Like Tree4Likes
 Old 03-07-2012, 01:37 PM   #41
J'sSpeed3's Avatar
Posts: 722   (View Stats)
J'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the world
Groans: 76
Originally Posted by Whiteboy View Post
See, I told you so
Haha I know thanks to everyone for the help
| 2007 True Red Mazdaspeed 3 GT |
GO: | SURE SRI V2 | COBB TIP | CP-E FMIC | Corksport DP | Corksport CBE | Cobb AP RICHTUNED | Autotech Internals | SURE RMM | Denso ITV-22's | Turbosmart BPV |
SHOW: | Evo X Enkei's 18x8.5 +38 Painted CWP| Nitto Motivo's 225/40 | BC Racing Coilovers | SPC Camber Arms | DDM 3000k fogs | CPE Tow Plate |
J'sSpeed3 is offline   Reply With Quote
The Following 2 Users Say Thank You to J'sSpeed3 For This Useful Post:
JBR (03-12-2012), Whiteboy (03-07-2012)
 Old 04-10-2012, 05:03 PM   #42
Ray Danger 2020's Avatar
Posts: 768   (View Stats)
Ray Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the world
[QUOTE=Whiteboy;1292203]I thank the lord above for creating you and your knob!
QUOTE]
^^^ Giggity giggity goo
Power: BORG WARNER S360 TURBO w/ .70A/R SINGLE SCROLL HOTSIDE HTP 3.5" WHALE PEEN TIAL 44mm EWG (red) FJ PERFORMANCE TUBULAR MANIFOLD w/ VBAND EWG OUTLET/VBAND CATLESS DP/VTA EWG TUBE/FMIC PIPING - HOTSIDE ROUTED UNDER CAR/AN OIL FEED/DRAIN LINES ULTIMATE RACING CBE TREADSTONE TR1035 FMIC CORE AUTOTECH HPFP INTERNALS COBB TUNING ACCESSPORT GO FAST BITS TMS RESPONS BOV NGK LTR7IX-11
Handling: JAMES BARONE RACING RSB/88aRMM/88aTMM/80aPMM SONIC TUNING S3 COILOVERS STOPTECH SPORT STOP CROSS DRILLED ROTORS BRIDGESTONE POTENZA RE-11 235/40/18 SPC REAR CAMBER ARMS
Extra Shit:SURE SHORTCUT/COUNTERSHIFT/ANCHORS JAMES BARONE RACING SPHERICAL HEAVY KNOB/51r BATTERY TRAY/STAGE II OCC CORKSPORT LED REAR BUMPER REFLECTORS/LED INTERIOR KIT/URETHANE EXHAUST HANGERS/GAS HOOD PROP STRUTS BOSCH 3-BAR MAP SENSOR BITWISE PnP MAP HARNESS COBB TUNING 3-PORT EBCS DDM TUNING 8000K LOWS/3000K FOGS O.Z. RACING ULTRALEGGERAS 18x8 +48 MUTEKI SR48 OPEN ENDED LUGS NUTS ARP 100-7708 EXTENDED WHEEL STUDS HELLA SUPERTONES RALLY ARMOUR MUDFLAPS (BLACK WTH RED LETTERS)
K04 POWER FIGURES
277HP/325TQ SixTuned On 93
314HP/356TQ Rfinkle2 Tuned With 33% Corn
S360 POWER FIGURES
365HP/356TQ Purple Drank Tuned ON 93
421HP/392TQ Purple Drank Tuned w/ 3 GAL E85 MIX
NUMBERS LIMITED BY STOCK BLOCK ON STOCK FUELING TILL SPRING
Ray Danger 2020 is offline   Reply With Quote
 Old 04-10-2012, 09:35 PM   #43
Whiteboy's Avatar
Posts: 2,032   (View Stats)
Whiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the world
Groans: 142
[quote=Ray Danger 2020;1353705]
QUOTE]
You must love dick with a quote like that because I'll give you my, "Giggity Giggity Goo"!!! Again, this is about Jamie's knob...doesn't mean I won't give you mine
~My Mod List: ETS TMIC; CP-E SRI; COBB TIP; CP-E DP; CP-E RMM; CP-E Safe Seals; ITV-22's; GHL SS CBE; TWM STS w/bushings; Autotech HPFP Internals; AP (Stratified by Lex); Matt Damond OCC; CP-E Triple Gauge Pod w/ Prosport Premium Boost, AFR, and Oil Pressure Gauges; JBR Eliminator Shift Knob~
Whiteboy is offline   Reply With Quote
JBR SSP + BUSHINGS + HEAVY KNOB = D08SPEED3 MazdaSpeed 3 - Engine, Transmission & Driveline 1 07-22-2011 06:51 AM
Page generated in 0.25154 seconds with 22 queries
