 Old 11-20-2013, 02:49 PM   #1
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
Default silicon by-pass hose for cx7
Do the gen 1 bpv hose from a speed 3 a cx7
My girl has an 2008 cx7 with the mzr disi and her by-pass house has cracks in it. Do you have a product that will fit her car everything is factory no mods. But if a jbr hose is the same price or close then I will convince her to get this higher quality hose instead of buying oem
Fwiw I think it will fit
 Old 11-20-2013, 03:56 PM   #2
King Scumbag's Avatar
Posts: 2,384   (View Stats)
I would assume they would be the same. They have the same TMIC? and same Cold pipe? in the same position? With the bpv being in the same spot?
Upon looking at scamatics of the cx7 motor. The intake setup and cold pipe are the exact same. I'm almost positive it will work. Maybe a little trim.
07 BLACK MICA MS3
PATTY/JEFF BUILT MOTOR
STOCK BLOCK
BOSTON STRONG
 Old 11-20-2013, 04:15 PM   #3
I believe it will fit also. We make ours a little long so it can be easily trimmed down with sharp scissors.
Hose barb cap and factory oil cooler hose dia 06Speed6 MazdaSpeed 6 - Engine, Transmission & Driveline 8 04-07-2010 12:19 PM
Page generated in 0.24210 seconds with 22 queries
