Like Tree9Likes
 Old 08-18-2011, 09:54 AM   #1
Arrow JBR MAZDASPEED 3/6 & CX-7 Thermal Insulating Gaskets In Stock!!
James Barone Racing
Performance Aftermarket Parts & Accessories
Thermal Insulating Intake Gasket Kit
Thermal Insulating Throttle Body Gasket & Coolant Bypass Kit
The Mazda 2.3L MZR DISI engine is assembled using paper thin metal gaskets between the intake manifold and cylinder head. The same paper thin style metal gasket is used between the throttle body and intake manifold. This design allows intense heat to be transferred to both, greatly increasing boost air temperature and robbing you of horsepower.
The JBR Thermal Insulating Intake Gasket Kit prevents this unwanted transfer of heat thus reducing boost air temps and increasing horsepower.
Constructed out of .062 virgin grade PTFE with a temperature rating of 500°F. CAD designed and ported to ensure there’s no reduction in flow. Thin enough to be effective without the risk of cracking your intake manifold. And it’s reusable too!
The JBR Thermal Insulating Gasket Kit is stackable up to 4 thick while utilizing stock mounting hardware.
LINK TO PRODUCT PAGE
Application: Mazdaspeed 3/6, CX-7 All
Kit Includes:
1 Insulating Intake Manifold Gasket
1 Insulating Intake Manifold Gasket Spacer
Detailed Online Installation Instructions
Free Shipping
The JBR Thermal Insulating Throttle Body Gasket & Coolant Bypass Kit prevents this unwanted transfer of heat from the intake manifold and eliminates the 200°F coolant from flowing through it. This reduces boost air temps and increases horsepower.
Constructed out of .062 virgin grade PTFE with a temperature rating of 500°F. CAD designed and ported to ensure there’s no reduction in flow and it’s reusable too!
The JBR Thermal Insulating Throttle Body Gasket Kit is stackable up to 4 thick while utilizing stock mounting hardware.
Kit Includes:
1 Insulating Throttle Body Gasket
1 Brass Barbed Coupler
2 Coolant inlet caps
Free Shipping
The JBR Thermal Insulating Intake Gasket Kit & Thermal Insulating Throttle Body Gasket Kit perform even better when combined with the JBR EGR Block off Kit. What’s the point in re-circulating hot exhaust gas in to a cool intake plenum?
The Following 23 Users Say Thank You to JBR For This Useful Post:
atvfreek (08-18-2011), bazzarino (10-23-2011), Black Metal (08-19-2011), Ckmazdaspeed3 (09-04-2011), Dash08 (08-19-2011), daztdMS6 (08-18-2011), Easter Bunny (08-22-2011), Enki (09-05-2011), HaXiR (01-28-2015), helmetface (09-03-2011), JacksonMS30 (08-31-2011), jracer (09-02-2011), karl-hungus (08-29-2011), kunfu (08-19-2011), littleloogy (11-14-2015), Monotonous ONE (08-21-2011), RayRay (02-10-2012), shadesofgray19 (08-19-2011), Sid3wayS (11-01-2011), SLOWHATCH (08-21-2011), TexasSpeed3 (08-29-2011), wolly6973 (08-18-2011), zxhoya (05-10-2013)
 Old 08-18-2011, 10:00 AM   #2
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
So for the TB bypass you just hook the 2 coolant lines together with the barb?
 Old 08-18-2011, 10:04 AM   #3
dgus429's Avatar
Posts: 189   (View Stats)
dgus429 has a reputation beyond reputedgus429 has a reputation beyond reputedgus429 has a reputation beyond reputedgus429 has a reputation beyond reputedgus429 has a reputation beyond reputedgus429 has a reputation beyond reputedgus429 has a reputation beyond reputedgus429 has a reputation beyond reputedgus429 has a reputation beyond reputedgus429 has a reputation beyond reputedgus429 has a reputation beyond repute
Looks good jamie!!
dgus429 is offline   Reply With Quote
 Old 08-18-2011, 10:09 AM   #4
Yep, and cap the open coolant ports on the throttle body.
 Old 08-18-2011, 10:10 AM   #5
myt_tuf1's Avatar
Posts: 256   (View Stats)
myt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the world
Can you buy the bypass separate, or does it have to be with the TB TIG?
Prosport Mech Boost Gauge|Jbarone SSP/Bushings|CS SRI/TIP/RSB/RP|H&R Springs|Koni Yellows|Cobb FMIC/AP|Denso ITV22|Torque Solutions RMM|SPC Camber Links|Enkie RPF1 17x9 +45 w/Continental DWS Extreme Contact 235/45-17|SURE IM/TB TIG|CP-e HPFP|Grimspeed ECBS|DO Stage 2 w/100% Meth|MD OCC
myt_tuf1 is offline   Reply With Quote
 Old 08-18-2011, 10:25 AM   #6
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
this is exactly how i did my coolant bypass
i think my barb is too small though...i bought 2 just in case...gotta try the other
 Old 08-18-2011, 08:05 PM   #7
laxplayermjd's Avatar
Posts: 779   (View Stats)
detailed instructions are a must, or people will be cracking their manifold left and right as they did with the sure tigs. people have a tendency to overtorque as well
laxplayermjd is offline   Reply With Quote
 Old 08-18-2011, 08:54 PM   #8
daztdMS6's Avatar
Posts: 214   (View Stats)
daztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond repute
I'm so getting one of these.....TB. When are they going on sale? lol
MazdaSpeed 6
DashHawk, CorkSport TIP & SRI, CorkSport TMIC, SU RMM, CPE rear diff mount, Perrin EBCS, TurboSmart BPV, TWM Stage 2 STS + metal bushings, Denso ITV-22, SM OCC, JBR EGR deletion & TIG, silicone boost tubes, Bilstein HD shocks, LED light bulbs, TRS clear projectors, 35W DDM Tuning HID foglights, Hawks HPS brake pads, Amsoil in the rear diff, pto & trans, factory navi, XCarLink USB.
daztdMS6 is offline   Reply With Quote
The Following User Says Thank You to daztdMS6 For This Useful Post:
JBR (08-19-2011)
 Old 08-19-2011, 07:13 AM   #9
They're on sale now.
Thermal Insulating Gasket Kits
Black Metal (08-19-2011), Dash08 (08-19-2011), daztdMS6 (08-19-2011)
 Old 08-19-2011, 09:11 AM   #10
kunfu's Avatar
Posts: 467   (View Stats)
kunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the world
Groans: 56
Oh damn how did I miss this post. I have a question though, whats the benefit of selling them as stackable and not just making the thickest one possible that the stock components would allow?
Speed 3 2007:
NATOR NY mod. SURE SRI and TIP, OBX Test Pipe, SURE RMM, KMD Internals, JBarone SSP, Koni FSD's,Solid shifter bushings, Cobb AP, Stainless brake lines, EGR delete, OCC, HIDs, IV-22's, Turbo timer.
kunfu is offline   Reply With Quote
The Following 2 Users Say Thank You to kunfu For This Useful Post:
Dash08 (08-19-2011), JBR (08-19-2011)
 Old 08-19-2011, 09:23 AM   #11
That's a really good question.
The cost of raw PTFE in 1/4" thickness is very, very expensive; like $15-$1800.00 per 4x8 sheet. Stamping costs are increased as well. So the cost to the consumer would be too high and the gains in performance are not significant enough that the majority of guys would really benefit from it. Hope that makes sense.
Thanks,
Jamie
Broxer (10-12-2011), Dash08 (08-19-2011), neotide87 (10-05-2011)
 Old 08-19-2011, 09:27 AM   #12
kunfu's Avatar
Groans: 56
Thanks,
Jamie
Makes perfect sense. Thanks for keeping the cost reasonable.
Speed 3 2007:
 Old 08-19-2011, 09:47 AM   #13
ScarMS3's Avatar
Posts: 2,088   (View Stats)
Groans: 97
so what would be the point of capping off the tb, after the bypass of course....i did this with a spare piece of 1/4 inch hard line i had, but didnt cap the coolant barbs.
 Old 08-19-2011, 11:43 AM   #14
Just to keep crap out.
thanox2 (08-21-2011)
 Old 08-19-2011, 02:52 PM   #15
daztdMS6's Avatar
Wink
No no, sale price...cheaper. lol. I don't need it now, but I'll waiting for it to have a special sale price.
Mx52star likes this.
MazdaSpeed 6
 Old 08-19-2011, 03:10 PM   #16
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
Quick question I'm sure some people might wonder...
Will these offer the same performance for a mild daily driver as for a fully bolted, BT motor?
By mild, I mean a few bolt ons and maybe a tune.
Or, would you need an aftermarket IC to really get the full effects?
this forum serves 2 purposes
The Following User Says Thank You to Dash08 For This Useful Post:
zatara (08-19-2011)
 Old 08-21-2011, 04:57 PM   #17
Bump! I missed this thread somehow, and I'm forever on the forums.
Jbarone ftw.
86AmishMs3 (08-29-2011), Monotonous ONE (08-21-2011), TexasSpeed3 (08-29-2011), Vader (08-22-2011)
 Old 08-22-2011, 11:36 AM   #18
I think every little bit helps regardless of the amount of mods.
86AmishMs3 (08-29-2011), Dash08 (08-22-2011), Monotonous ONE (08-22-2011), zatara (08-22-2011)
 Old 08-22-2011, 11:41 AM   #19
asall667's Avatar
Posts: 1,017   (View Stats)
asall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the world
Groans: 56
Groaned at 37 Times in 18 Posts
so in order to take full advtange, you would have to buy each gasket x4 and stack them on top of each other?
2007 CBM MS3 GT 66K
Mods:
--Cobb SF SRI--Corksport TIP-- Speed Daddy FMIC Piping w/ TR8 Core--CPE 75A RMM--Test Pipe--Both res delete--TWM Short Shifter--Custom Fabric wrapped A pillars & Side Pillars--Gunmetal PC Genpu Wheels--Mazdaspeed Red Calipers (front & rear)--Laminx Fog Overlays--Foglight Mod--3M Gloss Black Roof--Custom Mudflaps--Evil Flying M--CPE Triple Gauge Pod--Propsort Boost-Oil Temp-Oil Pressure Gauges--Prosport Sammich Plate--SU Oil Spin On Conversion--Magnetic Drain Plug--Raceland Coilovers--SPC Rear Camber Arms--15MM H&R Spacers--Hawk HPS pads--Turbosmart Plumb Back BPV----
New VVT as of 50K miles Thanks Young Mazda
New K04 Turbo as of 57K miles Thanks Young Mazda
asall667 is offline   Reply With Quote
 Old 08-22-2011, 11:51 AM   #20
No...you see the most benefit with one and a little better with 2. I only tested with 2 and I know you can stack 4, so my assumption is there will be some better performance with 4.
 Old 08-28-2011, 09:33 PM   #21
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
You need to stop coming out with stuff after I've already bought,bad timing! Already have the SURE's, but I'll buy your egr blockoff.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
The Following User Says Thank You to 86AmishMs3 For This Useful Post:
rfinkle2 (08-29-2011)
 Old 08-29-2011, 07:40 AM   #22
TRex's Avatar
Posts: 3,139   (View Stats)
should we anticipate manifold cracking problems that have plagued all of these gaskets?
 Old 08-29-2011, 07:46 AM   #23
Groans: 819
one would assume that JBR has learned from the SURE fiasco and complete dropping of the ball and fucking of atleast a dozen or so couches to include actual directions for this peice.
The Following 3 Users Say Thank You to Monotonous ONE For This Useful Post:
Dash08 (08-31-2011), JBR (08-30-2011), rfinkle2 (08-29-2011)
 Old 08-29-2011, 07:56 AM   #24
86AmishMs3's Avatar
Groans: 338
With SURE it's not really a product problem, SURE should have included directions for the slow. When you install a gasket that thick you can definately tell that fuel rail bracket does not line up.
But at JBR's piece, are you including a lower spacer like SURE does. If people use two of these gaskets and crank the bottom bracket on the manifold down are customers going to get cracked manifolds. Just don't want your customer service blemished by something that is really finicky and fragile to install.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
AlsMS6 (05-28-2016)
 Old 08-29-2011, 07:59 AM   #25
If you follow my instructions exactly, especially the part about loosening the fuel rail cover and the torque specs you will have no issues.
Thanks,
Jamie
The Following 7 Users Say Thank You to JBR For This Useful Post:
aromig (06-11-2014), Dash08 (08-31-2011), Easter Bunny (08-29-2011), helmetface (09-03-2011), karl-hungus (08-29-2011), rfinkle2 (08-29-2011), TRex (08-29-2011)
 Old 08-29-2011, 07:36 PM   #26
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
jamie, how about a discount for buying both tigs? your detailed instructions having me finally wanting to buy them. i still have to install your egr block off kit.
 Old 08-29-2011, 07:53 PM   #27
Stealth01's Avatar
Posts: 6,910   (View Stats)
Groans: 201
I heard that too....:p
Stealth01
2006 Mazdaspeed6 GT
 Old 08-29-2011, 09:23 PM   #28
Groans: 819
do it bro...its worth it
i refuse to believe that it doesnt make a substantial difference
and if you have fucked with the intake mani before at all then its an easy install...otherwise take your time and take it slow
oh...and fuck you stealth! why barb small? cause genpu?
Stealth01 (08-31-2011)
 Old 08-31-2011, 08:03 AM   #29
patrick failman
Groans: 74
i pulled the trigger on both. interested to see how much the charge temp drops.
 Old 08-31-2011, 05:44 PM   #30
I <3 your mom
Dash08's Avatar
Groans: 293
Post results after DH reading.
 Old 09-02-2011, 05:01 PM   #31
patrick failman
Groans: 74
step # 24 (loosen rear fuel rail cover bolts)... how much do you loosen them and you don't re-tighten them, correct? i'm doing this over the weekend and don't want to get bnoon'd with incorrect / missing instructions.
The Following User Says Thank You to karl-hungus For This Useful Post:
daztdMS6 (12-11-2011)
 Old 09-02-2011, 05:21 PM   #32
86AmishMs3's Avatar
Groans: 338
If i were you I wouldn't even bother putting the two fuel rail cover bolts back in the ones that connect to the manifold.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 09-02-2011, 08:01 PM   #33
You loosen the fuel rail cover enough so it moves around. Then after ALL of the manifold bolts are installed and torqued, INCLUDING both of the front fuel rail cover bolts, you re-tighten the 2 rear cover bolts you loosened in step 24. There is NO need to leave any bolts out if you follow my instructions exactly.
Thanks,
Jamie
daztdMS6 (12-11-2011), karl-hungus (09-02-2011)
 Old 09-02-2011, 08:14 PM   #34
patrick failman
Groans: 74
thanks, jamie!
 Old 09-04-2011, 12:25 AM   #35
stang9779's Avatar
Posts: 1,066   (View Stats)
stang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the world
If I live in a climate that can get cold from time to time, will the TB coolant bypass affect my car?
2010 MS3 Velocity Red w/ Tech Package
Custom FreekTune e85 mix
GTX3071r - Cobb AP - CP-e Big TIP, XcelXL - Hallman PRO RX MBC - Steedspeed exhaust manifold - CS TMIC, CBE, Air Box, Interior LED kit, Mud Flaps - JBR EGR Block off, 88D RMM, 80D PMM, 88D TMM, HSK, RSB, SSP - KMD V2.1 internals - CNT DP - Forge BPV V2 - MD OCC - TWM FSS - NGK LTR7IX-11 - Konig Kilograms 18x8 +45 on 245/40zr18 Hankook V12's - H&R sport springs - SPC RC kit - Aeroforces Dual gauges - DDM tunning HID 35w 6000k - 20% black window tint, clear bra
Future Mods DO stage 2 WMI, Intake manifold of some type.
stang9779 is offline   Reply With Quote
 Old 09-04-2011, 03:51 AM   #36
MSP611's Avatar
Posts: 2,291   (View Stats)
how much for both for a speed6?
In progress:
 Old 09-04-2011, 04:21 AM   #37
86AmishMs3's Avatar
Groans: 338
If it does it takes no time to switch it back. I did remover the tmic to get adequate access but that takes like 5 min.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 09-04-2011, 09:40 AM   #38
stang9779's Avatar
My last car didn't have a coolant in the TB. I don't see why this one does.
 Old 09-04-2011, 10:55 AM   #39
patrick failman
Groans: 74
apollo 13 fail. no one got hurt but mission failure.
good news... got the tb bypass / gasket and egr block off done no problem.
turbo and front of the tb looked good after 30k miles...
inside tb pretty nasty...
Monotonous ONE (09-04-2011)
 Old 09-04-2011, 11:00 AM   #40
Groans: 819
Pretty standard unfortunately
Page generated in 0.58758 seconds with 37 queries
