| JAMES BARONE RACING JBR is a leading manufacturer of high-quality aftermarket parts for the Mazda community. We take pride in our reputation for providing the highest-quality performance products at the best values, and we back up that reputation with outstanding customer service and free shipping. We are committed to the Mazda platform and we actively partner with other members of the community in our selection, design, and testing of new products to make sure they meet their needs. We control every step in the engineering and fabrication process to ensure the highest standards of workmanship. The result is a line of products whose performance and reliability have been proven both on the street and on the track. Visit us at jamesbaroneracing.com |
| Approved MSF Vendor ![]() Join Date: Sep 2009
Rep Power: 7118 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,203
(Thread Starter) | Not Ranked : 0 score Details: JBR Under Mounted FMIC Piping Kit, 2007* - 2013** Mazdaspeed 3 for TreadStone TR8, TR8L or TR6 Intercoolers ![]() The OEM top mount intercooler is sufficient for stock horsepower but, for those wanting to make more, it simply isn't capable of providing the cooling capacity necessary. To make more power, the OEM top mounted intercooler needs to be removed and replaced with a larger front mounted intercooler. The JBR Under Mounted Front Mounted Intercooler Piping Kit for the 2007 – 2013 Mazdaspeed 3 makes that possible, easily and more effectively than any other piping kit on the market. The JBR Under Mounted Hot Side Piping Kit is designed to fit all clocked OEM/BNR and most big turbo setups. ![]() Routing the piping beneath the motor reduces the amount of hot side charge piping by 12-16% when compared to other kits on the market. Reducing the amount of piping decreases turbo spool up time, reduces boost temperatures and makes for an impressive, almost sleeper looking engine bay. The JBR kit is constructed from mandrel bent 6061 aluminum piping and 7 layer hi-strength thick walled silicone hoses and couplers. All of which is tucked neatly above the belly pan. Routing the piping beneath the motor reduces the amount of hot side charge piping by 12-16% when compared to other kits on the market. Reducing the amount of piping decreases turbo spool up time, reduces boost temperatures and makes for an impressive, almost sleeper looking engine bay. ![]() Upon exiting the intercooler, the cool boost air enters another one piece, high strength, thick walled silicone hose and travels from there, all the way to the intake manifold. Silicone has a very low heat transfer coefficient so, the hot ambient air in and around the engine bay will not be able to penetrate through all of the layers of silicone therefore, the cold air you just spent $800 to get cool, will stay cool. All other kits currently on the market have several couplers, elbows, and connections long before ever reaching the intake manifold. Not only does that make for a difficult installation but the potential for leaks is drastically increased. Application: 2009 – 2013 Mazdaspeed 3 Best when used with a Treadstone *TR8, TR8L or **TR6 Intercooler All kits will include coolant and vacuum hose necessary to clock your turbo. Features: - Designed, Engineered and Manufactured in the USA - Black wrinkle coated aluminum piping - Mounting bracket to secure the piping beneath the motor - 7 layer High strength, thick walled silicone hoses and couplers - Stainless T-bolt clamps JBR FMIC Piping Kit Includes: - Hot and cold side piping - BPV Adapter flange and mounting hardware - 8 Stainless T-bolt clamps - 1 mounting bracket for hot side piping - 1' of coolant hose - 1' of vacuum hose - Waste gate actuator & coolant Pipe mounting brackets (OEM/BNR KIT) - TR8 and TR6 Mounting Brackets* (2007 - 2009 ONLY) - Installation instructions are available in our support section - Shipping is free in the US & our Hassle Free Lifetime Warranty is included * 2007 - 2009 Mazdaspeed requires core mounting brackets that are included with this kit **2010 - 2013 Mazdaspeed with TR8 intercooler requires a crash bar. 2010 - 2013 TR6 intercooler requires mounting brackets but no crash bar. ![]() ![]() ![]() ![]() Last edited by JBR; 04-09-2015 at 12:18 PM. |
| The Following 17 Users Say Thank You to JBR For This Useful Post: | Addikted To Boost (05-26-2015), A_tired_goose (05-27-2015), Benis (04-12-2015), Big_Burd (04-11-2015), chrismazda6 (04-11-2015), Code Monkey (04-10-2015), dan7225 (05-20-2015), Dralphy (05-26-2015), kpuser1 (04-11-2015), Mauro_Penguin (04-09-2015), MD1032 (04-11-2015), mituc (04-12-2015), nomorecivic! (04-11-2015), ryguy 3 (04-10-2015), SpeedRebirth (04-09-2015), trancehead (04-09-2015), [R]usty (04-09-2015) |
![]() Join Date: Jul 2014 Location: San Antonio, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 97
| Not Ranked : 0 score That looks awesome! So much better looking and less clutter than all those over-the-top kits. Great work
__________________ 2012 MazdaSpeed3 with Tech Stock AF |
![]() Join Date: May 2014 Location: Coopersburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 186
| Not Ranked : 0 score I wish I had a grand to drop on getting the whole setup + crash bar. Oh well...I'll just wait for my next tax return I guess lol |
| The Following 2 Users Say Thank You to broda For This Useful Post: | Castillo817 (04-10-2015), JBR (04-12-2015) |
![]() Join Date: Aug 2009 Location: Hershey, PA
Rep Power: 265 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 84
Groaned at 7 Times in 4 Posts
__________________ '06 MS6: BNR S3//CP-E FMIC//Forge V3/CP-E Nano Intake//TIP//DNP Swain Tech Coated Exhaust Mani//CP-E Catted Swain Tech Coated DP//Magnaflow CBE//CP-E RMM & TT Rear Diff Mount//PnP & Coated Intake Mani// VCTS and EGR delete//GS EBCS//3 Bar MAP//RMM//SafeSeals//PT-P FP Internals//TWM Stage II STS//SSP//Saikou Michi OCC//Snow Stage 2 WMI w/ D07 nozzle//Cobb AP V3//RICH TUNE!//Stoptech Slotted Rotors and EBC RedStuff Pads//H&R springs w/spacers//Bilsteins//SPC Balljoints//AeroForce ScanGauge & WideBand//Snow Performance WMI Failsafe & Guardian Angel//Morimoto HID Projector Upgrade//Hella HID Fogs |
| The Following 2 Users Say Thank You to MazdaspeedKills For This Useful Post: | kgb (04-09-2015), Rmurray603 (04-09-2015) |
![]() Join Date: Aug 2013 Location: Alpharetta GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 58
| Not Ranked : 0 score Fantastic, im weird and the one reason I don't want to go FMIC yet is cause I dont like the piping going over top.
__________________ 2008 Mazdaspeed 3 GT - Cobb SRI, HKS BOV, Cobb AP V2, Sure RMM, EBC Front Rotors, Hawk HPS, ROCA PMM, Yokohama YK580, SenSen Rear shocks Planned: Cobb TIP, Autotech HPFP, MattD RMM, Koni Street Shocks/struts |
| Not Ranked : 0 score Outstanding! I'm going to go order mine right awa...... wait, what? Really? Oh. <<sigh>> Oh well..... <sniff>
![]() Join Date: Sep 2014 Location: SoCal from NC and NYC
| Not Ranked : 0 score great design. it works out for those who likes to keep people in the dark about your installs
__________________ __________________ 2012 Black MazdaSpeed3 Power: GTX3076R IWG / COBB EBCS / Bosch MAP Sensor Adapter Harness / Bosch 3 Bar T-MAP MAP Sensor with IAT / JBR TRU-3.5 / DM EGR Delete Kit / FORGE V1 BPV / AUTOTECH HPFP INTERNALS / UR TBE / UR DP / UR SP / NGK IRIDIUM IX / COBB SW / UR FMIC / MD OCC V1 & V2 / BrassCraft Coolant Bypass / RC IM Mani / cp-e Exi Mani / ZZB REPLACEMENT / Handling: DM TMM / DM RMM / DM PMM / JBR FSB / JBR RSB / JBR RTA / CS FEL / SPC CAMBER ARMS / BCRacing COILOVERS / GTSPEC STB /FRONT EBC YELLOWS / FRONT EBC SLOTTED ROTORS / GOODRIDGE SSL / TWM STS /RPF1 17x9 Wheels / 225/45-17 Toyo Proxes S4 / ACT ZX4-HDG6 / Extra Safety: COBB AP V3 / AEM WIDEBAND FAILSAFE (AFR) / V1 / AEM TRU BOOST / CS Skidplate / Innovate Motorsports MTX-D: Oil Pressure & Temperature / Fuel: 91 & 93 Octane / Looks: VENTPOD / JTMS3 DUAL POD / RB MUD FLAPS / Black Glossified Dipped Stock Wheels / GV OPEN MOUTH GRILL / JBR SHIFT KNOB / Black Powder Coated Front Calipers with Green MazdaSpeed Decals / Green Cabin and Trunk 8K Lights / Green Demon Headlights with black painted housing and RBG halo rings / RC signature VC / JTMS3 Stealth Sub Enclosure with a 10" JL Swallow Sub / baysonR MS-Style Lip Kit / COMING SOON AEM METH KIT / Anti Laser Priority /CS Radiator Panel / CS Rear Chassis Brace / CS Mid-Chassis Brace / CS Hood Scoop / DYNO TUNED by HYPNOTIC 93 and STREET TUNED on 91 soon e85 mix |
![]() Join Date: Mar 2010 Location: Tampa/Zephyrhills, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 80
| Not Ranked : 0 score @jbarone are you still going to offer us who already purchased your fmic kit any kind of discount on the hot side piping kit?
__________________ 2008.5 CPW JBR:3.5 intake, fmic, r51 Battery Box, Ancors, EGR Delete, Thermal Spacers, 5mm Wheel spacers, Shift plate. Matt Dimond OCC, Autotech Internals, CNT catted downpipe, itv-22, Threadstone T8L FMIC,SU Turbosmart Bpv, SUv2 Rmm |
| The Following User Says Thank You to mazdamx3freak For This Useful Post: | JBR (04-11-2015) |
![]() Join Date: Apr 2011 Location: HOFFMAN ESTATES IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 30
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score Too bad i ve just recently got installed a front intercooler and wont be able to get this JBR one for a while ..i guess until i ll ubgrade my turbo and then i ll need a bit bigger intercooler kit to support the bigger psi ..its no doubt that this kit is a lot smarter by definition in all aspects , very good job JBR!! U guys have also the best MM kit it was well worth to take down the previous "brand" and go with the 88Duro ![]() oh yeah |
Rep Power: 1237 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,288
Groans: 111
| Not Ranked : 0 score I guess this kit will work with a larger inlet turbo (4") with just an adapter. If it does this kit may risk becoming the last FMIC piping kit you will ever need.
![]() Join Date: May 2010 Location: Benton, AR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,028
| Not Ranked : 0 score What does the turbo Inlet have to do with anything?
__________________ 2010 Mazdaspeed 3 Liquid Silver Metallic HTA 3076 | HTP 4" Intake, battery tray, under mount piping | CPE Exhaust Manifold, downpipe, FMIC & Stage 2 RMM | MD TMM and PMM | Tial MV-R ewg w/ Kozmic dump tube | VCTS delete/Ported IM | JBR OCC, EGR delete, BSD w/ oil pan baffle & RSB | SP63 Oil Cap Breather | Synapse SB BPV | UR CBE | Autotech HPFP | H & R Coilovers | Whiteline Endlinks | Manley Pistons & Rods | L19 Head Studs | Kozmic 6th Port w/ DW65c ITFP | Snow Performance Stg 2 Meth | JMF Manifold | SouthBend Stg 3 Endurance Clutch | Tuned with |
| The Following User Says Thank You to jdmage_mx5 For This Useful Post: | mituc (04-12-2015) |
Groans: 111
| Not Ranked : 0 score You are right, that's on the intake side.
![]() Join Date: Jul 2014 Location: Waukesha, WI
Rep Power: 161 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 113
__________________ "RACING IS AN ADDICTION CURED ONLY BY POVERTY" Last edited by RusianKid; 05-14-2015 at 11:57 AM. |
| The Following 10 Users Say Thank You to RusianKid For This Useful Post: | Addikted To Boost (05-26-2015), Awal (05-15-2015), A_tired_goose (05-27-2015), dan7225 (05-20-2015), G1sdaname (05-19-2015), JBR (05-14-2015), JgamB (05-17-2015), Killer95GT302 (05-14-2015), mazdaspeedmyk (05-14-2015), Murcielago311 (05-14-2015) |
(Thread Starter) | Not Ranked : 0 score Looks so stock and sleeper too. I was wondering when we'd see someone post. We've sold so many of these. Hope to see more. |
![]() Join Date: Oct 2012 Location: Annapolis, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 35
| Not Ranked : 0 score Would love to have my 6 engine bay looking like that - everything so easily worked on
__________________ 2006 Mazdaspeed6 - Bone Stock! 1995 Mustang GT - Turbocharged / Motor work |
| The Following User Says Thank You to Killer95GT302 For This Useful Post: | ESA (05-27-2015) |
| Not Ranked : 0 score Now I just need to paint the valve cover and clean my engine bay!
__________________ "RACING IS AN ADDICTION CURED ONLY BY POVERTY" |
![]() Join Date: Jan 2014 Location: Atlanta, GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 260
| Not Ranked : 0 score I'll be posting pictures of install, hopefully soon. Sent from my iPhone using Tapatalk
__________________ CP-E Catted TBE | COBB: AP, RMM, EBCS | AutoTech Internals | Wheels - Montegi R116 BNR3 | JBR: Tru 3.0 Intake, Under-engine FMIC piping, SSP | TR8 | TurboSmart BPV MilTuned - e85 Next up: Make more money for Meth (2x) -Gabe- |
| The Following User Says Thank You to G1sdaname For This Useful Post: | JBR (05-19-2015) |
| Not Ranked : 0 score @jbarone; with BNR3 is the waste gate actuator mounting bracket needed? Sent from my iPhone using Tapatalk
No you don't Sent from my iPhone using Tapatalk
__________________ "RACING IS AN ADDICTION CURED ONLY BY POVERTY" | |
(Thread Starter) | Not Ranked : 0 score As mentioned The BNR S2 and S3 do not need the actuator bracket we offer. They can be clocked with actuator bracket they come with. The BNR S1 does require the bracket we offer. -Mike |
| The Following User Says Thank You to JBR For This Useful Post: | G1sdaname (05-22-2015) |
| Not Ranked : 0 score Anyone have a picture of a clocked BNR3? The JBR instructions show a stock turbo being clocked and the small difference is throwing me off, on step 6 page 4 I can't determine if that's how it should look or if that's where I start before clocking. This is after clocking the turbo as you can see the actuator bracket doesn't fit like this. ![]() Here is a picture of the instructions. ![]() This is how I figure it actually fitting, but I'm likely wrong. ![]() Sent from my iPhone using Tapatalk
![]() | | #24 | ![]() |
![]() Join Date: May 2010 Location: SLC, Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score That would shoot it up at your windshield.
__________________ 2009 MGM MS3 - / HTP 3"/ COBB AP, FMIC, RMM, & DP / AT Internals / Manley Rods & Pistons / ARP studs & bolts / Koyorad radiator / DM OCCs / ACT Clutch / Bilstein B16 / CS Camber Plates, Camber Arms, & Seals / JBR .125 RSB, BSD, 51R Battery Box & Raider's AD / StopTech Brakes |
![]() | | #25 | ![]() |
![]() Join Date: Nov 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 36
| Not Ranked : 0 score I am getting all excited. This is a killer set up.
__________________ 2013 Genpu GT, 245/40 Direzzas, CS SRI+TIP,CS TP+CB, CS TMIC, CS FP Internals, CS 80a RMM, CS BPV, Accessport V3, Tuned by Nishan |
![]() | | #26 | ![]() |
| Not Ranked : 0 score I'm hopeless , you are right if I picture it installed it definitely don't make sense. Sent from my iPhone
![]() | | #27 | ![]() |
It will make it much easier on the future clocked BNRs
| The Following User Says Thank You to RusianKid For This Useful Post: | Awal (05-27-2015) |
![]() | | #28 | ![]() |
| Not Ranked : 0 score Found this diagram and the EM connects from top. so yes it's definitely pointing in the wrong direction. So from the instructions it should be facing this way but the problem is the actuator bracket doesn't fit correctly. ![]() This hole doesn't align to bolt up the bracket. ![]() @jbarone; can you please point me in the right direction on clocking the BNR3? Thanks Sent from my iPhone
__________________ CP-E Catted TBE | COBB: AP, RMM, EBCS | AutoTech Internals | Wheels - Montegi R116 BNR3 | JBR: Tru 3.0 Intake, Under-engine FMIC piping, SSP | TR8 | TurboSmart BPV MilTuned - e85 Next up: Make more money for Meth (2x) -Gabe- Last edited by G1sdaname; 05-25-2015 at 09:43 PM. |
![]() | | #29 | ![]() |
| Not Ranked : 0 score Ok maybe it does fit after you start bending things. ![]() Sent from my iPhone
| The Following 3 Users Say Thank You to G1sdaname For This Useful Post: |
![]() | | #30 | ![]() |
![]() Join Date: Sep 2008 Location: Lynchburg, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,559
| Not Ranked : 0 score could you elaborate on which part of the arm you bent to make it work?
__________________ 09 MGM MS3 BNR S3 V2, Freek'd Corn Toon, Cobb AP V3, Cobb FMIC w/ JBR piping, JBR WP 3.5 silicone, Cobb EBCS, Turbo XS Catless DP and TP, CPE Nexus CBE, Autotechs, GFB Hybrid BPV, Damond Trilogy mounts (FTMFW), Bilstein B14 Coils, RX8 R3s |
![]() | | #31 | ![]() |
(Thread Starter) | Not Ranked : 0 score ^^You nailed it Sir!^^ Tweaking and adjusting the actuator arm will be necessary for the bracket to come in to place. |
![]() | | #32 | ![]() |
| Not Ranked : 0 score I didn't bend the rod, I just placed the bolt on the right hand side of the picture and forced the bracket to be able to fit the second screw. JBarone says you can bend the rod but I haven't tried it yet. Likely need to bend the tip of the rod upwards and should give a little better clearance so it doesn't feel so forced. Sent from my iPhone
![]() | | #33 | ![]() |
__________________ 09 MGM MS3 BNR S3 V2, Freek'd Corn Toon, Cobb AP V3, Cobb FMIC w/ JBR piping, JBR WP 3.5 silicone, Cobb EBCS, Turbo XS Catless DP and TP, CPE Nexus CBE, Autotechs, GFB Hybrid BPV, Damond Trilogy mounts (FTMFW), Bilstein B14 Coils, RX8 R3s | |
![]() | | #34 | ![]() |
(Thread Starter) | Not Ranked : 0 score This will do it. Bend the main section of the rod up and the very end down a bit. |
| The Following 3 Users Say Thank You to JBR For This Useful Post: |
![]() | | #35 | ![]() |
(Thread Starter) | Not Ranked : 0 score You can loosen the jamb nut on the actuator rod to get the end to rotate if needed. |
| The Following User Says Thank You to JBR For This Useful Post: | Addikted To Boost (05-26-2015) |
![]() | | #36 | ![]() |
![]() | | #37 | ![]() |
(Thread Starter) | Not Ranked : 0 score I think they would be better situated to address those questions. | |
| The Following User Says Thank You to JBR For This Useful Post: | Mauro_Penguin (05-27-2015) |
![]() | | #38 | ![]() |
Do you think the Corksport turbo is compatible with your kit, but I am glad to bring humor to your day instead.
| The Following User Says Thank You to RusianKid For This Useful Post: | JBR (05-27-2015) |
![]() | | #39 | ![]() |
The question that needs to be answered is...Can the CS turbo be clocked 180 degrees and will the actuator function properly? They should already have the answer to this. If it cannot be then obviously it will not work with our under mounted kit or any other under mounted kit. | |
| The Following 2 Users Say Thank You to JBR For This Useful Post: | OverBoosted (05-27-2015), RusianKid (05-27-2015) |
![]() | | #40 | ![]() |
| New Product Release!! Raider's Air Damn 2007 - 2009 Mazdaspeed 3 | Raider | JAMES BARONE RACING | 67 | 12-29-2017 02:24 PM |
| New Product Release! JBR FMIC Crash Bar for 2010 - 2013 Mazdaspeed 3 | JBR | JAMES BARONE RACING | 15 | 03-27-2017 08:25 AM |
| GI: JBR Under Mounted Hot Side Piping Kit 2007 - 2013 Mazdaspeed 3 | JBR | JAMES BARONE RACING | 94 | 06-07-2016 10:00 AM |
| New Product Release! JBR FMIC Piping Kit, 2007 - 2009 Mazdaspeed 3 | JBR | JAMES BARONE RACING | 13 | 02-08-2015 04:38 PM |
| New Product Release! JBR FMIC Piping Kit, 2010 - 2013 Mazdaspeed 3 | JBR | JAMES BARONE RACING | 19 | 01-25-2015 09:37 PM |
