Like Tree4Likes
  • 2 Post By JBR
  • 1 Post By [R]usty
  • 1 Post By Addikted To Boost
 Old 11-25-2014, 12:00 PM   #1
Arrow New Product Release! JBR FMIC Piping Kit, 2010 - 2013 Mazdaspeed 3
We only have 18 of these kits until January of 2015
The OEM top mount intercooler is sufficient for stock horsepower but, for those wanting to make more, it simply isn't capable of providing the cooling capacity necessary. To make more power, the OEM top mounted intercooler needs to be removed and replaced with a larger front mounted intercooler. The JBR Front Mounted Intercooler Piping Kit for the 2010 – 2013 Mazdaspeed 3 makes that possible, easily and more effectively than any other piping kit on the market.
Thin walled aluminum piping carries hot boost air from the turbo all the way to the base of the radiator. Aluminum was chosen here for its very high heat transfer coefficient. Meaning, boost temperature will begin to drop as soon as it exits the turbo. At the base of the radiator the aluminum then transitions to a one piece, high strength thick walled silicone hose, which then wraps around the core support and in to the intercooler. This design significantly reduces the typical number of connections, simplifies the installation and greatly lowers the chances for leaks.
Upon exiting the intercooler, the cool boost air enters another one piece, high strength, thick walled silicone hose and travels from there, all the way to the intake manifold. Silicone has a very low heat transfer coefficient so, the hot ambient air in and around the engine bay will not be able to penetrate through all of the layers of silicone therefore, the cold air you just spent $800 to get cool, will stay cool. All other kits currently on the market have several couplers, elbows, and connections long before ever reaching the intake manifold. Not only does that make for a difficult installation but the potential for leaks is drastically increased.
Application:
2010 – 2013 Mazdspeed 3
Requires the use of a Treadstone TR8 Intercooler
Features:
  • Black wrinkle coated and polished aluminum piping
  • 7 layer High strength, thick walled silicone hoses
  • Stainless T-bolt clamps
JBR FMIC Piping Kit Includes:
  • Hot and cold side piping
  • BPV Adaptor flange and mounting hardware
  • 7 Stainless T-bolt clamps
Mauro_Penguin and [R]usty like this.
Code Monkey (01-01-2015), Jansi (11-25-2014), JgamB (11-25-2014), macdiesel (11-29-2014), Mauro_Penguin (11-25-2014), neotide87 (11-25-2014), turboKart (11-25-2014), XxSmarTz (11-25-2014), [R]usty (11-25-2014)
 Old 11-25-2014, 12:01 PM   #2
First
chaser27 (11-25-2014)
 Old 11-25-2014, 12:48 PM   #3
Putin 2.3T's Avatar
Posts: 1,040   (View Stats)
Second.
2011 Mazdaspeed 3 [Sold]
The Following 2 Users Say Thank You to Putin 2.3T For This Useful Post:
chaser27 (11-25-2014), Easter Bunny (01-09-2015)
 Old 11-25-2014, 01:26 PM   #4
[R]usty's Avatar
Posts: 2,204   (View Stats)
I like that this kit has all the bends in long single pieces. This will make finding boost looks and installation a lot easier. Makes me want to upgrade. Excellent work as always Jamie!
JBR likes this.
2010 Mazdaspeed3 w/tech
The Following 2 Users Say Thank You to [R]usty For This Useful Post:
Jansi (11-25-2014), JBR (11-25-2014)
 Old 11-25-2014, 01:37 PM   #5
Addikted To Boost's Avatar
Posts: 1,837   (View Stats)
So @jbarone; for the gen win kit, are we talking like 6 months, 6 weeks? Any guess?
Shwaykid likes this.
09 MGM MS3
The Following User Says Thank You to Addikted To Boost For This Useful Post:
09TrueRedGTX (11-25-2014)
 Old 11-25-2014, 03:00 PM   #6
January 2015.
Addikted To Boost (11-25-2014), Mauro_Penguin (11-25-2014)
 Old 11-25-2014, 04:00 PM   #7
January 2015.
Masterbaiter (01-01-2015)
 Old 01-01-2015, 10:09 AM   #8
murda's Avatar
Posts: 42   (View Stats)
murda has a reputation beyond reputemurda has a reputation beyond reputemurda has a reputation beyond reputemurda has a reputation beyond reputemurda has a reputation beyond reputemurda has a reputation beyond reputemurda has a reputation beyond reputemurda has a reputation beyond reputemurda has a reputation beyond reputemurda has a reputation beyond reputemurda has a reputation beyond repute
What's your inventory like on these currently? Did you sell out of the first batch?
2010 GTX2867r MS3 380whp/390wtq 94 pump gas
murda is offline   Reply With Quote
 Old 01-01-2015, 10:03 PM   #9
tytanium's Avatar
Posts: 137   (View Stats)
tytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant future
@jbarone; to use your kits with the TR8L is all that is required is an inch trim on each side of the piping?
2007 CWP MS3
Powered by Purple Drank @ 22psi // ATP GT2871r // J2 Engineering catless downpipe // Continental Extreme Contact DW 245/40/17 // Rays Gram Lights 57DR 17x9 // // CP-e Nexus catback // resonator delete // Damond Motorsports rmm // GoFastBits bov // Maisonvi piston style shift knob // Cobb shift weight // Street Unit testpipe // Cobb Accessport V3 // JBR shifter bushings // Treadstone TR8L // JBR intercooler piping // Damond Motorsports power steering cooler // Denso 1-step colder plugs // Ramfab 4" intake // coolant bypass // Damond Motorsports egr block-off // Rally Armor mudflaps // Defi boost gauge // 3 bar MAP sensor // 3 port ebcs // Stratified Guardian Angel // JBR short shifter // Hotchkis rear sway bar // Stoptech ss brake lines // Centric premium brake rotors // Powerstop Z23 brake pads // Koni yellow shocks // Corksport springs // MOOG front and rear endlinks
tytanium is offline   Reply With Quote
 Old 01-05-2015, 03:37 PM   #10
Jkelley's Avatar
Posts: 218   (View Stats)
Jkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the world
January 2015.
it's january 2015
2008 Mazda Mazdaspeed3 GT (True Red) SOLD
~Mods: ATP GTX3071r IWG, JBR Tru 3.5" WP, UR V2 3" catless DP & TP, Tr8+JBR FMIC, Turbosmart BPV, CP-e HPFP, NGK 6510, Bosch 3bar MAP, Cobb 3-port EBCS, PERM PCV Plate, Damond OCC (1sealed, 1 VTA), Kozmic 1°/Damond 2° EGR Delete, Corksport seals, CP-e RMM 75A, JBR side MM 80A, Cobb AP V2, spin-on oil conversion, KSport Coilovers, SPC Performance Camber Arms, JBR IM/TB TIG, SURE Anchors
~~332whp @5300rpm / 354wtq @4800rpm @ 21psi on 91oct FREEKTUNED
~~380whp @6500rpm / 367wtq @4800rpm @ 20psi on e33 FREEKTUNED
2007 Mazda CX-7 (Burgundy Wine) SOLD
Jkelley is offline   Reply With Quote
 Old 01-05-2015, 04:27 PM   #11
Originally Posted by Jkelley View Post
it's january 2015
January has a few more days left but here's a few pics to chew on.
Cheese5.0 (01-05-2015), kpuser1 (01-05-2015), Mauro_Penguin (01-06-2015), MOCO MS3 (01-06-2015), Putin 2.3T (01-06-2015), Shwaykid (01-06-2015)
 Old 01-06-2015, 07:48 AM   #12
Jkelley's Avatar
Awesome, can I preorder?
 Old 01-06-2015, 12:01 PM   #13
PoetryInMotion's Avatar
Posts: 171   (View Stats)
PoetryInMotion has a reputation beyond reputePoetryInMotion has a reputation beyond reputePoetryInMotion has a reputation beyond reputePoetryInMotion has a reputation beyond reputePoetryInMotion has a reputation beyond reputePoetryInMotion has a reputation beyond reputePoetryInMotion has a reputation beyond reputePoetryInMotion has a reputation beyond reputePoetryInMotion has a reputation beyond reputePoetryInMotion has a reputation beyond reputePoetryInMotion has a reputation beyond repute
oh those bends are sick
2013 GenPU
PoetryInMotion is offline   Reply With Quote
 Old 01-06-2015, 02:07 PM   #14
prototype_x9's Avatar
Posts: 174   (View Stats)
prototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the world
Hmmm I just got my ets, but I will probably buy the gen1 kit. A fmic is happening in 2015
07 GT: JBR 3.5 wide path intake, FMIC, 51R small battery, grimmspeed EBCS, Cobb DP
3Bar map sensor, Kozmic primary and secondary EGR deletes, Bilstein PS14, whiteline endlinks,
hawk brake pads, rear camber arms. Speedbakery tuning in the works
prototype_x9 is offline   Reply With Quote
 Old 01-09-2015, 03:41 PM   #15
Jkelley's Avatar
I check this thread daily 😔
 Old 01-25-2015, 03:14 PM   #16
murda's Avatar
I'd like to add some input in to this kit for the gen2 with my GTX2867r. The 2.5-2 inch reducer provided with this kit is too short to reach this turbo. I've had to outsource a longer reducer, one that's 5 inches long. This should be long enough to reach the turbo.
 Old 01-25-2015, 05:09 PM   #17
Are saying the reducer coupler we supply should be 5" in length? If it was the hot side pipe would be too high for use with stock turbo.
We can get longer reducer couplers or increase the leg on the hot side pipe.
 Old 01-25-2015, 05:23 PM   #18
murda's Avatar
Exactly. The one supplied for the stock turbo is 2.5 or 3 inches long? And its a couple inches short of reaching this particular turbo. Its actually difficult to find 5" long reducers. Most of them are around 3 maybe 4", but I did eventually find one.
 Old 01-25-2015, 07:24 PM   #19
ShadowHunter117's Avatar
Posts: 55   (View Stats)
ShadowHunter117 is a splendid one to beholdShadowHunter117 is a splendid one to beholdShadowHunter117 is a splendid one to beholdShadowHunter117 is a splendid one to beholdShadowHunter117 is a splendid one to beholdShadowHunter117 is a splendid one to beholdShadowHunter117 is a splendid one to behold
You mind sharing where you found yours? I have the exact same turbo so I will need one as well.
@jbarone; maybe you could offer a longer reducer coupler option for people with turbos that need them?
2011 Black Mica MS3
Engine: HTP 3.5" Intake, HTP Small Battery Box, GTX2867R Turbo, TR6 Intercooler w/CX Racing Pipe, PNP Stock Intake Mani w/ VTC Delete, Steadspeed Exhaust Mani, CNT Catted DP, 3" Magnaflow Exhaust, Autotech HPFP Internals, JBR OCC, JBR EGR Delete, 3-bar MAP Sensor, Grimmspeed EBCS, Forge BPV V2, Stratified Tuned
Handling: CS Lowering Springs, JBR Rear Swaybar, JBR PMM/TMM(70 duro) RMM(88 duro), GTSPEC Chassis Braces(Except trunk), Front Strut Tower Bar, 17x9 TRMotorsports C3 Wheels w/ 245/40ZR17 Michelin Pilot Sport A/S 3
Waiting to Install: Stratified Guardian Angel, Snow Performance Stage 2 Meth Kit w/Failsafe and Trunk Mount Tank
ShadowHunter117 is offline   Reply With Quote
 Old 01-25-2015, 09:37 PM   #20
murda's Avatar
PM sent. I don't want to crap on this thread.
New Product Release! JBR FMIC Crash Bar for 2010 - 2013 Mazdaspeed 3 JBR JAMES BARONE RACING 15 03-27-2017 08:25 AM
Cx racing piping or pg piping for my fmic blake0521 2010 MS3 - Turbo Induction 34 09-25-2014 03:51 PM
CorkSport Product Release: Mazdaspeed 2010-2013 Single Exit Exhaust CorkSport CorkSport 62 04-11-2014 10:01 AM
Product Release! CorkSport Gen 1 Mazdaspeed 3 FMIC Radiator Shroud CorkSport CorkSport 16 08-25-2013 07:33 PM
Product Release! CorkSport Mazdaspeed 6 FMIC for SRI CorkSport CorkSport 15 06-08-2012 03:04 PM
Page generated in 0.40976 seconds with 30 queries
