-focus mount eliminates wheel hop, firewall bang, and you won't miss shifts. I'm corn tuned doing a little better than 300whp, which also seems to be very common for the DD crowd.
I hate to suggest a Ford OEM part when one of our best vendors with the best customer service could be taking our money instead.
Even if it required more frequent bushing swaps or was prone to material breakdown, it would still be a better solution than inserts on the scrawny OEM mount that is prone to metal fatigue and ultimate failure.
2¢
2.0t03speed 11-18-2013 10:45 AM
if you want something that doesn't add nvh get the JBR rmm. shit is so quiet
VulgarKyle 11-18-2013 11:03 AM
There is l YouTube videos showing a bottle with water vibrating. If its to much for you to handle put the stock back in. The 70 will vibrate also. If you would have read its all about compromise.
Mikey 11-18-2013 11:42 AM
wow they let you off very easy. Why didnt your do research before installing. The price you have to pay because "race car"
6ixof1 11-18-2013 11:51 AM
As others have said, it will be barely noticeable after break in. For me it was about 1k miles. I drive my car hard on occasion so it's well worth it IMO.
rymanmazda 11-18-2013 11:57 AM
It is worth it if you drive hard or track it.
Quigs 11-18-2013 12:00 PM
I don't even notice the vibes from my 88d RMM anymore.
Honestly OP if you want the true performance of an aggressive mount you kind of just need to suck it up. You did buy a performance car after all, not a luxury car with a smooth ride. Either that or at least do some researching first as there are a ton of threads on RMMs on here.
I'd say that the only constructive advise that there is would be to get a mount that better suits your needs.
JgamB 11-18-2013 12:02 PM
The only way to research the vibes is to sit in someone else's car that is mounted. Everyone's tolerance for NVH is different, and some cars seem to transmit more or less vibes and noise with the same mounts.
Exhaust mods have a large part in the NVH as well. OP should have no shame in asking for help about something subjective.
Tommy 11-18-2013 12:05 PM
Good news is that the vibes are between 1k and 2k and since you'll never drive at those rpms, you're fine. They will lessen as it breaks in and you'll get used to the rest.
Quigs 11-18-2013 12:24 PM
I agree that everyone is different and will therefore tolerate NVH differently. However, if he had read the multiple threads about the topic he may have decided that it wasn't worth the NVH to him prior to him purchasing the mount and now being unhappy with it.
As long as the OP gives it 1000 miles or so to break in I think he will be very happy with his purchase, which is what I meant when I recommended he research before committing to a product. The vibes should die down significantly and he will still have the performance of an outstanding product. I was skeptical as well when I first installed my 88d, but now that it's significantly broken in people that ride with me don't even know that I have an upgraded mount.
EDIT: OP, re-torque (or at least check) the bolts to make sure they are at spec after a few hundred miles. If it comes a little loose during break in it will add NVH and multiple threads mention needing to re-torque to fix excessive vibes.
12blkms3 11-18-2013 12:39 PM
Possible install error? Did you make sure you used the same bolt that connects to the chassis, it made a huge difference for me.
The Ridge 11-18-2013 01:52 PM
I read a number of threads and it seemed that most people only noticed any vibrations with the AC on. But like exhaust drone, vibration sensitivity varies from person to person and in some cases car to car. I think I will give it a while and see if the break in makes enough of a difference along with checking the bolt tq. I didn't start this thread to bash or say anything negative about the mount itself, just that it was not as I expected from my research.
Quote:
I used the same one.
Raider 11-18-2013 01:53 PM
If you torqued it properly, applied loctite, then just drive it. Takes time to settle, as every other thread about this says.
The Ridge 11-18-2013 01:54 PM
2¢
Thanks for mentioning the Focus Electric mount possibility. I'm going to give this mount some break-in time first but that's now the back-up plan.
Raider 11-18-2013 02:02 PM
1 Attachment(s)
Attachment 136529
manila 11-18-2013 02:03 PM
I've been running this mount for close to a year now and love it.
The only vibes I notice are getting out of first gear and when cruising in 6th @60> mph
My shit barely vibes when the AC is on too.
anavrinIV 11-18-2013 02:19 PM
install pmm and tmm. Driver for 5k miles with all mounts in. Replace pmm and tmm with stock. Your car will never seem so quiet and smooth.
T2J 11-18-2013 02:20 PM
No vibes with my 88a RMM. Maybe there is a vibrator in your ass?
King Scumbag 11-18-2013 04:12 PM
Nothing else needs to be said.
The point has been made.
OP, recheck everything per the instructions and then do it again. Give it close to 1k miles before you decide there is too much NVH. Along with what others said, if you were looking for performance but the feel of a DD you would have read more in plenty of threads that people decided to do with the 70d and that the people want *racecar* were more then likely running 80-88d mounts.
I understand that your just expressing your views. But you really need to give things like this time before you can understand how it truly performs, bringing it to it's limits and understanding the things you sacrifice with performance sometimes.
Come back in 900-1k miles and then let us know how you feel about it.
-Pat
WhiteWidow 11-18-2013 04:16 PM
Give it up to 5k miles before removing! Then make a decision. I think you will thank us down the road for real. If not go with 70 duro after the 5k break in. You will still be able to resell it no prob. People love those mounts.
CWP_MS3 11-18-2013 06:21 PM
Quote:
Takes a couple weeks for them to settle. Give it a couple months and it will really be good.
JBR 11-18-2013 07:17 PM
As mentioned above, confirm the installation. Best to remove it and reinstall. Then let it break in. You have a a great mount now. Give it some time.
The Ridge 11-18-2013 09:17 PM
I appreciate the help. I'll update after breaking it in and re-installing so if someone goes searching with the same question they have another info source.
MrZephyr97 11-20-2013 08:45 PM
Quote:
-Pat
How much of an improvement is the 70d over stock? Is it still significant enough to warrant a $125 price tag? Because I would like my car to have slightly better performance but I will not be driving it hard or tracking it.
CWP_MS3 11-21-2013 04:48 AM
Quote:
Anything is a vast improvement over stock. That mount doesn't even belong on a prius. With that being said, I think the 70d is a pretty damn comfortable mount.
jm211 11-21-2013 05:25 AM
Dont over tigten the bolts. Domt under tighten the bolts. Check the bolts for tightness frequently.
The only things that rattle for me are:
Plastic containter on roof that holds glasses, lights for front seats and sun roof controls.
Cig container
Cup holder
This is fixable. Just need to get something soft material like rubber to stop the rattles.
donjohnk 11-21-2013 04:45 PM
So when one decides he wants a motor mount does he bother reading about them and see what to expect? Or does one buy it and say hey I got a motor mount but then not know anything about them? Just curious.
agentgordon27 11-22-2013 07:57 AM
I bought all three in highest, after install I was thinking, "Shit, what did I do." Then a few thousand miles later all I hear is all the engine noises. Sometimes I wish I would have went with the 70 all around, especially since the rear mount design update, but I'm a guy so I can justify any decision by saying "fuck it"
JBR 11-22-2013 08:10 AM
70 would do nothing for noise an little for vibration. You made the right choice.
King Scumbag 11-22-2013 01:49 PM
Quote:
your making me wish i never got the 70d trio now. I felt like i was "race car" till you posted this ;) lol
atvfreek 11-22-2013 02:14 PM
Quote:
Well once that 70 PMM is all broken in, you can sell it to me and get the 88 :)
YABBAMZR 11-22-2013 08:13 PM
Quote:
Haha thinking about that pmm now? You got all that power!
Page generated in 0.20035 seconds with 11 queries
