 Old 07-26-2013, 10:02 PM   #1
Chill Hill's Avatar
Posts: 175   (View Stats)
Chill Hill has a reputation beyond reputeChill Hill has a reputation beyond reputeChill Hill has a reputation beyond reputeChill Hill has a reputation beyond reputeChill Hill has a reputation beyond reputeChill Hill has a reputation beyond reputeChill Hill has a reputation beyond reputeChill Hill has a reputation beyond reputeChill Hill has a reputation beyond reputeChill Hill has a reputation beyond reputeChill Hill has a reputation beyond repute
Default Clunking w/ Rear Sway Bar...
Okay so I got it all greased up, only thing I keep getting a clunking sound...
I was hoping it was because I needed to grease them but I still get a decently loud clunk noise going over any kind of bump in the road. It sounds similar to a spare tire not being tightened down all the way and bumping around (but its not my tire nor my jack, I checked them). I rechecked all the bolts and they're all tight.
Any idea as to what this sound is? I've had the bar installed 4 months and its gotten progressively worse over the last 2 months. HELP!
2012 Liquid Silver Metallic Mazdaspeed 3
JBR RSB | JBR SSP | JBR RMM
Cobb SRI | Cobb TIP | Cobb AP | Magnaflow Catback
Carbon Fiber Interior | Black Emblems | Rally Armor Mudflaps | Matte Black Wheels
Chill Hill is offline   Reply With Quote
 Old 07-26-2013, 10:24 PM   #2
Playaj's Avatar
Posts: 1,232   (View Stats)
Playaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the world
Groaned at 9 Times in 7 Posts
My guess would be endlinks
2009 Black Speed3 - AP, JBR Powerpath stage II Sri, JBR 70 duro tmm, JBR Ssb, JBR Short shift kit, JBR RSB, JBR 5mm spacers, ETS Tmic, TWM big type-R shift knob, RX-8 wheels, CPE Stage 2 rmm, H&R Springs, Bilstein B8's
to be installed :
3 Port EBCS
HTP 3" intake/ MAF/ TIH
Autotech internals
Corksport Pmm
Test pipe
SBC Rear Camber Arms
Playaj is offline   Reply With Quote
 Old 07-27-2013, 03:02 AM   #3
CamSpeed360's Avatar
Posts: 793   (View Stats)
CamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the world
Groaned at 31 Times in 13 Posts
Make sure you didn't install it upside down... Yes I'm serious. Happened to a local guy. Also, your nuts need to be tight. After you have taken a spin, re-tighten all the nuts.
2007 Black Mica MS3
JBR 3.5 Whale Penis Intake = Cobb V2/Treadstone FMIC = PTP HPFP internals
Snow Meth Injection, AIS 5GPH = TurboXS Downpipe/Racepipe = SSP-OCC
Road Magnet Springs = Bilstien B8 shocks = Cobb RSB = SURE RMM
Tuned by the FREEK
CamSpeed360 is offline   Reply With Quote
 Old 07-27-2013, 03:20 AM   #4
Vegasspeeed's Avatar
Posts: 274   (View Stats)
Vegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond repute
Groaned at 8 Times in 7 Posts
Probably end links. I had the same clunking sound and one of my bolts wasn't tight enough
sure test pipe, both resonators deleted, RL coilovers, XXR 521's machined silver, muteki gold lug nuts
Vegasspeeed is offline   Reply With Quote
 Old 07-27-2013, 06:17 AM   #5
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
I had a sound like that recently. Ended up being the strut bolt on the bottom side was two turns loose. No idea.
But that made my sound go away
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 07-27-2013, 06:40 AM   #6
turbo test's Avatar
Posts: 798   (View Stats)
turbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the world
Groaned at 9 Times in 5 Posts
I agree on the endlink comment.
I tried blue locktite but not strong enough need to get back under the car and see what red can do for me.
Sent from my EVO using Tapatalk 2
2010 Velocity Red MS3-Eibach PRO-KIT-EVO X Rims-SU RMM-SU solid shifter bushings-CP-e HPFP-CP-e tip-CP-e cai-CP-e hks ssqv bov kit-ddm slim hid kit 35w-5000k-JBR Heavy Shift Knob-JBR RSB-AQ Motorsports catted downpipe-Magnaflow full 3in CBE- SPC camber arms (Stratified tuning) 91/e85 tuned
turbo test is offline   Reply With Quote
 Old 07-27-2013, 09:59 AM   #7
adrager622's Avatar
Posts: 745   (View Stats)
Groans: 46
As others have said, it's the end links. I had this clunking issue a few months back and the bolts for the end links were a little loose. Tightened them right back up and the clunking has been gone ever since.
2010 MS3 Black Mica
 Old 07-27-2013, 03:10 PM   #8
Chill Hill's Avatar
Here are the pics I promised...
Every time I tighten the endlinks they just spin they don't get any tighter
Sent from my HTCONE using Tapatalk 4 Beta
 Old 07-27-2013, 03:12 PM   #9
taf0422's Avatar
Groans: 192
Did you put an allen key in the end of the link?!
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 07-27-2013, 04:26 PM   #10
Chill Hill's Avatar
Lol yes I did. The Allen wrench looks similar to this and last time I tightened them I almost broke the Allen wrench because they were both spinning so I was about to break the wrench off the rest of them...
Everytime I go over a bump I feel like I'm in my old Lancer...lol
 Old 07-27-2013, 05:01 PM   #11
Wasn't this covered in your other thread?
adamizme (07-27-2013), taf0422 (07-27-2013)
 Old 07-27-2013, 06:02 PM   #12
Chill Hill's Avatar
Yeah, but someone told me it would be better to post in your section after I had already started the other.
 Old 07-29-2013, 08:37 AM   #13
DamagedGoods's Avatar
Posts: 304   (View Stats)
DamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the world
When an endlink is tight, it shouldn't continue to spin when attempting to tighten down more, would indicate that there is play in the threads, which may be your clunking.
2007 Mazdaspeed 6 - Bolted, Methed, Tuned
DamagedGoods is offline   Reply With Quote
The Following 3 Users Say Thank You to DamagedGoods For This Useful Post:
Chill Hill (07-30-2013), JBR (07-31-2013), Spec (07-30-2013)
WTF! knocking/clunking rear end Rizz Nasty MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 11-09-2012 04:26 PM
Clunking rear end... WTF is it? Rizz Nasty MazdaSpeed 3 - Engine, Transmission & Driveline 0 11-07-2012 06:40 PM
Hotchkis Rear Sway Bar Clunking Only When Angled Bump ms3brendan MazdaSpeed 3/6 - Suspension & Brakes 24 07-13-2010 10:36 AM
Hotchkis Front Sway Bars Clunking black leaf MazdaSpeed 3/6 - Suspension & Brakes 5 10-10-2008 10:36 AM
Page generated in 0.32295 seconds with 29 queries
