Like Tree78Likes
 Old 11-20-2012, 06:08 PM   #41
agentgordon27's Avatar
Posts: 560   (View Stats)
Originally Posted by MadOzodi View Post
I'm hugely tempted by this trilogy mount package (but in 70a duro). I've been calculating my savings on different parts and combinations of parts all effin day!
Doooo it, except I would do 70 on the sides and 88 for the RMM, I'm basing that on no scientific data, just wish someone else could tell me what its like.
Stock as fook.
 Old 11-20-2012, 06:49 PM   #42
BigRedSpecial's Avatar
Posts: 1,436   (View Stats)
Groans: 56
Originally Posted by agentgordon27 View Post
Doooo it, except I would do 70 on the sides and 88 for the RMM, I'm basing that on no scientific data, just wish I someone else could tell me what its like.
That's my intended route, although I really should stop thinking like a pussy and get the 80s.
Needed: Driver mod
 Old 11-20-2012, 08:31 PM   #43
Ms3_Miami's Avatar
Posts: 3,185   (View Stats)
Ms3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the world
Groans: 55
get the 80 PMM, 88 TMM and the dogbone..Vibes are not all that crazy and they fade away after a couple hundred miles.
08 Black Mica Ms3~full bolt ons/Nishan Tuned-Sold
NATOR FL
Ms3_Miami is offline   Reply With Quote
 Old 11-20-2012, 08:51 PM   #44
Boatcop1's Avatar
Posts: 256   (View Stats)
Boatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the world
Get the dog bone!!! I had an 80 and sold it for a Dog bone and couldn't be happier! Keep in mind I commute 100 miles a day in my car and it ain't no thang!! Dog bone or GTFO!
Boatcop1 is offline   Reply With Quote
 Old 11-20-2012, 09:00 PM   #45
Groans: 56
Have the dogbone. I'm probably the biggest dogbone whore on this site. I was referring to the side mounts.
Needed: Driver mod
 Old 11-20-2012, 09:00 PM   #46
MadOzodi's Avatar
Posts: 686   (View Stats)
Srsly?
@jbarone; can you mix and match like that in the Trilogy Mount Packages?
I don't ever plan on going back to the drag strip with the MS3. Mod-wise after all the Black Friday purchases, I'll have Cobb SF, TIH, TMIC, BPV, Upgraded HPFP internals, AP, and Test Pipe. Still don't know if I'm going to use the highest Stage 1 OTS map or the lowest Stage 2 OTS map.
Ugh, now you guys have me second guessing myself...HEPL!
07 COSMIC BLUE MS3 GT
MadOzodi is offline   Reply With Quote
 Old 11-20-2012, 09:52 PM   #47
Ms3_Miami's Avatar
Groans: 55
get the highest duro for both mounts. You get used to it after a while and u get the added stiffness for a little more vibes. Its up to u tho
NATOR FL
 Old 11-20-2012, 09:56 PM   #48
lilred's Avatar
Posts: 5,792   (View Stats)
I look at it this way... If its too much for you than its an easy resell and then go softer
tapafuck
2010 velocity red mica ms3
AP/AT internals
JBR SSP/bushings
JBR RMM
JBR stage 2 OCC
CS test pipe
 Old 11-20-2012, 10:04 PM   #49
Naaman's Avatar
Posts: 344   (View Stats)
Naaman is the leader of the worldNaaman is the leader of the worldNaaman is the leader of the worldNaaman is the leader of the worldNaaman is the leader of the worldNaaman is the leader of the worldNaaman is the leader of the worldNaaman is the leader of the worldNaaman is the leader of the worldNaaman is the leader of the worldNaaman is the leader of the world
Those mounts... That RSB... And now I'm tempted to trade in my CPE RMM for a new, shiny JBR one. Decisions, decisions, but exciting no matter what!
Naaman is offline   Reply With Quote
 Old 11-20-2012, 10:37 PM   #50
Keko's Avatar
Posts: 1,455   (View Stats)
Groans: 107
Groaned at 9 Times in 9 Posts
Srsly?
You can probably run the appropriate Stage2 OTS, I was able to. You should get an e-tune too
2012 MS3
Stratified 91
MadOzodi (11-20-2012)
 Old 11-21-2012, 06:12 AM   #51
We can mix and match mounts in the trilogy package. Just make a note in the comments during checkout and let us know what you want
Some guys do the 88 trilogy with a 70 PMM, 88 TMM and 88 rear.
Some guys do the 88 trilogy with a 80 PMM, 70 TMM and 88 rear.
Some guys do the 80 trilogy with a 70 PMM, 80 TMM and 80 rear.
Choose the appropriate package with the rear mount you want and let us know what sides you want in the notes during checkout.
Discuss......
CWP_MS3 likes this.
CWP_MS3 (11-21-2012), Kyle Undefined (11-21-2012), MadOzodi (11-21-2012), Pseud0logik (11-21-2012)
 Old 11-21-2012, 08:15 AM   #52
 Old 11-21-2012, 12:02 PM   #53
Pseud0logik's Avatar
Posts: 2,042   (View Stats)
Pseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the world
Groaned at 34 Times in 31 Posts
The PMM is the one that produces the most vibes, so that's why people go for the softer duro on that one correct?
Pseud0logik is offline   Reply With Quote
 Old 11-21-2012, 12:24 PM   #54
Yes, it's the noisiest not necessarily the mount that creates the most vibration.
 Old 11-21-2012, 12:33 PM   #55
Groans: 56
I've heard you advise against the PMM and BSD before; do you still feel the shaft delete and the 70a would be too rough?
Needed: Driver mod
 Old 11-21-2012, 12:47 PM   #56
It doesn't bother me all that much but some feel it's too harsh. Kinda depends on your tolerance and your performance goals.
BigRedSpecial (11-21-2012)
 Old 11-21-2012, 12:47 PM   #57
Rampage's Avatar
Posts: 91   (View Stats)
Rampage has much to be proud ofRampage has much to be proud ofRampage has much to be proud ofRampage has much to be proud ofRampage has much to be proud ofRampage has much to be proud ofRampage has much to be proud ofRampage has much to be proud of
I just purchased the 80 PMM and couldn't be any happier.
I will be purchasing the 88 RMM dogbone... can not wait!
Rampage is offline   Reply With Quote
 Old 11-21-2012, 12:53 PM   #58
These are on sale as is everything else. One of my personal favorite mods.
08.5MS3 (11-22-2012)
 Old 11-21-2012, 01:09 PM   #59
exentix's Avatar
Posts: 1,568   (View Stats)
Groans: 46
Yes the tb gasket and coolant bypass surprised me. I really didn't think it would be a noticeable difference, but it was. And pretty cheap. Get it while its hot guys. It's all good stuff couldn't be any happier with the parts I'm currently running
 Old 11-21-2012, 01:46 PM   #60
Keko's Avatar
Groans: 107
Do you have any specifics on improvement?
2012 MS3
Stratified 91
 Old 11-21-2012, 01:54 PM   #61
I've seen, and others have also reported 11-13 degree cooler BAT's after installing the set.
 Old 11-21-2012, 02:07 PM   #62
I think this sale may very well be the death of me.....
exentix (11-21-2012), jeopardy98 (11-22-2012), Pseud0logik (11-21-2012)
 Old 11-21-2012, 02:45 PM   #63
Keko's Avatar
Groans: 107
So many parts... so little monies.
Considering TIGs, OCC, RSB, PMM
@jbarone; The coolant bypass makes it skip the TB obviously. I guess the TB doesn't need coolant? Can you give a few details on this please? (im sure its been answered before but couldnt find anything right now)
2012 MS3
Stratified 91
JBR (11-21-2012)
 Old 11-21-2012, 02:52 PM   #64
MadOzodi's Avatar
The product page on his website gives a pretty good description of things...at least, good enough for me to have just added it to my cart, LOL!
 Old 11-21-2012, 02:52 PM   #65
As I understand it, the coolant is to prevent the throttle plate from freezing up or frosting in super cold climates. I've never heard of this happening with the bypass. I know plenty of our friends to the north running these in -30 degree temps have never reported any issues either.
Hope this helps.
danieldolina70 (11-22-2012), Keko (11-21-2012), MadOzodi (11-21-2012), uncorked11 (11-23-2012)
 Old 11-21-2012, 03:11 PM   #66
Keko's Avatar
Groans: 107
I think I'm gonna cave and buy all of that... Can't help it
Good thing is after this order I won't have many mods left to spend money on, aside from making big power.
2012 MS3
Stratified 91
JBR (11-21-2012)
 Old 11-21-2012, 03:45 PM   #67
Boost Tubes....T-Bolts INCLUDED!!
 Old 11-21-2012, 03:54 PM   #68
exentix's Avatar
Groans: 46
thats my understanding also. the only note i have for the tb coolant bypass is to make sure when you put the barb in the coolant lines to keep them together, make sure it is not going to hit the fan blades. ask me how i know
The Following 3 Users Say Thank You to exentix For This Useful Post:
DuoofDeath1 (11-21-2012), JBR (11-21-2012), Keko (11-21-2012)
 Old 11-21-2012, 10:12 PM   #69
DuoofDeath1's Avatar
Posts: 393   (View Stats)
DuoofDeath1 is the leader of the worldDuoofDeath1 is the leader of the worldDuoofDeath1 is the leader of the worldDuoofDeath1 is the leader of the worldDuoofDeath1 is the leader of the worldDuoofDeath1 is the leader of the worldDuoofDeath1 is the leader of the worldDuoofDeath1 is the leader of the worldDuoofDeath1 is the leader of the worldDuoofDeath1 is the leader of the worldDuoofDeath1 is the leader of the world
Code doesn't work yet...I stayed up for nothing, well i was up anyway but still.
DuoofDeath1 is offline   Reply With Quote
 Old 11-22-2012, 12:43 AM   #70
kolosok17's Avatar
Posts: 1,104   (View Stats)
kolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the world
Groans: 47
Code seems to work now! Picked up my first mods - the 88a RMM, mud flaps, and solid shift bushings. Thanks!!
2012 CWP Non-Tech MS3
JBR SSB, Mazda Rear Bumper Guards, JBR Mud Flaps, JBR 88a RMM, Mazda All-Weather Floor Mats,
COBB AP V2B, JBR RSB with Tru-Torsion brackets, Autotech Internals, CorkSport SRI+TIP, JBR Stage 2 OCC,
Mazda Rear Cargo Tray, Stratified S-OTS+ Stage 1 Map, NATOR NorCal Sticker
kolosok17 is offline   Reply With Quote
The Following User Says Thank You to kolosok17 For This Useful Post:
JBR (11-22-2012)
 Old 11-22-2012, 05:08 AM   #71
Yeah it is working fine now. Grabbed a 80 duro rmm, rsb, and a set of o-rings for my shift knob. Now the worst part begins...the wait until I receive my new toys. Lol
The Following User Says Thank You to DuoofDeath1 For This Useful Post:
JBR (11-22-2012)
 Old 11-22-2012, 06:24 AM   #72
Neutral  -1 score
The codes began working at midnight central time and will stop working at 11:59PM CST on Sunday. I have set the codes to have unlimited uses. SOOOoooo, I'm thinking about throwing some things on special once and a while so you can even get better discounts. For example The billet 70 and 80 duro mounts are on sale for $110, -10% that's $99.00!
Check back often. I may have some other things up my sleeve as well.
Happy Thanksgiving Turkeys!!
fooqr likes this.
Keko (11-22-2012), kmpeeps (11-22-2012), uncorked11 (11-23-2012)
 Old 11-22-2012, 08:03 AM   #73
Wheel spacers, 5mm set of 4 on special now Reg $80 now $70 + discount.
 Old 11-22-2012, 08:22 AM   #74
Damn, I figured it was a timezone issue. And the motor mount deal was the main reason I bought directly from you. Nothing sells parts like stacking discounts. Thanks again for the already sweet deals and can't wait to see what else you post. I feel like my PayPal BillMeLater is going to be hit again. Lol
happy thanksgiving to everyone
JBR (11-22-2012)
 Old 11-22-2012, 09:00 AM   #75
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
I wants bsd!!!! But now I want to wait and see if you put it on sale. Damn you Jamie Im sapposed to be with the family today not constantly refreshing this page.
TEAM LUXURY
 Old 11-22-2012, 09:06 AM   #76
New Product Release on Special NOW!! JBR Dry Wraps reg. $25.00 now $20.00 + discount.
BigRedSpecial likes this.
 Old 11-22-2012, 10:07 AM   #77
jeopardy98's Avatar
Posts: 1,920   (View Stats)
jeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the world
I just wanted to pop in and say thank you for the killer deals and the great products you provide our community. I have quite a few of this guy's parts on my car and he has ALWAYS had top quality products and outstanding customer service. I'll be ordering up my catch can and dry wrap before the end of the weekend.
Bone Stock 2012 BM Non-Tech for 2500 miles. (250 whp/265 wtq Moore Auto). Currently: K04/Cobb AP/AT internals/Magnaflow CBE/M2 DP/Cobb SRI/HTP TIP/CS boost tubes/CS recirc hose/TS BPV/SU TMIC/GS EBCS/JBR EGR delete/Coolant bypass/Thermal TB gasket/NGK 6510's/JBR SSP/JBR Knob/JBR 88 RMM/JBR SSB/DDM 35w 5000k HIDs/PAC Gateway iPod integration and Sirius. (301whp/360wtq Moore Auto). Finklefied Hypnotic tune. 14.1@106 Mason Dixon- Driver mod needed.
jeopardy98 is offline   Reply With Quote
The Following 2 Users Say Thank You to jeopardy98 For This Useful Post:
JBR (11-22-2012), uncorked11 (11-23-2012)
 Old 11-22-2012, 01:10 PM   #78
danieldolina70's Avatar
Posts: 366   (View Stats)
danieldolina70 is the leader of the worlddanieldolina70 is the leader of the worlddanieldolina70 is the leader of the worlddanieldolina70 is the leader of the worlddanieldolina70 is the leader of the worlddanieldolina70 is the leader of the worlddanieldolina70 is the leader of the worlddanieldolina70 is the leader of the worlddanieldolina70 is the leader of the worlddanieldolina70 is the leader of the worlddanieldolina70 is the leader of the world
I have almost everything you make but with the 10% off now ill have it all.....
[SIGPIC][/SIGPIC]//GT3076r EWG///GUARDIAN ANGEL///JMF INTAKE MANI///COBB EBC///LONG TUBE MANI///RICH TUNE///CPE PRE FILTER///CPE INTAKE and TIP COMBO///CPE TMM AND RMM///TURBO SMART BPV///CPE BIG ASS FMIC WITH CRASH BAR///COOLANT BYPASS///NGK-1 PLUGS///CPE HPFP/// LONG TUBE DP///CPE TRITON CBE///SURE PMM///SURE RSB///AEROFORCE GUAGES///JBR OCC///RALLY ARMOR FLAPS///6000 k HID LOWS AND FOGS///YELLOW-SPEED COILOVERS///KONIG WHEELS WITH 245/40/18 MICHELIN PS2 TIRES /KILLER BUILT TRANS WITH ACT 6 PUCK AND PRO LIGHT FLYWHEEL ////////// NATOR DELAWARE///////////////////////
STICKERS WON'T MAKE YOUR CAR FASTER .BUT HANGING WITH GUYS WITH NATOR STICKERS WILL
321 hp 359 tq Nator Pa. DYNO DAY 10/13/12 WITH KO4 TURBO
369 hp 368 tq NO meth or e85 ... MNM dyno day ......
danieldolina70 is offline   Reply With Quote
The Following User Says Thank You to danieldolina70 For This Useful Post:
JBR (11-22-2012)
 Old 11-22-2012, 03:01 PM   #79
Ok folks I'm up from my nap and ready to give something away. All orders placed using one of the flock codes are eligible. So if you've not placed and order yet you have one hour to become eligible for the 1st of several giveaways. Details of what and how to win coming at 5pm CST. Stay tuned Turkey's.
danieldolina70 (11-22-2012), Pseud0logik (11-22-2012), Sid3wayS (11-22-2012)
 Old 11-22-2012, 03:43 PM   #80
15 minutes!
BLACK FRIDAY JP@edgeautosport.com EdgeAutosport.com 42 11-25-2011 07:01 PM
Putting It In Perspective: Largest bankruptcies in U.S. history displayed graphically Haltech Automotive News 0 06-12-2009 12:50 PM
Page generated in 0.56788 seconds with 37 queries
