  • 1 Post By nindoja
  • 1 Post By SneakySin
 Old 04-28-2013, 07:18 PM   #1
nindoja's Avatar
Posts: 2,395   (View Stats)
Default JBR Rear Sway Bar review
TLDR; @jbarone; RSB is awesome and does exactly what it should do (reduce understeer).
Installation was a breeze, the directions provided online are all anyone needs to install the RSB correctly.
I was a little nervous changing out the RSB since I do a lot of road course events and didn't want to induce a lot of unmanageable oversteer in a corner. I stuck with the middle setting and was more than impressed with how the car handled.
The first hot session we had, I could immediately tell that the back end wanted to come around more than stock. The great thing was that it was a gradual oversteer. Never once did I feel that the back end was going to snap around when I didn't ask for it to.
I don't have any times for the sessions, but I could definitely tell that the car was faster through the corners than when I had the stock RSB on.
JBR likes this.
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
The Following 9 Users Say Thank You to nindoja For This Useful Post:
ABolewski (04-28-2013), bostongeorge (05-01-2013), galens47 (04-30-2013), JBR (04-29-2013), Keko (04-28-2013), Mauro_Penguin (04-30-2013), MAZ (04-30-2013), Rokusek (04-30-2013), snailD (04-28-2013)
 Old 04-28-2013, 07:46 PM   #2
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
good shit yo
 Old 04-28-2013, 07:59 PM   #3
manila's Avatar
Posts: 1,767   (View Stats)
I have the RSB too and also running it on the medium setting!
'12 MS3 Black Mica w/ Tech
 Old 04-28-2013, 08:28 PM   #4
Kdawg207's Avatar
Posts: 2,389   (View Stats)
Kdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the world
Have it. Love it
~~~NJ Nator OG~~~Then AND Now, Just Better~~~
Kdawg207 is offline   Reply With Quote
 Old 04-29-2013, 06:08 PM   #5
vroom4's Avatar
Posts: 145   (View Stats)
vroom4 has a reputation beyond reputevroom4 has a reputation beyond reputevroom4 has a reputation beyond reputevroom4 has a reputation beyond reputevroom4 has a reputation beyond reputevroom4 has a reputation beyond reputevroom4 has a reputation beyond reputevroom4 has a reputation beyond reputevroom4 has a reputation beyond reputevroom4 has a reputation beyond reputevroom4 has a reputation beyond repute
Groaned at 8 Times in 3 Posts
Oversteer in your ms3? I must be in a different car than you. I have yet to have my car over steer in any circumstance that is not a result of me completely messing up an element.
vroom4 is offline   Reply With Quote
The Following User Says Thank You to vroom4 For This Useful Post:
Crarrs (04-30-2013)
 Old 04-29-2013, 06:39 PM   #6
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
then you're doing it wrong. get a rsb and see if you don't change your tune.
Blue Pu.
 Old 04-30-2013, 09:17 AM   #7
vroom4's Avatar
I have konis on full stiff in the rear and a RSB on full stiff, if it is over steering, lower your rear tire pressure. You can go down to something like 35 # with no roll over and the back will stick like glue.
 Old 04-30-2013, 04:21 PM   #8
Crarrs's Avatar
Posts: 1,662   (View Stats)
It seems you're confusing "proper balance" with "oversteer".
2004 MSM TiGrey
The Following User Says Thank You to Crarrs For This Useful Post:
Nliiitend1 (04-30-2013)
 Old 05-01-2013, 01:33 PM   #9
anavrinIV's Avatar
Groans: 63
I may have misspoken, reading his post again I'm not sure what I was thinking of. I've had liftoff oversteer a couple times in situations I quite badly misjudged but overall I love the balance of my car with the sway bar. I can rocket around corners and never feel like the front of the car is out of its element.
Blue Pu.
 Old 04-29-2013, 06:09 PM   #10
ckMS3's Avatar
Posts: 1,112   (View Stats)
ckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the world
I love mine too.
BNR S3 // E85 Mix // Freektune
348tq/367whp -21.5 psi
Now - 25-26 psi + JBR 3.5 Intake
ckMS3 is offline   Reply With Quote
 Old 04-29-2013, 07:03 PM   #11
motherfnmonsta's Avatar
Posts: 2,308   (View Stats)
Groans: 106
I want one but they are out of red
 Old 04-30-2013, 08:37 AM   #12
Once you go black.....
Alexander (04-30-2013), bostongeorge (05-01-2013)
 Old 04-30-2013, 08:39 AM   #13
SneakySin's Avatar
Posts: 780   (View Stats)
SneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the world
Groaned at 7 Times in 4 Posts
...you'll need a wheelchair...
JBR likes this.
SneakySin is offline   Reply With Quote
The Following 3 Users Say Thank You to SneakySin For This Useful Post:
bostongeorge (05-01-2013), JBR (04-30-2013), Nliiitend1 (04-30-2013)
 Old 04-30-2013, 03:52 PM   #14
Groans: 106
once you gone white you been done right
 Old 04-30-2013, 03:05 AM   #15
allo80's Avatar
Posts: 46   (View Stats)
allo80 has much to be proud ofallo80 has much to be proud ofallo80 has much to be proud ofallo80 has much to be proud ofallo80 has much to be proud ofallo80 has much to be proud ofallo80 has much to be proud ofallo80 has much to be proud ofallo80 has much to be proud ofallo80 has much to be proud of
I have one and loved the bang for buck benefit to my ride. I too have it on the medium setting and have not ventured to the hard setting...crappy rear tyres wouldnt be able to hold on!!!
allo80 is offline   Reply With Quote
 Old 04-30-2013, 09:19 AM   #16
MAZ
MAZ's Avatar
MAZ is the leader of the worldMAZ is the leader of the worldMAZ is the leader of the worldMAZ is the leader of the worldMAZ is the leader of the worldMAZ is the leader of the worldMAZ is the leader of the worldMAZ is the leader of the worldMAZ is the leader of the worldMAZ is the leader of the worldMAZ is the leader of the world
LOVE my jbr rsb.....made a HUGE difference at the dragon.
What does matter is: length times diameter, plus weight over girth, divided by angle of the tip squared.
"Feel how hot I am through my pants." (Singleflusher, MNM 2013)
"My pants are so hot they're melting?!" (Jenneh, EMWNM 2013)
"Heeeeeeeeeeeey!!! Boooooooooooooobs." (NATOR National, ENM 2014)
"SCUUUUMMMMMBAAAAAAAAGGGGGGG!" (NATOR National, ENM@MDC 2015)
MAZ is offline   Reply With Quote
 Old 04-30-2013, 10:16 AM   #17
Mauro_Penguin's Avatar
Posts: 1,997   (View Stats)
Groans: 171
I just put mine on a couple of weeks ago too, didn't notice a huge difference on the middle setting. Driving around town, figured I would definitely notice it when making u-turns but it wasn't anything crazy. So a few days ago I had to take the highway, holy crap!!!!!!!!! I did the trilogy at the same time so I figured I would ride it a little quick and damn the back feels so tight now! Before it would kinda float, but now at highway speeds I definitely felt the back was sharper and more predictable when turning the car. Great easy simple mod! Can't wait to get the jbr camber arms and put some coilovers on it to really see how this thing can handle! Thanks Jamie for all the great products you make, and continue to develop!
 Old 04-30-2013, 06:35 PM   #18
nindoja's Avatar
I guess I should clarify. I was experiencing liftoff oversteer that was very controllable and easy to induce.
On the stock RSB, it liftoff oversteer was easy enough to encounter but it wasn't as controllable as with the JBR rsb.
True Red 2009 MS3
Critical Stats:
// 305whp/352tq
Progress Technology Rear Sway Bar Review Dash08 MazdaSpeed 3/6 - Suspension & Brakes 30 10-13-2014 11:17 AM
Rear diff mount and rear sway bar bcmps MazdaSpeed 6 - Engine, Transmission & Driveline 16 03-25-2014 06:33 PM
Rear sway Matx MazdaSpeed 3/6 - Suspension & Brakes 2 03-01-2011 12:16 AM
JBR (James Barone) Rear Sway Bar Review rlarsen462 2010 MS3 - Suspension & Brakes 9 02-15-2011 08:12 PM
Page generated in 0.40020 seconds with 33 queries
