  • 1 Post By Eighty8
 Old 09-09-2012, 07:54 PM   #1
Mr.Bison's Avatar
Posts: 118   (View Stats)
Mr.Bison is the leader of the worldMr.Bison is the leader of the worldMr.Bison is the leader of the worldMr.Bison is the leader of the worldMr.Bison is the leader of the worldMr.Bison is the leader of the worldMr.Bison is the leader of the worldMr.Bison is the leader of the worldMr.Bison is the leader of the worldMr.Bison is the leader of the worldMr.Bison is the leader of the world
Default Problems with SSP
Whats up guys
I just installed the SSP, along with an SRI. I originally installed it at the shortest throw setting, and it felt good, but a little bit too short for me. I adjusted it earlier today to the longest shift setting, and 5/10 times it grinds going into 3rd. Mind you, this is with the clutch all the way down, and slow, easy shifting, I'm not banging through the gears. Am I missing something?
I just don't understand why that would be happening, I've searched and some people have reccomended getting a lighter shift weight. Not sure how this helps
Any advice would be reccomended, the short throws are sweet but not when it grinds!
12' CWP MS3
--SURE Aeros SRI--Black Rear Valence--SURE Anchors--CS RMM 80D--FoMoCo Juice--CS Axleback--TWM Spector
Mr.Bison is offline   Reply With Quote
 Old 09-09-2012, 07:58 PM   #2
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
Try this>>>
Nator is what it does.
The Following 8 Users Say Thank You to kritz For This Useful Post:
AZSPEED3 (09-09-2012), bryansawiseone (09-09-2012), England15j (09-09-2012), exentix (09-09-2012), JBR (09-10-2012), Mr.Bison (09-09-2012), tddvrrn (09-09-2012), trf5000 (09-09-2012)
 Old 09-09-2012, 08:15 PM   #3
Mr.Bison's Avatar
Its not a problem of not going into gear, its just straight up grinding..
plus Im wondering why it only grinded when I put it in the longest setting, versus the shortest setting with no grind
12' CWP MS3
 Old 09-09-2012, 08:33 PM   #4
kritz's Avatar
Groans: 95
Just try the adjustment procedure and see what happens. You don't have motor mounts in your sig you really should get a RMM at the very least.
 Old 09-09-2012, 09:01 PM   #5
Eighty8's Avatar
Posts: 458   (View Stats)
Eighty8 is the leader of the worldEighty8 is the leader of the worldEighty8 is the leader of the worldEighty8 is the leader of the worldEighty8 is the leader of the worldEighty8 is the leader of the worldEighty8 is the leader of the worldEighty8 is the leader of the worldEighty8 is the leader of the worldEighty8 is the leader of the worldEighty8 is the leader of the world
I highly recommend putting in XT-M5-QS tranny fluid. I did that right after I installed my SSP and every shift is buttery smooth now.
kritz likes this.
Eighty8 is offline   Reply With Quote
 Old 09-09-2012, 09:10 PM   #6
exentix's Avatar
Posts: 1,568   (View Stats)
Groans: 46
What kritz said. Adjusting it makes a big difference. Just try it.
 Old 09-10-2012, 09:14 AM   #7
Thanks guys for pitching in and helping the OP.
As mentioned....Adjusting the shifter, changing the fluid, and motor mounts should clear up any issues regardless of the amount of throw reduction you choose. It's unfortunate that these things need to be done but, it's a well documented problem with these transmissions. What's even more frustrating is that some cars have no problems and some do. You could also try setting it somewhere in the middle and see how it performs.
Thanks,
Jamie
kritz (09-10-2012)
VVT Problems MazdaCX7Failure CX-7 > Issues & Troubleshooting 14 03-20-2013 03:34 PM
Official: Fisker Q&A sheds light, lots of light, on Karma problems, lots of Karma problems Haltech Automotive News 0 08-23-2012 02:50 PM
Problems with AC trdsw MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 07-03-2011 10:49 AM
VVT Problems mrmonk7663 CX-7 > Engine, Transmission & Driveline 6 04-01-2011 07:47 AM
Big Problems (MS6) phlselspd6 Mazdaspeed3/6 General Discussion 78 12-21-2010 10:32 PM
Page generated in 0.29091 seconds with 24 queries
