 Old 12-27-2011, 12:46 PM   #1
Arrow JBR MAZDASPEED 3 Transmission Motor Mounts in Stock!!
James Barone Racing
Performance Aftermarket Parts & Accessories
Details:
The JBR Transmission Mount is the only Vertically Oriented mount on the market. This mount can and will handle all the abuse you plan to throw at it. From street to strip it’s the only true 1 piece transmission mount for the 07’ - 2012 MAZDASPEED 3.
We’ve replaced the weak cast aluminum transmission perch with .250” plate and a 2.00” solid steel perch; welded not bolted.
The business end of the mount is constructed of .188 steel, CNC press braked plate with chromoly sleeves; welded not bolted.
Custom, Proven Poly Urethane bushings in your choice of 70, 80, and 88 Durometers allow you to choose the amount of stiffness you want to run without sacrificing comfort.
Wheel Hop? What wheel hop? Torque Steer? Gone. When combined with the #1 selling rear motor mounts on the market and the only vertically oriented passenger mount available anywhere, the problems that have plagued the MAZDSPEED 3 are now a thing of the past.
LINK TO PRODUCT PAGE
70 Durometer:
80 Durometer:
88 Durometer:
Hush (12-08-2012), MGM_GT3 (12-27-2011), ms3blackmica (12-10-2012), rolanblack (12-15-2012)
 Old 12-08-2012, 09:36 PM   #2
Kellerspeed3's Avatar
Posts: 2,518   (View Stats)
Kellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the world
Groans: 50
Groaned at 37 Times in 21 Posts
Beautiful piece of engineering, just got mine, now I just gotta get off my butt and take care of business.
2010 Velocity Red w/tech package: Cobb AP, Cobb DP, Tr8L FMIC, Auto Tech internals, BNR S-4 turbo, JBR 3.5 aluminum intake, CPE stage 2 rmm, JBR 80 duro TMM, JBR 70 PMM, JBR SSP and bushings, JBR 5mm spacers, JBR RSB, JBR By Pass Tube, Magna-flow CBE with the "fix", NGK 6510's, JBR EBCS, SSP OCC(now Kozmic), JBR EGR delete, EGR deleted, JBR IM TIG, JBR TB TIG-coolant by-pass, Turbo smart BPV, built block with CP pistons, eagle rods, ported head, pinned cams, shimmed valve springs, Spec clutch stage 3, FordMoCo full syth transmission fluid, Eibach pro kit, ported IM with VCTS delete, ported exhaust mani, Werksracing strut tower brace, TB Performance front traction bar and mid-chassis brace, Corksport adjustable struts and shocks, slotted/drilled rotors, SS brake lines, and lots of TLC. FreekTuned Kotzur built 93/E-85 Prius killa.
Kellerspeed3 is offline   Reply With Quote
 Old 03-21-2013, 02:14 PM   #3
TheFlash's Avatar
Posts: 2,095   (View Stats)
TheFlash is the leader of the worldTheFlash is the leader of the worldTheFlash is the leader of the worldTheFlash is the leader of the worldTheFlash is the leader of the worldTheFlash is the leader of the worldTheFlash is the leader of the worldTheFlash is the leader of the worldTheFlash is the leader of the worldTheFlash is the leader of the worldTheFlash is the leader of the world
Groaned at 33 Times in 30 Posts
The TMM just came in the mail. Thank you good sir! Will be going on when I get a chance. One more mount and the trilogy will be complete!
I drive a Mazda
TheFlash is offline   Reply With Quote
The Following User Says Thank You to TheFlash For This Useful Post:
JBR (03-21-2013)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f493/jbr-mazdaspeed-3-transmission-motor-mounts-stock-100657/
Passenger Side Motor Mount Bolts Broke!! - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 12-14-2012 09:28 PM
Passenger Side Motor Mount Bolts Broke!! - Page 2 - Mazda3Forums.com This thread Refback 09-21-2012 08:48 PM
JBR Mazda 3 and MAZDASPEED 3 Passenger Side Motor Mounts in Stock!! JBR JAMES BARONE RACING 20 03-27-2015 07:42 AM
JBR MAZDA 3/5 & MAZDASPEED 3 Rear Motor Mounts in Stock!! JBR JAMES BARONE RACING 183 11-20-2013 10:36 AM
JBR MAZDASPEED 6 Rear Motor Mounts In Stock!! JBR JAMES BARONE RACING 22 08-28-2013 05:32 AM
Are side motor mounts and transmission mount really necessary? the95z MazdaSpeed 3 - Engine, Transmission & Driveline 38 07-05-2010 03:00 PM
CP-E Motor Mounts for the Mazdaspeed 3 in stock ! kevin@gripgarage.com Mazdaspeed3/6 General Discussion 0 04-24-2009 02:25 PM
Page generated in 0.26090 seconds with 22 queries
