 Old 07-18-2014, 03:27 PM   #1
The_Names_E's Avatar
Posts: 54   (View Stats)
The_Names_E has a brilliant futureThe_Names_E has a brilliant futureThe_Names_E has a brilliant futureThe_Names_E has a brilliant futureThe_Names_E has a brilliant futureThe_Names_E has a brilliant futureThe_Names_E has a brilliant futureThe_Names_E has a brilliant futureThe_Names_E has a brilliant futureThe_Names_E has a brilliant futureThe_Names_E has a brilliant future
Default Jbr 88 duro rmm nut
I bought am 88duro rmm and just need to know what kind of nut to use with the stock bolt on my Gen 1 speed3.
The_Names_E is offline   Reply With Quote
 Old 07-18-2014, 10:07 PM   #2
What happened to the hardware that was included with it?
 Old 07-18-2014, 10:09 PM   #3
I bought it off the forum and unfortunately I forgot to ask or be told it wasn't included.
 Old 07-19-2014, 07:23 AM   #4
You're going to need 1, 1/2-13 x 3" grade 8 bolt, 2, 1/2" flat washers, 1, 1/2" lock washer and 1, 1/2-13 nut grade 8.
CaptObvious75 (07-25-2014), Gr8Speed (07-23-2014), IslandSpeed (07-31-2014), King Scumbag (07-19-2014), Mauro_Penguin (07-20-2014), mzr0818 (07-19-2014), Realgib3 (07-25-2014), The_Names_E (07-19-2014), XxSmarTz (08-04-2014)
 Old 07-19-2014, 07:25 AM   #5
mzr0818's Avatar
Groans: 221
I may have an extra
EMWNM 2013
2008 mazdaspeed 3 true red
Tuned by Nishan
 Old 07-19-2014, 07:57 AM   #6
Thanks!
 Old 07-19-2014, 07:11 PM   #7
King Scumbag's Avatar
Posts: 2,384   (View Stats)
@jbarone; doesn't the dog bones utilize the stock bolt at the trans bracket? I may be wrong but I thought that it did and you used the supplied nut and washer.
07 BLACK MICA MS3
PATTY/JEFF BUILT MOTOR
STOCK BLOCK
BOSTON STRONG
 Old 07-19-2014, 07:14 PM   #8
We have always supplied hardware with the mount for the connection at the trans bracket.
 Old 07-19-2014, 07:16 PM   #9
Oh ok I thought it utilized the stock bolt.
As I was
He bought the mount second hand and the seller didn't include anything.
@jbarone; this is what confused me because in the directions it utilizes the stock mounting bolt.
Tapatalk for what!
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
 Old 07-29-2014, 03:53 PM   #10
cuethenoise's Avatar
Posts: 136   (View Stats)
cuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the world
Groaned at 6 Times in 2 Posts
Yeah you definitely need a bolt man!
2012 Mazdaspeed3 w/ tech package
Stage 1 Stratified OTS
JBR Powerpath Stage 2
JBR 88a RMM
HPFP internals.
cuethenoise is offline   Reply With Quote
Page generated in 0.32921 seconds with 24 queries
