Like Tree8Likes
  • 3 Post By JBR
  • 1 Post By exentix
  • 1 Post By Shwaykid
  • 1 Post By JBR
  • 1 Post By tytanium
 Old 02-03-2015, 10:50 AM   #1
Arrow New Product Release! JBR FMIC Piping Kit, 2007 - 2009 Mazdaspeed 3
Details:
JBR FMIC Piping Kit, 2007 - 2009 Mazdaspeed 3 for TreadStone TR8 Intercooler
The OEM top mount intercooler is sufficient for stock horsepower but, for those wanting to make more, it simply isn't capable of providing the cooling capacity necessary. To make more power, the OEM top mounted intercooler needs to be removed and replaced with a larger front mounted intercooler. The JBR Front Mounted Intercooler Piping Kit for the 2007 – 2009 Mazdaspeed 3 makes that possible, easily and more effectively than any other piping kit on the market.
Thin walled aluminum piping carries hot boost air from the turbo all the way to the base of the radiator. Aluminum was chosen here for its very high heat transfer coefficient. Meaning, boost temperature will begin to drop as soon as it exits the turbo. At the base of the radiator the aluminum then transitions to a one piece, high strength thick walled silicone hose, which then wraps around the core support and in to the intercooler. This design significantly reduces the typical number of connections, simplifies the installation and greatly lowers the chances for leaks.
Upon exiting the intercooler, the cool boost air enters another one piece, high strength, thick walled silicone hose and travels from there, all the way to the intake manifold. Silicone has a very low heat transfer coefficient so, the hot ambient air in and around the engine bay will not be able to penetrate through all of the layers of silicone therefore, the cold air you just spent $800 to get cool, will stay cool. All other kits currently on the market have several couplers, elbows, and connections long before ever reaching the intake manifold. Not only does that make for a difficult installation but the potential for leaks is drastically increased.
Application:
2007 – 2009 Mazdspeed 3
Requires the use of a Treadstone TR8 Intercooler (Mounting Brackets Included - $35.00 Value!)
Features:
- Black wrinkle coated and polished aluminum piping
- 7 layer High strength, thick walled silicone hoses
- Stainless T-bolt clamps
- Maintains Clean OEM look with proper placement of the power steering cooler
JBR FMIC Piping Kit Includes:
- Hot and cold side piping
- BPV Adaptor flange and mounting hardware
- 7 Stainless T-bolt clamps
- Power Steer Cooler Mounting Brackets
- TR8 Intercooler Mounting Brackets ($35.00 Value)
The Following 16 Users Say Thank You to JBR For This Useful Post:
09TrueRedGTX (02-03-2015), Agent_Orange (02-08-2015), ArmanRus (02-08-2015), Chief_Wiggum (02-03-2015), cshunter (02-05-2015), Drive By Fire (02-03-2015), exentix (02-03-2015), Gr8Speed (02-03-2015), Hush (02-04-2015), Jkelley (02-03-2015), kpuser1 (02-03-2015), Mauro_Penguin (02-03-2015), Shwaykid (02-03-2015), thepatient77 (02-03-2015), tytanium (02-03-2015), [R]usty (02-03-2015)
 Old 02-03-2015, 04:33 PM   #2
09TrueRedGTX's Avatar
Posts: 127   (View Stats)
09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute
Has this kit been test fitted with the tr8l core? I'm curious if the 2 cores are different in overall dimensions (some say it is 2" longer), or the tr8l just has a bigger core but retains the same overall size.
Also, when do you plan to add the installation instructions to your website?
This kit looks great. Good work!
09TrueRedGTX is offline   Reply With Quote
 Old 02-03-2015, 05:26 PM   #3
exentix's Avatar
Posts: 1,568   (View Stats)
Groans: 46
I can't get over how good this kit looks.
JBR likes this.
The Following 2 Users Say Thank You to exentix For This Useful Post:
JBR (02-04-2015), Quigs (02-04-2015)
 Old 02-04-2015, 01:37 PM   #4
Shwaykid's Avatar
Posts: 646   (View Stats)
It's even better in person. Got it shipped to my work, the other car guys were drooling over that wrinkle black.
2008 Mazdaspeed3 GT
Jet Black Wax (06/24/2017)
Shwaykid is offline   Reply With Quote
 Old 02-04-2015, 02:49 PM   #5
Here's a link to the longest instructions I've ever had to write. Feed back on them would be much appreciated.
http://jamesbaroneracing.com/support...structions.pdf
-Jamie
kpuser1 (02-04-2015), Quigs (02-04-2015)
 Old 02-04-2015, 03:16 PM   #6
Shwaykid's Avatar
@jbarone Long, very detailed, and still easy to follow. Looking forward to this Saturday for the install. I have a feeling all those pics are going to come in handy.
JBR likes this.
2008 Mazdaspeed3 GT
The Following User Says Thank You to Shwaykid For This Useful Post:
JBR (02-04-2015)
 Old 02-04-2015, 03:27 PM   #7
We have not fitted it with the TR8L. The hoses I'm confident will work but the mounting brackets for the core and the PS cooler will not work.
09TrueRedGTX likes this.
09TrueRedGTX (02-04-2015)
 Old 02-04-2015, 03:37 PM   #8
Quigs's Avatar
Posts: 1,152   (View Stats)
Gah, I'm still so excited to order this. Tax return needs to hurry up!
2009 Mazdaspeed3
2000 Mazda Miata MX-5
NASA TTE build ongoing
 Old 02-04-2015, 03:43 PM   #9
emag remrofni's Avatar
Posts: 1,594   (View Stats)
emag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the world
Groans: 209
Groaned at 92 Times in 38 Posts
James, any idea if this will mount up to the Cobb V1 core?
// 09 CWP // Cobb SRI // SURE Race RMM // eBay double penetration DP // SU BPV // ITV22's // JBR SSP // KMD Internals // VTAK GAUGE // Cobb FMIC V.1 //
4 Gallon E85 by Stratified
My Photography - DarkSidePhotoshoot.com
it was a mexican
whoever said they are lazy is a stupid dumb fucking idiot
and they can do ANYTHING...they prolly got the wheels off with a branch and some hedge clippers
Originally Posted by FreeFlyFreak View Post
The dick bone is not connected to the asshole... Mind over matter, learn to control them both.
emag remrofni is offline   Reply With Quote
 Old 02-04-2015, 08:56 PM   #10
tytanium's Avatar
Posts: 137   (View Stats)
tytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant future
I would think to fit the tr8l you will just have to drilla new hole in the supplied brackets judging by the photos. I plan to use a tr8l as well
2007 CWP MS3
Powered by Purple Drank @ 22psi // ATP GT2871r // J2 Engineering catless downpipe // Continental Extreme Contact DW 245/40/17 // Rays Gram Lights 57DR 17x9 // // CP-e Nexus catback // resonator delete // Damond Motorsports rmm // GoFastBits bov // Maisonvi piston style shift knob // Cobb shift weight // Street Unit testpipe // Cobb Accessport V3 // JBR shifter bushings // Treadstone TR8L // JBR intercooler piping // Damond Motorsports power steering cooler // Denso 1-step colder plugs // Ramfab 4" intake // coolant bypass // Damond Motorsports egr block-off // Rally Armor mudflaps // Defi boost gauge // 3 bar MAP sensor // 3 port ebcs // Stratified Guardian Angel // JBR short shifter // Hotchkis rear sway bar // Stoptech ss brake lines // Centric premium brake rotors // Powerstop Z23 brake pads // Koni yellow shocks // Corksport springs // MOOG front and rear endlinks
tytanium is offline   Reply With Quote
The Following User Says Thank You to tytanium For This Useful Post:
09TrueRedGTX (02-05-2015)
 Old 02-05-2015, 05:25 AM   #11
youngwonder's Avatar
Posts: 147   (View Stats)
youngwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond repute
It looks like it will wont take long to install since it doesn't have a lot of separate pipes.
08 Mazdaspeed3
Hypnotic Tuned: e85
BNR s3 v2
AEM Meth Kit 100% Meth w/ DO10 (not using now)
Accessport V3
DNP Exhaust Manifold
Corksport Exhaust
JBR OCC s2
TR8 FMIC
CPE RMM Stage 2
HTP 3" Full Intake
Autotech Internals
CP-E downpipe - Catless
JBR short throw shifter
JBR shift knob
Corksport short shift plate
SS brakelines
Koni Yellow
H&R Springs
Low beam headlights - HID 6000k
Fog lights - HID 6000k
youngwonder is offline   Reply With Quote
 Old 02-05-2015, 05:50 AM   #12
Please keep us informed of how it works out.
 Old 02-07-2015, 08:13 PM   #13
Shwaykid's Avatar
Default Piping Kit Installed
@jbarone, thanks again for making this kit. I'm really happy with how easy the install was and how top notch the quality is.
Plenty of room for the cold side and my JBR CAI. That made me happy since that fitment seemed to be an unknown.
Install took 3.5 hours, including a beer break. I did this by myself. Granted, I have access to a lift, and I took full advantage of that. Even so, I took my time and I didn't end up with any spare parts.
I didn't end up removing the Ambient Air Temp sensor pod mount thingys. The bumper went on just fine. The inner one is touching the cooler, but I didn't care that much. Also, I don't have a cut off tool in TX with me. Another one of the tools still back in CA.
The previous owner royaly screwed up the driver side bumper cover mounts. It was completely held on by zip ties, and most of the mounting tabs were broken... Looks like I'll be contacting @Raider
for those quick removal dealios.
I don't imagine I'll see any huge changes in BATs until summer rolls around. It was 60 degrees out on my drive home, and my BATS were between 75 and 80 cruising, and would jump to maybe 87-90 when idling at a light. It was nice seeing the BATs drop instantly when I started moving.
tl;dr - This kit is badass and incredibly easy to install.
JBR likes this.
2008 Mazdaspeed3 GT
The Following 4 Users Say Thank You to Shwaykid For This Useful Post:
09TrueRedGTX (02-08-2015), JBR (02-08-2015), JgamB (02-08-2015), Mauro_Penguin (02-09-2015)
 Old 02-08-2015, 04:38 PM   #14
I'm really thrilled to hear you like the kit. Looks great!!
New Product Release! JBR FMIC Crash Bar for 2010 - 2013 Mazdaspeed 3 JBR JAMES BARONE RACING 15 03-27-2017 08:25 AM
New Product Release! JBR FMIC Piping Kit, 2010 - 2013 Mazdaspeed 3 JBR JAMES BARONE RACING 19 01-25-2015 09:37 PM
New Product Release!! JBR Short Shifter 2007 - 2009 Mazdaspeed 3 In Stock JBR JAMES BARONE RACING 204 12-29-2014 10:18 AM
Product Release! CorkSport Mazdaspeed 6 FMIC for SRI CorkSport CorkSport 15 06-08-2012 03:04 PM
Page generated in 0.38633 seconds with 27 queries
