Like Tree31Likes
 Old 03-03-2015, 11:50 AM   #1
Neutral  +1 score
Exclamation GI: JBR Under Mounted Hot Side Piping Kit 2007 - 2013 Mazdaspeed 3
This thread is to get a feel for how many kits we need to make. Provided there are no manufacturing headaches along the way, these kits should be available at the end of this month.
Details:
JBR Under Mounted Hot Side Piping Kit, 2007 - 2013 Mazdaspeed 3 $245.00 - $260.00 Includes free domestic shipping.
The JBR Under Mounted Hot Side Piping Kit is designed to fit all clocked OEM/BNR and most big turbo setups. Best when used with the Treadstone TR8, TR8L and TR6 Intercoolers.
The JBR kit is constructed from mandrel bent 6061 aluminum tubing that has been powder coated and high strength thick walled silicone hoses. Routing the piping beneath the motor reduces the amount of hot side charge piping by 12-16% when compared to other kits on the market. Reducing the amount of piping decreases turbo spool up time, reduces boost temperatures and makes for an impressive, almost sleeper looking engine bay. All kits will include a coolant pipe mounting bracket, plus some additional coolant and vacuum hose that may be necessary to clock your turbo.
A custom waste gate actuator mounting bracket is required when the kit is used with the OEM turbo.
Application:
2007 – 2013 Mazdaspeed 3
Best when installed with a Treadstone TR8, TR8L and TR6 Intercoolers
Features:
- Black wrinkle coated piping
- Mounting bracket to secure the piping
- 7 layer High strength, thick walled silicone hoses
- Stainless T-bolt clamps
JBR FMIC Piping Kit Includes:
- Hot side under mount piping and silicone couplers
- 6 Stainless T-bolt clamps
- 1 Coolant Mounting bracket
- 1' of coolant hose
- 1' of vacuum hose
- Waste gate actuator mounting bracket (OEM KIT)
The Following 23 Users Say Thank You to JBR For This Useful Post:
09TrueRedGTX (03-03-2015), Arnie1229 (03-04-2015), Cevaes_64 (04-02-2015), Cheese5.0 (03-27-2015), Chief_Wiggum (03-05-2015), Constantin (03-23-2015), danosrk (03-13-2015), exentix (03-03-2015), jack_hammer (03-03-2015), JgamB (03-03-2015), Jtaylor (03-05-2015), kbz0129 (03-03-2015), kgb (03-04-2015), kpuser1 (03-05-2015), l4nc3r (03-03-2015), magicka (03-04-2015), Mauro_Penguin (03-03-2015), MonoSpeed3 (03-21-2015), NCspecV81 (03-09-2015), neganox (03-03-2015), speed3 britz (03-03-2015), XxSmarTz (03-11-2015), [R]usty (03-04-2015)
 Old 03-03-2015, 11:57 AM   #2
kbz0129's Avatar
Posts: 986   (View Stats)
Sickkkkkk
@hatchedspeed3 Check it out!
JBR likes this.
2010 Ms3 PD Tuned
2006 Ms6 GT-Stock
Last edited by kbz0129; 03-03-2015 at 11:57 AM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to kbz0129 For This Useful Post:
hatchedspeed3 (03-03-2015), JBR (03-03-2015)
 Old 03-03-2015, 12:07 PM   #3
JgamB's Avatar
Posts: 2,566   (View Stats)
You did state you had a plan for the over-the-top FMIC piping kit buyers - can you divulge any information in that regard if we'd like to make the change?
JBR (03-03-2015), Mauro_Penguin (03-03-2015)
 Old 03-03-2015, 12:36 PM   #4
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
Am I the only one who thinks that this is way too much work for 15% shorter routing?
Koke382 and lolwrx like this.
Blue Pu.
The Following 3 Users Say Thank You to anavrinIV For This Useful Post:
Koke382 (03-03-2015), MSP6 (03-09-2015), Sid3wayS (03-04-2015)
 Old 03-03-2015, 12:49 PM   #5
We thought the EXACT same thing when we started designing this kit. We stood back and thought man, what a daunting task this is gonna be.
It takes 2.5 hours to remove, clock, re-install the turbo and install the hot side piping. Super easy for the most part and it fits and looks awesome!
 Old 03-03-2015, 12:49 PM   #6
shamie's Avatar
Posts: 952   (View Stats)
I'm curious about how much spool I'd get back by going to one of these under engine hot sides. 50, 200, 500 rpm? 500 rpm would be a no brainer where as 50 rpm would be a waste.
 Old 03-03-2015, 01:20 PM   #7
anavrinIV's Avatar
Groans: 63
I'm guessing closer to the low end. Put a tmic on and see where you sit then, it will be much less significant than that.
Blue Pu.
mazdaspeeding (03-03-2015)
 Old 03-03-2015, 01:23 PM   #8
hatchedspeed3's Avatar
Posts: 1,966   (View Stats)
looks great @jbarone;! Definately tempting. Also curious about how much more spool would be gained with the shorter routing. Will you be offering this in conjunction with your fmic kit? dont want to have an extra hotside laying around for nothing.
2009 CWP MS3 1-23-2014
JBR (03-03-2015)
 Old 03-03-2015, 01:51 PM   #9
NCspecV81's Avatar
Posts: 2,867   (View Stats)
Nice a better price than HTP. I like competition.
2013 CWP and Stock
The Following 3 Users Say Thank You to NCspecV81 For This Useful Post:
JBR (03-03-2015), Mauro_Penguin (03-03-2015), speed3 britz (03-04-2015)
 Old 03-03-2015, 02:00 PM   #10
mazdamx3freak's Avatar
Posts: 219   (View Stats)
mazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond repute
I would jump on this right now if your cold pipe could be bought as well or alone. If you offered this as a complete fmic piping kit with the cold pipe it would be perfect. as I prefer this rather than over the top design. I cant justify buying your fmic for 425.00 now and in a month buying this for another 260.00.
JBR likes this.
2008.5 CPW
JBR:3.5 intake, fmic, r51 Battery Box, Ancors, EGR Delete, Thermal Spacers, 5mm Wheel spacers, Shift plate.
Matt Dimond OCC, Autotech Internals, CNT catted downpipe, itv-22, Threadstone T8L FMIC,SU Turbosmart Bpv, SUv2 Rmm
mazdamx3freak is offline   Reply With Quote
The Following 4 Users Say Thank You to mazdamx3freak For This Useful Post:
hatchedspeed3 (03-03-2015), JBR (03-03-2015), magicka (03-04-2015), Shwa (03-03-2015)
 Old 03-03-2015, 03:21 PM   #11
Mochi's Avatar
Posts: 152   (View Stats)
Mochi is the leader of the worldMochi is the leader of the worldMochi is the leader of the worldMochi is the leader of the worldMochi is the leader of the worldMochi is the leader of the worldMochi is the leader of the worldMochi is the leader of the worldMochi is the leader of the worldMochi is the leader of the worldMochi is the leader of the world
Groaned at 9 Times in 5 Posts
so fucking nice im about to piss monies
JBR likes this.
1975 280Z Datsun - EX header, mild intake port, hotter cam, flattop pistons, black dragon muffler, 5speed swap - Retired Autox shit box
1991 240sx Nissan - shitty ebay "cold air intake", walboro 255 (Murdered by ExGF)
2008 Mazdaspeed 3 COBB V3 AP. JBR RMM. MD OCC. TRL8 w/CX RACING. JBR SHIFT WEIGHT. EVO X RIMS. MD PS COOLER. COBB SIR TIP. CORKSPORT RECIR. PURE tuned
2015 Mazda 3 - bone stock, Gen 1 speed3 rims in the front, Business in the back, 40MPG
"hold'n my dick!"
Mochi is offline   Reply With Quote
The Following User Says Thank You to Mochi For This Useful Post:
JBR (03-03-2015)
 Old 03-03-2015, 04:15 PM   #12
We'll be offering to those that have already purchased our FMIC piping kit 15% off of this hot side kit for the first 30 days after it becomes available.
El Beaner (03-03-2015), JgamB (03-03-2015), Mauro_Penguin (03-04-2015), mazdamx3freak (03-04-2015)
 Old 03-03-2015, 05:23 PM   #13
El Beaner's Avatar
Posts: 4,262   (View Stats)
That's an awesome looking kit. Makes me ALMOST wish I had waited (had I known I probably would have) but I'm loving the standard kit.
One question, I know the htp kit requires that you don't run the undertray, is that the same case for your kit?
JBR likes this.
SOLD 2012 LSM Tech - 11/17/17
The Following 4 Users Say Thank You to El Beaner For This Useful Post:
09TrueRedGTX (03-03-2015), JBR (03-04-2015), mazdaspeeding (03-03-2015), Shwa (03-03-2015)
 Old 03-03-2015, 05:32 PM   #14
Shwa's Avatar
Posts: 322   (View Stats)
This. I've been holding out to go fmic because I want an under car routing, but the only kit options aren't complete, so hopefully it becomes an option. As always thank you for contributing to the platform
JBR likes this.
The Following User Says Thank You to Shwa For This Useful Post:
JBR (03-04-2015)
 Old 03-03-2015, 05:41 PM   #15
JgamB's Avatar
That puts me at 75% commit. No intent to swap things now (standard kit is awesome) but when I go bigger I'd like to have it on hand - provided you're going to sell the cold side separately on a permanent basis.
JBR likes this.
JBR (03-04-2015)
 Old 03-03-2015, 05:41 PM   #16
Can't be serious?
Easter Bunny (03-04-2015), hatchedspeed3 (03-03-2015), JSmith (03-04-2015)
 Old 03-03-2015, 06:11 PM   #17
El Beaner's Avatar
Can't be serious?
No I misread the thread, there were a few people who said they don't run their tray because their custom underpipe kit required it. Htp said it will work with stock undertray
The Following 2 Users Say Thank You to El Beaner For This Useful Post:
Code Monkey (03-03-2015), Mauro_Penguin (03-04-2015)
 Old 03-03-2015, 08:34 PM   #18
09TrueRedGTX's Avatar
Posts: 127   (View Stats)
09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute
Nice looking kit. I'm glad I held off on your "over engine" kit.
I'm very curious as to what the price point will be for an under engine kit (with cold pipe), and also just the cold pipe alone.
Nice work!
JBR likes this.
09TrueRedGTX is offline   Reply With Quote
The Following User Says Thank You to 09TrueRedGTX For This Useful Post:
JBR (03-04-2015)
 Old 03-03-2015, 11:29 PM   #19
l4nc3r's Avatar
Posts: 153   (View Stats)
l4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the world
Yes please. So compared to the HTP, it's the same amount of connections. Less metal for heat absorption, seems friendlier where you mold to the front mount area. Is there going to be any issues with airflow around the ?'s 90 degree angle? Seems it would flow better if it was a little less drastic of a bend there. Or would that run into the inner wheel liner?
JBR likes this.
07 Red Speed3 - SHE'S ALIVE! SHE'S ALIVE!!!
GT3071R / HTP 4" Intake / Brentported Intake Manifold / CXRacing Piping with TR8L Core
DNP v2 Exhaust Manifold / Stainless Steelworks Downpipe/Test Pipe / HKS Hi-Power CatBack
FreekTuned E25 / HKS SSQV2 / JBR 88 Trio
Bilstein B8's / Eibach Prokit / Drag DR-34 18x8
Soon to be installed - Snow Performance Meth Kit with CM14 Nozzle
l4nc3r is offline   Reply With Quote
The Following User Says Thank You to l4nc3r For This Useful Post:
JBR (03-04-2015)
 Old 03-04-2015, 12:30 AM   #20
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
2.5 hours if you've done a turbo a dozen times but the majority of retards who take an hour to put on an intake are going to find it takes longer then that.
lolwrx and Arnie1229 like this.
TEAM LUXURY
The Following 9 Users Say Thank You to Sid3wayS For This Useful Post:
anavrinIV (03-04-2015), Arnie1229 (03-04-2015), Easter Bunny (03-04-2015), JSmith (03-04-2015), Mauro_Penguin (03-04-2015), Micha (03-04-2015), Scare Dem (03-04-2015), taf0422 (03-05-2015), thehead (03-17-2015)
 Old 03-04-2015, 04:57 AM   #21
BLKSTIG's Avatar
Posts: 507   (View Stats)
Are you working in something for the speed6?
The Following User Says Thank You to BLKSTIG For This Useful Post:
Micha (03-04-2015)
 Old 03-04-2015, 06:09 AM   #22
^ For MS6 owners, Jbarone will offer a commemorative plate with glass shards glued on so we can drag our balls on it.
thehead and Mauro_Penguin like this.
The Following 12 Users Say Thank You to Code Monkey For This Useful Post:
BLKSTIG (03-04-2015), Cdnspeed6 (04-05-2016), chapdawg (03-26-2015), Easter Bunny (03-04-2015), hatchedspeed3 (03-04-2015), jack_hammer (03-04-2015), Mauro_Penguin (03-04-2015), Mazdazilla6 (03-12-2015), Micha (03-04-2015), RalliartRsX (03-04-2015), rob ms6gt (03-05-2015), thehead (03-17-2015)
 Old 03-04-2015, 07:55 AM   #23
Micha's Avatar
Posts: 3,436   (View Stats)
You do realize the transfer case and driveshaft are in the way right?
I am slow again.
I modded it a little.
 Old 03-04-2015, 07:58 AM   #24
^ Nothing a 270-degree elbow, a 235-degree elbow, and a 195-degree elbow can't fix.
The Following 7 Users Say Thank You to Code Monkey For This Useful Post:
BLKSTIG (03-04-2015), Easter Bunny (03-04-2015), Mauro_Penguin (03-04-2015), Micha (03-05-2015), RalliartRsX (03-04-2015), sporkbomb (03-04-2015), thehead (03-17-2015)
 Old 03-04-2015, 08:14 AM   #25
BLKSTIG's Avatar
Htp said they can do it lol
 Old 03-04-2015, 10:03 AM   #26
The cold side will be available separately very soon. Pricing will be attractive as always.
09TrueRedGTX likes this.
09TrueRedGTX (03-04-2015), JgamB (03-04-2015), Mauro_Penguin (03-04-2015), mazdamx3freak (03-04-2015), Mikey (04-03-2015), Shwa (03-04-2015)
 Old 03-04-2015, 12:33 PM   #27
awesome, in that case you will be seeing my money very soon.
JBR likes this.
2008.5 CPW
The Following User Says Thank You to mazdamx3freak For This Useful Post:
JBR (03-04-2015)
 Old 03-04-2015, 01:18 PM   #28
sporkbomb's Avatar
Posts: 295   (View Stats)
sporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the world
Does this come in pink?
2007 MS3 GT
Autotech CDFP Internals || Cobb AP, SRI, TIH, DP, CB, BPV, EBCS, FSB & RSB || cp-e Injector Seals, EGR Delete|| JBR OCC, Shifter Plate, PMM & TMM, TB & Intake TIG, Coolant Bypass|| Mazdaspeed Coilovers || TRZ RMM|| TWM Bushings || MOOG Front & Rear Endlinks
2006 MS6 GT (ZZB Rebirth)
Autotech CDFP Internals || BNR Stage 3 || Bosch 3 Bar || Cobb AP || cp-e Injector Seals, CBE, DP || ETS TMIC || Full Race EM || H&R Coilovers || JBR Mounts, 3.5" WP Aluminum Intake || Matt Damond OCC, Shifter Plate, EGR Delete || Racing Beat Rear Endlinks || Relentless PnP IM || SPC Balljoints || Whiteline RSB || The Company of Which I Will Not Name Front & Rear Diff Mounts
1990 Miata
I like it raw
sporkbomb is offline   Reply With Quote
The Following 2 Users Say Thank You to sporkbomb For This Useful Post:
 Old 03-04-2015, 01:50 PM   #29
cam1391's Avatar
Posts: 326   (View Stats)
You seen the htp kit?
 Old 03-04-2015, 01:56 PM   #30
yes I have. Not sure which one I would want to go with, or if I even want to go over the top or under the car....decisions decisions...
 Old 03-04-2015, 02:11 PM   #31
Flow is better. There is one less hard 90 going this route then over the top.
 Old 03-04-2015, 02:33 PM   #32
l4nc3r's Avatar
Actually didn't think about that.... Good show. Will be interested here as soon as I get my car back running.
 Old 03-04-2015, 02:38 PM   #33
cam1391's Avatar
Id definately go under engine. Although I have alternative motives, like being able to leave the top mount on for stock appearance/cleanness. I like this jbr kit, I just hate how much silicone there is. Silicone bulges and swells, and is the most likely part to fail over time. It is clean tho! I dont mind spending a little more for less coupler points when ive already invested in a big turbo, especially when daily reliability is vital, like it is for both of us.
 Old 03-04-2015, 02:51 PM   #34
i do believe the design and amount of this silicone will prevent swelling and bulging. Also, I do believe you will need 30+psi to really push that silicone, and I will not be going that high. I wouldnt go as far as just putting a stock tmic on for sleeper status/ cleanliness. A wire tuck and some powdercoat would work just fine. With that being said, metal piping leaves room for color options. I was thinking about this kit just so that @kbz0129; and I could do a comparison (BATs and what not).
 Old 03-04-2015, 05:39 PM   #35
swsmailman's Avatar
Posts: 1,118   (View Stats)
This peaks my interest very much.
I want to do a FMIC soon but want to do under the car routing. Definitely want to see how this turns out for pricing. Would be nice to have a full kit (hotside, cold side, and crash bar) minus the Core to be able to purchase it all at once.
2013 Liquid Silver MazdaSpeed
 Old 03-04-2015, 08:56 PM   #36
cnyms6's Avatar
Posts: 138   (View Stats)
cnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the world
MS6, MS6, MS6
2006 MS6 BCM
JBR SSP, CP-E RMM, CP-E Rear Diff mount, RSB, AT internals, Full Race Intake, TR8 FMIC, EGR delete, AP V3, Stratified tune, Carbotech pads, TLT springs, Bilsteins
SpeedPerformance rebuild, EFR 7163, Full Race Ex Mani & DP
Street: Conti DWS 225/50-17 on 17x7 et 45, Track: Nitto NT-05 255/40-17 on Enkei RPF1
137,000 miles of driving fun
cnyms6 is offline   Reply With Quote
The Following User Says Thank You to cnyms6 For This Useful Post:
 Old 03-05-2015, 08:24 AM   #37
Micha's Avatar
Screw that. I will just keep my over motor setup.
I am slow again.
WetzMS3 (03-09-2015)
 Old 03-05-2015, 12:04 PM   #38
lolwrx's Avatar
Posts: 217   (View Stats)
lolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the world
Love the idea but I already threw on my bnr and just ordered the original over the engine piping yesterday. Maybe down the road though.
BNR s3, Freek 3.5", Autotech internals, depo racing catless dp, TR6, JBR FMIC piping, 80a rmm, OCC, TIGs, EGR delete and Coolant bypass
FREEKTUNED
lolwrx is offline   Reply With Quote
 Old 03-06-2015, 11:36 AM   #39
cam1391's Avatar
Ive just had too many bad experiences with long silicone coupler. That being said, I have never used jbr couplers, so dont let that steer anyone away from this kit. As my friend here stated, it would take tremendous pressure to bulge couplers enough to worry about it.
Anywho, if you wanna help me out with the wire tuck ill be your best friend, if im not already lmfao. Ive yet to find a single even slightly half decent thread on how to go about it. If all else fails ill do like I did in the evo and just buy new harness connectors and run all new wires from the ecu. Color matched to the oem stuff or course =p. Did that in my 95 gs-x too, relocated th fuse box to the glove box.
The Following User Says Thank You to cam1391 For This Useful Post:
hatchedspeed3 (03-09-2015)
 Old 03-06-2015, 01:25 PM   #40
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
You mean this is the most interested you'll ever be in anything??!!
peak vs. peek vs. pique : Choose Your Words : Vocabulary.com
Heathbar likes this.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
The Following 9 Users Say Thank You to Nliiitend1 For This Useful Post:
Addikted To Boost (03-13-2015), Crarrs (03-09-2015), Easter Bunny (03-09-2015), macdiesel (03-06-2015), magicka (03-06-2015), Mauro_Penguin (03-06-2015), MD1032 (03-11-2015), Micha (03-13-2015), WetzMS3 (03-09-2015)
New Product Release! JBR FMIC Piping Kit, 2007 - 2009 Mazdaspeed 3 JBR JAMES BARONE RACING 13 02-08-2015 04:38 PM
New Product Release! JBR FMIC Piping Kit, 2010 - 2013 Mazdaspeed 3 JBR JAMES BARONE RACING 19 01-25-2015 09:37 PM
New Product Availability!! JBR Silicone Intake Hose 2007-2013 Mazdaspeed 3 JBR JAMES BARONE RACING 2 06-17-2014 05:10 PM
side mounted license plate holder? MSP611 Appearance - WHITE 15 11-02-2011 09:40 PM
Page generated in 0.61772 seconds with 43 queries
