Like Tree7Likes
 Old 02-08-2013, 04:36 PM   #81
Volcom8190's Avatar
Posts: 448   (View Stats)
Volcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the world
Originally Posted by thatsmrgimp2u View Post
So my girlfriends dad helped when I changed my transmission fluid, and when he tightened the valve at the bottom of the occ, I think it got stripped. I just can't get my head around how there could be vapor but no oil. I know it's thicker, so maybe the valve isn't opening all the way? How much would you charge me for another nozzle for the occ? I'd like to replace it anyway, due to strippage.
might be able to get one at lowes or any autoparts store. Its a pretty common fitting.
2010 - BMW 335i M-Sport - Lemans Blue Metallic
2005 - Kawasaki ZX-6R 636 - Magma Red
Volcom8190 is offline   Reply With Quote
 Old 02-08-2013, 08:29 PM   #82
That valve is just a drain and serves no other purpose but to drain the can. If it's not leaking you should be fine.
 Old 02-08-2013, 08:45 PM   #83
thatsmrgimp2u's Avatar
Posts: 834   (View Stats)
I just don't want to open it one day and it not want to close again.
Fluids
Rotella T6 A lot
Rislone Engine Treatment
Motorcraft XT-M5-QS(trans)
VP Methanol
~Splash of E85~
 Old 02-09-2013, 09:12 AM   #84
mingenyx's Avatar
Posts: 268   (View Stats)
mingenyx is the leader of the worldmingenyx is the leader of the worldmingenyx is the leader of the worldmingenyx is the leader of the worldmingenyx is the leader of the worldmingenyx is the leader of the worldmingenyx is the leader of the worldmingenyx is the leader of the worldmingenyx is the leader of the worldmingenyx is the leader of the worldmingenyx is the leader of the world
when i drain it is like a dark green ish color when it comes out
mingenyx is offline   Reply With Quote
 Old 02-09-2013, 09:58 AM   #85
PM sent.
Sounds pretty normal for this time of year.
Last edited by JBR; 02-09-2013 at 09:58 AM. Reason: MSF Database - Automerged Doublepost
 Old 02-20-2013, 01:35 PM   #86
jdm_mica's Avatar
Posts: 525   (View Stats)
jdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the worldjdm_mica is the leader of the world
I just went to drain my catch can and nothing came out. Is this normal? I have had it installed for about 4 weeks now. I got it during the black friday sale. I followed the instructions to the best of my knowledge. Anything I should look for? Maybe I put the hoses backwards?
Cobb AP (Stratified Tuned)
Corksport Stage 2 intake+recirc tube
Streetunit testpipe
Autotech internals
NGK LTR7Ix-11
Corksport RMM
RX-8s--235/40/18 Bridgestone Potenza RE-760
Stoptech brake kit+Motul RBF600
Whiteline RSB+endlinks
Dominant Engineering camber arms
JBR stage 2 OCC+ EGR delete+intake manifold gasket
HKS turbo timer
Prosport boost gauge+ventpod
Awaiting H&R springs/Koni yelows/ground control bumpstops
jdm_mica is offline   Reply With Quote
 Old 02-20-2013, 01:53 PM   #87
You bought it last November and installed it 4 weeks ago? We updated the directions and the location of the check valve since then so you may have the lines backwards. PM me and we'll figure it out.
Thanks,
Jamie
 Old 02-21-2013, 02:44 PM   #88
shadesofgray19's Avatar
Posts: 794   (View Stats)
Thanks,
Jamie
Why not keep both directions posted? I have your OCC in the box still that I bought last summer and will need the old directions for whenever I finally get around to my installs.
 Old 02-21-2013, 05:24 PM   #89
You'll wanna reconfigure you check valve and install it on the intake side if you have the stage 2 kit and use the current instructions. PM me if you need help when you're ready to install it.
shadesofgray19 (02-24-2013)
 Old 02-21-2013, 05:28 PM   #90
mingenyx's Avatar
I'm confused if I purchased mine last summer and its on do I need to reinstall a dif way?
 Old 02-21-2013, 06:04 PM   #91
King Scumbag's Avatar
Posts: 2,384   (View Stats)
Edit: also-
We did change the location of the check valve from the crank case side of the setup to the intake side of the setup. The new instructions address this change. The check valve is a one way valve so, if your OCC kit was received before 12/25/12 the CV is configured to go on the crank case side. If your kit was received after 12/25/12 your CV is configured to go on the intake manifold side. You cannot just switch the location of the valve, it must be reconfigured. If you would like to change the location PM me and I'll walk you through it. There is no need to be concerned about having the CV in the crank case side. Our catch cans and the included components can handle all the pressure any stock or heavily modded Mazdaspeed has to offer. We made this change because our customers requested it. You speak, we listen and do our best to accommodate.
Happy Holidays!
07 BLACK MICA MS3
PATTY/JEFF BUILT MOTOR
STOCK BLOCK
BOSTON STRONG
 Old 02-21-2013, 06:48 PM   #92
You mean just having the arrow on the valve pointing toward the manifold right?
Quit using big words like reconfigured... Lol
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
 Old 02-21-2013, 06:50 PM   #93
LOL ...yes.
If you bought and installed the kit before 12/25/12 there's nothing you need to do.
 Old 02-22-2013, 12:39 PM   #94
jdm_mica's Avatar
Just to clarify, the check valve needs to be connected on the hose attached to the intake manifold? Once that is done, will i need to swap the hoses attached to the can? Swap the bottom, to the top. vice versa? Intake hose goes on bottom of the can?
Streetunit testpipe
Autotech internals
NGK LTR7Ix-11
Corksport RMM
HKS turbo timer
 Old 02-22-2013, 01:05 PM   #95
Yes. Intake hose goes on the top. PCV hose Hose on the bottom. Arrow on the CV must be pointing towards the intake manifold.
 Old 02-22-2013, 01:12 PM   #96
jdm_mica's Avatar
So check valve on intake hose pointing towards the manifold. Most likely in the ^ position
Streetunit testpipe
Autotech internals
NGK LTR7Ix-11
Corksport RMM
HKS turbo timer
 Old 02-22-2013, 01:18 PM   #97
KevMS6's Avatar
Posts: 316   (View Stats)
I presume it's fine to install this the way corksport suggests if we choose to?
Tuned with by
 Old 02-22-2013, 01:48 PM   #98
You can do whatever you want but I would never suggest it. Pulling the oil that the OCC doesn't capture back in through your intake, turbo, then through the inter-cooler is NOT a good idea.
 Old 02-22-2013, 03:16 PM   #99
KevMS6's Avatar
Cheers Jamie - I'll stick to your instructions
Tuned with by
 Old 03-04-2013, 02:50 PM   #100
jdm_mica's Avatar
So just got around to fixing my catch can. Check valve points towards intake manifold nipple, just unscrew both sides and reverse it. Doing it a second time, made this pretty simple. Just hate the lack of space on our cars. Looking forward to the junk that comes out
Streetunit testpipe
Autotech internals
NGK LTR7Ix-11
Corksport RMM
HKS turbo timer
The Following User Says Thank You to jdm_mica For This Useful Post:
JBR (03-04-2013)
 Old 03-04-2013, 05:13 PM   #101
This is what I just pulled from mine around 4k miles. It usually is much darker. This look normal?
Is it possible that methanol is making its way down into the occ breaking down the oil? Just checked all my fittings and they are fine.
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
 Old 03-04-2013, 05:35 PM   #102
Doubtful. Looks like condensation to me.
Rokusek (03-04-2013), thatsmrgimp2u (03-07-2013)
 Old 03-05-2013, 05:40 PM   #103
agentgordon27's Avatar
Posts: 560   (View Stats)
Either that or someone pissed in your oil
Stock as fook.
 Old 03-06-2013, 06:21 PM   #104
bzwyatt's Avatar
Posts: 543   (View Stats)
bzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the world
Groaned at 35 Times in 14 Posts
I've always gotten a couple ounces when I drained my OCC every 5k miles, at oil changes. Last time I got like 20 oz! I use an 8 oz water bottle and usually it is 1/4 filled, but this time I filled it and drained it twice, and filled it again halfway. Not sure why the difference, I use the same oil, I don't think I missed draining last time and anyway it was like 5 times as much, not just twice.
Anyway, lots of stuff in there, it works. Curious though, if there is a likely reason - is it normal to collect more/less at different times, and why might that be?
bzwyatt is offline   Reply With Quote
 Old 03-10-2013, 09:28 AM   #105
Ordered this with check valve and the EGR block off. I really think I would rather head off the dirty valves/oil in intake than wait till having to clean crap off and regret not doing this as soon as possible. I have 3000 miles now, hopefully they're still clean.
Stock as fook.
 Old 03-10-2013, 12:30 PM   #106
Dr. Speed's Avatar
Posts: 610   (View Stats)
Dr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the world
^^ Same here. Just under 3000 miles and I'll be installing my JBR OCC asap.
| 2012 CWP | Cobb AP + AT Internals | HTP 3" Intake | 91oct + DO WMI (D07, 50/50) + 3gal E85 | UR Test Pipe | cp-e TMIC | JBR Trilogy, OCC, EGR Block, SSB | TBC Bypass |
Freektuned - 313/351 - Stock DP
Dr. Speed is offline   Reply With Quote
 Old 03-11-2013, 07:35 PM   #107
Stock as fook.
The Following User Says Thank You to agentgordon27 For This Useful Post:
JBR (03-11-2013)
 Old 03-11-2013, 07:45 PM   #108
We have had such great success with our catch cans that sometimes we run out. Our apologies. I assure you it'll be worth the wait
-Jamie
 Old 03-11-2013, 08:10 PM   #109
Oh I know, it's supposed to be a compliment, just throwing a "I want it now!" tantrum.
*EDIT*
I will say this though, a lot of companies would just leave me hanging and let it go until it shipped out, JBR is proactive and sends an email 'splaining everything and expected ship times.
Stock as fook.
 Old 03-15-2013, 02:50 PM   #110
versyejr's Avatar
Posts: 31   (View Stats)
versyejr has a spectacular aura aboutversyejr has a spectacular aura about
Talking OCC for MS6
So, Jamie, when will you have them in stock again? And, any discounts available?
Thanx
versyejr is offline   Reply With Quote
 Old 03-15-2013, 05:44 PM   #111
Thanx
JBR 10% "It's a Fresh Start" Sale Storewide!!
As for "stock" can't speak for @jbarone; on that one.
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
 Old 03-15-2013, 06:42 PM   #112
I got an email from him on the 11th of March saying expected ship date from then was 2-weeks:
"Thanks for ordering with JBR! We are sorry to inform you that the Stage 2 Oil Catch Can Kit is currently out of stock. We are in the process of manufacturing more now. Expected ship date is about 2 weeks. You will be notified again when your order has shipped."
Stock as fook.
 Old 03-15-2013, 08:53 PM   #113
That is correct about another week or so. I'd order now and take advantage of the sale though. They'll ship as soon as they are finished.
agentgordon27 (03-31-2013), King Scumbag (03-15-2013)
 Old 03-31-2013, 04:05 PM   #114
Thanks for the lickity split shipping on the catch can and other shtuff, I have a question about the VTA setup. I am not fully bolted yet but will be there shortly along with an ethanol e-tune, will there be drive-ability issues with the VTA while still using a stage 1 OTS tune until then?
@jbarone;
Stock as fook.
 Old 04-01-2013, 06:42 AM   #115
@jbarone;
I don't suspect there will be but we have not tested this on a true Stage 1 car. I would either choose to wait or monitor things closely. Look for good oil production in the can and, if there's no smoke out of the tail pipe I'd say your fine.
-Jamie
Rokusek likes this.
agentgordon27 (04-01-2013)
 Old 04-09-2013, 08:13 AM   #116
ANITIX87's Avatar
Posts: 1,394   (View Stats)
ANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the world
Groans: 93
Groaned at 27 Times in 16 Posts
@jbarone; how is stock of these units looking? I am toying with the idea of getting a Stage2 because of the check valve.
I couldn't tell based on the images on your website, but is there a sight for how full the OCC gets?
How difficult is the install? I'm basically a complete noob.
TIS
TOTS
2012 Mazdaspeed3, CWP, Tech Package. COBB AccessPort V3, AUTOTECH HPFP Internals, JBR 3" Wide-path SRI+TIP, CP-E TMIC, UR 3" Test Pipe, CP-E Triton CBE, FORGE V2 BPV, DENSO ITV22 Plugs, JBR RMM 88a, JBR OCC, JBR RSB Kit, JBR Solid Shifter Bushings, CP-E Tow Plate, CorkSport ECU Relocation, TSW Nurburgring Bronze 18x7.5
alphasaur: "Fuck I just beat it to surprise tranny porn. Saw the dick right when I came fml"
ANITIX87 is offline   Reply With Quote
 Old 04-09-2013, 10:41 AM   #117
TIS
Out of stock, more in the making...1-2 weeks. No site. They leak, turn dark and become useless. I would not recommend a can with a site. The install is a bit of a job but, if you can read, our instructions are the best available and will walk you through it step by step.
-Jamie
ANITIX87 (04-09-2013), Menace1 (04-09-2013)
 Old 04-15-2013, 08:48 AM   #118
OCC's back in stock early.
Here's a shot for ya...Our shop PU after about 800 miles.
 Old 04-15-2013, 11:10 AM   #119
MMmMmmm Yummmayyy. Do you drain it until the can is empty (Just the contents drain out). Or will oil continue to flow if you leave the drain valve open?
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
 Old 04-15-2013, 11:49 AM   #120
Only the contents will drain out, nothing more.
JBR EGR Block Off Kits In Stock!! JBR JAMES BARONE RACING 137 03-21-2015 07:33 PM
06' - 2011 MAZDA 5 Short Shift Plate Kits In Stock!! JBR JAMES BARONE RACING 4 06-18-2010 07:38 AM
06' - 2011 MAZDA 3 Short Shift Plate Kits In Stock!! JBR JAMES BARONE RACING 3 06-18-2010 07:38 AM
Page generated in 0.59560 seconds with 33 queries
