Like Tree5Likes
 Old 08-02-2013, 04:18 PM   #1
ztnedman1's Avatar
Posts: 338   (View Stats)
ztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the world
Default Never ending jbr swaybar squeek
I have tried everything. Install exactly like instructions, New bushings, putting the bar high in brackets low in brackets. Over tighten brackets under tighten brackets over grease under grease collars close collars far stiff setting mid soft settings I tired Teflon tape , no matter WHAT I FUCKING DO THE SLOW SPEED BUMP SQUEEKS WILL NOT STOP.
When I take off sway bar.... noise is gone. I'm addicted to the stiff setting but cannot handle the squeek.
Edit: OEM endlinks were shot. New OEM fixed issue.
2010 Velocity Red MS3 (140k+ miles) Intake/Exaust/AP selftuned(313/399 long time ago) - SOLD
2004 Corvette Z06
SCCA Bowling Green Match Tour - GS 1st place
SCCA Wilmington Champ Tour - GS 2nd place
SCCA National Championship - GS 3rd place
SCCA Grenada Match Tour - AS 1st place
ztnedman1 is offline   Reply With Quote
The Following User Says Thank You to ztnedman1 For This Useful Post:
Manny (08-02-2013)
 Old 08-02-2013, 04:26 PM   #2
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
try new endlinks
Big_Burd likes this.
The Following 6 Users Say Thank You to Etipp98 For This Useful Post:
Big_Burd (08-03-2013), ckMS3 (08-03-2013), El_Diablo (08-03-2013), Mauro_Penguin (08-08-2013), socks (08-08-2013), ztnedman1 (08-13-2013)
 Old 08-02-2013, 04:33 PM   #3
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
What kind of grease did you use? Did you check the upper end link nuts? I had that issue and ended up replacing one of the end links my original carxwas a 2010.
Sent from fastest ko4 Pu!
Nator is what it does.
p057 (08-05-2013)
 Old 08-02-2013, 04:36 PM   #4
ztnedman1's Avatar
Mobile 1 synthetic. Can remember the weight it's red though. Upper End link nuts are tight, moving the endlinks around without the bar has no noise at all and movement is smooth. I've checked everything and nothing is loose.
2004 Corvette Z06
 Old 08-02-2013, 04:49 PM   #5
[R]usty's Avatar
Posts: 2,204   (View Stats)
hmmm... mine went in without any issues besides a loose nut after a week. I didn't even add any more grease then what was supplied. Maybe one of the brackets is bent out of shape and is causing the urethane to rub in a weird way.
2010 Mazdaspeed3 w/tech
 Old 08-02-2013, 04:53 PM   #6
ztnedman1's Avatar
That's why I replaced them. First set squeeked and so do these, assuming that's the cause
2004 Corvette Z06
 Old 08-02-2013, 04:56 PM   #7
mrtheandrew's Avatar
Posts: 468   (View Stats)
mrtheandrew is the leader of the worldmrtheandrew is the leader of the worldmrtheandrew is the leader of the worldmrtheandrew is the leader of the worldmrtheandrew is the leader of the worldmrtheandrew is the leader of the worldmrtheandrew is the leader of the worldmrtheandrew is the leader of the worldmrtheandrew is the leader of the worldmrtheandrew is the leader of the worldmrtheandrew is the leader of the world
Are the brackets mounted too high and causing the sway bar to rub on the control arm? Its been a while since I looked under there, but I know the ends of the bar are close to something just above it.
2007 True Red MS3
Koni Yellows || H&R Springs || JBR RSB || JBR Dogbone RMM || Centric Blanks || CS Pads || Goodridge SS Brake Lines || CS SSP || Hella Supertones || 55w 5000k HIDs/35w 3000k fogs || eonon D5151 HU/Nav/PS2 || 17x8 RPF1s || 235/45 DW || CS BPV || CS Intake/TIP || CXRacing/Godspeed FMIC || Ultimate Racing TP || Autotech Internals || AP v3
mrtheandrew is offline   Reply With Quote
 Old 08-03-2013, 08:30 AM   #8
ztnedman1's Avatar
Hmmm. Every time I have installed I have not jacked the car up. I did to check deeper and now see that the end links are hitting the control arm. The plastic cover has a chip on both sides. Can't really get anymore clearance no matter where I mount the bar(roughly 1/8", if that). Note this is with stiff setting. The bar made noise on medium setting before too though.
I ripped the plastic cover off the end links and wrapped them up with electric tape, perhaps this will cure the squeek...
2004 Corvette Z06
 Old 08-02-2013, 05:35 PM   #9
kritz's Avatar
Groans: 95
What hole do you have the endlink engaged in? Not that should make a difference just curious.
 Old 08-02-2013, 05:36 PM   #10
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
One reason why I'm glad corksport bar has grease certs on the bushings. I would grease them to the point where its messy try again. If still there its not the bushi gs
Sent from my Nexus 4 using Tapatalk 2
Damond Built Speed 6
 Old 08-02-2013, 10:22 PM   #11
How are you greasing the bushings? Not with what but how? I know of no one else with a sway bar that squeaks either. Possibly not the sway bar? And just because when you take it off and it doesn't make the noise does not necessarily mean it's the bar.
Grease fittings...why didn't I think of that?
Last edited by JBR; 08-02-2013 at 10:22 PM. Reason: MSF Database - Automerged Doublepost
The Following 8 Users Say Thank You to JBR For This Useful Post:
Apacheguy1584 (08-03-2013), Big_Burd (08-03-2013), btstarcher (08-02-2013), Keko (08-03-2013), Kyle Undefined (08-03-2013), Mauro_Penguin (08-08-2013), Rokusek (08-04-2013), YABBAMZR (08-03-2013)
 Old 08-03-2013, 08:22 AM   #12
ztnedman1's Avatar
The current install I packed the bushings with about 1/16 in of grease all around with my finger. Then I put a ltttle grease in between the urethane and bracket. Then hit it with a grease gun after install.
Other attempts include light coating, no coating, grease gun until the shit is falling on my garage floor, etc...
What else could it be? I used to think it was the plastic strut covers hitting the tires but I expected to still hear it with no bar.
2004 Corvette Z06
 Old 08-02-2013, 10:55 PM   #13
outshined's Avatar
Posts: 423   (View Stats)
outshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the world
Using the grease fittings, I keep mine lubed with Green Grease (every 3-4 months) and it has never once squeaked.
Originally Posted by James Madison
[The Constitution preserves] the advantage of being armed which Americans possess over the people of almost every other nation...(where) the governments are afraid to trust the people with arms.
outshined is offline   Reply With Quote
 Old 08-03-2013, 08:38 AM   #14
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
...Are you referring to the plastic cover that protects them during shipping or the actual boot that isn't supposed to be removed?
kritz (08-03-2013)
 Old 08-03-2013, 08:57 AM   #15
ztnedman1's Avatar
The hard plastic semi sphere cover. Im to the point were I will tear everything in half back there to find the issue then I will replace what needs to be replaced.
Either way, taking them off did not solve the issue. Best way I can describe the noise is the squeek a washing machine makes when off balance. This is over EVERY mild bump, even rough pavement patches and especially entering raised drive areas at an angle. It does not make this noise under hard cornering or swaying back and forth.
2004 Corvette Z06
 Old 08-03-2013, 09:11 AM   #16
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
My exhaust squeaks like your saying. Its annoying but I'm too lazy to use my poly exhaust mounts:-D. Don't break your car turn up the radio, holy Hell man
The Following User Says Thank You to skeeter149 For This Useful Post:
p057 (08-05-2013)
 Old 08-03-2013, 09:17 AM   #17
ztnedman1's Avatar
Its louder than the radio.
2004 Corvette Z06
 Old 08-03-2013, 12:26 PM   #18
It's not the sway bar. No way.
kritz (08-03-2013), Mauro_Penguin (08-08-2013), YABBAMZR (08-03-2013)
 Old 08-07-2013, 04:58 PM   #19
ztnedman1's Avatar
Originally Posted by Dash08 View Post
Anger management sessions.
Originally Posted by p057 View Post
fucking anger issues much? jesus christ.
I dont know how the MS3 bar is set up, but on the 6 you have these collars with bushings that allow you to bolt the bar to the subframe (endpoints go to endlinks) i left one of the nuts slightly loose to move the bar and i guess i must have had forgotten to tighten it down. it caused awful squeaking for a while and it turned out the bracket was just sliding up and down. tightened it really well, drop of loctite and used lube everywhere and it is as silent as can be.
Has to be a troll.
All you Gandhi mother fuckers can fuck off, and that goes double for the brownie gandhi.
Its not like this just happened and in two minutes I lost it. I spend over 3 hours a day in my car and drive over 3k miles a month. Lets see you go 40k miles with an annoying squeek that you can't get rid of that is in your ear for half the damn day. I deal with noises pretty well since I run a 40k a year car with hard mounts and catless exaust, but after many months this got old. So yes after a shitty week I had a Red mist/pms/faggotry moment where I went Chris Brown on my steering wheel(which I already fixed).
In the words of Eric Cartman... I do what I want.
Please do not mistake my assholish posts as a dig on you or your products James. In fact I love your stuff, the RMM/PMM/Tig/EGR block and even this sway bar.
edit: was endlinks. The noise came back yesterday NON STOP over bumps again and is definately not the endlinks hitting as I thought it might be. This time I decided to install the stock bar to see if it is just caused by connecting both sides of the car together.
Currently with the stock bar there is NO noise again. D.E.A.D silent.
Is it possible I am still installing wrong... sure i guess. But this is not my first rodeo with any car let alone the MS3. I managed to install my pump, downpipe and clean my valves, etc.. with no help and no issues so I find it hard that I have messed up 6 bolts TWICE with an aftermarket bar but not with the stock bar. Either way, I am going to order yet ANOTHER set of bushings, hopefully with better results this time.
2004 Corvette Z06
The Following User Says NO Thank You to ztnedman1 For This Un-useful Post:
p057 (08-08-2013)
 Old 08-07-2013, 05:07 PM   #20
warlord's Avatar
Posts: 756   (View Stats)
Read my post in this thread. JBR RSB Grease Fittings
It's the only thing you haven't tried so you have nothing to lose. I could never go back to the stock bar and be happy.
2014 IS350 (sold)
2013 MS3 Stage2 E85 (sold)
2011 MS3 Stage2 (sold)
warlord is offline   Reply With Quote
 Old 08-07-2013, 05:21 PM   #21
ztnedman1's Avatar
Trust me, Im not happy with the sloppy stock bar.
I saw your post before which is why I tried teflon but that did nothing. With the new bushings ill try some marine grease.
2004 Corvette Z06
 Old 08-07-2013, 07:36 PM   #22
skeeter149's Avatar
Groans: 91
Whatever works for you mate, its your car but this brownie Ghandi fucker has 2 years on you on this forum. At least I can install a rsb without it causing me to go apeshit on my steering wheel. I just strip endlinks in the process. Just because I can't afford to donate doesn't mean I'm new shit head, 2008 holmes check the profile!
The Following 2 Users Say Thank You to skeeter149 For This Useful Post:
p057 (08-08-2013), stevehuff (08-12-2013)
 Old 08-07-2013, 09:27 PM   #23
JgamB's Avatar
Posts: 2,566   (View Stats)
Fortunately JBR has just expanded their product line.
The Following 7 Users Say Thank You to JgamB For This Useful Post:
Easter Bunny (08-08-2013), kgb (08-24-2013), Mauro_Penguin (08-08-2013), neganox (08-08-2013), p057 (08-08-2013), stevehuff (08-12-2013), xantho99 (08-07-2013)
 Old 08-03-2013, 01:09 PM   #24
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
Anyone have any suggestions? Preferably before I break something more expensive.
this forum serves 2 purposes
The Following 15 Users Say Thank You to Dash08 For This Useful Post:
cshunter (08-03-2013), daafisch (08-08-2013), Easter Bunny (08-08-2013), El_Diablo (08-03-2013), JBR (08-03-2013), Kyle Undefined (08-03-2013), L3THAL6 (08-03-2013), Mauro_Penguin (08-08-2013), Micha (08-08-2013), p057 (08-05-2013), Raider (08-08-2013), speeda (08-05-2013), stevehuff (08-12-2013), theMANIMAL (08-05-2013), ztnedman1 (08-03-2013)
 Old 08-03-2013, 01:40 PM   #25
cshunter's Avatar
Posts: 1,312   (View Stats)
Inb4 airbag hits op in the face...
2013 CWP That's slow
Previous: MILTUNED E85 K04
The Following User Says Thank You to cshunter For This Useful Post:
p057 (08-05-2013)
 Old 08-03-2013, 01:58 PM   #26
Look just above the sway bar on each end and see if it rubbing on anything just above it. When I had my bushing brackets mounted too high the bar would rub on the ends.
2007 True Red MS3
 Old 08-03-2013, 02:38 PM   #27
exentix's Avatar
Posts: 1,568   (View Stats)
Groans: 46
Are your struts blown by any chance? Maybe the bar being stiff is putting more strain on them? Just thinking out loud...
 Old 08-03-2013, 02:41 PM   #28
ckMS3's Avatar
Posts: 1,112   (View Stats)
ckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the world
^what he said check your struts to see if they're blown.
BNR S3 // E85 Mix // Freektune
348tq/367whp -21.5 psi
Now - 25-26 psi + JBR 3.5 Intake
ckMS3 is offline   Reply With Quote
 Old 08-03-2013, 03:03 PM   #29
ztnedman1's Avatar
Struts are fine. I lowered the bar and tried some washers to give me some more clearence and it seems to have solved it for most everything but the bigger movements. I think without the covers the extra space is just enough now. I'm thinking a slightly longer aftermarket end link might be the answer.
Thanks for the help guys
2004 Corvette Z06
 Old 08-04-2013, 07:47 AM   #30
agentgordon27's Avatar
Posts: 560   (View Stats)
Did you install the sway bar backwards? Kidding, this just made me remember the camber arm debacle.
Stock as fook.
 Old 08-04-2013, 07:50 AM   #31
kritz's Avatar
Groans: 95
Take a photo for us.
 Old 08-05-2013, 11:28 AM   #32
[R]usty's Avatar
Do you have a go pro?
 Old 08-05-2013, 02:22 PM   #33
v8 convert
p057's Avatar
Posts: 1,782   (View Stats)
p057 has disabled reputation
Groans: 220
I litteraly freaked out and beat the shit out of my steering wheel. So now that's nice and recessed.
p057 is offline   Reply With Quote
 Old 08-05-2013, 05:03 PM   #34
Mizzle's Avatar
Groans: 324
Has to be a troll.
The Following 2 Users Say Thank You to Mizzle For This Useful Post:
JBR (08-06-2013), Mauro_Penguin (08-08-2013)
 Old 08-05-2013, 07:22 PM   #35
865ms3's Avatar
Posts: 2,602   (View Stats)
all these sway bar posts....ive had mine probably two years. autocross...many many trips through tail of the dragon and ive greased it maybe twice (grease as recommended i just forget). ive never had a single noise other than the THUMP of the wheel dropping back to the ground. i <3 JBR!
Brent
-Built Block-5858-Meth
Dragon Slayer Setup
FreekTuned
The Following 3 Users Say Thank You to 865ms3 For This Useful Post:
JBR (08-06-2013), Mauro_Penguin (08-08-2013), YABBAMZR (08-05-2013)
 Old 08-08-2013, 06:45 AM   #36
It's not the bar...It's the stress it's putting on some other component(s). Bars don't squeak and neither do the bushings. I bet if you installed it on another car it would not squeak.
bislag (08-08-2013), kritz (08-08-2013), Mauro_Penguin (08-08-2013), ztnedman1 (08-13-2013)
 Old 08-08-2013, 07:35 AM   #37
ztnedman1's Avatar
Then why would the stock bar not make noise if this bar was making noise even on the soft setting. If you search urethane sway bar squeek you get many results on Google on of the more prominent being the Shelby gt500. It also happens to match my sound almost dead on.
2004 Corvette Z06
 Old 08-08-2013, 07:49 AM   #38
Because the stock bar is way less stiff then our bar on the softest setting.
With this being one of the most popular bars on the market, you would think there would be at least one other instance of this kind of noise occurring and there's not so, I'm going stand firm on it's something else.
If you want to send the bar and the bushings to us I'll install it in our shop car.
Easter Bunny (08-08-2013), Jabl3s (08-08-2013), p057 (08-08-2013), ztnedman1 (08-13-2013)
 Old 08-08-2013, 07:53 AM   #39
bislag's Avatar
Posts: 395   (View Stats)
bislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the world
You're seriously the only person who has had this problem and been unable to resolve it. It is likely that it is another suspension component. The only time a bar should squeak is if there is extra friction from lack of grease, or movement that should not be occurring due to wear or something being loose. You say everything is tight and the bushings are both new and greased.
Replace your endlinks (not like they aren't cheap) and check your other suspension components. Something else is either loose or worn. Oh and see if you can get a video or recording of it. People just might be able to help narrow it down by sound. Or continue having a shitty attitude, either works.
When I had a Pu I put the JBR bar on there and flogged it mercilessly around corners. The only problem I ever had was clunking due to the endlink loosening, which was easily resolved. It never once squeaked. I still have that bar and if you want I'll stop being lazy and make a FS thread and you can buy it from me and prove to yourself what we already know; it's not the bar.
bislag is offline   Reply With Quote
The Following 2 Users Say Thank You to bislag For This Useful Post:
 Old 08-08-2013, 08:00 AM   #40
Are you sure it's not the rear hatch squeaking?
Squeek squeek coming from FR wheel/well filphil MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 05-14-2009 02:43 PM
Page generated in 0.60911 seconds with 40 queries
