Like Tree3Likes
  • 1 Post By aaronc7
  • 2 Post By JBR
 Old 02-14-2016, 10:08 AM   #1
El Beaner's Avatar
Posts: 4,262   (View Stats)
Default Is this a serious issue for BT guys (or even k04 high psi)
Not bashing JBR kit, I have it and am happy with it but one day I plan on going BT. As it is now I peak at 23 psi and according to the video this is only 20-21 psi.
This was posted to a Dallas Facebook page
SOLD 2012 LSM Tech - 11/17/17
The Following 14 Users Say Thank You to El Beaner For This Useful Post:
ArmanRus (02-15-2016), aromig (06-11-2016), Easter Bunny (02-14-2016), g00s3y (02-14-2016), Hush (02-14-2016), Mauro_Penguin (02-15-2016), MD1032 (02-15-2016), MS3Shadow (02-14-2016), mxlplx71 (02-17-2016), NCspecV81 (02-14-2016), speedfreak44 (02-14-2016), Vansquish (02-14-2016), WetzMS3 (02-15-2016), Yatta (02-15-2016)
 Old 02-14-2016, 11:45 AM   #2
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
Pretty cool video really. Variable volume piping...it's a feature!
Easter Bunny likes this.
The Following 8 Users Say Thank You to aaronc7 For This Useful Post:
aromig (06-11-2016), Cheapspeed (02-14-2016), Easter Bunny (02-15-2016), knocturnal (03-20-2016), MD1032 (02-15-2016), NCspecV81 (02-14-2016), Vansquish (02-14-2016), WetzMS3 (02-15-2016)
 Old 02-14-2016, 04:35 PM   #3
tytanium's Avatar
Posts: 137   (View Stats)
tytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant future
I have the jbr kit @ 22psi on a 2871 and haven't noticed any issues, but this definitely got my attention
2007 CWP MS3
Powered by Purple Drank @ 22psi // ATP GT2871r // J2 Engineering catless downpipe // Continental Extreme Contact DW 245/40/17 // Rays Gram Lights 57DR 17x9 // // CP-e Nexus catback // resonator delete // Damond Motorsports rmm // GoFastBits bov // Maisonvi piston style shift knob // Cobb shift weight // Street Unit testpipe // Cobb Accessport V3 // JBR shifter bushings // Treadstone TR8L // JBR intercooler piping // Damond Motorsports power steering cooler // Denso 1-step colder plugs // Ramfab 4" intake // coolant bypass // Damond Motorsports egr block-off // Rally Armor mudflaps // Defi boost gauge // 3 bar MAP sensor // 3 port ebcs // Stratified Guardian Angel // JBR short shifter // Hotchkis rear sway bar // Stoptech ss brake lines // Centric premium brake rotors // Powerstop Z23 brake pads // Koni yellow shocks // Corksport springs // MOOG front and rear endlinks
tytanium is offline   Reply With Quote
The Following User Says Thank You to tytanium For This Useful Post:
Amaroms3 (02-14-2016)
 Old 02-14-2016, 04:38 PM   #4
NCspecV81's Avatar
Posts: 2,867   (View Stats)
@tytanium; the likelihood of you noticing this until it's too late is very high. Your's is likely doing the samething under WOT/boost conditions. You just don't have a camera there to capture it.
2013 CWP and Stock
 Old 02-14-2016, 04:54 PM   #5
NCspecV81's Avatar
Here's an interesting tidbit. Here's a boost curve from vdyno bewteen a BNRs4 with JBR piping and HTA3586 with stainless steel hard pipes from a UR kit.
See if you can decipher which is which. These were taken in the same geographical region on the same day within 30 minutes of one another.
2013 CWP and Stock
aromig (06-11-2016), Easter Bunny (02-15-2016)
 Old 02-14-2016, 05:12 PM   #6
Zoom66's Avatar
Posts: 281   (View Stats)
I am putting my car on the dyno next weekend and will try to get my GoPro to record this action to investigate. I have the underside piping as well with a TR8 core. My tune peaks at 26 psi.
The Following 2 Users Say Thank You to Zoom66 For This Useful Post:
Easter Bunny (02-15-2016), NCspecV81 (02-14-2016)
 Old 02-14-2016, 07:24 PM   #7
sheston's Avatar
Posts: 1,847   (View Stats)
How many times can it do that before the balloon pops? Wonder what it looks like closer to 30 psi
 Old 02-14-2016, 07:26 PM   #8
speedfreak44's Avatar
Posts: 1,391   (View Stats)
I would have to say blue is the hardpipe one
The line up:
 Old 02-14-2016, 08:28 PM   #9
Djohns's Avatar
Posts: 3,944   (View Stats)
Woah. Now this is an interesting find! Thank you!
2010 black mica speed3
Soon:built motor
 Old 02-14-2016, 08:55 PM   #10
Djohns's Avatar
I'm going to say the red is JBR?
Soon:built motor
 Old 02-15-2016, 05:25 AM   #11
The piping was tested at 40 psi for continuous periods of time much longer than a wot pull. Burst rated at 150 psi. We haven't seen any problems for the two years they've been available.
HP is not effected nor is acceleration. Lag is increased a a wee bit.
The graph is not really apples to apples. Two different turbos and likely two different tunes.
We've been tracking our shop Mazdaspeed 3 for two years with no issues.
Lifetime warranty = nothing to be concerned about.
XxSmarTz and El Beaner like this.
The Following 22 Users Say Thank You to JBR For This Useful Post:
aaronc7 (02-15-2016), Boost_creep (02-16-2016), Code Monkey (02-15-2016), cshunter (02-18-2016), Dralphy (02-17-2016), Easter Bunny (02-15-2016), El Beaner (02-15-2016), Gr8Speed (02-15-2016), Hush (02-15-2016), klingon (02-15-2016), littleloogy (02-15-2016), Mauro_Penguin (02-15-2016), mazdaspeedmyk (02-15-2016), monkey.bones.007 (02-15-2016), MS3Shadow (02-15-2016), mxlplx71 (02-17-2016), NC-MS3Rob (02-15-2016), PurplFox (02-15-2016), speed3Texas (02-17-2016), Thepedigree13 (02-20-2016), XxSmarTz (02-17-2016), Yatta (02-15-2016)
 Old 02-15-2016, 10:14 AM   #12
klingon's Avatar
Posts: 3   (View Stats)
klingon will become famous soon enough
Interesting find! Although someone was telling me about having a hole blown in their bumper, but I never saw any proof.
klingon is offline   Reply With Quote
 Old 02-15-2016, 11:10 AM   #13
Yatta's Avatar
Posts: 1,862   (View Stats)
So to clarify, 40 PSI constant at what temperature(s) (does hotter charge air change the burst rating)?
Was pressure varied on the test or just held at 40 PSI?
Does the tubing hit a maximum expansion point or will it increase with pressure?
Fully expanded are there clearance issues (i.e. sharp, pointy or abrasive wear on exterior of tubing)
During fault analysis/testing what failed first? the tubing or the clamps?
It doesn’t surprise me that it expands, couplers do the same thing but to a much lessor degree.
Thanks!
The Following 4 Users Say Thank You to Yatta For This Useful Post:
klingon (02-15-2016), NCspecV81 (02-15-2016), WetzMS3 (02-15-2016), Z32_MS3 (02-16-2016)
 Old 02-15-2016, 06:55 PM   #14
JSmith's Avatar
Posts: 707   (View Stats)
Groans: 106
The silicone couplers I've Qualified were tested under harsher conditions than an engine bay will ever see and lasted over 100K cycles. Apples to oranges perhaps but the silicone impregnated cloth can potentially be OK.
 Old 02-15-2016, 11:59 PM   #15
shaneski's Avatar
Posts: 505   (View Stats)
Mines been running the JBR cold side silicone FMIC pipe for a year around 29psi and so far it's still in one piece.
The Following 5 Users Say Thank You to shaneski For This Useful Post:
Boost_creep (02-16-2016), gdawg25 (02-16-2016), Gr8Speed (02-16-2016), littleloogy (02-16-2016), XxSmarTz (02-17-2016)
 Old 02-16-2016, 06:20 PM   #16
sheston's Avatar
I guess I was assuming there was something wrong with the pipes in the video. Thinned some how, inferior material, ....
 Old 02-16-2016, 06:36 PM   #17
Correct me if I am wrong @JBR; but don't these have a metal wire wrapped through them like the intakes? I am actually surprised they move that much
The line up:
 Old 02-17-2016, 09:01 AM   #18
Thanks!
Pulse testing was performed at 30, 35 & 40 PSI for 50 seconds per cycle. 30 cycles each.
Test pressure was reached in the first 15 seconds and held for the remaining 30.
Testing was performed at 155* F.
Temperatures below 300* F have no effect on the burst rating.
Max temperature rating 500* F.
Maximum expansion is reached at ~18psi
Clamp and hose failure never occurred during testing. Bust rating is given based on hose diameter, layers of silicone, layers of reinforcement and other data collected based on use by the manufacturer over many years of being in business.
Piping was designed with clearance taken in to account. Rubbing can cause failure and must be mitigated by the customer. Failure due to rubbing is not covered by the warranty.
The Following 8 Users Say Thank You to JBR For This Useful Post:
Boost_creep (02-18-2016), Cheapspeed (02-19-2016), Code Monkey (02-17-2016), Gr8Speed (02-17-2016), lolwrx (02-19-2016), maisonvi (02-19-2016), XxSmarTz (02-17-2016), Yatta (02-17-2016)
 Old 02-17-2016, 10:43 AM   #19
Shwaykid's Avatar
Posts: 646   (View Stats)
Real world:
I have more than 20k miles on this kit in a year; not a single issue. Mods in sig, target boost is 19psi.
I don't go to the track or the strip, but I have plenty of pulls on it. I have always hit and hold boost targets.
2008 Mazdaspeed3 GT
Jet Black Wax (06/24/2017)
Shwaykid is offline   Reply With Quote
The Following User Says Thank You to Shwaykid For This Useful Post:
 Old 02-17-2016, 11:35 AM   #20
Yatta's Avatar
So not having this kit, do the directions for installation indicate how much clearance is needed do to expansion to avoid rubbing? You did pulse testing which is great, really what I was asking about, but clearly some are a little shocked by the expansion and covering this in the install doc would (should) alleviate those concerns.
 Old 02-18-2016, 05:06 AM   #21
rob ms6gt's Avatar
Posts: 416   (View Stats)
How were you guys expecting a silicone hose to react?
ROB MS6GT
2006 Liquid Platinum Metallic Mazdaspeed 6
Stratified Tune, Stratified GA V2, Cobb AP V2, GTX3071R, HTP 4" Intake, Synchronic Diverter Valve, 3 bar MAP, Stratified Boost Dial, Corksport Injector Seals, Autotech Internals, Ebay DP, Custom TR8 FMIC, DevilsOwn Meth, Damond Catch Can, JBR 70 Duro Trilogy, TT front diff mount, Penis Eater top diff mount, Cut OEM Springs, Koni Yellows
rob ms6gt is offline   Reply With Quote
The Following 3 Users Say Thank You to rob ms6gt For This Useful Post:
aromig (06-11-2016), Boost_creep (02-18-2016), WetzMS3 (02-18-2016)
 Old 02-18-2016, 01:05 PM   #22
Boost_creep's Avatar
Posts: 829   (View Stats)
So not having this kit, do the directions for installation indicate how much clearance is needed due to expansion to avoid rubbing? You did pulse testing which is great, really what I was asking about, but clearly some are a little shocked by the expansion and covering this in the install doc would (should) alleviate those concerns.
Fixed
 Old 02-19-2016, 10:01 AM   #23
Yatta's Avatar
Fixed
thanks. me and english, english and I....
Boost_creep (02-19-2016)
High Pressure Fuel Pump, OMG GUYS!!! ptperformance Mazdaspeed3/6 General Discussion 56 07-20-2010 04:02 PM
Geneva 2010: Citroen DS High Rider rides in on its high horse Haltech Automotive News 0 03-03-2010 07:30 AM
Page generated in 0.44504 seconds with 35 queries
