 Old 10-28-2016, 11:07 AM   #1
Exclamation New Product Release!! Focus ST Oil Cooler Kits in Stock!
Details:
Are you tuned? Are you a track Junkie? Are you both? Within 10 minutes of being on track or an evening of repeatedly putting a few car lengths on your buddies STI, the oil temperature and coolant temperatures in your Focus ST can begin to rise in to unsafe territory which can eventually lead to overheating. Either of these conditions or a combination of both will result in prolonged excessive oil temperatures that prematurely breaks down the oil and increases engine wear.
The JBR Focus ST Oil Cooler Kit employs a 19 row core constructed out of aluminum corrugated-fins & internal tubular plates greatly increasing both thermal efficiency and mechanical strength, so you get the smallest, lightest and more importantly, the most efficient oil cooler package.
Custom length commercial grade -10AN fittings and large ID stainless braided lines are the key to minimizing the pressure drop and making for an easy installation.
The polished billet aluminum sandwich plate incorporates 2, 1/8” NPT ports for additional gauges and sensors.
Custom mounting brackets and stainless steel hardware keep the core solidly mounted out front of the radiator maximizing its exposure to incoming airflow resulting in an oil temp reduction of over 30⁰F.
Features:
  • Designed and Manufactured in the USA
  • Direct bolt on application
  • Corrugated-fin & tubular plate aluminum core
  • Commercial grade –AN10 fittings and large ID Stainless lines
  • +30⁰ drop in oil temps
Includes:
  • 1 Oil cooler core
  • 2 Stainless braided hoses
  • 1 Sandwich plate & 2 1/8” NPT Plugs
  • 2 Application specific core mounting brackets
  • 2 Aluminized fiber glass heat shield sleeves
  • Stainless steel mounting hardware
 Old 10-28-2016, 12:51 PM   #2
ThOrZwAr's Avatar
Posts: 43   (View Stats)
ThOrZwAr has much to be proud ofThOrZwAr has much to be proud ofThOrZwAr has much to be proud ofThOrZwAr has much to be proud ofThOrZwAr has much to be proud ofThOrZwAr has much to be proud ofThOrZwAr has much to be proud ofThOrZwAr has much to be proud ofThOrZwAr has much to be proud ofThOrZwAr has much to be proud of
Default wat?
...wrong forum?
2012 MS3 - FreekTuned - 93 tune: 332/310 - E25 tune: 377/356
CS Stage II SRI/TIP // CS Turbo // CS EBCS // CS 3.5 MAP // CS HPFP // CS BPV // CS OCC // SU TMIC // ATP Catless Long DP // JBR 88 Duro RMM // Damond PMM/TMM // CS Front Strut Bar // CS Rear Sway Bar // EBC Redstuff Pads // EBC Rotors // Cobb V3 AccessPort // NGK Plugs (step colder)
ThOrZwAr is offline   Reply With Quote
 Old 10-28-2016, 01:20 PM   #3
Originally Posted by ThOrZwAr View Post
...wrong forum?
Bingo (10-28-2016), knocturnal (11-07-2016), monkey.bones.007 (10-30-2016), MS3Shadow (10-28-2016), SaveMelMac (10-28-2016)
 Old 10-28-2016, 06:01 PM   #4
ThOrZwAr's Avatar
Default :/
Touché sir... touché.
 Old 10-28-2016, 09:01 PM   #5
BuddySpeed3's Avatar
Posts: 479   (View Stats)
Groaned at 7 Times in 4 Posts
So this does indeed work with our platform?
Does this only work with the spin on filters? Or does it work with the cartridge ones as well?
Thanks!
 Old 11-07-2016, 01:02 PM   #6
knocturnal's Avatar
Posts: 266   (View Stats)
Kit looks great. I hope that is able to fit on our cars
Mods:
Stratified Tuned Stage 2 OTS+
273whp/330wtq
SnailD Tuned on Meth
316whp/359wtq
412whp/373wtq
New Product Re-Release!! FST and MS3/6 Oil Catch Can Kits JBR JAMES BARONE RACING 17 01-16-2017 07:28 AM
New Product Release!! Focus ST Oil Pan Baffle Kits!! JBR JAMES BARONE RACING 2 01-09-2016 07:02 PM
New Product Release!! Ford Focus ST Sound Symposer Block-off and Delete Kits JBR JAMES BARONE RACING 11 07-24-2015 08:58 PM
New Product Release!! Ford Focus ST Mud Flap Kits JBR JAMES BARONE RACING 0 05-11-2015 12:41 PM
New JBR Product Release!! - Focus ST Driver's Side Transmission Mounts in stock!! JBR JAMES BARONE RACING 4 03-07-2014 10:47 AM
Page generated in 0.29218 seconds with 23 queries
