Like Tree15Likes
  • 6 Post By Downmented
  • 1 Post By JBR
  • 1 Post By Downmented
  • 3 Post By Downmented
  • 2 Post By the public enemy
  • 1 Post By Rokusek
 Old 03-22-2013, 03:23 PM   #1
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
Default MS6 TMM & PMM
First off, thank you to @jbarone; for the opportunity to test these mounts for the MS6.
Some of you may have already seen my review for the transmission mount for the MS6, but here is a recap as it will lead directly into the initial impressions and functionality of the passenger mount.
80 Duro Transmission mount, install was pretty straight forward and a bit easier for me than most since my battery has been relocated to the rear, so that was one step less than most will require. Initially i thought something was wrong because of hearing the transmission whine. After about 400-500 miles the sound and vibes decreased significantly, although with just the upgraded TMM, you will still feel the vibes at idle and hear the whine when in low rpms going through the gears.
70 Duro Passanger mount, again, install was simple and personally didnt take me any longer than 45 minutes to swap the old out with the new. Hopped in the car and the cold start was intense. My hood was rattling like crazy on the latch so i personally stuck a rag under there until it stopped. Once at normal operating temp everything was fine and the vibes decreased even more with the combo of the TMM & PMM.
When going through gears the motor definitely feels allot more stable and less sloppy. I thought that just the TMM was an improvement until i had the combo of the two.
All in all the trio of JBR mounts for the MS6 are a must have, they should be bought as a trio in order to feel the true advantage of being fully mounted.
And of course, pics for all to enjoy.
I would like to add that for the passenger mount, there will not be welds on the production run of this part. It will be a solid 1 piece unit.
Thanks,
-Chris
TiGraySpeed6, JBR, ckMS3 and 3 others like this.
700HP CLUB
11.479@124mph
#DIX
The Following 19 Users Say Thank You to Downmented For This Useful Post:
agentgordon27 (03-22-2013), amggilly305 (03-23-2013), ckMS3 (03-23-2013), Code Monkey (03-22-2013), Dralphy (03-22-2013), Easter Bunny (03-28-2013), Hush (03-22-2013), JBR (03-22-2013), Jh8909 (03-23-2013), KusteLokal (03-23-2013), LMB77 (03-22-2013), psychophyr (03-25-2013), rob ms6gt (03-24-2013), Rokusek (03-29-2013), sidekick (03-29-2013), SpeedRebirth (03-22-2013), tbot (03-22-2013), TiGraySpeed6 (03-22-2013), Vader (03-22-2013)
 Old 03-22-2013, 03:59 PM   #2
tbot's Avatar
Posts: 2,821   (View Stats)
Groans: 40
I can't wait until all 3 are available!!! Thanks for the right up!
The Following User Says Thank You to tbot For This Useful Post:
Downmented (03-22-2013)
 Old 03-22-2013, 04:52 PM   #3
mczimer's Avatar
Posts: 1,249   (View Stats)
mczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the world
Are you saying you had less NVH with the three stiffer mounts vs just the TMM/RMM?
mczimer is offline   Reply With Quote
The Following User Says Thank You to mczimer For This Useful Post:
 Old 03-22-2013, 05:01 PM   #4
Downmented's Avatar
Groans: 493
Thats exactly what im saying Granted that is at idle, at normal operating temp. Through the gears is a bit different. It isnt more NVH, its just been shifted through different areas if that makes any sense.
700HP CLUB
11.479@124mph
#DIX
The Following 3 Users Say Thank You to Downmented For This Useful Post:
JBR (03-22-2013), mczimer (03-22-2013), Rokusek (03-29-2013)
 Old 03-22-2013, 05:36 PM   #5
mczimer's Avatar
Hmm that is really interesting, the PMM has always been attributed to the most vibes out of all the mounts, well, with AWR at least. Thanks for the write up, more info is always appreciated
 Old 03-22-2013, 05:36 PM   #6
You're also gonna see a significant reduction in noise and vibration after the PMM breaks in. The great thing about this mount is the orientation of the bushing. It will perform just as well after 10k miles as it did on day one and it's not gonna fail like horizontally oriented mounts tend to.
Downmented likes this.
agentgordon27 (03-22-2013), Downmented (03-22-2013), Jh8909 (03-23-2013), rob ms6gt (03-24-2013), Rokusek (03-29-2013), tbot (03-22-2013)
 Old 03-22-2013, 05:39 PM   #7
Downmented's Avatar
Groans: 493
Keep in mind that all of the other passenger mounts for the MS6 have horizontal bushing, where the JBR has vertical
Rokusek likes this.
700HP CLUB
11.479@124mph
#DIX
amggilly305 (03-23-2013), Jh8909 (03-23-2013), mczimer (03-22-2013)
 Old 03-22-2013, 05:52 PM   #8
mczimer's Avatar
That is why I think this is a great test
 Old 03-22-2013, 07:04 PM   #9
rolanblack's Avatar
Posts: 2,110   (View Stats)
Good job on your analysis. Badass craftsmanship never fails
The Following User Says Thank You to rolanblack For This Useful Post:
 Old 03-22-2013, 10:30 PM   #10
agentgordon27's Avatar
Posts: 560   (View Stats)
^Truf
I have the stiffest trilogy for Gen2 and I was like "cheezus what did I do" after install. Week later, not so bad, three months later, mostly transmission noises and a rumble right after take off and that's it. And really, think about it, horizontally oriented ones are ALWAYS being compressed upwards when the engine is even sitting while parked.
So the hole goes from whistle face o to oh face 0
Stock as fook.
The Following User Says Thank You to agentgordon27 For This Useful Post:
Downmented (03-23-2013)
 Old 03-22-2013, 11:51 PM   #11
Pseudonym's Avatar
Posts: 1,429   (View Stats)
love that this is posted days after i ordered the awr trio...
The Following 2 Users Say Thank You to Pseudonym For This Useful Post:
Downmented (03-23-2013), WhiteWidow (03-28-2013)
 Old 03-23-2013, 06:56 AM   #12
Downmented's Avatar
Groans: 493
Sell them or return them and get the j r trio, you will not be disappointed
Sent from Tapaty Talkaty
700HP CLUB
11.479@124mph
#DIX
agentgordon27 (03-23-2013), Rokusek (03-29-2013), TheFlash (03-23-2013)
 Old 03-23-2013, 07:37 AM   #13
6ixof1's Avatar
Posts: 700   (View Stats)
Thanks for the review. I have the JBR TMM - which I will prolly install on my vacay next next week. I CAN'T wait for the PMM.
Black Mica Mazdaspeed 6
The Mad Scientist Tunings
 Old 03-23-2013, 07:42 AM   #14
Stealth01's Avatar
Posts: 6,910   (View Stats)
Groans: 201
Yeah, the tranny whine had me feeling the same way. Different mount set, I know, but it made me nervous at first lol. Good write up.
Stealth01
2006 Mazdaspeed6 GT
The Following 2 Users Say Thank You to Stealth01 For This Useful Post:
agentgordon27 (03-23-2013), Downmented (03-23-2013)
 Old 03-23-2013, 08:39 AM   #15
the public enemy's Avatar
Posts: 1,133   (View Stats)
the public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the worldthe public enemy is the leader of the world
in for all three. I don't want anything else. Lol.
2006 Mazdaspeed6 GT Pearl Whitewater
"A life lived at half throttle is a life half lived."
Pulling like a freight train whilst sounding like a tractor.
the public enemy is offline   Reply With Quote
The Following 4 Users Say Thank You to the public enemy For This Useful Post:
agentgordon27 (03-23-2013), Downmented (03-23-2013), Rokusek (03-29-2013), Sb the boss (03-24-2013)
 Old 03-23-2013, 09:23 AM   #16
5000lbs of voiceless fury
Caligula's Avatar
Posts: 3,140   (View Stats)
Caligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the world
Groans: 185
Groaned at 124 Times in 81 Posts
Question. Why do I need a TMM? From looking at the engine whilst on the dyno, the RMM I have seems to keep engine movement under load in check. Also (as you know) the MS6 no haz twerk steer or wheel hop.
Basically, I'm just looking for a legitimate reason to upgrade.
2015 Telsa Model S 85D - Delivered 10/21/2015 FYEN!
SOLD!!! 2007 Mazda MS6 - //AWD//BNR S3//cp-e TMIC//cp-e CDFP//Cobb AP//Cobb TIH//Cobb EBCS//Bosch 845 3 Bar//MS-CAI//Custom DP//TS Kompact BPV//Magnaflow CBE//AWR RMM//JBR Stage 3 SSP Kit//JBR EGR Delete//H&R Springs//
Caligula is offline   Reply With Quote
 Old 03-23-2013, 02:14 PM   #17
Downmented's Avatar
Groans: 493
When the only mount i had was the JBR RMM, and i upgraded to his TMM, i did notice a significant difference. shifts felt allot more stable, and i had more a piece of mind that when ripping through gears, something was less likely to give. With all of them, i feel allot more confident that my power is going to the ground with everything being more stable and secure. This may not be the best explanation as to why you SHOULD upgrade, but thats how i personally felt after only upgrading the TMM while on stock PMM.
Hope that helps.
JBR, Rokusek and Caligula like this.
700HP CLUB
11.479@124mph
#DIX
The Following 4 Users Say Thank You to Downmented For This Useful Post:
JBR (03-23-2013), King Scumbag (03-23-2013), Rokusek (03-29-2013), the public enemy (03-24-2013)
 Old 03-24-2013, 12:22 AM   #18
redboat's Avatar
Posts: 634   (View Stats)
redboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the world
There a price out for the PMM?
redboat is offline   Reply With Quote
 Old 03-24-2013, 06:35 AM   #19
Downmented's Avatar
Groans: 493
Not yet, but very soon you too can have your very own Jbr Pmm.
700HP CLUB
11.479@124mph
#DIX
 Old 03-24-2013, 06:38 AM   #20
Moar torque transfer, cleaner shifts, and knowing your other mounts aren't going to blow up.
Case and point (though on a 3): I helped a local install an RMM and his stock PMM blew up. I mean fluid everywhere on the passenger side of the engine. He bought an 88a PMM and the vibes were pretty wild but I've been in meaner. Installed his TMM and the vibes were distributed cleaner and even with just an intake and vtcs/egr he's fighting for traction until just after shifting into third (its kinda cold out :/). Shifts are easier, car responds immediately, and these mounts won't blow. Put that to AWD:
Rokusek and Downmented like this.
The Following 3 Users Say Thank You to the public enemy For This Useful Post:
Downmented (03-24-2013), Jh8909 (03-24-2013), Rokusek (03-29-2013)
 Old 03-25-2013, 11:48 AM   #21
psychophyr's Avatar
Posts: 770   (View Stats)
psychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the world
Nice! I'll have to pick up a set of these to replace my SURE mounts when they inevitably explode into tiny bits of poorly-engineered shit. Quality stuff Jamie!
2006 Mazdaspeed6 GT BCM
SpeedPerf6rmanc3 10.6:1 Pistons, PI Fuel Kit, PnP Head, 75mm TB, Pinned Cams/Keyed Crank, 11mm H11 Head Studs \\ PT&E PT6266 CEA BB S-Comp. \\ Manley H+ Rods \\ JMF V2 PI Intake Mani w/ Bosch 1000cc Injectors
Squash Performance Top Hat w/ Dual DW300 Pumps \\ AEM FPR \\ Split Second AIC1 \\ CP-e LRT Ex. Mani, SAFEseals, RDM, EGRD \\ SURE TMM, PMM, Juggernaut, Anchors \\ TiAL MVR, Q \\ Bosch 4 Bar MAP
HTP 4" Intake \\ Autotech HPFP Internals \\ ATP Catless DP \\ ACT HD 6-Puck w/ Streetlite FW \\ Cobb AP \\ Treadstone TR10 \\ Magnaflow CBE \\ MSD Dashhawk \\ JBR SSP, BSD, RMM
Stratified EBCS \\ Corksport SS Braided Clutch Line \\ H&R Coilovers \\ SPC BJs \\ Rotora Drilled/Slotted Rotors \\ H2 Ceramic Pads \\ Enkei EKM3 7.5+45 \\ VG Sharkfin \\ RHO-Plate
Most powerful MS6 720/584 @42psi E42 9Oct13 Tuned by NISHAN
psychophyr is offline   Reply With Quote
The Following User Says Thank You to psychophyr For This Useful Post:
JBR (03-25-2013)
 Old 03-28-2013, 10:40 PM   #22
WhiteWidow's Avatar
Posts: 44   (View Stats)
WhiteWidow has much to be proud ofWhiteWidow has much to be proud ofWhiteWidow has much to be proud ofWhiteWidow has much to be proud ofWhiteWidow has much to be proud ofWhiteWidow has much to be proud ofWhiteWidow has much to be proud ofWhiteWidow has much to be proud ofWhiteWidow has much to be proud ofWhiteWidow has much to be proud of
Groaned at 5 Times in 2 Posts
I might try these out once my AWR's get used up lol
WhiteWidow is offline   Reply With Quote
 Old 03-29-2013, 06:38 AM   #23
Rokusek's Avatar
Posts: 5,551   (View Stats)
awesome write up chris! I know my mounts are fucking amazing!!! HUGE difference in shifting, the feel of the car in corners as well. knowing that the motor is more one with the chassis is a great feeling, especially when you can feel the difference.
I'm impatient to ride in your car now with the Trio.
TWO WEEKS!!!
Downmented (03-29-2013)
 Old 03-29-2013, 06:48 AM   #24
Downmented's Avatar
Groans: 493
TWO WEEKS!!!
Trio, im hesitant to even install my Turbine Tech FMM now lol
Rokusek likes this.
700HP CLUB
11.479@124mph
#DIX
The Following User Says Thank You to Downmented For This Useful Post:
 Old 03-29-2013, 07:55 AM   #25
shadesofgray19's Avatar
Posts: 794   (View Stats)
Do you feel that the FMM is even needed now?
 Old 03-29-2013, 08:01 AM   #26
Downmented's Avatar
Groans: 493
Dont know yet, we will see once i start pushing everything power wise and start launching it. Im all for stability though, and i have the mount, so no reason not to install it.
700HP CLUB
11.479@124mph
#DIX
WhiteWidow (03-29-2013)
 Old 03-29-2013, 10:27 AM   #27
tbot's Avatar
Groans: 40
The one thing that I like about the FMM is that it damn near stops all front to rear rotational movement of the motor. I know some people, granted they didn't have these awesome mounts that Jaime has, would have the motor rock and hit the hood. The FMM would eliminate this problem. On top of that it really does add quite a bit of support over all. I remember swapping out my TMM for the AWR one after I already had the FMM and even after removing the TMM and RMM we could not get the tranny lined back up to get the bolt through because of the FMM. When we tried jacking up the motor/tranny it ended up lifting the entire car.
Basically for the extremists I think it's a good idea to add...Like skaterz, DJ, Downmented...me once I get top mount turbo swapped in...
The Following 2 Users Say Thank You to tbot For This Useful Post:
Downmented (03-29-2013), WhiteWidow (03-29-2013)
 Old 03-29-2013, 10:36 AM   #28
Caligula's Avatar
Groans: 185
Yea I'm thinking that's overkill for my application. No?
 Old 03-29-2013, 10:44 AM   #29
Downmented's Avatar
Groans: 493
I think the trio of JBR mounts for the MS6 is a must have, thats my honest opinion. If your talking about the FMM + these 3 mounts, yes that may be overkill for some people. But its perfect for those of us attempting to push the envelope.
700HP CLUB
11.479@124mph
#DIX
Caligula (03-29-2013), the public enemy (04-02-2013), WhiteWidow (03-29-2013)
Page generated in 0.70959 seconds with 34 queries
