  • 1 Post By JBR
 Old 07-12-2013, 10:47 AM   #1
Exclamation JBR July Specials Thermal Intake, Throttle Body Gaskets & Dry Wrap Pre-Filters are on SALE!!
Now thru the end of July all Thermal Intake and Throttle Body gaskets with coolant bypass kits will be on sale as well as all JBR Dry-Wrap Pre-Filters.
JBR Dry-Wrap Pre-Filters fit all filters for the most common intake systems on the market except for COBB.
It's hot outside and BATS are high. Lower them by installing our PTFE Thermal Insulating Intake and Throttle Body Gasket with Coolant Bypass kits.
Mauro_Penguin likes this.
Mauro_Penguin (07-12-2013), mike w (07-12-2013), mWindu (07-14-2013), Ryguy (07-12-2013), sidekick (07-14-2013)
 Old 07-14-2013, 10:57 AM   #2
mWindu's Avatar
Posts: 244   (View Stats)
mWindu is the leader of the worldmWindu is the leader of the worldmWindu is the leader of the worldmWindu is the leader of the worldmWindu is the leader of the worldmWindu is the leader of the worldmWindu is the leader of the worldmWindu is the leader of the worldmWindu is the leader of the worldmWindu is the leader of the worldmWindu is the leader of the world
For those of you who are skeptical on how well these perform...
I installed all these a couple weeks ago. My BATS have dropped significantly. Normal city driving never exceeds 130 degrees.
That may sound high, but I live in Southern California, and the last few weeks we have been living in 105+ degrees just about every day.
And on the highway or in the mornings, BATS are not even 15 degrees over ambient temps. I couldn't believe my AP when I saw it.
Sorry for the novel, but buy this stuff yo! You'll be glad you did!
\\2008.5 MGM Speed3//
POWER
\\Autotech HPFP//HTP 3.5" Intake\\CNT Catback//Corksport TP\\TR1035 FMIC//P&P Intake Mani\\JBR TIGS//EGR Delete\\
HANDLING
\\JBR 88 Duro Trilogy Mounts//H&R Coilovers\\JBR RSB//Whiteline Adjustable Rear Endlinks\\Corksport Camber Plates//JBR Camber Arms\\SS Brake Lines//
\\Stoptech Drilled Rotors\\
\\STRATIFIED TUNED//
mWindu is offline   Reply With Quote
The Following User Says Thank You to mWindu For This Useful Post:
 Old 07-14-2013, 02:36 PM   #3
jdm_mica's Avatar
Posts: 525   (View Stats)
jdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the world
Truth
Cobb AP (Stratified Tuned)
Corksport Stage 2 intake+recirc tube
Streetunit testpipe
Autotech internals
NGK LTR7Ix-11
Corksport RMM
RX-8s--235/40/18 Bridgestone Potenza RE-760
Stoptech brake kit+Motul RBF600
Whiteline RSB+endlinks
Dominant Engineering camber arms
JBR stage 2 OCC+ EGR delete+intake manifold gasket
HKS turbo timer
Prosport boost gauge+ventpod
Awaiting H&R springs/Koni yelows/ground control bumpstops
jdm_mica is offline   Reply With Quote
 Old 07-14-2013, 02:47 PM   #4
Kyllo24's Avatar
Posts: 288   (View Stats)
Kyllo24 is the leader of the worldKyllo24 is the leader of the worldKyllo24 is the leader of the worldKyllo24 is the leader of the worldKyllo24 is the leader of the worldKyllo24 is the leader of the worldKyllo24 is the leader of the worldKyllo24 is the leader of the worldKyllo24 is the leader of the worldKyllo24 is the leader of the worldKyllo24 is the leader of the world
Groaned at 5 Times in 1 Post
Fuuuuuu just bought my tigs. Lol.
sent from genwon
Richtuned on k04 92 oct. 280whp/335wtq
Richtuned on 50/50 E85 300whp/350wtq
AUTOTECH HPFP INTERNALS
Corksport: Coilovers, Front endlinks, SS Brake lines, Rear sway bar, Downpipe, Racepipe, Exhaust hangers, Licence plate relocation kit
JBR: 80 duro motor mount trilogy, Solid shifter bushings
Cobb: XLE BPV, STS, FMIC
Other: HTP 3" intake, autoexe rear toe bar,Moog rear endlinks, 3 Bar MAP sensor, Grimmspeed 3 port EBCS
Ricer Mods: EVO X GSR wheels powdercoated gold, Valve cover powdercoated gold, Hawk hps brake pads, Stoptech slotted front and rear rotors, 15% Window tint, saikou michi OCC, DDM HIDS 5000K lows 3000k fogs, Rally armor mud flaps
Kyllo24 is offline   Reply With Quote
 Old 07-30-2013, 01:26 PM   #5
This ends tomorrow folks.
JBR MAZDASPEED 3/6 & CX-7 Thermal Insulating Gaskets In Stock!! JBR JAMES BARONE RACING 90 12-31-2014 11:00 AM
intake manifold and throttle body kmac MazdaSpeed 3/6 - Turbo Induction 130 05-25-2011 06:57 PM
Page generated in 0.26427 seconds with 23 queries
