 Old 04-04-2015, 02:26 PM   #1
cnyms6's Avatar
Posts: 138   (View Stats)
cnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the world
Default GI: Radiator shroud for MS6
Track or high Hp MS6s need a version of this new product from Jamie. Who is interested?
Raider's Air Damn 2007-2009 Mazdaspeed 3 [MS3-AIR-DAMN] - $70.00 : James Barone Racing, Aftermarket Performance
2006 MS6 BCM
JBR SSP, CP-E RMM, CP-E Rear Diff mount, RSB, AT internals, Full Race Intake, TR8 FMIC, EGR delete, AP V3, Stratified tune, Carbotech pads, TLT springs, Bilsteins
SpeedPerformance rebuild, EFR 7163, Full Race Ex Mani & DP
Street: Conti DWS 225/50-17 on 17x7 et 45, Track: Nitto NT-05 255/40-17 on Enkei RPF1
137,000 miles of driving fun
cnyms6 is offline   Reply With Quote
 Old 04-04-2015, 04:08 PM   #2
Amnesiac's Avatar
Posts: 315   (View Stats)
Groaned at 6 Times in 4 Posts
I was just thinking of making one myself. I'd be interested
Amnesiac is offline   Reply With Quote
 Old 04-04-2015, 08:03 PM   #3
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Wouldn't route any air down on the 6, it would only prevent air going up.
The 6 front is molded to drive air up from the upper part of the upper grill, and has an extra plastic shroud that should be removed if you run FMIC to allow direct air path to the radiator instead of pushing air up as well.
Speed6 FMIC Coolant Temp Fix Discussion
340hp / 371tq
Amnesiac (04-04-2015), ms6mil (04-04-2015)
 Old 04-05-2015, 09:57 AM   #4
cnyms6's Avatar
@TiGraySpeed6; Yep, your thread is a good first step to make air flow at the radiator, but it doesn't seal off the air flow abovef the radiator through the gaps where the ducting to the TMIC shroud used to be. I'm looking for something that will seal them off also to increase the differential pressure across the radiator and thus air flow through it. Leaving those gaps open gives the air flow at the front of the car an easier path to the engine bay around the radiator. So, really looking to take your good work up another level.
2006 MS6 BCM
 Old 04-05-2015, 07:57 PM   #5
It actually doesn't have an easy path- the top opening flows up, the lower opening flows straight to the radiator. Along with sealing up the bottom you get stock coolant temps.
If you want to stop air flow from entering the engine compartment via the top opening, where the TMIC ducting is/was, using a variation on the raider plate might work but I don't see it lowering coolant temps. With the unique stepped shape of our hood and bumper we'd only need a plate in the center area. It would be interesting to see what thickness of material would be just right to deal with the slight upward curve of the hood, but not be too thick for the sides of the center section.
Very possible it could replace the washers for the screws that mount the bumper and center grill piece......
Anyway, it'd help keep things clean, but wouldn't help with coolant temps. Worth taking a stab at though...
340hp / 371tq
 Old 04-05-2015, 08:44 PM   #6
shadesofgray19's Avatar
Posts: 794   (View Stats)
How about a hood piece and bumper piece to retain weather stripping and seal hood better when removing hood ducting? This wiil force air through radiator.
 Old 04-05-2015, 08:49 PM   #7
The rad support is designed to push air up into the TMIC ducting. Unless you cut that support the best you can do is block airflow into the engine compartment.
File Type: jpg Screenshot - 4_6_2015 Mon , 8_31_58 AM.jpg (365.9 KB, 17 views)
340hp / 371tq
Product Release! CorkSport Gen 1 Mazdaspeed 3 FMIC Radiator Shroud CorkSport CorkSport 16 08-25-2013 07:33 PM
Why is my radiator fan on after doing the tb MOD? zumanback MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 04-07-2011 09:56 AM
Radiator Fan badams118 MazdaSpeed 3 - Engine, Transmission & Driveline 3 06-03-2009 09:06 PM
ETS TMIC, to shroud, or not to shroud? steven88 MazdaSpeed 3/6 - Turbo Induction 0 09-12-2008 11:08 PM
Page generated in 0.43657 seconds with 24 queries
