JBR Mazda 3 and Mazdaspeed 3 Coilover Suspension Kits in Stock!! http://www.jamesbaroneracing.com/sho...AZ-0413-CO.JPG Details: Designed with a wide range of adjustabilty, the JBR coilover suspension kit lets you ride to work and carve up the town in maximum style and comfort. Then, when the weekend comes and you're preparing to grid, fine-tune all four corners and transform your Mazda from a mean street machine into a corner hugging track beast. With 32 points of compression and rebound adjustment as well as being fully height adjustable, these coilovers are the only choice when it comes to use on the street and the track. The JBR front coilovers include camber plates machined from 6061 aluminum and anodized for a sleek look and corrosion protection. They're then fitted with nickel plated steel adjustment plates with pillow ball mounts for smooth, quite operation that will last a lifetime. http://www.jamesbaroneracing.com/sto...amberPlate.JPG The front dampers are of a mono-tube construction with 32 points of compression and rebound adjustment. They carry a 24 month warranty and are fully re-buildable. The entire front assembly is height adjustable from -.5" to -2.95". http://www.jamesbaroneracing.com/sto...00-Dampers.JPG In the rear you'll find another mono-tube damper also with 32 points of compression and rebound adjustment. Included with the rear dampers are upper mounts machined from 6061 aluminum, secured to the damper with soft yet very durable rubber bushings. They also carry a 24 month warranty and are fully rebuildable. http://www.jamesbaroneracing.com/sto...ShockMount.JPG The lower mount for the rear dampers are again machined from 6061 aluminum with nickel plated steel sleeves and rubber bushings. http://www.jamesbaroneracing.com/sto...ShockMount.JPG The rear height adjustment is achieved with adjustable spring perches that bolt in to the lower control arm providing a range of adjustment from -.5" to -2.95". http://www.jamesbaroneracing.com/sto...arAdjuster.JPG The front and rear springs are made from high quality metal alloy spring steel which undergoes a cold winging process followed by induction hardening and tempering to maintain spring rates, maximize fatigue life and minimize deformation. The front springs are 7.5K and the rear springs are 4.5K http://www.jamesbaroneracing.com/sto...05-Springs.JPG *Applications Available:
*Product images and options may vary slightly by model. Features:
Includes:
We're making more of these! |
Wow great price! How long are they on sale for? I really dislike the ride quality of my Koni STR.Ts and I'd love to buy me a set of these come tax season. Sent from my STV100-1 using Tapatalk |
Quote:
Suspension packages will be coming soon too. |
Those are sexy. Suspension packages you say?? I'll be here waiting. My sig needs all things suspension. |
Swift springs option? |
Quote:
What are you looking for? We can get most any spring rate from our manufacturer. |
Quote:
Sent from my SM-G935T using Tapatalk |
Quote:
Quote:
I give up |
| All times are GMT -7. The time now is 02:05 AM. |
