 Old 03-09-2014, 07:25 PM   #1
timmcc02's Avatar
Posts: 253   (View Stats)
Groaned at 9 Times in 3 Posts
Default Clank sound after spacer install
So after I installed the 5mm JBR spacers in the front I've been getting this clanking metal on metal sword sound only from the front left wheel area. I've pulled the wheel off twice now and reput back on, ive retorqued lugnuts several times. I can't seem to get rid of the noise. You can only hear it when taking off/ slow speeds. Anyone experienced this? Are the spacers directional? Can't figure this out. Gonna put it on a rack tomorrow at work and check it out from underneath.
 Old 03-09-2014, 07:32 PM   #2
Playaj's Avatar
Posts: 1,232   (View Stats)
Playaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the world
Groaned at 9 Times in 7 Posts
The Instructions do say to put the on a certain way. I'm lookin at mine now and they seem to have a Groove to go on
2009 Black Speed3 - AP, JBR Powerpath stage II Sri, JBR 70 duro tmm, JBR Ssb, JBR Short shift kit, JBR RSB, JBR 5mm spacers, ETS Tmic, TWM big type-R shift knob, RX-8 wheels, CPE Stage 2 rmm, H&R Springs, Bilstein B8's
to be installed :
3 Port EBCS
HTP 3" intake/ MAF/ TIH
Autotech internals
Corksport Pmm
Test pipe
SBC Rear Camber Arms
Playaj is offline   Reply With Quote
 Old 03-09-2014, 07:42 PM   #3
timmcc02's Avatar
Just checked instructions on his site and it says nothing about installing them a certain way.
 Old 03-09-2014, 09:05 PM   #4
Not directional, no special way to put them on either.
Take that one off and see if the noise goes away. I'm betting something is coming in contact with the black inner dust shield. That is the only thing in that area that can make that type of noise. Make sure there is plenty of space between it and the rotor.
-Jamie
Playaj (03-10-2014)
 Old 03-10-2014, 08:06 PM   #5
timmcc02's Avatar
Got this figured out today, the lock nut on my valve stem fell into the wheel and was making the noise, just happened to start hearing it when I put on the spacers. But nothing a little red loctite couldn't fix.
The Following 2 Users Say Thank You to timmcc02 For This Useful Post:
Playaj (03-10-2014), Sergeant_M (03-11-2014)
Amp/Sub install with LOC sound issues Bipedal 2010 MS3 - Car Audio & Electronics 8 01-23-2011 02:23 AM
grinding sound after install of cobb springs??? dixie789456 MazdaSpeed 3/6 - Suspension & Brakes 4 03-27-2010 09:32 PM
new radio install no sound bose amp... help Sniper2606 MazdaSpeed 3/6 - Car Audio & Electronics 2 10-07-2009 03:10 PM
Page generated in 0.35645 seconds with 22 queries
