Like Tree73Likes
Closed Thread
 Old 11-15-2014, 03:58 PM   #81
Gr8Speed's Avatar
Posts: 5,702   (View Stats)
I'm using the angled 1/8npt holder but if memory serves me right they are all the same thickness. Pretty sure DO is the thickest so making sure it would fit by adding 1/8" more would not cause a train wreck.
What thickness are they using? Looks like 1"?
Gr8Speed is offline
 Old 11-15-2014, 04:02 PM   #82
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
The holder or the spacers?
I never did measure either one but can if I need too. Basically the thickness of the MD plate plus a little more than a JBR tig thickness would have been great.
Now don't get me wrong, having theses plates available are AWESOME! If they were just a hair thicker my install would have been a little easier.
jdmage_mx5 is offline
 Old 11-15-2014, 04:04 PM   #83
Gr8Speed's Avatar
The plate. It looks like theirs is about an inch, but hard to tell from pictures.
Gr8Speed is offline
ualeks (11-16-2014)
 Old 11-15-2014, 08:35 PM   #84
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
Don't know about the MD spacer but the JMF spacer is like 0.57" thick.
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
mrmonk7663 is offline
The Following 2 Users Say Thank You to mrmonk7663 For This Useful Post:
Gr8Speed (11-15-2014), Mauro_Penguin (11-16-2014)
 Old 11-16-2014, 08:56 AM   #85
rob ms6gt's Avatar
Posts: 416   (View Stats)
So where's the stuff for the 6? All I see is 3 parts that happen to fit the 6.
ROB MS6GT
2006 Liquid Platinum Metallic Mazdaspeed 6
Stratified Tune, Stratified GA V2, Cobb AP V2, GTX3071R, HTP 4" Intake, Synchronic Diverter Valve, 3 bar MAP, Stratified Boost Dial, Corksport Injector Seals, Autotech Internals, Ebay DP, Custom TR8 FMIC, DevilsOwn Meth, Damond Catch Can, JBR 70 Duro Trilogy, TT front diff mount, Penis Eater top diff mount, Cut OEM Springs, Koni Yellows
rob ms6gt is offline
 Old 11-16-2014, 01:01 PM   #86
cletusb's Avatar
Posts: 488   (View Stats)
How thick is the egr delete plate?
cletusb is offline
 Old 11-16-2014, 02:55 PM   #87
Lanyard, oil restrictor, injector seals and studs.
Code Monkey is offline
Easter Bunny (11-16-2014)
 Old 11-16-2014, 03:15 PM   #88
macdiesel's Avatar
Posts: 825   (View Stats)
Interested in the construction of the license plate relocator.
macdiesel is offline
 Old 11-16-2014, 07:07 PM   #89
~.480
Aluminum hex tow bolt, stainless hardware, stainless plate bracket.
Last edited by JBR; 11-16-2014 at 07:07 PM. Reason: MSF Database - Automerged Doublepost
JBR is offline
 Old 11-17-2014, 02:59 AM   #90
TazFc3s's Avatar
Posts: 184   (View Stats)
TazFc3s has a reputation beyond reputeTazFc3s has a reputation beyond reputeTazFc3s has a reputation beyond reputeTazFc3s has a reputation beyond reputeTazFc3s has a reputation beyond reputeTazFc3s has a reputation beyond reputeTazFc3s has a reputation beyond reputeTazFc3s has a reputation beyond reputeTazFc3s has a reputation beyond reputeTazFc3s has a reputation beyond reputeTazFc3s has a reputation beyond repute
Gen1 Piping? or did i miss something? holding off on buying piping because the the other thread said both gens... making sure i didnt miss anything. thanks.
Wiseco Pistons // Manley Rods // ACL Bearings // ARP main/head studs // ATP 3" Downpipe // Resonator Delete // Corksport stage II intake // Autotech HPFP internals // Megan Racing coilovers // RX8 wheels // 235/40 Bridgestone RE760 // JBR recirc hose // FORGE v1 BPV // SPEC stage II+ Clutch/Flywheel // Corksport SSP // Corksport solid shift bushings // Whiteline control arm bushings // Whiteline bump steer kit // CP-e TMIC // JBR BSD // Street Unit boost tubes
FREEK OTS+ on Cali 91
TazFc3s is offline
 Old 11-17-2014, 11:37 AM   #91
MOCO MS3's Avatar
Posts: 644   (View Stats)
You already know what we need and want! JBR is bringing back excitement to the platform!
MOCO MS3 is offline
 Old 11-17-2014, 12:13 PM   #92
thomas_cory2000's Avatar
Posts: 676   (View Stats)
thomas_cory2000 is the leader of the worldthomas_cory2000 is the leader of the worldthomas_cory2000 is the leader of the worldthomas_cory2000 is the leader of the worldthomas_cory2000 is the leader of the worldthomas_cory2000 is the leader of the worldthomas_cory2000 is the leader of the worldthomas_cory2000 is the leader of the worldthomas_cory2000 is the leader of the worldthomas_cory2000 is the leader of the worldthomas_cory2000 is the leader of the world
I should know an exact date in the new few days.
-Jamie
I was you once, not the way to go about it....bruh.
It's been a few days :-p
The Money Pit: 2011 MS3 - Mica Black - Tech Package - Cobb SRI, TIH, AP, Hella horns, CP-E Stage II RMM, JBR OCC, SSB, ATP Catless DP, UR catback exhaust, Autotech HPFP Internals, Turbo Smart Kompact bpv, Sure Shortcut, DIY clutch travel mod, DMM tuning HID 4300K fogs, & Freek tuned!
zoom zoom bitches...
thomas_cory2000 is offline
 Old 11-17-2014, 02:47 PM   #93
El Beaner's Avatar
Posts: 4,262   (View Stats)
on the 3" intakes - will they require the smaller battery/tray or will they work with stock?
SOLD 2012 LSM Tech - 11/17/17
El Beaner is offline
 Old 11-17-2014, 02:51 PM   #94
Stock, all that's required is to remove the outer ECU cover.
The 3.5" will require a battery box or relocate the ECU to the fuse box cover.
El Beaner likes this.
JBR is offline
 Old 11-17-2014, 02:53 PM   #95
El Beaner's Avatar
Well looks like I'm gonna sell the HTP 3.5 intake I just bought and pick up your 3" intake.
The Following User Says Thank You to El Beaner For This Useful Post:
JBR (11-17-2014)
 Old 11-17-2014, 03:17 PM   #96
spals's Avatar
Posts: 305   (View Stats)
spals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the world
@jbarone; what options for intake to turbo couplers are you offering with the aluminum intakes? I know you said a 3.5" would fit with ECU relocation. Does this statement still hold if you are using a BNR S3?
CP Pistons 88mm, Manley H-Beams, Balanced Crank
BNRS3V2, Cobb Catted DP, ETS TMIC, 3.5" JBR Alum Intake, AT HPFP
GS EBCS, 3 Bar Map, JBR 88 RMM, DM OCC, TIGs, BSD+Baffle
SBC Stage 2 Daily, JBR RSB, Koni Yellow, Konig Miligrams 18x8.5, Nitto NT-05 245/45
Spalsbuilt-Freektuned
spals is offline
 Old 11-17-2014, 03:22 PM   #97
We'll have every coupler size and yes it will fit with the BNR.
Mauro_Penguin likes this.
JBR is offline
Mauro_Penguin (11-17-2014)
 Old 11-17-2014, 07:03 PM   #98
You'll be glad you did. I'm very, very pleased with how these intakes look, sound and more importantly, perform.
-Jamie
JBR is offline
 Old 11-17-2014, 07:10 PM   #99
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
Lol why would you ever go to a smaller intake. Htp 3.5 is a great intake
Sent from my gs5
mrshoulders likes this.
Damond Built Speed 6
Deldran is offline
 Old 11-17-2014, 07:12 PM   #100
Gr8Speed's Avatar
Sent from my gs5
Again, we aren't in your thread bashing you. You don't need to be in this one.
And HTP intakes are great for big turbo builds... as in you'll have a reason to go big turbo when they launch themselves into your stocker.
Gr8Speed is offline
The Following User Says NO Thank You to Gr8Speed For This Un-useful Post:
Easter Bunny (11-17-2014)
 Old 11-17-2014, 07:17 PM   #101
Deldran's Avatar
Groans: 118
Um, did you read my post? didn't bash anyone simply stated it's dumb to sell a perfectly good intake for a smaller one
Sent from my gs5
Deldran is offline
Mauro_Penguin (11-18-2014)
 Old 11-17-2014, 07:17 PM   #102
Gr8Speed's Avatar
Sent from my gs5
Yeah I guess. Due to the nature of your past posts in this thread I didn't take it that way. Youre right though. My bad.
Gr8Speed is offline
 Old 11-17-2014, 07:22 PM   #103
El Beaner's Avatar
Sent from my gs5
From what the previous owner of my turbo said it did cause slight boost creep. Also I don't want to deal with small battery and tray.
 Old 11-17-2014, 07:23 PM   #104
Gr8Speed's Avatar
You on a k04 or BNR?
Gr8Speed is offline
 Old 11-17-2014, 07:25 PM   #105
Deldran's Avatar
Groans: 118
I ran a small battery for 2 winters no issues at all with starting, and I had no creep issues. once I buy a small bat tray it will go on my 6 and I'm sure I will have no issues
Sent from my gs5
Deldran is offline
 Old 11-17-2014, 07:26 PM   #106
Gr8Speed's Avatar
Sent from my gs5
Yeah I also had no issue with a 51r. Found one with 600 CCA and it turned every time.
Gr8Speed is offline
 Old 11-17-2014, 07:44 PM   #107
El Beaner's Avatar
Currently on a k04 but I just bought a gtx2867r and the htp 3.5 intake from econman. The gtx2867r has a 3" inlet so I figure a 3" intake will be a good option for it
That will be going in early Q2 next year once I finish gathering the additional items I need. I had forgotten that jbr was coming out with the new intakes. Once I get the intake he sent I'll probably sell it to get $$ towards the new jbr 3"
 Old 11-17-2014, 07:46 PM   #108
Deldran's Avatar
Groans: 118
If you have a bigger turbo you want a 3.5 inch intake. Stick with the htp
Sent from my gs5
Deldran is offline
 Old 11-19-2014, 04:53 PM   #109
EvoFire's Avatar
Posts: 389   (View Stats)
Any concrete dates for the aluminum 3" intake? Possibly black friday?
EvoFire is offline
 Old 11-19-2014, 08:51 PM   #110
We're waiting on the silicone to arrive. As soon as it does they will be on sale.
JBR is offline
 Old 11-19-2014, 11:37 PM   #111
El Beaner's Avatar
Sent from my gs5
I want to avoid boost creep that has occurred with this intake on the turbo I bought. I'll be fine and happy with the 3" from JBR.
JBR likes this.
JBR (11-20-2014)
 Old 11-20-2014, 04:47 AM   #112
Mike@Stratified's Avatar
Posts: 1,119   (View Stats)
FWIW, I got the Tru-3 installed without removing the ECU cover.
Mike@Stratified is offline
The Following User Says Thank You to Mike@Stratified For This Useful Post:
JBR (11-20-2014)
 Old 11-20-2014, 06:06 AM   #113
Deldran's Avatar
Groans: 118
Boost creep can be tackled in the tune or make sure you take a Dremel to the iwg. Going smaller for a bt is no good
Sent from my gs5
Deldran is offline
Easter Bunny (11-24-2014)
 Old 11-21-2014, 09:19 AM   #114
MizzyMS3's Avatar
Posts: 511   (View Stats)
MizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the world
GOOD SHIT JAMIE. Already told Wifey she's buying me that short shifter for Christmas!
2012 CWP MS3 w/ Tech Package
Cobb AP V3 Purple Drank Tuned (E33 mix) | HTP 3.5' Intake | eBay Catless DP | UR CBE | CX-Racing FMIC | Autotechs | Turbosmart Dual Port BOV | JBR Short Throw Shifter | JBR Stage 2 SSP | JBR 88 duro RMM | RallyArmor Mudflaps | Eibach pro kit + Koni Yellows + SPC Camber Arms | NGK step colder
MizzyMS3 is offline
 Old 11-24-2014, 08:21 PM   #115
stockms3's Avatar
Posts: 840   (View Stats)
Groans: 74
Can't wait for the ACTUALLY AFFORDABLE injector seals!
stockms3 is offline
The Following User Says Thank You to stockms3 For This Useful Post:
Gr8Speed (11-25-2014)
 Old 11-25-2014, 07:55 PM   #116
Mazdaspeed3KHP's Avatar
Posts: 273   (View Stats)
Mazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond repute
Need that 3.5 intake for the 3071r im about to buy!! Waiting patiently..
It shows how much dedication you have when you release this many products at the same time. Thank you for all the hard work this year.
2012 Black Mica Speed 3
300whp-341wtq tuned by John @ Tork Motorsports (2/4/14)
Stock K04/PTP Internals/CP-E TMIC/Sure Full 3" Intake with 3" MAF Housing/ATP Long Catless DP/UR CBE/Sonic Tuning Coilovers / 18x9 +35 RPF1 SBC
Mazdaspeed3KHP is offline
The Following User Says Thank You to Mazdaspeed3KHP For This Useful Post:
JBR (11-25-2014)
 Old 11-25-2014, 08:25 PM   #117
They will be available very soon.
JBR is offline
Mauro_Penguin (11-26-2014)
 Old 11-25-2014, 08:46 PM   #118
Lbspeed's Avatar
Posts: 234   (View Stats)
Lbspeed is the leader of the worldLbspeed is the leader of the worldLbspeed is the leader of the worldLbspeed is the leader of the worldLbspeed is the leader of the worldLbspeed is the leader of the worldLbspeed is the leader of the worldLbspeed is the leader of the worldLbspeed is the leader of the worldLbspeed is the leader of the worldLbspeed is the leader of the world
Will the intakes be available for black friday you think? Waiting on the 3.5 as well
Stage 2 all day bruh
Lbspeed is offline
The Following 2 Users Say Thank You to Lbspeed For This Useful Post:
JBR (11-25-2014), Mauro_Penguin (11-26-2014)
 Old 11-25-2014, 08:50 PM   #119
KennyFish's Avatar
Posts: 552   (View Stats)
KennyFish is the leader of the worldKennyFish is the leader of the worldKennyFish is the leader of the worldKennyFish is the leader of the worldKennyFish is the leader of the worldKennyFish is the leader of the worldKennyFish is the leader of the worldKennyFish is the leader of the worldKennyFish is the leader of the worldKennyFish is the leader of the worldKennyFish is the leader of the world
I know what I'm asking the wife for xmas!!
KennyFish is offline
 Old 11-25-2014, 08:50 PM   #120
I would like to by the end of the weekend but I'm running short on time.
JBR is offline
EvoFire (11-26-2014), Mauro_Penguin (11-26-2014)
Closed Thread
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f493/copious-new-upcoming-products-jbr-180084/
Copious New & Upcoming products from JBR!! - Mazdaspeed Forums This thread Refback 11-13-2014 11:11 AM
copious amounts of black soot lmnt 2010 MS3 - Troubleshoot/Diagnostics 346 06-04-2014 11:12 PM
Official: Aston Martin releases copious images of the Vanquish [w/video] Haltech Automotive News 0 09-09-2012 06:30 PM
SURE upcoming products? dadderllama Mazdaspeed3/6 General Discussion 30 01-16-2012 11:50 PM
Chrysler's upcoming 6.4L V8 only for SRT, not for Ram? Haltech Automotive News 1 03-14-2010 11:35 AM
Page generated in 0.57253 seconds with 41 queries
