Like Tree9Likes
 Old 06-27-2013, 05:40 PM   #81
jdm_mica's Avatar
Posts: 525   (View Stats)
jdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the world
Just ordered mine! Excited to see lower temps, now just gotta get that radiator hose and coolant lines away from cold pipe.
Cobb AP (Stratified Tuned)
Corksport Stage 2 intake+recirc tube
Streetunit testpipe
Autotech internals
NGK LTR7Ix-11
Corksport RMM
RX-8s--235/40/18 Bridgestone Potenza RE-760
Stoptech brake kit+Motul RBF600
Whiteline RSB+endlinks
Dominant Engineering camber arms
JBR stage 2 OCC+ EGR delete+intake manifold gasket
HKS turbo timer
Prosport boost gauge+ventpod
Awaiting H&R springs/Koni yelows/ground control bumpstops
jdm_mica is offline   Reply With Quote
 Old 12-01-2013, 09:47 PM   #82
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
So, has anyone had issues with the fuel rail cover bolts not lining up correctly after installing TIGs? @jbarone;
 Old 12-02-2013, 08:06 AM   #83
Did you loosen the cover like indicated in the instructions? Should not be an issue.
 Old 12-02-2013, 07:59 PM   #84
sidekick's Avatar
Groans: 47
The cover had been completely removed, but after breaking the torque on all of the other bolts and fucking with the egr tube, everything went back together without issue.
 Old 02-27-2014, 02:12 PM   #85
redboat's Avatar
Posts: 634   (View Stats)
redboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the world
About to order a IM tig for my new manifold. No one has posted about running more than one Tig except JRB himself, any leaks between the 2 gaskets? ATR graphs?
Also, I had to replace my HPRV about 2 weeks ago, and I've been crusing around without my fuel rail cover any harm doing that?
redboat is offline   Reply With Quote
 Old 08-02-2014, 12:40 PM   #86
akira4978's Avatar
Posts: 23   (View Stats)
akira4978 has a spectacular aura aboutakira4978 has a spectacular aura about
If we stack more than 2 gaskets, we just tighten to spec as normal correct?
akira4978 is offline   Reply With Quote
 Old 08-02-2014, 12:43 PM   #87
Yes.
More than 2 may require longer hardware.
 Old 09-25-2014, 11:26 PM   #88
Hargarbl's Avatar
Posts: 642   (View Stats)
Groans: 51
I'm about to install these on my ms6 after cleaning my valves. My question once you get to torqueing the bolts down, do you just torque them 1-2-3-4-5, or do they need to be done 3-2-4-1-5, or does it just really not matter in this case?
 Old 09-25-2014, 11:29 PM   #89
Please see the install instructions in the support section of our website. The sequence can be found there.
Thanks,
Jamie
Hargarbl (09-26-2014)
 Old 09-25-2014, 11:47 PM   #90
Hargarbl's Avatar
Groans: 51
Thanks,
Jamie
I did look at them, that's why I was asking. I'm so used to being told to start from the center and work out that I just wanted to make sure I wasn't misreading it.
 Old 12-31-2014, 11:00 AM   #91
bfak66's Avatar
Posts: 106   (View Stats)
bfak66 has a reputation beyond reputebfak66 has a reputation beyond reputebfak66 has a reputation beyond reputebfak66 has a reputation beyond reputebfak66 has a reputation beyond reputebfak66 has a reputation beyond reputebfak66 has a reputation beyond reputebfak66 has a reputation beyond reputebfak66 has a reputation beyond reputebfak66 has a reputation beyond reputebfak66 has a reputation beyond repute
Got my TB Coolant Bypass installed along with the TB gasket. Install was easy after i was able to get the extremely difficult to reach worm clamp off the TB boost tube.
bfak66 is offline   Reply With Quote
Page generated in 0.31425 seconds with 26 queries
