| JAMES BARONE RACING JBR is a leading manufacturer of high-quality aftermarket parts for the Mazda community. We take pride in our reputation for providing the highest-quality performance products at the best values, and we back up that reputation with outstanding customer service and free shipping. We are committed to the Mazda platform and we actively partner with other members of the community in our selection, design, and testing of new products to make sure they meet their needs. We control every step in the engineering and fabrication process to ensure the highest standards of workmanship. The result is a line of products whose performance and reliability have been proven both on the street and on the track. Visit us at jamesbaroneracing.com |
![]() Join Date: Jul 2011 Location: Bowling Green, KY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 140
(Thread Starter) | Neutral : +1 score After visiting Jamie @jbarone; a few months ago, I sprouted the idea of taking a stock speed6 and slowly modding it while getting dyno numbers along the way. Using many constants, such as the same car, same dyno and same gas, we could find out the true difference in power with different modifications. I know that people have sort of done this throughout the years this platform has been out but I’m setting out to make this as thorough of a comparison as possible so any myths that are out there (if there are any) will be put to rest. This could also start up some good conversation regarding the platform and make it more advanced once this is all said and done. Jamie agreed that this would be a good idea and to contact Alex @Lex; to see if he could help make this work. So, I did just that. Alex agreed to help with this project soon after I contacted him. THE JOURNEY: Mod Path We both came up with a modification path that made sense. This path is really just experimental and there may be another way that makes more sense to you. I will give a thorough review of what I thought about the modification path once I am done, however. I really have no idea how this is all going to turn out in the end (numbers wise). For the sake of easiness I am going to call each set of modifications a phase.
THE JOURNEY: Assumptions
THE JOURNEY: Dyno Numbers
Documentation of this whole process will be in the next few posts as well as spread throughout this thread. I’m trying my best to do my part to help this platform further expand and just help out this site in any way I can so if there are any questions/comments you have please post them up and I will do my best to answer them or get someone that is more knowledgeable than me to chime in. Thank you for reading, Justin a.ka. JB a.k.a. jbmazda6 a.k.a. The Ginger Jew (True fact right here) P.S. Thank you again to JBR and Stratified for their efforts, they are much appreciated. THE JOURNEY: The Actual Journey I will try my best to update this along with my posts throughout the thread. I will probably consolidate all my posts throughout this thread in this one section. Stick with me as I decide what to do! 2/24/14: Stock Out Raise that bitch up! Had to grind off the exhaust nuts at the back of the testpipe and after I took it off I found a shitload of soot inside. I found a black hole: Before: After: I was previously on the S-OTS stage 2 map before I went back to stock. Going back to stock made my car penis decrease in size by a few inches but I knew it would be for the better in the end. I forgot how slow a stock speed6 was. 2/25/14: Stock Dyno I went to Cobb Plano to get my stock baseline dyno done. After three pulls on the dyno I found out what this car makes stock, 228whp/261wtq. And here's a video of the three pulls. Stock is so quiet: https://www.youtube.com/watch?v=ob8s...ature=youtu.be The log of the three pulls is also attached and is called "All Three Dyno Runs". Sorry about the generic name. Already uploaded it or else I'd change the name. 3/13/14: I love me some E! After confirming the modification path with Alex I made some purchases. I acquired Stratified's 3-Port EBCV and Guardian Angel along with some NGK IX's from Edge. Somehow my NGK's got lost on the way to my house so I called up EdgeAutosport and they had a new set two day shipped to me. Thank you @JP@edgeautosport.com; (can't remember who helped me out but I talked to a few of you and you were all awesome). Picking up the unicorn jizz: Beautiful Stratified parts: 3/17/14: Time to get Stratified! After a long time coming (not really just felt like it) I got my first Stratified tune, a 25% E85 tune set up to work with a 3-Port EBCV in 3-Port mode along with HPFP internals. This is "Phase 1". Now that I had the first tune on my hands I could install the 3-Port and Guardian Angel. My first impression on these parts was great. Good quality and felt solid. I wasn't a huge fan of the plastic clamps that were included and ended up only using them where the vacuum hose connected to the Stratified parts (seemed to work best here). I used the stock clamps and some I had laying around for the wastegate, boost source, bpv, etc. After making a quick run to Autozone for extra vacuum hose and some nipples to put on the restrictor side of the wastegate I ran into a small problem. Where am I going to put these things in a stock engine bay?! Not too much space. I currently have the JBR small battery tray so I had room on the side of the intake to mount the 3-Port directly to the battery. This location should be good for the life of the car. Now.. where to mount the Guardian Angel. I decided to mount it as seen below. I just had to cut a small hose in the airbox to allow the vacuum hose nipple that is routed to the bpv to be accessible. This location allows for adjust-ability of the Guardian Angel's settings along with looking clean as fuck. I would highly suggest this location for anyone with the stock intake running this unit. Pictures of the Guardian Angel and 3-Port mounted up: FOMOCO's to NGK IX's. The FOMOCO's didn't have too many miles on them when I took them out (maybe a couple thousand): After everything was installed I went out for a drive to see if the Guardian Angel was working properly (set it at the lowest setting). Sure enough when I went WOT it shut me down from what it thought was a boost spike. Did a few more adjustments and got it all set up right. What a great piece to have just for safety purposes. I highly recommend it to anyone and everyone. Worth the money. The 3 port is also a nice piece to have as it controls boost much better and allows for more boost up top (Mazda 3 Port Electronic Boost Control Valve [MAZ 3P EBCV (0100-0005.2)] - $85.00CAD : Stratified Automotive Controls). As I said before, both were great quality! Now that I officially have a Stratified tune on my car I could apply the sticker: 3/30/14: Revisions, revisions, revisions! I now have a few revisions in my pocket and the car is feeling great. It feels just about as quick, if not quicker, than when I had the S-OTS tune on it before I stocked out. The stock intake is quite restrictive and I'm not seeing flow above 245 g/sec in optimal conditions. I will be heading to the dyno (hopefully) on April 8th to get this phases numbers. Any guesses?! lol I will post a few logs, vDynos, and actual dyno info after this tune is finished. So hard waiting for each phase as I'm so excited for the next one but at the same time I'm even more excited for the ones beyond that. I've been scouring the FS threads here while waiting, however, and picked up a CPE TMIC from @thehead;. Thanks again man. I am now looking to pick up a downpipe so if you know of anyone or have one for sale please let me know! I haven't seen one for sale in ages. Probably because they're such a PITA to take out. Also, there was a North of North Dallas meet yesterday where we did a few compression tests. My car came out with 190, 190, 185, 195 going from left to right (1-4). Thank you @kevdog; for supplying the compression tester and hosting and @Cheapspeed; and @El Beaner; for helping out. Good news! More updates coming soon!
__________________ JBR: Whale Penis, SSP+Weight+Bushings+Knob, Boost Tubes, Bypass Valve Hose, TMM, PMM, RMM, OCC, TIG's, Small Battery Tray Other: Stratified 3-Port EBCS, Stratified Guardian Angel, Cp-e Catted Downpipe, Cp-e Top Mount Intercooler, Cp-e Rear Diff Mount, Autotech Internals, H&R Coilovers Sponsored By: JamesBaroneRacing.com Last edited by jbmazda6; 01-04-2015 at 01:38 PM. |
| The Following 19 Users Say Thank You to jbmazda6 For This Useful Post: | Chief_Wiggum (03-30-2014), Cpt_Rum-bo (01-05-2015), El Beaner (03-30-2014), Hush (04-06-2014), ItsNox (03-31-2014), JBR (03-30-2014), JgamB (03-30-2014), King Scumbag (03-31-2014), Lex (03-30-2014), Mauro_Penguin (03-30-2014), MD1032 (01-12-2015), MTLspeed6 (05-28-2014), Raider (03-30-2014), redneck4Christ (06-20-2014), sidekick (07-30-2014), SparkySparks (05-28-2014), speed23 (03-31-2014), VulgarKyle (03-30-2014), zooomMPS3 (05-10-2014) |
(Thread Starter) | Not Ranked : 0 score Reserved
__________________ JBR: Whale Penis, SSP+Weight+Bushings+Knob, Boost Tubes, Bypass Valve Hose, TMM, PMM, RMM, OCC, TIG's, Small Battery Tray Other: Stratified 3-Port EBCS, Stratified Guardian Angel, Cp-e Catted Downpipe, Cp-e Top Mount Intercooler, Cp-e Rear Diff Mount, Autotech Internals, H&R Coilovers Sponsored By: JamesBaroneRacing.com |
![]() Join Date: Dec 2013 Location: Orlando, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 60
| Not Ranked : 0 score Subbed |
| The Following User Says Thank You to itzjustme407 For This Useful Post: | jbmazda6 (03-31-2014) |
| Not Ranked : 0 score Good work Justin! In for results.
| The Following User Says Thank You to btstarcher For This Useful Post: | jbmazda6 (03-31-2014) |
![]() Join Date: Jan 2011 Location: Toronto
Rep Power: 0 ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score I really like this approach, and even tho I have an MS3, I'm still interested to see how the mods affect an MS6.
__________________ [SIGPIC][/SIGPIC]http://www.cardomain.com/ride/496686/2002-mazda-miata-mx-5 |
| The Following User Says Thank You to Mty Mous For This Useful Post: | jbmazda6 (03-31-2014) |
![]() Join Date: Oct 2013 Location: Ponder, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 454
| Not Ranked : 0 score Well the power gains he gets should translate very easily to the MS3 since it is the same platform(engine). Of course the MS3 would have higher whp/wtq numbers due to lower drive train loss but still is a good guage on what would happen.
__________________ Current 2017 Ford Fusion Sport - TT AWD V6 Upgraded LED lighting, Steeda Oil Catch Catch SOLD 2012 LSM Tech - 11/17/17 |
| The Following User Says Thank You to El Beaner For This Useful Post: | jbmazda6 (03-31-2014) |
(Thread Starter) | Not Ranked : 0 score Percentage increases will be shown along with the numbers. I personally like percentages rather than saying a part will add X amount of HP onto your car.
![]() Join Date: Jan 2013 Location: South Boston, MA
Rep Power: 1402 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,475
. I was looking for a strong base or structure to build my review because its all over the place right now! Thanks for the help . Gotta find things spread throughout my entire computer taking notes while doing everything haha.This is good stuff man!
__________________ 07 BLACK MICA MS3 PATTY/JEFF BUILT MOTOR BNRS3V2 349/344 VD 93 FREEKTUNE E25 382/375 GSD DynoJet 141020 STOCK BLOCK FREEK KORN TUNE 335whp/356wtq ENM 14 K04 ~ Ordnance, Droppn' Warheads of Foreheads Since 1922 ~ BOSTON STRONG Last edited by King Scumbag; 04-08-2014 at 06:02 PM. | |
| The Following User Says Thank You to King Scumbag For This Useful Post: | jbmazda6 (04-08-2014) |
__________________ JBR: Whale Penis, SSP+Weight+Bushings+Knob, Boost Tubes, Bypass Valve Hose, TMM, PMM, RMM, OCC, TIG's, Small Battery Tray Other: Stratified 3-Port EBCS, Stratified Guardian Angel, Cp-e Catted Downpipe, Cp-e Top Mount Intercooler, Cp-e Rear Diff Mount, Autotech Internals, H&R Coilovers Sponsored By: JamesBaroneRacing.com | |
| The Following User Says Thank You to jbmazda6 For This Useful Post: | King Scumbag (03-31-2014) |
@jbmazda6; Just throwing it out there but i bought the J2 Ebay DP and it has been great. Has a few cons but nothing major. Lmk if you wanna know more info on it. Cant got wrong with the M2 either.
__________________ 07 BLACK MICA MS3 PATTY/JEFF BUILT MOTOR BNRS3V2 349/344 VD 93 FREEKTUNE E25 382/375 GSD DynoJet 141020 STOCK BLOCK FREEK KORN TUNE 335whp/356wtq ENM 14 K04 ~ Ordnance, Droppn' Warheads of Foreheads Since 1922 ~ BOSTON STRONG | |
![]() Join Date: Nov 2013 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 481
| Not Ranked : 0 score Subbed Sent from my iPhone using sausage fingers
__________________ 2010 speed w/tech//Freektune//Autotech hpfp//Cobb APv3-SRI-TIH--cold air box//Corksport--Axle back exhaust//adjustable shocks and springs//LED's//Damond RMM--PMM--TMM--OCC stage II--SSP with OEM weight//HKS SSQV recirc//Fomoco honey//JBR bsd and baffle--shift bushings--51R battery tray--STS--bypass hose--tig tb coolant bypass//M2 test pipe//NGK 6510 one step chilly//StopTech SS brake lines//ETS TMIC//Progress 32mm rear sway//UMBRA tint by Nino 35%//Hawk DTC-60 up front and HPplus pads in rear//Mazda5 oem+rear brake kit//TrackMasters hood struts// Coming up: Corksport injector seals |
| The Following User Says Thank You to macdiesel For This Useful Post: | jbmazda6 (04-08-2014) |
![]() Join Date: Jun 2013 Location: Marseilles, Illinois
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 271
| Not Ranked : 0 score Subbed, I have a 3 but essentially the same motor, can't wait to see how this goes. Double tappin' the Moto
__________________ 2013 VRM MS3 |
| The Following User Says Thank You to darthxar For This Useful Post: | jbmazda6 (04-08-2014) |
![]() Join Date: May 2009 Location: Huntsville, AL
Rep Power: 1431 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,522
| Not Ranked : 0 score @JgamB; this type of tuning science seems right up your alley
__________________ True Red 2009 MS3 Damond Motorsports: RMM // Short Shift Plate Suspension: Koni Yellows // Swift Spec-r springs // Fatcat motorsports front bump stops // Rear Camber Arms Brakes: Hawk HPS pads // ATE Superblue fluid // Stainless Steel Brake Lines Other: CP-e Safe Seals // MattDamond shift plate // Masonvi shift knob // 3.5" WP w/recirc // RSB // IM + TB tigs // Synapse Engineering FMIC + BOV // Autotech internals Tune: hypnotic tuned Critical Stats: // 305whp/352tq // 13.34 @ 98 - Mason Dixon Dragway - 4/13/14 Titanium Gray 2006 Mazdaspeed 6 Damond Motorsports: OCC // Short shift plate // Turbo oil feed restrictor bolt Other: Autotech internals // Ebay M2 DP // Masonvi shift knob // |
| The Following User Says Thank You to nindoja For This Useful Post: | JgamB (03-31-2014) |
![]() Join Date: Mar 2013 Location: Huntsville, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,402
__________________ Manley forged long block, secret snail, manifolds, and 2gal E85 tune running like a champ - about to dial in a lot of meth and see what we've got. 13.10@117.1 full weight DD no prep 1/4 (BNR S3 / E85) | |
| The Following User Says Thank You to JgamB For This Useful Post: | jbmazda6 (04-08-2014) |
![]() Join Date: Mar 2014 Location: St. Louis, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17
| Not Ranked : 0 score Subbed! |
| The Following User Says Thank You to Scott4957 For This Useful Post: | jbmazda6 (04-06-2014) |
(Thread Starter) | Not Ranked : 0 score UPDATE 4/13/14: Clutch pedal As mentioned in the first post, I currently have the full face ACT clutch. I have had problems ever since I had it installed 2.5 years ago. I've gone through a master cylinder and now two clutch pedals. Luckily this one was salvageable. After I examined the carnage I decided that it needed some more bracing. Bracing and welds are pictured below. The clutch feels so much better now. Before I could barely get the clutch to disengage. After having so many problems I believe I may go back to stock. This clutch really isn't all that great and feels like it slips a bit. Really just wanna take it out and examine everything. The rear main seal may be toast. As for updates on the tune, it is almost finished. It's taking more revisions than I thought but that's ok because it's just going to be all that much better. Will be heading to the dyno as soon as the tune is finished.
__________________ JBR: Whale Penis, SSP+Weight+Bushings+Knob, Boost Tubes, Bypass Valve Hose, TMM, PMM, RMM, OCC, TIG's, Small Battery Tray Other: Stratified 3-Port EBCS, Stratified Guardian Angel, Cp-e Catted Downpipe, Cp-e Top Mount Intercooler, Cp-e Rear Diff Mount, Autotech Internals, H&R Coilovers Sponsored By: JamesBaroneRacing.com Last edited by jbmazda6; 05-12-2014 at 08:59 PM. |
| The Following 2 Users Say Thank You to jbmazda6 For This Useful Post: | ItsNox (04-16-2014), Mauro_Penguin (04-14-2014) |
![]() Join Date: Nov 2011 Location: Minooka, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 545
| Not Ranked : 0 score @jbmazda6; we just replaced my clutch and it turned out to be a rear main seal issue. 40,000 miles. sent while failing
__________________ 2012 Mazdaspeed3 Black Mica HYPNOTIC TUNED, FREEK TUNED, HTP full 3" intake/TIP, HKS SSQV 4 full VTA, Corksport catless downpipe, Corksport catless Racepipe, Cobb AP V3, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 80duro PMM, JBR cylindrical shift knob, Fidanza aluminum flywheel, EBC green brake pads, Centric high carbon rotors, Nitto NT555 tires, Gorilla spline lug nuts, DDM tuning HID's lows, Resonator Delete. |
| The Following User Says Thank You to GODspeed7 For This Useful Post: | ItsNox (04-16-2014) |
![]() Join Date: Apr 2013 Location: Atlanta, Georgia
Rep Power: 1578 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,584
Sent via Tapafail
__________________ '06 Mazdaspeed 6 GT Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth - Miltuned On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.![]() | |
(Thread Starter) | Not Ranked : 0 score Bad rear main seal causes slipping as some oil gets onto the clutch plate/flywheel which makes it slip as the pressure plate pushes the disc onto the flywheel
| The Following 2 Users Say Thank You to jbmazda6 For This Useful Post: | ItsNox (04-16-2014), SofaKingAwesome (04-16-2014) |
| COCKSTRONG ![]() ![]() ![]() Join Date: Jul 2011 Location: Your Mom's House
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,809
Groans: 890
| Not Ranked : 0 score nice write up
__________________ Searching for something? Try MS3Shadow's Custom Search EVERY "I DON'T USE MSF" FACEBOOK RETARD EVER |
| The Following User Says Thank You to SofaKingAwesome For This Useful Post: | jbmazda6 (04-16-2014) |
![]() Join Date: Jun 2013 Location: Raleigh, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 511
Groans: 42
| Not Ranked : 0 score subbed
__________________ [SIGPIC][/SIGPIC] SOLD//Brent - 2010 CBM MS3 - Hypnotic Tuned with ZERO Pride SOLD //CorkSport SRI&TIP //CorkSport Race RMM //Cobb AP v3 //Autotech Internals //Cobb Knob //CorkSport SSP&Bushings //UR Catted DP //UR Resonated TP //UR CBE //Forge V2 BPV //Corksport TMIC //NGK Plugs //Corksport Springs //Rays Gram Lights 57C6 18x8.5 +45 //Michelin Pilot Sport A/S3 235/40 //JBR RSB //StopTech Slotted Rotors //StopTech Street Performance Pads //Goodridge SS Lines |
sent while failing
__________________ 2012 Mazdaspeed3 Black Mica HYPNOTIC TUNED, FREEK TUNED, HTP full 3" intake/TIP, HKS SSQV 4 full VTA, Corksport catless downpipe, Corksport catless Racepipe, Cobb AP V3, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 80duro PMM, JBR cylindrical shift knob, Fidanza aluminum flywheel, EBC green brake pads, Centric high carbon rotors, Nitto NT555 tires, Gorilla spline lug nuts, DDM tuning HID's lows, Resonator Delete. | |
(Thread Starter) | Not Ranked : 0 score 4/21/14: More Toys So I finally broke down and picked up a v3 off the FS section. Also, Jamie sent me a whale penis in the mail. It's beautiful. Hoping to get to the dyno this week.
| The Following 5 Users Say Thank You to jbmazda6 For This Useful Post: | btstarcher (04-21-2014), ItsNox (04-21-2014), JBR (06-13-2014), King Scumbag (04-21-2014), speed23 (04-21-2014) |
![]() | | #24 | ![]() |
Sent via Tapafail
![]() | | #25 | ![]() |
Man I'm fucking slacking, taking me forever to peice my FREEKISH review together!
![]() | | #26 | ![]() |
![]() Join Date: Nov 2009 Location: McKinney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 852
| Not Ranked : 0 score Awesome man! NoND dongs are getting large!
__________________ gtx3076 and shit |
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score UPDATE 4/30/14: POWAHHH So, I was able to hit up the dyno today. Made better numbers than I thought but still need to talk over why my boost spiked towards the end of the run with Lex. Will be putting the big dong on tonight. Also thinking about picking up an ethanol content analyzer to make sure I have the correct amount of E85 in the tank at all times. Anyone have experience with these? Here's the dyno graph. Will get better pics soon. 276whp/346wtq for phase 1. That's +38hp/+85tq with just e and a 3-port.
__________________ JBR: Whale Penis, SSP+Weight+Bushings+Knob, Boost Tubes, Bypass Valve Hose, TMM, PMM, RMM, OCC, TIG's, Small Battery Tray Other: Stratified 3-Port EBCS, Stratified Guardian Angel, Cp-e Catted Downpipe, Cp-e Top Mount Intercooler, Cp-e Rear Diff Mount, Autotech Internals, H&R Coilovers Sponsored By: JamesBaroneRacing.com Last edited by jbmazda6; 05-10-2014 at 10:27 PM. |
| The Following 5 Users Say Thank You to jbmazda6 For This Useful Post: | allo80 (05-01-2014), Chief_Wiggum (04-30-2014), mozzie6 (05-03-2014), Scott4957 (05-28-2014), torquemaniac (05-09-2014) |
![]() | | #28 | ![]() |
![]() Join Date: Sep 2013 Location: Yelm, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 39
| Not Ranked : 0 score Sub |
![]() | | #29 | ![]() |
![]() Join Date: Jun 2012 Location: Houston, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,245
| Not Ranked : 0 score Can't wait to see the results from the next phases.
__________________ 2012 Liquid Silver Metallic MazdaSpeed3 with Tech Package. South Bend Clutch Stage 3 Endurance | TWM Full Replacement Shifter | Synapse Engineering BPV | Autotech Internals | Grimmspeed EBCS - 3port | NGK 1 Step Colder Plugs | CNT Catless DP and CBE w/resonator deleted | COBB AP - E35 Tune | HTP 3.5" Intake w/ AMSOIL Dry Filter and Pre-Filter | HTP Battery Tray w/ Energizer 51R | CP-E TMIC | CorkSport DISI Silicone Boost Tubes | Damond Motorsports/Saikou Michi Co. Stage2 OCC | Damond Motorsports Short Shift Plate | Sure Countershift | BOSCH 3 Bar MAP w/MattJackson86 PnP Harness | JBR Rear Sway Bar | JBR EGR Block Off Kit | JBR Manifold - TIG | JBR Throttle Body TIG & Coolant Bypass | JBR 88a RMM | JBR 88a TMM | JBR 80a PMM |JBR DISI Bypass Valve Hose | Ported and Polished Intake Manifold DIY | RX8 Wheels w/ Nitto Motivo 235/40/18 Tires | CP-E Towplate | DIY Custom 600g Shift Knob | Redline Tuning Hood QuickLIFT | 30% / 15% Tint | Craven Speed Stubby Antenna | Broadway 400mm Rear View Mirror | Debadged Mazdaspeed 3 Waiting to be installed: Devil's Own Stage 2 DVC-30 Meth Injection | Damond Motorsports Meth Throttle Body Plate On Order: Coming Soon: DIY Projects: FYCN - TEAM LBN BEERS - FYCN-TEAM MUMFORD - FYCN |
![]() | | #30 | ![]() |
| Not Ranked : 0 score Really gonna be interesting to see how much the big dong adds to power
![]() | | #31 | ![]() |
(Thread Starter) | Not Ranked : 0 score UPDATE 5/28/14: Dyno Day Approaching I finally have some time to update this thread, so here it goes... Quite a bit has happened since I last posted up on here, but at the same time not so much happened. After the last dyno, I proceeded to install a massive penis on my car. Install wasn't as smooth as I had liked but I eventually got that SOB in place and bolted everything back up. I will post a review of the part itself in my review thread for JBR. Enjoy a picture of a big black penis: Went to go take her for the initial test drive with the new map uploaded and only made it about a 1/2 mile before the car shut off. Ended up getting towed home by my roommate and got to work on figuring out what was wrong. Don't feel like explaining everything here so I will link you to the thread I made if you would like to read up: http://www.mazdaspeedforum.org/forum/foru...k-help-169685/ After that problem was solved I proceeded to get logs and @Lex; would make the necessary revisions for me. After a few exchanges we finally got to the last map this week. I will be heading to the dyno this Friday to see what numbers she'll put down. Hopefully it's close to the 300whp/350 tq area. Really looking to see more power later in the rev range though.. we shall see.. STAY TUNED! Also, during all of this I decided I would paint the cp-e intercooler I bought off a member here. Looks like new! I've got a cp-e catted downpipe waiting for install too super excited about the next few phases.Sorry about the shitty cell phone pics this time around!
| The Following 4 Users Say Thank You to jbmazda6 For This Useful Post: |
![]() | | #32 | ![]() |
| Not Ranked : 0 score Good stuff man, wish I had the time and money to get a good break down like this step by step, dyno by dyno! I guess I'll just be comparing turbos with the peen whenever I decide to upgrade lol Tapatalk for what!
![]() | | #33 | ![]() |
(Thread Starter) | Not Ranked : 0 score I promise I haven't forgotten about this! Just been super busy. Will update this weekend with progress.
| The Following 3 Users Say Thank You to jbmazda6 For This Useful Post: |
![]() | | #34 | ![]() |
(Thread Starter) | Not Ranked : 0 score 6 hours on a wednesday night was definitely not fun but the pizza, beer, and good company helped a lot. Sadly it is raining here so I probably will not get good fourth gear logs today. I really hope we can finish this tune and the smaller intake tune by August 12th!
![]() | | #35 | ![]() |
![]() Join Date: Jul 2014 Location: Bloomington, IN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 55
| Not Ranked : 0 score subscribed for updates!!
__________________ 2011 Speed3 - Tech Package Cobb AP - JBR SRI - JBR TIP - AT HPFP Internals - OBX catless TBE - CS TMIC - JBR 88 RMM - JBR Rear Sway Bar - RallyArmor Mudflaps Freektune OTS+ Waiting on install: JBR Short Shift Plate - Swift Springs |
![]() | | #36 | ![]() |
![]() Join Date: Oct 2012 Location: Vallejo, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 252
| Not Ranked : 0 score Where did stage 3 go? |
![]() | | #37 | ![]() |
(Thread Starter) | Not Ranked : 0 score It is conplete. Results to come. I decided I would like to finish everythung before publishing the results.
![]() | | #38 | ![]() |
| Not Ranked : 0 score Too late. I've already switched to a 5.5" intake with a shop vac filter. My car won't idle but it pulls 600 g/s on K04. ![]() Anxious to see the results!
| The Following 5 Users Say Thank You to JgamB For This Useful Post: | bstover17 (07-30-2014), Code Monkey (09-16-2014), ItsNox (07-30-2014), Mauro_Penguin (07-31-2014), sidekick (07-30-2014) |
![]() | | #39 | ![]() |
![]() Join Date: May 2013 Location: Bryn Mawr, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,449
very fun build to watch..keep it coming!
__________________ 2013 LSM Mazdaspeed3 - stocked out and traded 6/5/2017 2017 LGM Golf R - South Bend stage 3 daily clutch / IE intake / Wagner IC / AWE downpipe / Indvidia catback / EQT Tuned 2004 Yamaha R6 - Micron Ricer Pipe / PC 2005 Honda CBR 600 F4i - R.I.P. 10/29/13 | |
| The Following User Says Thank You to WAMBUSHHHH! For This Useful Post: | JgamB (07-31-2014) |
![]() | | #40 | ![]() |
| Not Ranked : 0 score Almost done? I'm excited to see results since I'm doing everything pretty similar and want to know what to expect! |
| My JBR Journey | Menace1 | JAMES BARONE RACING | 8 | 03-17-2013 03:21 PM |
| My VD journey | x09MS3GT | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 9 | 05-30-2012 01:21 PM |
| MY ATR Journey... | cld12pk2go | Cobb ATR Support | 120 | 06-14-2011 05:11 PM |
| My journey after the MS6 | JohnnyT | Members Rides Gallery | 9 | 06-14-2010 11:52 AM |
