Like Tree24Likes
 Old 09-21-2013, 08:36 AM   #121
speed23's Avatar
Posts: 1,480   (View Stats)
Originally Posted by julienjj View Post
Got my 70 pmm installed today... torqued to 70/lb no problem. I think I will loosen them hower.
Is it just me or the engine is loud as fuck now ? vibration are very low, but the sound level is very high inside the cabin
I am the same way. Vibes aren't that bad, and will decrease alot over time, but there alot of extra noise.
 Old 09-21-2013, 11:08 AM   #122
julienjj's Avatar
Posts: 292   (View Stats)
julienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the world
The way it is right now I can almost count the amount of teeth per second that are meshing with the chain on the vvt gear.
hopefully it will settle out.
in the meantime I drive a DTM racecar lol
edit: Worth mentionning that the stick just glide into each gears like it never did before. Shifting in second super fast isnt an issue anymore.
Current money pits:
2006 MS6 Black mica
CP-E RMM|COBB AP|Test pipe|RX-8 oem wheels|Corksport SRI+TIP|Autotech CDFP|Michelin Pilot Super Sports 235/40ZR18|
|HKS SSQV|COBB Sift weight|Corksport mudflaps (Because rallycar)| JBR 70A Sidemounts|
2008 BMW 135i 6MT
M package|JB4 tune|255/35r18 Michelin PSS|BMW Performance exhaust|
julienjj is offline   Reply With Quote
 Old 10-12-2013, 06:54 AM   #123
Fizzyb's Avatar
Posts: 26   (View Stats)
Fizzyb is a splendid one to beholdFizzyb is a splendid one to beholdFizzyb is a splendid one to beholdFizzyb is a splendid one to beholdFizzyb is a splendid one to beholdFizzyb is a splendid one to beholdFizzyb is a splendid one to behold
Installed my trilogy today, wish to christ I had have re-read this thread first. One is soft with torque wrench, fine with normal ratchet.
But the back one is completely f**ked using the specified torque. Can't get the bolt in or out, it is refusing to go up or down. It is as good as it is going to get, but hopefully it not being anywhere near fully tight doesn't f**k anything up...
@jbarone , maybe the instructions need to have the torque recommended changed? Seems rather hit and miss for those bolts for them working or completely shagging them...
Yeah, I would be careful torquing the frame bolts to 70 lbs as the exact same thing happened to me, but it was my front bolt. Seems odd that those two bolts exceed the stock maximum torque spec by more than 20%, while the others are specified on the low end of the stock torque specs, 45 for the nut on the body and 60 for those on the studs on the motor. If I had looked at the manual I would have torqued them down to 50 lbs and not 70. I usually pick the middle of the broad torque specs in that book.
Fizzyb is offline   Reply With Quote
 Old 10-12-2013, 09:00 AM   #124
I will lower the torque spec.
Funkster777 (10-12-2013), phate (10-12-2013), TiGraySpeed6 (10-12-2013)
 Old 10-12-2013, 10:43 AM   #125
Fizzyb's Avatar
Cheers mate, will deff help others in the future I think.
One of mine is fine (can't move with with a ratchet), but the rear is moving both ways (without getting tighter or looser) with a ratchet, my fingers are solidly crossed that it will be enough to hold it, but if anyone has any ideas on how to get it out and how to replace the bit the bolt goes into, it would be appreciated.
 Old 10-14-2013, 12:02 PM   #126
Specs updated to 50 ft/lbs.
Fizzyb (10-14-2013), IamJamen (11-08-2013)
 Old 11-08-2013, 07:20 AM   #127
Fizzyb's Avatar
UPDATE!!!
Figured that their will always be people asking questions about things, so more input the bettera. Done about 1500k's on them thus far (nearly 1000miles for those who prefer those units)
Running the 70d trilogy. First, the build on these things are nuts, most solid looking things I have ever seen, almost a shame to put them in.
First 70k's was pretty nutty vibration and noise, but bang on 70, dropped a lot
Next big drop was around 500k I spose, still had that really cool whine from the tranny but the vibes were dropping, and the car no longer felt "tiring to drive".
The next 1000k's till now and its pretty damn smooth considering solid mounts, at idle you can hear the engine tick, only time I really notice the mount still is 2nd gear doing 2000-3000 rpm (holding around round abouts or whatever).
Overall car noise is more, but its a connected mechanical noise. At a highway cruise it sounds almost stock, and I imagine it will keep on dropping.
Shifting is just a million years ahead of the slop you get from factory, 1-2 shifts are now possible, and 2nd-3rd-4th can be done snap shifts, none of this waiting around BS.
If you can afford the trilogy, go for it, worth absolutely every penny / dollar / euro / bitcoin.
And now we wait for JBR diff mounts :p
The Following 3 Users Say Thank You to Fizzyb For This Useful Post:
6erforlife (11-08-2013), IamJamen (11-08-2013), sidekick (02-27-2014)
 Old 12-10-2013, 10:47 AM   #128
julienjj's Avatar
I finaly installed my TMM yesterday. dosent add much vibes over the PMM, but like fizzyB said, there is now a nice transmission whine, and I also hear the synchos meshing when changing gear.
Current money pits:
2006 MS6 Black mica
2008 BMW 135i 6MT
 Old 01-10-2014, 08:23 AM   #129
jucca's Avatar
Posts: 159   (View Stats)
jucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond repute
Have RMM 80duro, now with 1500miles on it, most of vibration gone specially that one on idle, but in beetwen 2500-3000 rpms are still very noticable, many sounds coming out from dash, windows etc. Wonder if that will be ever gone?
Love how it shifts now, but vibrations don't like much.
Cobb AP V3
Stratified tune
Autotech HPFP internals
M2 DP
JBR PowerPath stg II
Sure RMM
Sure Rear Diff Mount
TurboXS 50/50
Grimspeed EBCS
NGK Iridium step colder
Ebay OCC
EGR delete
3BAR MAP w/ Harness
3" CBE w/ high flow mufflers
Eibach -35mm
18x9 JapanRacing JR3 w/ 235/40/18 Kumho KU39
jucca is offline   Reply With Quote
 Old 01-10-2014, 10:10 AM   #130
Fillups66's Avatar
Posts: 75   (View Stats)
Fillups66 has much to be proud ofFillups66 has much to be proud ofFillups66 has much to be proud ofFillups66 has much to be proud ofFillups66 has much to be proud ofFillups66 has much to be proud ofFillups66 has much to be proud ofFillups66 has much to be proud ofFillups66 has much to be proud ofFillups66 has much to be proud of
Groaned at 17 Times in 2 Posts
Anyone run the 80 duro RMM and 70 duro TMM and PMM? What are the vibes like? I have the 80 duro RMM and the vibes are barely noticeable. I'm wondering if its much of a difference going softer on the other two mounts?
Fillups66 is offline   Reply With Quote
 Old 01-13-2014, 04:56 PM   #131
norcalcasey's Avatar
Posts: 163   (View Stats)
norcalcasey has a reputation beyond reputenorcalcasey has a reputation beyond reputenorcalcasey has a reputation beyond reputenorcalcasey has a reputation beyond reputenorcalcasey has a reputation beyond reputenorcalcasey has a reputation beyond reputenorcalcasey has a reputation beyond reputenorcalcasey has a reputation beyond reputenorcalcasey has a reputation beyond reputenorcalcasey has a reputation beyond reputenorcalcasey has a reputation beyond repute
Groaned at 5 Times in 2 Posts
I have the 80A PMM, that got me fully bolted and i HAZ big vibes. I would go with the 70a personally
2006 MS6 Titanium - MS v1 CAI, Corksport TIP, Forgev1 BPV, Tien S-tech Springs, JBR SSP, JBR 80 RMM, CS 85 Duro TMM Inserts, JBR solid bushings. ebay test pipe, laminx 6% headlight/fodlight shields. Magnaflow Mufflers, 5k DDM Fogs, BBS RK 18x7.5 +42 18lbs- I Needz teh AP and HPFP
norcalcasey is offline   Reply With Quote
 Old 02-26-2014, 11:45 AM   #132
big angry bird's Avatar
Posts: 372   (View Stats)
big angry bird is the leader of the worldbig angry bird is the leader of the worldbig angry bird is the leader of the worldbig angry bird is the leader of the worldbig angry bird is the leader of the worldbig angry bird is the leader of the worldbig angry bird is the leader of the worldbig angry bird is the leader of the worldbig angry bird is the leader of the worldbig angry bird is the leader of the worldbig angry bird is the leader of the world
so today during lunch i said "fuck it!, let's get mounted"
took me 30min from start to finish by my damn self.
stock pmm bushing was cracked and had a hole at the bottom which looked like it leaked something because the frame was full of filth and residue.
so i started snuggling the pmm and i swear it felt like my car was cinderella and the pmm was the perfect fit. didnt struggle rocking the engine at all.
so then came the big moment. put the key in the ignition, dotted my eyes, and crossed my teeth. turned the car on...immediately i said:
"what the fuck are all these pussies crying about?!?!; this is NOTHING!"
"teeth chatter?!?! seriously?!?!? pfffffffffffffffffffft"
i swear i read numerous threads/posts of people complaining and removing the mount after they "couldnt take it anymore"... bunch of niggas with sensitive vags.
i fucking love this mount and im so glad i got it at 80d, shit feels amazing, throttle response is improved, and i love the little buzz it has. reminds me of when i first put in the rmm.
(side note: i dont have BSD)
edit: would like to point out that i had the RMM for about 5k miles already so the vibes weren't as intense compared to those that went in dry and did all 3 mounts at once.
JBR TMM is next!
JBR likes this.
2006 Mazdaspeed6 GT BCM #3162 ~gone she will be missed...
big angry bird is offline   Reply With Quote
The Following User Says Thank You to big angry bird For This Useful Post:
JBR (02-26-2014)
 Old 02-26-2014, 06:25 PM   #133
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
I'm not sure if my TMM is fucked or if my RMM/PMM make my car vibrate so much, but throttle transitions and engine braking are horrible. There's a ridiculous resonance in the cabin and I can hear my fucking timing chain constantly. Lol. But fuck it, becauseracecar.
 Old 02-26-2014, 09:20 PM   #134
meelo88's Avatar
Posts: 557   (View Stats)
meelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the world
I don't have increase vibes really, just hear the TOB when the clutch is out at idle...did NOT do the BSD
"If I can't fix it, it was meant to be broken"
[SIGPIC][/SIGPIC] 2007 MazdaSPEED 6 Titanium Grey
TUNED BY NISHAN
POWER
SpeedPerformanc3 Wiseco Pistons (88mm)::Manley Forged H-Beams::BNR S3::Bosch 3Bar Map Sensor::CP-E Ex Mani::SBC Stg 2 Clutch::JBR RMM 80a::JBR STG II SRI::JBR Boost Tubes::JBR BPV Return::JBR SSP::CS TMIC::CS DP::Stratified 3 Port EBCS::Stratified Guardian Angel::TurboXS RP::Custom 3" Catback Exhaust::KMD 2.1::Flex Innovations Ground Kit::Turbosmart BPV::MD OCC::TWM Stage 1::BC Coilovers::Hawks HPS::EGR Delete::SURE Dreadnaught::SURE Juggernaut::SURE TIG
COSMETIC AND AUDIO
Mori H1 Proj Retrofit::DDM 3k HID Fogs::RPM Rear LED Reflectors::RPM Side LED Reflectors::Morel Elate 6 2W 6.5" Components::Morel Maximo 5C 5.25" Coaxial::Arc Audio KS300.4::Arc Audio KS1000.1::Audison BitOne.1::Zapco ST4
meelo88 is offline   Reply With Quote
Dual Product Release!! CorkSport Mazdaspeed 3 Passenger Side Motor Mount and Transmission Insert CorkSport CorkSport 143 04-13-2016 12:00 AM
JBR MAZDASPEED 6 Rear Motor Mounts In Stock!! JBR JAMES BARONE RACING 22 08-28-2013 05:32 AM
JBR MAZDASPEED 3 Transmission Motor Mounts in Stock!! JBR JAMES BARONE RACING 2 03-21-2013 02:14 PM
CP-E Motor Mounts for the Mazdaspeed 3 in stock ! kevin@gripgarage.com Mazdaspeed3/6 General Discussion 0 04-24-2009 02:25 PM
Page generated in 0.36461 seconds with 30 queries
