Like Tree13Likes
 Old 07-16-2013, 07:33 AM   #81
bigmike's Avatar
Posts: 278   (View Stats)
bigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond repute
The whole point is the turbo!!! If the new Mazdaspeed is just going to be mostly a tuned Mazda 3 then why even waste the money upgrading? Just get a 3 and mod it. Without the turbo, there seems very little performance mods are even possible. What are we going to spend our money on?
2/1 91 octane gasoline/E85, Stratified tuned, ~340 hp/360 ft·lb
AEM Water/methanol injection kit 550 ml/min nozzle ~5 psi/10 psi triggers 1/1 methanol/water Filter Autotech HPFP internals BrakeBest Brake pads Front Clarion XC1410 car amplifier COBB Tuning Downpipe Catback exhaust Front mount intercooler v2.0 XLE bypass valve Hybrid mode Short ram intake Turbo inlet hose Airbox Sport springs Short throw shifter Shift knob Shifter weight AccessPORT V3 Corksport Mid chassis brace Oil catch can Rear sway bar Radiator shrouds LED light kit cp-e SAFEseal injector seals Excalibur Wheel Accessories Black acorn bulge lug nuts 3/4" Echlin Ignition Parts Tire pressure monitoring system Left, right tire Firehawk Wide Oval Indy 500 tires 225/40R18 XL Ground Control Frim strut bump stops Front Interstate Mega-Tron battery James Barone Racing Rear motor mount 88 durometer Transmission side motor mount 80 durometer Passenger side motor mount 80 durometer EGR block off kit Thermal insulating intake gasket kit Thermal insulating throttle body gasket Coolant bypass kit Solid shifter bushings Bypass valve hose Kicker 40CSS684 component speaker system Front KS68 speakers Rear 11PT10CA powered subwoofer enclosure Koni Sport yellow shock absorbers Front 540 degrees LLumar ATR 35 film Mazda 2004-2008 RX-8 rims 18" x 8" FL22 engine coolant Monroe Sensa-Trac shock absorbers Rear Motorcraft XT-M5-QS transmission fluid NGK Iridium IX 6510 LTR7IX-11 spark plugs ~0.28" gap Shell Rotella T6 5W-40 motor oil SSP Primary EGR delete kit Stratified Tuning Guardian Angel ~21.5 psi trigger Visual Garage Shark fin antenna
bigmike is offline   Reply With Quote
 Old 07-18-2013, 05:37 PM   #82
dubtastic's Avatar
Posts: 204   (View Stats)
dubtastic has a reputation beyond reputedubtastic has a reputation beyond reputedubtastic has a reputation beyond reputedubtastic has a reputation beyond reputedubtastic has a reputation beyond reputedubtastic has a reputation beyond reputedubtastic has a reputation beyond reputedubtastic has a reputation beyond reputedubtastic has a reputation beyond reputedubtastic has a reputation beyond reputedubtastic has a reputation beyond repute
Groaned at 44 Times in 13 Posts
I really don't think a na motor is going to be used. To use a non turbo motor would indicate a huge jump backwards in performance. In the hot hatch arms race you have to be over 200 to gain any ground.
dubtastic is offline   Reply With Quote
 Old 07-18-2013, 08:44 PM   #83
Juyoung's Avatar
Posts: 75   (View Stats)
Juyoung is the leader of the worldJuyoung is the leader of the worldJuyoung is the leader of the worldJuyoung is the leader of the worldJuyoung is the leader of the worldJuyoung is the leader of the worldJuyoung is the leader of the worldJuyoung is the leader of the worldJuyoung is the leader of the worldJuyoung is the leader of the worldJuyoung is the leader of the world
Exactly, to win the hot hatch war mazda needs more than a mere 200 hp
Sent from my SGH-I747M using Tapatalk 4 Beta
Juyoung is offline   Reply With Quote
 Old 07-19-2013, 01:22 AM   #84
BlueDmnSpeed's Avatar
Posts: 1,129   (View Stats)
it's not a speed if it isn't turbo'd
RichTuned
BlueDmnSpeed is offline   Reply With Quote
 Old 07-19-2013, 06:56 AM   #85
jm211's Avatar
Posts: 943   (View Stats)
I would love to see Mazda stay true to their original disi design, however playing devils advocate I cant help but consider Mazda no longer has Ford's support. Additionally, their sales have sucked esspecially with second gen 3's and 6's as well as the two. Speed sales are lethargic too.
Going with what haltec said, i wouldnt expect another speed for 3 or so years. They need to build up their consumer market to get the resources for the "prosumer" market. This new design hopefully sparks sales for Mazda.
It sucks but it makes sense. Luckily, Mazda has experience in turbo disi, supercharges, rotary and light weight performance so they wont leave us hanging.
The Following User Says Thank You to jm211 For This Useful Post:
Juyoung (07-19-2013)
 Old 07-19-2013, 07:29 AM   #86
Raider YOLO'd my mom
spdandpwr's Avatar
Posts: 965   (View Stats)
spdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the world
Originally Posted by wolly6973 View Post
Glad you are coming around, but the main point of my post was that there is no way that a bolted civic beats a ms3 with an intake and tune.
Sent from my SGH-I777 using Tapatalk 2
yea, you're right! I definitely had to have ran a stock ms3. If anything, this makes me super excited to get an intake an a tune. F!ck you Honda1!!!...
spdandpwr is offline   Reply With Quote
 Old 07-19-2013, 10:36 AM   #87
461_SS's Avatar
Posts: 1,160   (View Stats)
461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world
Honestly I'd like to see Mazda not have another Speed 3. It's nice and all, but they need a change. I'd personally love to see a turbodiesel RWD Speed 6. Now that would be a blast to drive on and off the track!
461_SS is offline   Reply With Quote
 Old 07-19-2013, 11:28 AM   #88
ajkulish's Avatar
Posts: 412   (View Stats)
ajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the world
Groans: 40
There will be no more speed3 mazda said it themselves. The next mazdaspeed will be a turbo deisel speed6
2006 Mazdaspeed 6 VRM
GTX3076r|Manley Pistons+Rods|AEM WMI|PnP Head|ACT 6 puck+Streetlite|COBB AP|Dramatuned|CorksportTBE|Autotech Internals|Forge v1|JBR Mounts|H&R Springs
RIP - 2007 Mazdaspeed3 GT 22V
COBB AP+SF+TIH|E30 tuned by Mark Gibson|H&R Springs|eBay Downpipe|CXRacing FMIC|KMD+Aviva|SU RMM|TurboXS Hybrid|TWM Base Bushings|Masonvi Knob
ajkulish is offline   Reply With Quote
 Old 07-19-2013, 11:40 AM   #89
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
Originally Posted by 461_SS View Post
Honestly I'd like to see Mazda not have another Speed 3. It's nice and all, but they need a change. I'd personally love to see a turbodiesel AWD Speed 6. Now that would be a blast to drive on and off the track!
Fixed AWD please
Sent from my Nexus 4 using Tapatalk 2
Damond Built Speed 6
 Old 07-19-2013, 12:01 PM   #90
461_SS's Avatar
Naa RWD! Way more fun to drive and actually takes an "educated" foot to race the car on a track. Just take a look at the Speedsource GX Mazda 6's. They actually use 51% stock components of Mazda's skyactiv diesel engine. Pretty freaking sweet!
 Old 07-19-2013, 12:07 PM   #91
Deldran's Avatar
Groans: 118
Meh I like awd launches
 Old 07-19-2013, 12:09 PM   #92
trf5000's Avatar
Posts: 2,290   (View Stats)
I honestly think that if Mazda would have actually advertised the speed more than they did (not at all) it would have sold much better.
Its pretty much a cult car. Ford Advertised the hell out of the ST, an they are essentially eating up potential MS3 buyers before they even get seat time in an MS3.
2010 MS3 - Sold
2015 CX-5 GT AWD - Current
The Following 3 Users Say Thank You to trf5000 For This Useful Post:
Deldran (07-19-2013), Juyoung (07-22-2013), RobT2009 (08-02-2013)
 Old 07-19-2013, 01:15 PM   #93
ajkulish's Avatar
Groans: 40
you guys forget that mazdaspeed was not meant to be a production car. am i the only one who remembers back to the days of the msp and msm when it was only supposed to be a 2 year run model? the mazdaspeed3 came along and completely killed the original point of mazdaspeed street cars. 6 model years and unlimited production. im glad the speed3 is done, for now at least. maybe someday it can make a return but im not too mad about it.
The Following User Says Thank You to ajkulish For This Useful Post:
Mistersix (09-02-2013)
 Old 07-19-2013, 05:06 PM   #94
trf5000's Avatar
The only reason I want the current DISI to keep going as a production model is selfish. The more cars on the road with that motor=more aftermarket support.
Look at how many gens EVOs had to go through to get major aftermarket players. Same with Subaru etc. If they kill the DISI now, big name aftermarket support will never come. If they keep pumping it out, eventually there is enough of on them on the road to warrant big budget R&D and aftermarket support.
Juyoung likes this.
2010 MS3 - Sold
El_Diablo (07-20-2013), Juyoung (07-21-2013), Koke382 (07-19-2013)
 Old 07-21-2013, 10:48 AM   #95
dubtastic's Avatar
I'm sorry where exactly did you read this? I believe both vehicles have a very good chance of returning. On the contrary there has been more evidence to support its return than its demise.
http://m.motortrend.com/wot/should-t...ll-385621.html
 Old 07-21-2013, 10:57 AM   #96
CaptObvious75's Avatar
Posts: 535   (View Stats)
CaptObvious75 is the leader of the worldCaptObvious75 is the leader of the worldCaptObvious75 is the leader of the worldCaptObvious75 is the leader of the worldCaptObvious75 is the leader of the worldCaptObvious75 is the leader of the worldCaptObvious75 is the leader of the worldCaptObvious75 is the leader of the worldCaptObvious75 is the leader of the worldCaptObvious75 is the leader of the worldCaptObvious75 is the leader of the world
Groaned at 12 Times in 7 Posts
Going NA would be like going back to port injection. This isn't a civic si...
--2010 Black Mica Mazdaspeed3--
Stock af
CaptObvious75 is offline   Reply With Quote
 Old 07-21-2013, 02:00 PM   #97
ajkulish's Avatar
Groans: 40
Should the Next MazdaSpeed3 be Naturally Aspirated? (W/Poll)
I read a bulletin somewhere. also I work as an engineer in the automotive industry and have many friends who work at mazda who assured me that it will not return. sorry to burst everyones bubble. they might have a higher hp na version but it will not be badged a mazdaspeed
 Old 07-21-2013, 10:44 PM   #98
dubtastic's Avatar
Interesting. What exactly do your friends do for Mazda?
 Old 07-22-2013, 06:33 AM   #99
ajkulish's Avatar
Groans: 40
I work in plastics and gaskets mostly, but some other engine components and work with them to help design cam covers, oil pans, head and specialty gaskets etc. for example (but before i was here) my company actually designed the valve cover for the genone ms3 and we designed and manufactured the head gaskets, valve cover gaskets, and oil pan gaskets.
but i also have mazda friends who work at dealerships, my dad was a service manager for a local mazda dealership, and i have friends in mazdaspeed motorsports development who are giving me the same information
 Old 07-22-2013, 09:08 AM   #100
dubtastic's Avatar
Not saying that there isn't an air of truth from your friends, but there is far more evidence showing there will be another sporty 3/speed3, well at least I deeply hope so. It's not uncommon for companies such as Mazda to keep tight lipped until things are a bit more production ready.
 Old 07-22-2013, 09:09 AM   #101
ajkulish's Avatar
Groans: 40
there may be a sporty version but there are no immediate plans for a new ms3
 Old 07-22-2013, 06:07 PM   #102
Davsetz's Avatar
Posts: 458   (View Stats)
Davsetz is the leader of the worldDavsetz is the leader of the worldDavsetz is the leader of the worldDavsetz is the leader of the worldDavsetz is the leader of the worldDavsetz is the leader of the worldDavsetz is the leader of the worldDavsetz is the leader of the worldDavsetz is the leader of the worldDavsetz is the leader of the worldDavsetz is the leader of the world
I think the Speed 3 is probably dead. And to be fair it would be because of the niche market they refused to really try to expand out of.
NEW MAZDASPEED 6
OLD 2008 MS3 GT3071R / JBR 3.5 Widepath Intake / JBR 80/88 PMM & TMM / Torque Solutions 75 RMM / Autotech Internals / CX Racing FMIC Piping TR8 Intercooler / Grimmspeed EBCS / NGK ITV-22 / Bosch 3 bar MAP / Cobb AP / Cobb DP / Devil's Own DVC -30 Meth Kit / Turbosmart BPV
FREEK PERMED
Davsetz is offline   Reply With Quote
 Old 07-23-2013, 12:05 AM   #103
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
It's not dead. But it will just change dramatically. Think of the differences between the RX7 and the RX8.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 09-02-2013, 12:38 AM   #104
impossible's Avatar
Posts: 733   (View Stats)
Groans: 30
Originally Posted by spdandpwr View Post
Having come from the 8th gen Civic Si, I can say that N/A is equally as fun and is way more responsive stock for stock Also, my bolt-on si barely walked a genpu (on a highway run) that had an intake and a tune. Clearly N/A can hang.
I think what makes Mazda so great is the overall package: power, handling, fit and finish, and value. This is why I ended up with a genpu. If Mazda can maintain those attributes, I don't care what they throw in the car, as long as it's similarly as fast as the current gen...no point in taking steps backward in terms of the performance -- that's for Honda to do.
I had an FA5 too.. I miss that 32mpg haha
 Old 09-03-2013, 03:12 AM   #105
Matx's Avatar
Posts: 1,681   (View Stats)
Matx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the world
so in that logic the new MS3 is ugly and slow as fuck
MS6 COBB-BROKEN: SOLD
GXP G8: Sold
EVO 8: speed rapist
14 Wrangler
Originally Posted by backward_0 View Post
.... I will be more than happy to fuck your world off....
Matx is offline   Reply With Quote
 Old 09-03-2013, 11:14 AM   #106
spdandpwr's Avatar
With simple bolt-ons, they weren't too bad. I'm so used to the loudness of the si that I feel like my magnaflow (on my ms3) sounds stock. Regardless, so happy with my mazda. hope she doesn't blow, lol.
 Old 09-03-2013, 11:21 AM   #107
impossible's Avatar
Groans: 30
Yeah I'm thinking like you right now too haha
 Old 09-03-2013, 11:30 AM   #108
spdandpwr's Avatar
^by the way, I see you're active on Youtube videos of MS3s, do you know of any good race videos featuring MS3s? I want to see what they can do.
 Old 09-03-2013, 12:02 PM   #109
dubtastic's Avatar
You know I would not be opposed to a NA mazdaspeed, however with that being said, it would need to produce over 210-220 HP to even stand a chance against the competition and make up for the lack of torque. I would miss the turbo grunt, but if the car can dance then I wouldn't mind trading in some HP.
I believe they mentioned the 2.0 skyactiv, wonder what the 2.5 could do if it was given the mazdaspeed treatment.
 Old 09-03-2013, 12:29 PM   #110
impossible's Avatar
Groans: 30
Fully bolted E85 MS3 pulling on Evo X with bolt on's & Tune
 Old 09-03-2013, 05:14 PM   #111
slw97's Avatar
Posts: 147   (View Stats)
slw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond repute
Here is another:
@801MS3;
801ms3 - 1.85, 11.93@120, stock motor, slicks, gt3071, 26psi falling to 22psi, meth.
Originally Posted by Ckmazdaspeed3 View Post
I don't know about you, but most of my races are impromptu. I'm not like, "hey dude, pull over so I can switch to my super special meth map" lol.
Originally Posted by TRex
"i don't care if it is a soccer mom in a mini van, if that whore launches on me im going at it like i'm racing a supra....just so i can bask in the sweet sweet tears of their defeat.
Originally Posted by rodrigo View Post
couple things to say...... first off the immaturity to be driving at those......ahhhhh shut up woman!!!!
2013 CWP MS3- CS 3" SRI, CS Catted DP, CS 80 Duro Race RMM, GFB BPV, CS STS, AutoTech FP Internals, CS FMIC piping w/TR-6 Core, Res Delete
304 Whp 371 Wtq DYNOJET 3 Gal E85
Purple Drank Tuned
2007 Ms3- Mazda speed CAI, gutted 2nd CAT, AccessPORT (SnailTooned), CorkSport RMM Inserts, flat black gen 1 wheels. 298 WHP 320 WTQ Sold but not forgotten
Last edited by slw97; 09-03-2013 at 05:15 PM. Reason: MSF Database - Automerged Doublepost
slw97 is offline   Reply With Quote
The Following User Says Thank You to slw97 For This Useful Post:
Juyoung (09-03-2013)
 Old 09-03-2013, 06:27 PM   #112
alphasaur's Avatar
Posts: 2,847   (View Stats)
Groans: 235
Originally Posted by slw97 View Post
Here is another:
@801MS3;
lolfuuuuu didnt read whole thread.
Brandon M likes this.
/Turbo ep3 BWAAAAA PSH
/speed 3- bye
/lol nator.
 Old 09-03-2013, 06:33 PM   #113
msantana101's Avatar
Posts: 1,517   (View Stats)
Mazdaspeed 3 vs Evo X - YouTube
That cah has so much fackin tawk
Sent from my iPhone using Tapatalk - now Free
FreekTuned
Tommy (09-03-2013)
 Old 09-03-2013, 08:02 PM   #114
impossible's Avatar
Groans: 30
that was my favorite part of the video haha
Tommy (09-03-2013)
 Old 09-04-2013, 08:20 AM   #115
Brandon M's Avatar
Posts: 15   (View Stats)
Brandon M has much to be proud ofBrandon M has much to be proud ofBrandon M has much to be proud ofBrandon M has much to be proud ofBrandon M has much to be proud ofBrandon M has much to be proud ofBrandon M has much to be proud ofBrandon M has much to be proud ofBrandon M has much to be proud of
No,that would be like when Mazda went from the beautiful TT RX-7...to the N.A,Renesis,slow as shit RX-8....why would they make the same mistake twice? But then again it would make our cars sooooo much better and more valuable I would think...classics one day.
Brandon M is offline   Reply With Quote
 Old 09-04-2013, 08:29 AM   #116
Brandon M's Avatar
And also if its not turbo,wouldnt it just be considered a regular 3?And Supposedly (I dont know how true this is) a monster Speed6 is coming soon,at least thats what the Mazda salsmen told me when i bought my Speed.He said "supercharged".im just sayin what he told me,not sure if its true.
 Old 09-04-2013, 08:42 AM   #117
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
Unless your sales guy has an insider he doesn't know a damn thing. This is coming from a sales consultant for Ford and Chrysler products. I have an inside guy for Ford Ecoboost information but everything else is dark to me.
 Old 09-04-2013, 08:46 AM   #118
Tyhackman15's Avatar
Posts: 1,742   (View Stats)
Twin charged diesel 6. Would take the market by storm. Of course it won't happen, but it should...
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
 Old 09-04-2013, 09:09 AM   #119
BigRedSpecial's Avatar
Posts: 1,436   (View Stats)
Groans: 56
You definitely won't see a supercharged mazda.
Needed: Driver mod
The Following User Says Thank You to BigRedSpecial For This Useful Post:
Juyoung (09-05-2013)
 Old 09-04-2013, 09:46 AM   #120
Dimenus's Avatar
Posts: 2,825   (View Stats)
Groans: 33
For $$$$$$$$$$$
2012 Velocity Red Mica
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f493/should-next-mazdaspeed3-naturally-aspirated-150101/
Autoblog - Next Mazdaspeed3 could go naturally aspirated? - Stiri - Club Mazda This thread Refback 07-15-2013 11:59 AM
Report: Next SVT Mustang may axe Shelby name, go naturally aspirated Haltech Automotive News 0 06-10-2013 05:50 PM
Current generation BMW M3 to be the last naturally aspirated M car Haltech Automotive News 0 04-04-2011 11:50 AM
Report: Mercedes looking at naturally aspirated 5.5-liter V8 for AMG Haltech Automotive News 0 01-12-2011 02:30 PM
Shelby to offer naturally aspirated, automatic GT350 models Haltech Automotive News 3 05-06-2010 04:57 PM
WRC confirms series to go normally aspirated? Haltech Automotive News 0 03-25-2009 05:40 PM
Page generated in 0.65669 seconds with 42 queries
