Like Tree3Likes
  • 1 Post By
  • 1 Post By
  • 1 Post By
 Old 06-06-2013, 01:02 PM   #1
warlord's Avatar
Posts: 756   (View Stats)
Originally Posted by Turbojoe View Post
I took the entire piece out and it does help bring down the Intake and BAt's as air now passes directly over the intake manifold. Also I have a FMIC and took out the scoop from the hood and you will be amazed how much more heat comes out now. One last thing if you decide to leave that piece of the OEM intake you could get the new Cobb SRI box that utilizes that section and acts as a ram air. Just my 2 cents enjoy the new intake!!
I found the same thing. When I ran a cp-e nano SRI my IAT's were lower with that piece of oem intake ducting removed. Lower BAT's were inconclusive but IAT's were definitely better. The best way to lower IAT's with an SRI is to remove the weather stripping at the rear of the hood. IAT's dropped a solid 4* with that free mod.
Oem intake ducting meaning the one with the round end. That's the one i removed. The square one that clips to the radiator housing I left in. IAT's (under hood temps) got hotter when I removed it so I re installed it.
2014 IS350 (sold)
2013 MS3 Stage2 E85 (sold)
2011 MS3 Stage2 (sold)
warlord is offline   Reply With Quote
The Following User Says Thank You to warlord For This Useful Post:
classybum (06-07-2013)
James Barone Power Path SRI / TIP bhamitgeek JAMES BARONE RACING 12 05-19-2013 03:26 PM
Questions before ordering a "Path Stage II Power Intake" levon.mark JAMES BARONE RACING 37 03-26-2013 05:01 PM
JBR Power Path Stage 1 SRI swerv0428 JAMES BARONE RACING 0 03-08-2013 10:54 AM
Stage 2 -Mod Path Dilemma J_Logik Gen2 MS3 General Discussion 40 02-14-2012 05:31 PM
GenPu's factory fuel cut factory tune psi (relative pressure) WRX_Fan_0717 2010 MS3 - ECU Computer Tuning 1 03-09-2011 11:14 PM
Page generated in 0.23798 seconds with 22 queries
