Like Tree7Likes
 Old 04-28-2012, 01:27 PM   #41
bieberhole69's Avatar
Posts: 548   (View Stats)
bieberhole69 is the leader of the worldbieberhole69 is the leader of the worldbieberhole69 is the leader of the worldbieberhole69 is the leader of the worldbieberhole69 is the leader of the worldbieberhole69 is the leader of the worldbieberhole69 is the leader of the worldbieberhole69 is the leader of the worldbieberhole69 is the leader of the worldbieberhole69 is the leader of the worldbieberhole69 is the leader of the world
Groaned at 74 Times in 21 Posts
I want one
Sent from me using Tapshoes
bieberhole69 is offline   Reply With Quote
 Old 04-28-2012, 04:10 PM   #42
radbrad's Avatar
Posts: 538   (View Stats)
I need a second one. But I will be installing it in a somewhat weird location. I'm going to put it infront of my battery, and I might need some extra hose. Would that be doable?
Edit: I'm putting my 2nd occ there because my custome fmic gets in the way of a lot of stuff.
07Speed3
 Old 04-28-2012, 04:13 PM   #43
PM when you're ready and I'll get you the extra hose.
Jamie
 Old 04-28-2012, 06:43 PM   #44
BigRedSpecial's Avatar
Posts: 1,436   (View Stats)
Groans: 56
Stage 2 ordered. Hopefully this will make a difference with my knock problems (at the very least it'll take care of the ungodly mess I saw when I pulled my TB off)
Needed: Driver mod
 Old 04-29-2012, 05:47 AM   #45
SPD3-11's Avatar
Posts: 33   (View Stats)
SPD3-11 is a glorious beacon of lightSPD3-11 is a glorious beacon of lightSPD3-11 is a glorious beacon of lightSPD3-11 is a glorious beacon of lightSPD3-11 is a glorious beacon of light
Groaned at 9 Times in 2 Posts
Default Any drawbacks ?
Leaning heavily in buying a JBR OCC for my MS3 Gen2. Theres alot for OCC's on the market but seems like JBR's are top notch. This car is my daily driver so keeping it running well for along time is extremely important. Is there any drawbacks with a catch can? I assume this can only help.
2011 Velocity Red MS3
K&N CAI / Cobb TIH / Cobb FMIC / Cobb Downpipe / Cobb Catback / Turbosmart Dual Port BOV / Sure RMM / Sure Short Shift / AP / Autotech Internals / JBarone CC / Denso ITV-22 / Umbra 35% Tint / Stage 2 map / 21 psi
SPD3-11 is offline   Reply With Quote
 Old 04-29-2012, 11:38 PM   #46
Dubcnea's Avatar
Posts: 223   (View Stats)
Dubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond repute
i have 2 questions. hopefully neither of them sound too dumb:
1. not that it 'really' matters since this type of mod is apparently helping the longevity of the engine, but is installing an OCC going to have any affects on hp/tq?
2. what's the benefit of stage 2? er, perhaps reworded a little...what's the time when one says "well i have these mods so i better get stage 2 instead of stage 1"?
thanks for any info!
2012 CPW Mazdaspeed 3
Dubcnea is offline   Reply With Quote
 Old 04-30-2012, 07:51 AM   #47
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
1. No. However, it will help keep the IM nice and clean, thus saving your intake valves from what would inevitably be going in there. Combined with an EGR Delete, you'll be saving them even more.
2. Stage 2 includes a check valve. It's a one-way valve to prevent anything from leaving the can and heading into your IM. It's a fail-safe.
That said, go with Stage 2.
Dubcnea (04-30-2012)
 Old 04-30-2012, 02:35 PM   #48
Dubcnea's Avatar
thank you! i will do more research on the EGR delete as well.
 Old 05-06-2012, 02:35 PM   #49
RobLoMS3's Avatar
Posts: 21   (View Stats)
RobLoMS3 is a glorious beacon of lightRobLoMS3 is a glorious beacon of lightRobLoMS3 is a glorious beacon of lightRobLoMS3 is a glorious beacon of lightRobLoMS3 is a glorious beacon of lightRobLoMS3 is a glorious beacon of light
Originally Posted by boostin08 View Post
-Weird thing tho, after install, cover plate back on and everything ready to go, turned key and no start!?! WTF!? No click no nothing... checked for codes with AP, nothing.. Disconneted battery, still nothing. Took cover plate off and inspected everything that i installed, nothing unplugged..No start.. Pulled hoses off OCC, turned key, fired up!? Put everything back together and starts fine everytime, everything back to normal.. Weird.... ??
im having this same problem but w/o the joy of the car starting.. i did egr delete, and coolent bypass as well realy impressed i have your rmm all your stuff is epic! now if i can only find y my car wont start..
2008 MS3 AEM CAI, COBB TIP, HKS CB, TURBOXS BPV, COBB FMIC, JBR RMM, JBR OCC, CP-E CATTED DP, TB TIG, SnailD Tune E85
RobLoMS3 is offline   Reply With Quote
 Old 05-06-2012, 05:44 PM   #50
Look in the area of the starter. None of those mods can result in the car not starting. The only thing possible is something got knocked loose. Most activity for the occ and the egr take place around the starter.
 Old 05-07-2012, 01:06 PM   #51
RobLoMS3's Avatar
It was the neutral safty switch. I have no idea how it went out between me driving in the morning and after the install but it did.
tapin
 Old 05-18-2012, 04:42 AM   #52
thatsmrgimp2u's Avatar
Posts: 834   (View Stats)
So would the check valve relieve a PCV valve that could be sticking?? I think mine is starting to give up the ghost and if the stage 2 will keep me from having to buy mazdas shitty valve whenever they go bad, ill go that route.
Fluids
Rotella T6 A lot
Rislone Engine Treatment
Motorcraft XT-M5-QS(trans)
VP Methanol
~Splash of E85~
The Following User Says Thank You to thatsmrgimp2u For This Useful Post:
JBR (05-18-2012)
 Old 05-18-2012, 05:35 AM   #53
Absolutely! That is one of the most important reasons to have a GOOD quality check valve. You don't want to rely on the OEM or the addition of some universal CV picked up from Autozone or NAPA that is worse then OEM. Plus changing the stock one out when it does fail requires removing the whole intake manifold.
thatsmrgimp2u (05-18-2012)
 Old 05-27-2012, 04:30 PM   #54
Ordered muh stage 2 yesterday! Super excited to know all that crud will finally end up somewhere other than my valves
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
JBR (05-27-2012)
 Old 08-12-2012, 06:41 PM   #55
Chief_Wiggum's Avatar
Posts: 419   (View Stats)
Installed mine today, another great quality product from JBR. I can't wait to see what comes out of this thing in a few thousand miles or so.
JBR (08-12-2012)
 Old 08-23-2012, 06:08 PM   #56
Everything needed is include with this kit. Hoses, clamps, fittings, drain valve, check valve and the mounting bracket. Nothing to source, nothing extra to buy. Order, install, enjoy.
 Old 11-22-2012, 09:31 AM   #57
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
Any cutaway pics of the occ? I'm just curious as to what the internals of the can actually look like. I've done my research on different ways to set up an occ, trying to determine the best option and best can design
Blue Pu.
 Old 11-22-2012, 09:54 AM   #58
anavrinIV's Avatar
Groans: 63
Blue Pu.
 Old 11-22-2012, 10:37 AM   #59
There is no other OCC with 4 filter plates to separate out the oil than ours. No mesh to disintegrate, or anything to replace. It works and keeps on working. Explosion proof too.
anavrinIV (11-23-2012), Keko (11-22-2012)
 Old 11-23-2012, 08:35 PM   #60
Stretcher's Avatar
Posts: 46   (View Stats)
Stretcher is a glorious beacon of lightStretcher is a glorious beacon of lightStretcher is a glorious beacon of lightStretcher is a glorious beacon of lightStretcher is a glorious beacon of light
My only quip with the can at all! is the drain location. Was there a reason other than worry of it getting hit on the bottom that you did not place it on the bottom to properly drain all sediment from the can?
eric
Stretcher is offline   Reply With Quote
 Old 11-23-2012, 09:45 PM   #61
SparkySparks's Avatar
Posts: 1,314   (View Stats)
eric
That is the only thing that has kept me from ordering one my self. The can is very similar to the Saikou Michi catch can I had on my truck. I do like the fact that JBR uses 4 plates instead of 3 like the Saikou Michi uses. Now if only there was an option for a bottom drain. All the other JBR parts I have seen are very well made, love my dog bone, so I have no doubt the OCC is also very well made and works great. I just wonder why the side drain location was chosen over the more traditional bottom location.
On Order:
Coming Soon:
DIY Projects:
 Old 11-24-2012, 10:17 AM   #62
The drain was placed on the side to eliminate the chances for the drain to get ripped of if car bottoms out. This can be even more of an issue with lowered vehicles. Also depending on the angle of some parking lots and driveways the potential is also increased to rip the drain off. Side discharge is the way we ensure there are no issues that will leave you stranded. The can can also be rinsed out with some gas should you feel there is sediment build up; which I've not yet encountered.
Hope this helps. Oh and they are on sale for the next 2 days!!
Thanks,
Jamie
 Old 12-29-2012, 10:07 AM   #63
Boatcop1's Avatar
Posts: 256   (View Stats)
Boatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the world
Originally Posted by econman View Post
I did my OCC install today. It took me about 1.5 hours to do with about 30 minutes spent trying to get the hose off my PCV value. The clamp was slightly melted or glued to the hose, so it wasn't moving away from the valve - eventually I was able to keep the clamp open long enough to just slide the hose off the value.
Anyways I just had one question about the install. On the OCC, does the hose from the PCV valve go on the top outlet, or does the one from the intake go on the top? Based on what I read, the one from the PCV valve should go on the top outlet and that's how I installed it.
Here are some pictures of the final install - if there are any issues with what you see, please let me know
You read right. Everything looks perfect. Good job!!
I was going to do the install today but the instructions state that the PCV hose should be installed on the bottom port of the OCC? Can someone clarify?
Also what is the difference between the instructions for OCC's recieved pe and post 12/25/12? I read both and couldn't figure it out unless I overlooked something.
Boatcop1 is offline   Reply With Quote
 Old 12-29-2012, 07:48 PM   #64
econman's Avatar
Posts: 355   (View Stats)
econman is the leader of the worldeconman is the leader of the worldeconman is the leader of the worldeconman is the leader of the worldeconman is the leader of the worldeconman is the leader of the worldeconman is the leader of the worldeconman is the leader of the worldeconman is the leader of the worldeconman is the leader of the worldeconman is the leader of the world
It looks like the location of the check valve was changed. In the pre 12/25 instructions, the check valve is placed between the PCV valve and the catch can. In the post 12/25 instructions, the check valve is placed between the intake manifold and the catch can.
@jbarone - why the change in the installation between the two version? Is there any reason to change the way my V1 is installed? Would it be preferable for the catch can not to be under boost pressure from the manifold?
econman is offline   Reply With Quote
 Old 12-29-2012, 07:59 PM   #65
Boatcop1's Avatar
Looks like I will hold off on this install. I would think you would not want the CC under incresed pressure via boost. I guess we'll see.
 Old 12-30-2012, 06:58 AM   #66
anavrinIV's Avatar
Groans: 63
@jbarone; has clarified this before in other threads, the cv is there to releive pressure on the pcv valve. The can is desinged to take any pressure you can throw at it but other designs call for having the cv between the im and occ where his called for it to be between the occ and pcv. Per jamie it doesn't matter where you put it in his setup
Blue Pu.
 Old 12-30-2012, 07:56 AM   #67
We did change the location of the check valve from the crank case side of the setup to the intake side of the setup. The new instructions address this change. The check valve is a one way valve so, if your OCC kit was received before 12/25/12 the CV is configured to go on the crank case side. If your kit was received after 12/25/12 your CV is configured to go on the intake manifold side. You cannot just switch the location of the valve, it must be reconfigured. If you would like to change the location PM me and I'll walk you through it. There is no need to be concerned about having the CV in the crank case side. Our catch cans and the included components can handle all the pressure any stock or heavily modded Mazdaspeed has to offer. We made this change because our customers requested it. You speak, we listen and do our best to accommodate.
Happy Holidays!
Hush (12-30-2012)
 Old 12-30-2012, 08:36 AM   #68
Boatcop1's Avatar
I received mine on Dec 28th.
As far as the hose routing though; this post suggests the PCV hose goes to the top port in the OCC but the instructions say route it to the bottom port in the OCC?
I'd Tap that, two times!
 Old 12-30-2012, 08:53 AM   #69
I'm not sure what post you're referring to. Just follow the instructions and you'll be fine.
 Old 12-30-2012, 12:50 PM   #70
Boatcop1's Avatar
This is what I am refering to. Econman installed the hose comming from the PCV valve on the top inlet of the OCC and you confirmed this was correct.
The instructions on the JBR support page say to install the hose from the PCV valve on the bottom inlet of the OCC.
It makes perfect sense to connect it to the bottom port seeing that the intake hose must stay on top of the PCV hose from engine to can.
Just looking for clarification on this. Thanks for your Patience with me
 Old 12-31-2012, 05:53 AM   #71
I must have been stoned. The hose goes on the bottom. Sorry for the confusion.
Boatcop1 (12-31-2012), SirCutsalot25 (07-31-2014)
 Old 01-23-2013, 11:44 AM   #72
Heavy stock on these, get yours now.
 Old 02-07-2013, 03:38 PM   #73
This is what I just pulled from mine around 4k miles. It usually is much darker. This look normal?
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
 Old 02-07-2013, 04:12 PM   #74
jdm_mica's Avatar
Posts: 525   (View Stats)
jdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the world
I will drain mine for the first time on this Saturday. ^^^That looks like straight gasoline...
Cobb AP (Stratified Tuned)
Corksport Stage 2 intake+recirc tube
Streetunit testpipe
Autotech internals
NGK LTR7Ix-11
Corksport RMM
RX-8s--235/40/18 Bridgestone Potenza RE-760
Stoptech brake kit+Motul RBF600
Whiteline RSB+endlinks
Dominant Engineering camber arms
JBR stage 2 OCC+ EGR delete+intake manifold gasket
HKS turbo timer
Prosport boost gauge+ventpod
Awaiting H&R springs/Koni yelows/ground control bumpstops
jdm_mica is offline   Reply With Quote
 Old 02-07-2013, 04:14 PM   #75
Hmm, interesting...it does look like mostly gasoline. FWIW, this is what came out of mine;
Why you should buy a JBR OCC
 Old 02-07-2013, 04:59 PM   #76
I might pull my manifold off next week to see what's going on. I put the check valve between the manifold and the occ, forgot I made that change as well... I made sure everything was flowing the right way. It should open under vacuum no matter what right? I switched it so the entire system wouldn't be pressurized. I know it looks like gas but it doesent smell like it really.
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
 Old 02-07-2013, 05:05 PM   #77
The arrow on the CV needs to be pointing towards the manifold.
thatsmrgimp2u (02-07-2013)
 Old 02-07-2013, 05:25 PM   #78
Yeah it is, I was sure to reverse it from how you had sent it.
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
JBR (02-07-2013)
 Old 02-07-2013, 05:28 PM   #79
Good. Most likely more water than anything. Typical of this time of year although, I would expect it to be darker. I'd give the setup a good once over to be sure.
 Old 02-07-2013, 08:10 PM   #80
So my girlfriends dad helped when I changed my transmission fluid, and when he tightened the valve at the bottom of the occ, I think it got stripped. I just can't get my head around how there could be vapor but no oil. I know it's thicker, so maybe the valve isn't opening all the way? How much would you charge me for another nozzle for the occ? I'd like to replace it anyway, due to strippage.
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
JBR EGR Block Off Kits In Stock!! JBR JAMES BARONE RACING 137 03-21-2015 07:33 PM
06' - 2011 MAZDA 5 Short Shift Plate Kits In Stock!! JBR JAMES BARONE RACING 4 06-18-2010 07:38 AM
06' - 2011 MAZDA 3 Short Shift Plate Kits In Stock!! JBR JAMES BARONE RACING 3 06-18-2010 07:38 AM
Page generated in 0.59123 seconds with 36 queries
