| JAMES BARONE RACING JBR is a leading manufacturer of high-quality aftermarket parts for the Mazda community. We take pride in our reputation for providing the highest-quality performance products at the best values, and we back up that reputation with outstanding customer service and free shipping. We are committed to the Mazda platform and we actively partner with other members of the community in our selection, design, and testing of new products to make sure they meet their needs. We control every step in the engineering and fabrication process to ensure the highest standards of workmanship. The result is a line of products whose performance and reliability have been proven both on the street and on the track. Visit us at jamesbaroneracing.com |
![]() Join Date: Feb 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,452
Groans: 82
(Thread Starter) | Not Ranked : 0 score Install was a breeze, just got the car up on ramps. Only problems I ran into were my own - I originally put the bar on backwards so I had to take it off and flip it. Instructions were great, and if you were to do this on your own without messing up, it should take 20-30 minutes max. Car feels stiffer in the back, and the steering does seem sharper - hard to tell though until I get more time driving it. Overall I would say I'm glad I got the rsb, and further I'm glad I got it from Jbarone - as always the quality and fitment are top notch, and the instructions are clear and well written with plenty of photos. I'd also like to say that with the RSB, I'm completely happy with the suspension. My only previous complaint was the understeer, and in the one corner I was able to take at a speed high enough to induce understeer, it was so minimal I feel as though calling it understeer isn't appropriate - more like having the front and rear let go in a sequence that made the car exceptionally easy to rotate through a corner. If anything, I would say the car feels more planted and solid overall. IMO it's a worthwile investment and will make the car much less frustrating to drive when grip does run out. I dunno if it'll be worth $185 to everybody, but it sure as shit was for me. Again, I will edit this with more impressions as I get a chance to drive it more. |
![]() Join Date: Nov 2010 Location: Lubbock, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 169
| Not Ranked : 0 score Which setting do you have it on? |
Groans: 82
(Thread Starter) | Not Ranked : 0 score Middle holes, like recommended in the guide - I'm still running the stock front sway bar. Not really in a hurry to tackle that install, but I may pick up a FSB if JBarone comes out with one. Got a chance to drive the car on the interstate for 150-200 miles or so yesterday, and it does feel very planted at speed, but I was only able to take it to around 110 mph max, and even then only briefly. I gotta say it feels as planted at 110 as it does at 80 though, so no concerns about that. The only thing I would change is the car still does feel nervous, but that's more because of the shocks/dampers than anything. Any ambiguity in the back of the car is gone - I've heard people complain about a "floaty" feeling at higher speeds, but I never really experienced it with the car stock so I can't say. Just feels more solid. The balance of the car is way better, and when it gets warmer out I'll be able to comment on the handling limits of the vehicle as well. I know I said I was completely happy with the suspension as is, but I'm still going to get some koni FSDs down the road if the stock dampers ever take a crap on me. |
| The Following User Says Thank You to Speed3eak For This Useful Post: | JBR (01-16-2011) |
| Approved MSF Vendor ![]() Join Date: Sep 2009
Rep Power: 7119 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,203
Jamie | |
| The Following User Says Thank You to JBR For This Useful Post: | Speed3eak (01-16-2011) |
Groans: 82
(Thread Starter) | Not Ranked : 0 score Update: I got a chance to take the car for a medium-speed spin (as high as I would like to go on 2-lane backroads in the middle of the night haha) - haven't been able to get the tires to break loose turning, and I took a turn marked for 35 miles an hour at around 80. I know, doesn't take the biggest balls to do, but hey, like I said it's pretty late and there are a lot of deer around where I live so I didn't feel like pushing it much farther than that. The car seems to have settled some; highway 'nervousness' is much less noticeable than it was on my first highway blast. Overall, I'd say the car is as neutral as I could hope for - I need to get into autox to really explore the handling limits of the vehicle in a proper setting. Now I gotta take the car to an alignment shop and check to toe after reading nate's findings. I'll probably post another update or two, but not for a while unless I find something negative to write about, which I doubt will be the case. So far, car is great, handles great, steering feels taught - love the way the car responds now. Wish it came from the factory like this. |
| The Following User Says Thank You to Speed3eak For This Useful Post: | JBR (01-21-2011) |
Groans: 82
(Thread Starter) | Not Ranked : 0 score Another update - I know I said I wouldn't unless I found something bad, but I do really, really like how the car handles now. I was able to break loose the grip (finally) taking a turn (with a lot of asphalt on either side), and the car rotates well throughout the corner - I wouldn't say there is 0 understeer, because I'm not a good enough of a driver to make those calls, but the car is as neutral as I can hope for on these stock tires. We'll see what happens when I replace the stock rubber, but until then I'm a happy camper with how the car handles - the RSB is a much greater improvement than I originally had thought. |
![]() Join Date: Sep 2009 Location: Rosemead, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 717
Groans: 27
| Not Ranked : 0 score i used to get yaw under heavy braking when i was on stock suspension .. scary as hell when your hitting triple digits going down hill and have to get on the brakes and the rear end wants to go side ways ... + on rsb being a great mod ... on the stiffest setting the car will oversteer and three-wheel. but i use the soft settings
__________________ 08 MS3 () Arias Pistons & Pauter Rods, P&P Head, Port match IM, DCR VVT, ARP Head Studs, Autotech CDFP internals, F2 BSD & Baffle, Cobb AP, Cobb SRI, PG TIP, CS Test Pipe, FMIC, Tial QR, JBR RMM/TMM, Oil spin-on Conversion, NGK iridiums IX () Koni Yellows, Roadmagnet springs(6.5k Front, 6.4k Rear), Cobb RSB, TB trunk brace, AWR Rear Endlinks, SPC rear camber arms () Centric Slotted Rotors/ Posi-Quiet pad () Fidanza 11lbs. Flywheel, E4P STS, Cobb Shifter Weight, TWM Bushings, Redline MT-90 Last edited by easy; 01-27-2011 at 08:26 PM. | |
| The Following User Says Thank You to easy For This Useful Post: | JBR (01-28-2011) |
![]() Join Date: Mar 2010 Location: Indy
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 840
| Not Ranked : 0 score yea I been using the middle hole on the rsb. I did notice but this may be me but when I make a slow 3 pt turn (backing out of driveway) it sounds like in the front a slow turning rubbing noise until car straightens up while engine is still cold. Anyone know what that is or where to look at on the car?
__________________ 2007 Mazdaspeed 3 Sport SSM Corksport SRI / HPFP Internals / Front Arm Bar // Cp-e RMM 75d // JBR RSB / IM & TB Gaskets / Bypass Valve Hose // Cobb AP / Shifter Weight // SU Shifter Bushings // Sure TIP // Viper 5901 |
![]() Join Date: Mar 2008 Location: Brea, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 103
| Not Ranked : 0 score Jamie, Any plans in the future to come out with a front bar to compliment the rear? |
Groans: 82
(Thread Starter) | Neutral : +1 score
Correct me if I'm wrong though jamie. | ||
Thanks, Jamie | |
![]() Join Date: May 2008
Rep Power: 0 ![]() ![]() Thanks: 2
| Not Ranked : 0 score Thanks from Down Under, Just want to say a BIG thankyou to Jamie for such prompt service & an excellent product (RSB). I ordered it on the 6th of May & received it on the 17th....pretty quick delivery. Ive only had it on for about 30km , but can feel the difference immediately. You can tell its made well & of a high quality. I will make sure that ozmpsclub.com know what a great product you produce & deliver. Cheers, Ad.
__________________ TXS SRI, GFB GT Hybrid BOV, Custom CBE, Hi-Flow 2nd Cat, TRZ Poly Mount, Cobb Springs. |
| The Following User Says Thank You to AD_07 For This Useful Post: | JBR (05-19-2011) |
| AEM CAI Installed | Creatve | 2010 MS3 - Engine, Transmission & Driveline | 20 | 10-15-2009 07:05 PM |
| ETS 3.5 installed | shucky | MazdaSpeed 3/6 - Turbo Induction | 7 | 09-09-2009 06:33 PM |
| PTP TMM V2 installed | bioevolve | MazdaSpeed 3 - Engine, Transmission & Driveline | 9 | 03-27-2009 05:09 PM |
| just installed AP | gtlaw | Cobb Access Port/Maps | 1 | 11-11-2008 02:35 PM |
