 Old 05-04-2014, 09:54 AM   #1
BananaNutz's Avatar
Posts: 32   (View Stats)
BananaNutz is an unknown quantity at this point
Default speed6 oil catch can mounting?
anyone got any ideas on where to mount the can? the instructions are only for a 3, and i can't find a place for it to save my life.
BananaNutz is offline   Reply With Quote
 Old 05-04-2014, 10:37 AM   #2
Big Dog's Avatar
Posts: 730   (View Stats)
Big Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the world
Groans: 89
Groaned at 9 Times in 9 Posts
Ran into this issue myself. Bit of a pain. With Jamie's design a lot of talked about places on say, Matt Damond's site doesn't work so great or maybe they just weren't too my liking. I can be a bit picky about my cars) If you have an aftermarket intake and are not using the stock airbox or a Cold Air Box you can make a bracket to hang it in the side of the engine bay. You can use the original battery box bolts. Mine kind of floats there but it has been on the car for about 5,000 miles without issue. I'm also running stage 2 can from Jamie with a check valve.
Big Dog is offline   Reply With Quote
 Old 05-04-2014, 11:56 AM   #3
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
Oil catch can problem + oil leak question
 Old 05-06-2014, 12:04 AM   #4
keymaster's Avatar
Posts: 397   (View Stats)
keymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the world
I got the Matt Damond kit and installed it where he recommended, on the horn bracket in the right front corner. It's a bit of a bitch to get the hoses routed over there, but otherwise it's a good spot with room for the can. I don't know how the JR can compares though, if it's a lot bigger it might be difficult to get it there, and I don't know if your hoses will reach.
Make sure you route the hoses correctly, getting them backwards is a bad thing...
2007 Mazdaspeed 6 GT
keymaster is offline   Reply With Quote
 Old 05-06-2014, 12:09 AM   #5
6erforlife's Avatar
Posts: 48   (View Stats)
6erforlife has much to be proud of6erforlife has much to be proud of6erforlife has much to be proud of6erforlife has much to be proud of6erforlife has much to be proud of6erforlife has much to be proud of6erforlife has much to be proud of6erforlife has much to be proud of6erforlife has much to be proud of
I have mine bracketed on the frame underneath my intake like @Big Dog; said. Brackets are like $2.50 at HD but I don't remember the bolt size or thread pitch to bolt it with. I've put about 4k miles on it so far without issue but I forgot to put a hose on the end of the spout so draining is a bit of a pain in the ass
Liquid Platinum 07 Speed 6 #10177
JBR 80duro RMM, Sure Juggernaut, Sure Dreadnaught
GTX3071, Cobb AP, HTP3.5" Intake, Streetunit TMIC, M2 DP, TurboSmart BOV, Grimmspeed EBCS, AT Internals, GP Werks BSD & Baffle, Denso ITV22, TWM Stage 2, Dashhawk, JBR OCC, JBR TB TIG, SURE IM TIG, VTCS Delete, Ford Transit Oil Filter Conversion, Clean Valves!
LED tail lights, 20% tint, EVO X rims and VG Sharkfin
Big Turbo baby!
6erforlife is offline   Reply With Quote
AP Mounting Locations rbflurry Gen2 MS3 General Discussion 1 09-27-2013 06:19 AM
Another mounting TheFlash JAMES BARONE RACING 22 07-03-2013 02:08 PM
TRZ Dogbone mounting tip... deyomatic 2010 MS3 - Engine, Transmission & Driveline 8 08-01-2010 02:45 AM
Gauge mounting xezerax Interior 9 11-29-2009 12:06 PM
Page generated in 0.40637 seconds with 24 queries
