Like Tree6Likes
 Old 04-12-2011, 11:25 AM   #41
Originally Posted by tddvrrn View Post
ETA for other engine mounts? months? years?
i'd like to get them from you, but if it will be a while i may get a trans mount from elsewhere then sell it when yours come out..
impatience is key.
Late summer early fall.
Monotonous ONE (04-14-2011), tddvrrn (04-12-2011)
 Old 04-12-2011, 12:39 PM   #42
Speed3eak's Avatar
Posts: 2,290   (View Stats)
Groans: 82
Also, I don't know if I posted this in this particular thread - remember guys, that driver311, who's pushing 400whp, is using all stock mounts, except for the rear, which he filled with urethane.
Chances are you're making less power than him, so if the side mounts are anything like the rear mounts that are being offered, then it is 100% worth it to wait.
I got my rear mount over a year ago, but if the JBarone mounts had been out then you better believe I would have picked one up. I'd like to see a comparison between the JBR 80 duro and the cp-e 75 duro - my guess is that the JBR would be at, near, or possibly even below the vibes of the cp-e.
Jamie, I know you say that the washers that the cp-e use contribute to the "noise" or "vibrations" of the mount, but tbh there's enough pressure on them I can't see them moving around enough to create any extra chatter or vibrations. I think the cp-e is a very well designed mount, much like your own, and I think a shootout between the two would make for an interesting read.
The Following User Says Thank You to Speed3eak For This Useful Post:
JBR (04-13-2011)
 Old 04-12-2011, 04:41 PM   #43
Dawgbizkitz's Avatar
Posts: 122   (View Stats)
Dawgbizkitz has a reputation beyond reputeDawgbizkitz has a reputation beyond reputeDawgbizkitz has a reputation beyond reputeDawgbizkitz has a reputation beyond reputeDawgbizkitz has a reputation beyond reputeDawgbizkitz has a reputation beyond reputeDawgbizkitz has a reputation beyond reputeDawgbizkitz has a reputation beyond reputeDawgbizkitz has a reputation beyond reputeDawgbizkitz has a reputation beyond reputeDawgbizkitz has a reputation beyond repute
I met up with Jamie today and bought one of the 70d mounts from him. Installed it this afternoon. The difference between JB's and the stock mount would be like comparing apples to oranges. Only noticeable vibration is stopped at idle. It is very mild steering wheel vibes. Otherwise, feels like stock except the car feels better in shifts and wheel hop has been drastically reduced. Keep in mind that I replaced a stock RMM with 62k miles on it with this so as you can imagine the improvement.
Dawgbizkitz is offline   Reply With Quote
The Following User Says Thank You to Dawgbizkitz For This Useful Post:
JBR (04-13-2011)
 Old 04-12-2011, 10:24 PM   #44
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
anyone compared the molly to the trz? molly's bushings look bigger. not by much, but it may eliminate some nvh...
the reason i was considering all the mounts is my quest to eliminate drivetrain bounce. with the trz it was gone, but the vibes were nutty. with my su the vibes are barely there but the bounce is back, but not as bad as stock.
maybe the jbr 80 billet..?
fuck, i don't know!
The Following User Says Thank You to tddvrrn For This Useful Post:
JBR (04-13-2011)
 Old 04-12-2011, 10:41 PM   #45
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
fuck, i don't know!
In due time man. These came out yesterday!
As for your dilemma...the Molly will be similar to the TRZ. Go with the 80 billet.
Tapawhat?
The Following 2 Users Say Thank You to 08.5MS3 For This Useful Post:
JBR (04-13-2011), tddvrrn (04-15-2011)
 Old 04-13-2011, 05:48 AM   #46
I should have been more clear....You are correct the spacers are in there very snug and tight; it's all that metal surface area in contact with the sub-frame which "in my opinion" contributes to the added NVH. Not they are loose and or vibrating. I believe that having just bushing in contact with the sub-frame reduces the noise and vibes considerably.
Thanks,
Jamie
Speed3eak (04-13-2011)
 Old 04-13-2011, 07:41 PM   #47
Speed3eak's Avatar
Groans: 82
Thanks,
Jamie
I see what you're saying, but in my opinion/experience, metal on metal contact doesn't necessarily serve to increase noise/vibrations. When two separate pieces of metal are pressed together snugly, they vibrate as though they were once piece (again, in my experience). Plus, the engine is still connected to the subframe via the mount, so if the metal pieces effectively vibrate at the same rate/intensity as the subframe, IMO the difference comes down to the material.
I don't know the characteristics of urethane vs. epdm, tensile characteristics or otherwise, but it occurs to me that the cp-e design (especially the shape of the spacers), seems to allow a less stiff material effectively behave like a much stiffer one, when you consider how the forces are applied and distributed to an engine mount. The shape of the spacers appear to progressively distribute force towards the center of the mount (where the material is thinner) with engine load, and conversely away from it under low-load situations.
Now, this may or may not be the case, but those were my thoughts initially upon receiving the cp-e mount. If the EPDM does fail, CP-E offers a lifetime warranty on all of their products, so in my case driving gently for a week while the stock mount is still installed would not be a deterrent to purchasing the cp-e mount.
Like I said before, if your RMM had been out, I would have absolutely bought it without hesitation before any other mount. I just think that the fact that you name the cp-e mount off hand/casually and point out what you believe to be design flaws with it is unfair to cp-e without a counterpoint opinion. I'm sure you there are aspects of every mount that you can critique (hence why yours doesn't look like any other mount), it just occurred to me that the cp-e was targeted disproportionately in this discussion.
JBR (04-14-2011)
 Old 04-14-2011, 06:08 AM   #48
Chief_Wiggum's Avatar
Posts: 419   (View Stats)
Installed Jamie's 70 duro RMM yesterday; I was surprised by how much it improved shift action. It also feels more solid than the AWR RMM I replaced. I've only noticed some vibration at idle with the A/C on, but it doesn't bother me at all.
The JBR trifecta (bushings, SSP, heavy knob) should really be the superfecta; bushings, SSP, heavy knob AND RMM. As always, great stuff Jamie...keep it up!
The Following 2 Users Say Thank You to Chief_Wiggum For This Useful Post:
spec2k5 (04-14-2011), Speed3eak (04-14-2011)
 Old 04-16-2011, 04:10 PM   #49
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
just got mine in .. gotta say, its such nice piece. I don't remember the SU mount i had being this nice.. Its a solid piece... it's lot thicker than it looks in the pics... and i like how the bushing doesn't stick out the ends like torque solutions and Sure.. that lil bit you see in the his pics is a flap..the entire bushing is inside the mount. Awesome work James!
JBR (04-16-2011)
 Old 04-17-2011, 02:29 AM   #50
Big Titty Sucker
BLK_MS3's Avatar
Posts: 1,612   (View Stats)
BLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the world
Groans: 139
So Jamie I see it says your mounts have less vibs then the others. How much difference between the 70 and 80 duro then? They seem so close, no?
BLK_MS3 is offline   Reply With Quote
The Following User Says Thank You to BLK_MS3 For This Useful Post:
JBR (04-18-2011)
 Old 04-17-2011, 09:23 AM   #51
so after installing it I see why the dog bone style is superior in rigidity. Tightening down the supplied bolt ,you can see the mount move/flex..After installing it last night and going for a quick drive;i gotta say at first i didn't know what to look for as far as improvement..its been a while since i had a rmm.. But today i noticed getting into any gear feels better.. You don't feel you have to baby it.. There is not much movement in the drivetrain..as for wheel hop I don't know, I haven't tried launching yet.. Vibs? so minimal its not worth mentioning < and its not broken in yet..I would say the 80 duro billet style would be just fine aswell.
Update:.. feel the vibs more now.. its not there so much when you first start the car..but after when you come to a light..but nothing crazy, just more than I had felt.Still not broken in.... I gotta re-tighten it to 70lbs cause i know its a lot more now..heard it might cause more vibs if you over tighten..not sure why or if it true but ill tighten per instructions.
JBR (04-18-2011)
 Old 04-17-2011, 07:38 PM   #52
Update: I'm about 300 miles in with this mount. I don't notice the vibration anymore. I'm still retaining the improved shifts and lack of wheel hop. The steering wheel vibration has ceased. Thanks again Jamie.
The Following 2 Users Say Thank You to Dawgbizkitz For This Useful Post:
JBR (04-18-2011), Speed3eak (04-17-2011)
 Old 04-17-2011, 08:02 PM   #53
Fozzy's Avatar
Posts: 193   (View Stats)
Fozzy has a reputation beyond reputeFozzy has a reputation beyond reputeFozzy has a reputation beyond reputeFozzy has a reputation beyond reputeFozzy has a reputation beyond reputeFozzy has a reputation beyond reputeFozzy has a reputation beyond reputeFozzy has a reputation beyond reputeFozzy has a reputation beyond reputeFozzy has a reputation beyond reputeFozzy has a reputation beyond repute
Just ordered a 70d, along with a new knob and RSB. Can't wait to get everything!
Fozzy is offline   Reply With Quote
The Following User Says Thank You to Fozzy For This Useful Post:
JBR (04-18-2011)
 Old 04-17-2011, 10:17 PM   #54
maxed_out_saloon's Avatar
Posts: 689   (View Stats)
maxed_out_saloon is the leader of the worldmaxed_out_saloon is the leader of the worldmaxed_out_saloon is the leader of the worldmaxed_out_saloon is the leader of the worldmaxed_out_saloon is the leader of the worldmaxed_out_saloon is the leader of the worldmaxed_out_saloon is the leader of the worldmaxed_out_saloon is the leader of the worldmaxed_out_saloon is the leader of the worldmaxed_out_saloon is the leader of the worldmaxed_out_saloon is the leader of the world
just ordered the 80duro. cant wait to get it and install it
maxed_out_saloon is offline   Reply With Quote
The Following 2 Users Say Thank You to maxed_out_saloon For This Useful Post:
JBR (04-18-2011), tddvrrn (04-18-2011)
 Old 04-18-2011, 06:49 AM   #55
A bit more, but well with in the range of tolerance.
Thanks,
Jamie
The 80's should be shipping out towards the end of the week.
Thanks for the order.
Jamie
Last edited by JBR; 04-18-2011 at 06:49 AM. Reason: MSF Database - Automerged Doublepost
maxed_out_saloon (04-18-2011)
 Old 04-18-2011, 09:34 AM   #56
Big Titty Sucker
BLK_MS3's Avatar
Groans: 139
Thanks,
Jamie
Cool, but I guess for a 60 mile a day daily driver you would recommend the 70? I want as few vibes as possible.
Thanks!
 Old 04-18-2011, 08:24 PM   #57
tddvrrn's Avatar
Groans: 103
^ i bet you won't even notice the vibes if you get an 80, at least once it's broken in..
stay away from the dogbone style mounts if you don't want noise/vibes. i had a trz and the drone that thing brought into the cabin was too much, especially at highway speeds.
that being said, it was one solid mother!
 Old 04-19-2011, 12:21 PM   #58
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
Just ordered my 88 duro dogbone molly mount.... Holla at your boy!
860whp/677wtq
2.7 V6 Ecoboost
JBR (04-20-2011)
 Old 04-20-2011, 05:23 PM   #59
burntRice's Avatar
Posts: 215   (View Stats)
burntRice is the leader of the worldburntRice is the leader of the worldburntRice is the leader of the worldburntRice is the leader of the worldburntRice is the leader of the worldburntRice is the leader of the worldburntRice is the leader of the worldburntRice is the leader of the worldburntRice is the leader of the worldburntRice is the leader of the worldburntRice is the leader of the world
Groaned at 25 Times in 5 Posts
Just got the shipping confirmation!
08' Speed3 GT --> CP-e sri - CP-e tip - forge v1 bpv - TWM short shift - JBR shift knob - JBR 88duro trilogy - JBR shifter bushings - CNT racing CBE - CNT racing DP (waiting for fuel pump) - Evo X's - Federal SS595's 225/40r18
burntRice is offline   Reply With Quote
 Old 04-21-2011, 12:09 AM   #60
Buddhamonk's Avatar
Posts: 174   (View Stats)
Buddhamonk is the leader of the worldBuddhamonk is the leader of the worldBuddhamonk is the leader of the worldBuddhamonk is the leader of the worldBuddhamonk is the leader of the worldBuddhamonk is the leader of the worldBuddhamonk is the leader of the worldBuddhamonk is the leader of the worldBuddhamonk is the leader of the worldBuddhamonk is the leader of the worldBuddhamonk is the leader of the world
Groaned at 15 Times in 8 Posts
I just ordered the 70D after spending 3 days reading all the posts on RMM. Sounds like the JBR is the way to go since the CPE is on back order on SU website. Looking forward to trying it out.
Buddhamonk is offline   Reply With Quote
The Following User Says Thank You to Buddhamonk For This Useful Post:
JBR (04-21-2011)
 Old 04-21-2011, 01:29 PM   #61
hey jamie, have the 80duro mounts been shipped out yet. im itching to get mine installed
The Following User Says Thank You to maxed_out_saloon For This Useful Post:
JBR (04-21-2011)
 Old 04-21-2011, 03:31 PM   #62
No, unfortunately not. It looks like the uptick in the economy has pushed those of us not spending 100K back in the line a bit, and my manufacturer is running behind trying to fill some larger orders that CAME IN AFTER MINE. AND I"M PISSED ABOUT IT. (End Rant)
Looks like another week and a half. I would be happy to refund the few 80 duro orders pending if you guys would like to go with someone else. I totally understand.
Thanks,
Jamie
maxed_out_saloon (04-21-2011)
 Old 04-21-2011, 11:18 PM   #63
Thanks,
Jamie
ok cool thanks for the update. and no its cool ill wait it out for ur mount to be done. thanks anyways
 Old 04-22-2011, 01:35 PM   #64
PapaSmurf's Avatar
Got my Molly dog bone mount in today but no hardware :-( was going to install it along with my tranny mount this weekend but looks like I'll only be doing my tranny mount since the hardware won't get here till the 25th.
Product looks great jamie and thanks for the great customer service!
860whp/677wtq
2.7 V6 Ecoboost
 Old 04-22-2011, 05:11 PM   #65
foodtime's Avatar
Posts: 225   (View Stats)
why did you go with the Molly dog bone? tracking your car?
 Old 04-22-2011, 05:18 PM   #66
PapaSmurf's Avatar
Yes and no.
I go to the track about once a month and the 60 duro CPe mount I have just isn't enough, it's good for a DD'er but not good at all on the track.
Also the dog bone high duro mounts make your tranny shift that much smoother and gives u even a less chance to miss a gear. I could care less about vibes, I just don't want my engine to move so it can put more power to the ground and keep the wheel hop minimal. I'm also going to be putting on a tranny mount with this dog bone rmm and than am going to wait till Jamie cones out with a passenger mount and pick that up also.
860whp/677wtq
2.7 V6 Ecoboost
 Old 04-27-2011, 09:02 AM   #67
OneBAMFpog's Avatar
Posts: 642   (View Stats)
OneBAMFpog is the leader of the worldOneBAMFpog is the leader of the worldOneBAMFpog is the leader of the worldOneBAMFpog is the leader of the worldOneBAMFpog is the leader of the worldOneBAMFpog is the leader of the worldOneBAMFpog is the leader of the worldOneBAMFpog is the leader of the worldOneBAMFpog is the leader of the worldOneBAMFpog is the leader of the worldOneBAMFpog is the leader of the world
Groaned at 25 Times in 11 Posts
I just ordered my dogbone mount too
2010 Black Mica Mazdaspeed 3 Stock
2010 Velocity Red Mica Mazdaspeed 3
Current Mods:
COBB SRI -- TIH -- ACCESSPORT -- EBCS
CP-E DP AUTOTECH FP INTERNALS CORKSPORT 80 MM DUAL EXHAUST
JBR SOLID SHIFTER BUSHINGS -- 88 DURO RMM -- TMM -- PMM--TIG AND COOLANT BYPASS FORGE BPV
ACT ZX5-HDG6 CLUTCH KIT DEVIL'SOWN METH KIT
EDDIE BAUER CARSEAT MOD
DJ tuned: 302 whp and 339 wtq
"YOU PULLED ON ME LIKE A FREIGHT TRAIN!"
OneBAMFpog is offline   Reply With Quote
The Following User Says Thank You to OneBAMFpog For This Useful Post:
JBR (04-27-2011)
 Old 04-27-2011, 12:08 PM   #68
PapaSmurf's Avatar
Be prepared for hella vibes. :-)
860whp/677wtq
2.7 V6 Ecoboost
 Old 04-27-2011, 12:23 PM   #69
I's not that bad.
 Old 04-27-2011, 12:39 PM   #70
PapaSmurf's Avatar
I's not that bad.
i guess coming from a broken 60 duro cpe rmm, its a big difference. haha
i dont mind it at all, just saying.
860whp/677wtq
2.7 V6 Ecoboost
JBR (04-28-2011)
 Old 04-27-2011, 12:44 PM   #71
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
I's not that bad.
How does it compare to the TRZ dogbone-style RMM? I'm curious, as my poly TRZ dogbone causes serious NVH at about 1500-2000 RPM.
JBR (04-28-2011)
 Old 04-27-2011, 01:15 PM   #72
PapaSmurf's Avatar
That's were I get NVH at with the JBR. 1500-2000
860whp/677wtq
2.7 V6 Ecoboost
JBR (04-28-2011)
 Old 04-27-2011, 01:22 PM   #73
danxk3nnz's Avatar
Posts: 73   (View Stats)
danxk3nnz has a reputation beyond reputedanxk3nnz has a reputation beyond reputedanxk3nnz has a reputation beyond reputedanxk3nnz has a reputation beyond reputedanxk3nnz has a reputation beyond reputedanxk3nnz has a reputation beyond reputedanxk3nnz has a reputation beyond reputedanxk3nnz has a reputation beyond reputedanxk3nnz has a reputation beyond reputedanxk3nnz has a reputation beyond reputedanxk3nnz has a reputation beyond repute
Groaned at 12 Times in 7 Posts
Same here.
danxk3nnz is offline   Reply With Quote
 Old 04-27-2011, 03:19 PM   #74
OneBAMFpog's Avatar
Small vendors have no excuse for not shipping out quickly unless they are out of stock. I had a tracking number withing 45 mins of ordering my JBR dogbone today.
Current Mods:
JBR (04-28-2011)
 Old 04-27-2011, 08:06 PM   #75
Buddhamonk's Avatar
Got my billet 70 duro within 4 days of ordering and I installed it today. It was a pain getting that car on jack stands but afterwards it was a breeze. The smooth shifting is what impresses me the most! It's almost as smooth as my 1996 integra now =) I get slight vibration at idle, especially with AC on but it's worth it
JBR (04-28-2011)
 Old 04-27-2011, 08:39 PM   #76
slapshotman7's Avatar
Posts: 53   (View Stats)
slapshotman7 has a reputation beyond reputeslapshotman7 has a reputation beyond reputeslapshotman7 has a reputation beyond reputeslapshotman7 has a reputation beyond reputeslapshotman7 has a reputation beyond reputeslapshotman7 has a reputation beyond reputeslapshotman7 has a reputation beyond reputeslapshotman7 has a reputation beyond reputeslapshotman7 has a reputation beyond reputeslapshotman7 has a reputation beyond reputeslapshotman7 has a reputation beyond repute
Just ordered mine, can't wait to get it on.
slapshotman7 is offline   Reply With Quote
 Old 04-28-2011, 05:13 AM   #77
Depending on how much you drive; in about 3 weeks it will be pretty much gone.
Jamie
I agree; but I also feel that large vendors should ship out quickly as well.
I ship everything in less than 24 hours. In most cases it's within a few hours of the order being placed so it can get on the truck the day it's ordered.
Thanks,
Jamie
Last edited by JBR; 04-28-2011 at 05:13 AM. Reason: MSF Database - Automerged Doublepost
maxed_out_saloon (04-28-2011), Monotonous ONE (04-28-2011), PapaSmurf (04-28-2011), Post pwned (05-11-2011), silvapain (04-28-2011)
 Old 04-28-2011, 05:45 AM   #78
Jake5713's Avatar
Posts: 1,775   (View Stats)
Are the 80 duro's still set to ship the 2nd? Great customer service thanks Jamie!
Jake5713 is offline   Reply With Quote
The Following User Says Thank You to Jake5713 For This Useful Post:
JBR (04-28-2011)
 Old 04-28-2011, 01:44 PM   #79
hamptotl's Avatar
Posts: 677   (View Stats)
hamptotl is the leader of the worldhamptotl is the leader of the worldhamptotl is the leader of the worldhamptotl is the leader of the worldhamptotl is the leader of the worldhamptotl is the leader of the worldhamptotl is the leader of the worldhamptotl is the leader of the worldhamptotl is the leader of the worldhamptotl is the leader of the worldhamptotl is the leader of the world
Hey Jamie I got my delivary con. on the 25th and its saying expect it on the second you think its legit or just prepairing me for the worst. I am in VA so pretty close to you actually.
NatorVA07 1995 Miata M
Sway bars end links butterfly brace bilsteins with sleeves and Jackson Racing Header.
hamptotl is offline   Reply With Quote
The Following User Says Thank You to hamptotl For This Useful Post:
JBR (04-28-2011)
 Old 04-28-2011, 05:18 PM   #80
No sorry they will not be shipping on the 2nd. The will be shipping this Saturday the 30th.
Thanks,
Jamie
Not sure. PM me the email address you ordered with and I'll look in to it.
Thanks,
Jamie
Last edited by JBR; 04-28-2011 at 05:18 PM. Reason: MSF Database - Automerged Doublepost
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f493/jbr-mazda-3-5-mazdaspeed-3-rear-77448/
SURE Rear Motor Mount - 2010-13 Mazda 3/Mazdaspeed 3 Forums This thread Refback 09-30-2013 07:01 PM
SURE Rear Motor Mount - 2012 Mazda 3/Mazdaspeed 3 Forums This thread Refback 11-23-2012 03:55 PM
My 2011 MazdaSpeed 3 : mazda This thread Refback 03-07-2012 07:39 PM
SURE Rear Motor Mount - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Pingback 04-11-2011 06:29 AM
CP-E Motor Mounts for the Mazdaspeed 3 in stock ! kevin@gripgarage.com Mazdaspeed3/6 General Discussion 0 04-24-2009 02:25 PM
Who Has Rear Motor Mounts in stock? Arrowpoint Mazdaspeed3/6 General Discussion 2 12-29-2008 08:01 PM
Page generated in 0.59654 seconds with 40 queries
